VasjaS
Prispevkov: 90
Pridružen: Sr feb 14, 2007 1:05 pm
Kraj: Vrtojba
Napisal/-a VasjaS Sr apr 11, 2007 8:40 am
I don't like it :evil:
Evo je bil itak zmeri lepši kot impreza če mene kdo praša :twisted:
Jaz sem nezmotljiv! Enkrat sem mislu da sem se zmotil, ampak sem se motil!
axa
Prispevkov: 284
Pridružen: Po sep 15, 2003 11:25 pm
Kraj: Ilirska Bistrica
Napisal/-a axa Sr apr 11, 2007 8:46 am
To je bla zadnja lepa impreza zame:
Uribobo
Prispevkov: 455
Napisal/-a Uribobo Sr apr 11, 2007 9:15 am
Tale je tud lepa.
Napisal/-a esem Če apr 26, 2007 12:58 pm
WRX STI
dober približek
Insajderske informacije o WRX STI
The unveiling of the 2008 Subaru Impreza WRX at the New York Auto Show caused both nods of approval and gasps of horror. Some liked the European flavor of the new design while others missed the hard-edged nature of past WRXs. Subaru has taken a new direction with its popular pocket-rocket, introducing a sporty-looking 5-door hatchback and an elegant sedan. But the question on everyone's mind was: What will happen with the super-high-performance WRX STI?
Unlike Mitsubishi and its Evo X, Subaru isn't quite ready to show off the styling of its highest-performing vehicle. The official debut of the car is still a few months away — probably at the Tokyo Motor Show this October — but we were able to get our hands on some vital information that provides a clear picture of what the next WRX STI will be like, including its basic appearance.
Take the exterior of the stock 5-door WRX and inject it with large doses of steroids; now you have an idea of how the next WRX STI will look. The car is about 3-4 in. wider than the stock Impreza WRX, with pronounced fender flares front and rear. “Muscular” is the operative term here, with the overall essence of the STI being that of a purebred race car instead of a street-legal 5-seater. The grille will be different from that of the stock WRX — black mesh will replace the chrome highlights of the stock car's — with the Subaru badge and STI logo placed inside. The car is a bit shorter than the current STI, measuring about 174.0 in. bumper to bumper, but wheelbase has grown to 103.1. As with the current model, gold-colored wheels will be optional, but they'll be 18 in. instead of the current model's 17s. The huge rear wing that has defined past WRX STIs will be replaced by something more subtle, like a diffuser coming off the roof.
Underneath the hood scoop is the same turbocharged 2.5-liter flat-4 of the past model. JDM (Japan domestic model) STIs will be powered by a 2.0-liter flat-4 for World Rally homologation reasons. The output of the 2.0-liter flat-4 is rumored to be at 300 bhp, which means our 2.5-liter version should pump out about 320. Torque will be around 320 lb.-ft. at 4000 rpm. The slight boost in power, coupled with the fact that the car will be about 50 lb. lighter, will make the next WRX STI just as quick as, if not quicker than, the Evo X.
Subaru Impreza WRX STI
Price
est $35,000
Curb weight
est 3300 lb
Wheelbase
103.1 in.
Length
est 174.0 in.
Width
est 71.0 in.
Height
est 58.0 in.
Engine & Drivetrain
Type
alum. block & heads, turbo flat-4
Valves
4-valves/cyl
Displacement
2457 cc
Horsepower
est 320 bhp @ 6000 rpm
Torque
320 lb-ft @ 4000 rpm
Transmission
6-speed manual
Chassis & Body
Layout
front engine/awd
Body/frame
unit steel
Brakes, f&r
vented discs, ABS
Steering
rack & pinion, variable pwr assist
Suspension, f/r
MacPherson struts/multilink
Wheels
forged alloy, 18 in.
Tires
Bridgestone Potenza, 235/40R-18
Performance
0–60 mph
est 4.5 sec
0–1320 ft (¼ mile)
est 12.5 sec
Sixty mph should come in around 4.5 seconds, and the quarter-mile mark in about 12.5. The boxer powerplant will be mated to a 6-speed manual gearbox — no automatic or twin-clutch system will be offered. What's new is Subaru's SI-Drive. This system, already in the Legacy spec.B, allows the driver to map the throttle to three different settings: Intelligent, Sport and Sport Sharp. It modifies the engine's torque characteristics, changing the way power is delivered. Intelligent mode is programmed for everyday commuting, while Sport Sharp is intended for sessions under the red mist, with super-quick throttle response and faster power delivery to the four wheels.
There probably won't be fancy traction- or yaw-control systems in the STI like in the Evo X, but DCCD (driver's control center differential) remains, allowing the driver to vary the torque delivery between the front and rear axles. The suspension system will be MacPherson struts up front and a multilink setup at the rear, the latter similar in geometry to that of the Legacy wagon. There are rumors that custom performance dampers, produced with Yamaha, and 6-pot front brake calipers from Brembo may make it into production. A yaw-control system similar to Mitsubishi's AYC is said to be in the works, but we're not sure if it will make it into this car. What we do know is the new STI will have sharper handling characteristics than the current model, without a sacrifice in ride quality, thanks to improved structural rigidity, a retuned suspension and its compact size.
