Fan je napisal/-a:Ja v koliko je EGR vgrajen, se ga lahko blindira. Problem pri avtorju je, da ima nov motor, kje ni EGRa. Torej ta del kjer ima elektronika vpisan EGR, ne bo deloval pravilno, ker ga ni - posledično bo prižgana MIL lučka in vozilo v servisnem načinu.
gr3mlin je napisal/-a:Pozdravljeni, prosim za pomoč
Za toyoto avensisa 2004 letnik je bil kupljen motor (1cdftv) ,ki nima egrja, na mojem je egr. Zanima me če se najde tukaj kdo s kakšnim pamrtnim nasvetom in izkušnjo ali se ta motor da vseeno vgradit ali nam ta egr predstavlja velik problem?Avto ne bom dajal na odpad saj so me že šobe koštale cca 300 in motor 450, tako da moram speljati popravilo do konca.
Prosim za odgovore. Hvala
The Toyota CD engine is a 2.0 L (1,995 cc) diesel engine used in the Toyota Corolla, RAV4, Avensis and other vehicles. It is a DOHC engine with a bore and stroke of 82.2 mm × 94 mm (3.24 in × 3.70 in) with 116 hp (87 kW). The higher-output CD Series engines have now largely been replaced by the AD engine while low output applications where replaced by the ND engine.[1]
1CD-FTV
The 1CD-FTV (2.0 D-4D) is a compact inline-four turbocharged diesel engine initially in the first generation Avensis on November 22, 1999[2]
1st generation
Technical specifications:[2]
Fuel injection system: common rail 135 MPa (1,350 bar; 19,600 psi),6 hole solenoid injectors with pilot injection
Camshaft drive: timing belt
Exhaust gas treatment: EGR equipped with catalyst;(EGR cooler on RAV4)
Emission standard: Euro III
Compression Ratio:18.6:1
Fuel consumption combined: 39.2–47.9 mpg‑imp (7.21–5.90 L/100 km; 32.6–39.9 mpg‑US)
CO2 emission combined: 158–191 g (5.6–6.7 oz)/km
Applications:
Non-Intercooled Non VGT
90 PS (66 kW; 89 hp) at 4000 rpm, 21.9 kg⋅m (215 N⋅m; 158 lb⋅ft) at 2400 rpm (Europe, Net DIN)
August 2000 – September 2001 Eleventh generation Toyota Corolla (CDE110)
October 2000 – 2004 Twelfth generation Toyota Corolla (CDE120)[3][4]
First Generation Corolla Verso[5]
Intercooled Non VGT
111 PS (82 kW; 109 hp) at 4000 rpm, 25.5 kg⋅m (250 N⋅m; 184 lb⋅ft) at 2000-2400 rpm (Europe, Net DIN)
1999-2003 First generation Toyota Avensis[2]
Twelfth generation Toyota Corolla T-Spirit 5dr hatchback [5]
Intercooled VGT
116 PS (85 kW; 114 hp) at 4000 rpm, 25.5 kg⋅m (250 N⋅m; 184 lb⋅ft) at 1800-3000 rpm (Europe, Net DIN)
August 2001-?First generation Toyota Avensis Verso[6]
Second Generation Previa[7]
Second Generation RAV4[8]
2nd Generation
The 1CD-FTV was revised with a lower compression ratio and a second generation common rail system in preparation of then upcoming Euro IV emission standards. It was first introduced in the second generation Avensis in February 2003 where PM and NOX reducing D-CAT was also first implemented.[9]
Technical specifications:[9]
Fuel injection system: common rail 160 MPa (1,600 bar; 23,000 psi)/175–180 MPa (1,750–1,800 bar; 25,400–26,100 psi) on D-CAT Variants,6 hole solenoid injectors with pilot injection
Exhaust gas treatment: EGR, equipped with cooler and catalyst; 4-way DPNR Catalyst and Exhaust Port Injection on D-CAT Variants[9]
Emission standard: Euro IV (Euro III: Corolla Verso)
Compression Ratio:17.8:1
Fuel consumption combined: 45.6–48.7 mpg‑imp (6.19–5.80 L/100 km; 38.0–40.6 mpg‑US)
CO2 emission combined: 149–165 g (5.3–5.8 oz)/km
Applications:
Intercooled VGT with D-CAT
118 PS (87 kW; 116 hp) at 4000 rpm, 28.6 kg⋅m (280 N⋅m; 207 lb⋅ft) at 2000-2200 rpm (Europe)
February 2003 – June 2006 Second generation Toyota Avensis[9][10]
Intercooled VGT
116 PS (85 kW; 114 hp) at 3600 rpm, 28.6 kg⋅m (280 N⋅m; 207 lb⋅ft) at 2000-2200 rpm (Europe)
Twelfth generation Toyota Corolla[11]
Second Generation Corolla Verso[12][13]
References
"The 2004 Toyota Corolla"
(Press release). UK: Toyota. 18 June 2004. Retrieved 2020-10-21.
"Toyota Avensis SR D4-D"
(Press release). UK: Toyota. 22 November 1999. Retrieved 2020-10-21.
"Toyota At The British International Motor Show"
(Press release). UK: Toyota. 10 October 2000. Retrieved 2020-10-21.
Clifford, Joe (2015-04-21). "Corolla Generations: 2000 - 2006"
(Press release). UK: Toyota. Retrieved 2020-10-21.
"Teed up for success – the new Toyota Corolla"
(Press release). UK: Toyota. 2003-09-10. Archived from the original
on 2020-10-23. Retrieved 2020-10-21.
"Press Release: Avensis Verso A dynamic new contender for the MPV market"
(DOC) (Press release). UK: Toyota. June 2001.[dead link]
"New D-4D Engine For Previa"
(Press release). UK: Toyota. 16 May 2001. Retrieved 2020-10-21.
"Toyota Launches D-4D Diesel Engine For RAV4"
(Press release). UK: Toyota. 28 June 2001. Retrieved 2020-10-21.
"Press Release: The new Toyota Avensis"
(DOC) (Press release). UK: Toyota. February 2003.
"The new 2007 Toyota Avensis"
(DOC) (Press release). UK: Lexus. June 2006.
"Toyota Delivers Clean Performance And Clear Savings"
(Press release). UK: Toyota. 23 May 2003. Retrieved 2020-10-21.
"Toyota Corolla Verso"
(Press release). UK: Toyota. 2004. Retrieved 2023-06-10.
"Double Diesel Debut For Toyota Corolla Verso"
. Toyota (Press release). UK. 5 October 2005. Retrieved 2020-10-21.
Stub icon
This automobile-related article is a stub. You can help Wikipedia by expanding it.
Categories:
Toyota enginesDiesel engines by modelStraight-four enginesAutomobile stubs
This page was last edited on 19 November 2023