Subaru wanted to keep things simple with the next WRX STI, opting not to cram it with all kinds of high-tech gadgetry. The engineers decided to focus on the basics and keep the price tag as low as possible. Early reports indicate that the next WRX STI will be priced about $35,000, right in the neighborhood of a certain aforementioned compact sports sedan. The on-sale date of early 2008 is also right on top of the Mitsubishi Lancer Evolution X. The official launch of both cars is still more than a half year away, but the battle lines are already being drawn. We can't predict which car will come out on top, but we do know that it's going to be one helluva dogfight.
db
Prispevkov: 120
Pridružen: Če feb 22, 2007 6:39 pm
Kraj: from MS to MB
Napisal/-a db Če apr 26, 2007 2:53 pm
Meni je novi EVO dost bolj hud, kot IMPREZA, pravzaprav mi je impreza grda, čeprav mi je vedno bila legendarni avto. :evil: :(
GregaST
Prispevkov: 418
Pridružen: Pe feb 09, 2007 3:55 pm
Kraj: Medvode
Napisal/-a GregaST Če apr 26, 2007 4:08 pm
Z novo imprezo so brcnil v temo. Vse prejšnje impreze so ble lepe, tole je pa katastrofa. Ko vidim zraven evo x mi gre kar na jok. Nov lancer je fantastičen, nova impreza pa porazna.
tha_man
Prispevkov: 1008
Napisal/-a tha_man Če apr 26, 2007 8:19 pm
Heh Impreza je svojeverstna žival... do sedaj mi je ob izidu bila še vsaka grda, a mi po nekaj časa tudi vsaka postala všečna... še posebej ko sem jo vidu v živo. Tud tale že na filmčkih zgleda bolj kul kot na slikah., tk da mogoče bo z njo enako. Zaenkrat mi je še relativno grda, ampak manj kot takrat ko sem jo prvič vidu :)
Napisal/-a Lignage Po apr 30, 2007 11:21 pm
Link: Subaru Impreza WRX
lp, mm
Prispevkov: 11407
Napisal/-a martin_krpan So maj 12, 2007 4:27 pm
Impreza S-GT za japonski trg:
Prispevkov: 11407
Napisal/-a martin_krpan To maj 22, 2007 5:47 pm
Impreza WRX (na Japonskem imenovana S-GT)
Beige notranjost :jao:
davorz
Prispevkov: 604
Kraj: Velenje
Napisal/-a davorz To maj 22, 2007 5:54 pm
tile zadni dve slikci niti pod razno nista istega modela. Mogoče je spodnja slika osnovno opremljene impreze, saj so postavitve merilnikov čisto drugačne..
Take a closer look :)
Jorgi
Prispevkov: 1934
Kraj: zabji raj
Napisal/-a Jorgi To maj 22, 2007 5:54 pm
A sm že povedala, kok me motijo zadnje lampe? :P
Obey me. You'll be happier.
im nobody
Prispevkov: 3321
Kraj: laško
Napisal/-a im nobody To maj 22, 2007 6:02 pm
men pa odkrito povedano je lepa...evo pa najlepši avto v zgodovini avtomobilizma :P :D :twisted: :twisted:
passat 1.9 tdi 110,235 nm
Na levi pas...do konca gas
modri D.
Prispevkov: 867
Napisal/-a modri D. To maj 22, 2007 6:22 pm
UUU lej lej radio ma... al neki tazga :D Sam zadi je pa neka mešanica BMW serije 1 pa tastare ibize - al se sam men tko zdi? ;)
Prispevkov: 11407
Napisal/-a martin_krpan To jul 03, 2007 7:48 pm
Impreza WRX STi - spy shots:
dEjaN_
Prispevkov: 167
Pridružen: So dec 31, 2005 1:55 pm
Kraj: dolenjska
Napisal/-a dEjaN_ To jul 03, 2007 8:08 pm
Impreza mi ni bila nkol ne vem kako lep avto, tudi ta model ni nič boljši...ampak ko sem prvič vozil Imprezo WRX STi, sem pozabil na "lepoto" avtomobila...skratka zadeva me je totalno navdušila, predvsem menjalnik, vozne lastnosti...avto je res 1. liga. Skratka naj na koncu pride vn kakršnakoli Impreza, ko jo sprobaš, se vanjo zaljubiš (mišljena je najmočnejša različica).
ALLi^
Prispevkov: 24
Pridružen: Ne jun 17, 2007 7:20 pm
Napisal/-a ALLi^ To jul 03, 2007 8:14 pm
Prejšnja Impreza kot sedan je bila veliko bolj atraktivna ...
Kot vem, je ciljna publika za ta avto ameriška mladina :roll: ... Nekaj v rangu golf GTI-ja (kar je tam čez lučo skoraj vsakemu dosegljiv normalen avto ...)
Impreca
Prispevkov: 31
Pridružen: Ne dec 11, 2005 11:31 pm
Napisal/-a Impreca To jul 03, 2007 8:28 pm
Lepota je zelo subjektivna zadeva odvisna od vsakega posameznika. Ampak če si le malce ogledaš katerokoli do sedaj narejeno Imprezo WRX Sti, lahko mirno ugotoviš da je to pravi športni avtomobil in tudi izredno lep po vrhu. Tudi men tele prve slikce nove Impreze niso najbol všeč sam upam, da bo najhujša različicia lepša. Pa še glede primerjave Impreze z Golfom GTI, to ni primerljivo. Ne po ceni, ne po tehniki in ne po voznih lastnostih.
Napisal/-a IcEm4n To jul 03, 2007 8:56 pm
še najlepša impreza mi je bla prejšnji model (ne ta k je zdj v prodaji, ampak prejšnji)
Napisal/-a esem Če avg 09, 2007 6:38 pm
Subaru in Petter Solberg bosta v Frankfurtu predstavila WRC dirkalno izvedbo (po imenu sicer še Subaru WRC Concept), ki bo zgledala takole
