drugmirko
Prispevkov: 2762
Napisal/-a drugmirko Pe feb 24, 2006 10:25 pm
smack the bastard:
odrasli: 5 zvezdnih komadov in sicer skupno 35 točk! od tega 15 točk za front, 17 točk za side, 3 točke za belt reminder
deca: 4 zvezdice in 37 točk
pešci: 3 zvezdice in 19 očk
noben predel telsa voznika ali sopotnika ni dobil ocene slabše kot "dobra", je pa voznik malo bolj rumen kot pa zelen...
živeo drugmirkooooo!!!!
Napisal/-a Joie de vivre! To okt 10, 2006 10:00 am
Da ne bom odpiral nove teme (jih je že preveč), bom tole vtaknil kar tukaj. Prihaja novi 207 SW:
LP,
Martin
Doc_
Prispevkov: 1783
Kraj: Nekje na Primorskem
Napisal/-a Doc_ Sr okt 11, 2006 6:55 pm
Ni videt....
Napisal/-a Lignage So okt 14, 2006 10:29 pm
Mislim, da je bla nalepljena tale slikca...
lp, mm
Napisal/-a esem Po okt 16, 2006 12:33 pm
CC - ji se že veselo vozijo
celostranska slika
http://photos1.blogger.com/blogger/4965 ... CC%208.jpg
Slika Slika
Slika Slika
Slika Slika
še več celostranskih slik tu
http://carscoop.blogspot.com/2006/10/sc ... 07-cc.html
Napisal/-a esem Pe nov 24, 2006 11:56 am
207 GTI ?
bo imel 175 konjski turbo motor (PSA-BMW), ki je tudi v Miniju Cooper S. Verjetno pride še močnejši RC. Čakamo
PS Citat je z guglom preveden iz šp. v an., zato bolj tak
Spanish Autoblog je napisal/-a:New Peugeot 207 GTI?
Published Nov 23, 2006, 2:25 p.m. ET by Enrique Garci'a
Although still there are no official images of the new sport version of the 207, little by little we are compiling more information on the mechanics. Finally, 1.6i T with 175 will be the motor CV the one that from place to the variant GTI? , he himself who already takes the new generation of the Mini ones in the Cooper S.
With such power, new the 207 km/h in less than 8 seconds will be able to accelerate from 0 to 100, maintaining a guessed right balance between use affability, comfort and assayed consumption - considering 175 CV, by assumption.
Depending on the country, the final denomination has still not been confirmed, since some rumors indicate that this motor will give to life to the GTi and others, to the RC. If this last one, in the 206 already develops 180 CV, we do not think that he is effective to replace it by one of smaller power, and less seeing as their rivals raise without stopping - Clio RS is ***reflxed mng, with 197 CV by example.
In any case, it is clear that the aesthetic one of version RC will take own details whereas the GTi is basically he himself car, although with something of maquillaje. Of course, a good complement for GT 150 CV, the present top of range of the 207.
Napisal/-a esem Ne nov 26, 2006 7:44 am
RC naj bi imel 210 KM.
207 GTI - prvi vtisi z vožnje tu
http://www.autoexpress.co.uk/news/motor ... 7_gti.html
Auto Express je napisal/-a: ...But the overall set-up was largely unaltered. As we have said before, the ordinary 207 has superior steering and chassis balance, plus keener handling, than the equivalent Clio, and although it’s hard on this evidence to gauge whether the GTi will get the better of the 197, there are plenty of reasons to be optimistic.
The car we drove turns in tautly, grips hard and the flexible engine ensures there’s plenty of torque to pull you out of tight corners. It’s nimble and changes direction with relish, although it doesn’t have the same frenetic energy as the 197. However, once fitted with full sound insulation, it’s likely to be a better companion on long trips, thanks to its more supple suspension....
CLIO3
Prispevkov: 259
Pridružen: To okt 10, 2006 6:34 pm
Kraj: Kranjsterdam
Napisal/-a CLIO3 Ne nov 26, 2006 7:56 am
nasplosno 207 :huh:
Clio III Dynamic Sport 1.6 16V
Prispevkov: 11407
Napisal/-a martin_krpan So dec 16, 2006 1:39 pm
Prve spy fotke karavanske dvestosedmice:
in photoshop:
rok46
Prispevkov: 2861
Napisal/-a rok46 So dec 16, 2006 2:50 pm
ta fotoshop zgleda šop 407SW
Napisal/-a Lignage Ne dec 17, 2006 2:36 am
Oblika Peugeota 207 res ni najbolj posrečena in na slikah avto izgleda lepše kot pa v resnici. Z Malo leposukcije, predelave njegovega obraza in drugih ogledal (ker ta vzeta iz C4 mu nikakor ne sedejo) pa bi stvar izgledala mnogo boljše.
To je prvi novejši Peugeot, katerega oblika me je razočarala. 207 preprosto ni več 206.
lp, mm
Napisal/-a IcEm4n Če dec 28, 2006 12:48 pm
2007-ica?
pery
Prispevkov: 716
Kraj: cerknica
Napisal/-a pery Če dec 28, 2006 1:22 pm
CLIO3 je napisal/-a:nasplosno 207 :huh:
men tud nekak ne potegnejo te 207ice,sploh cc :jao:
Slika Slika Slika
Jorgi
Prispevkov: 1934
Kraj: zabji raj
Napisal/-a Jorgi Če dec 28, 2006 1:41 pm
IcEm4n je napisal/-a:2007-ica?
Bojim se, da ima peugeot nasplošno resno oblikovalsko krizo... vse kar jim uspe je popačit prejšnjo oblikovno svežo in domiselno osnovo v nekaj neproporcionalnega z predimenzioniranimi detajli (prednja maska, luči..). Meni osebno so po 406tki in 206tki vsi modeli oblikovno eno samo veliko razočaranje.
Obey me. You'll be happier.
Napisal/-a IcEm4n Če dec 28, 2006 1:57 pm
do 307 (še ne faceliftane) so mi bli še všeč, to kar je pa zdj, je pa več al mn isto
Eazy-O
Prispevkov: 1119
Napisal/-a Eazy-O Če dec 28, 2006 2:54 pm
Jao je tale 2007 ena zmeda elementov... :shock:
CERES
Prispevkov: 439
Kraj: Gorenjska
Napisal/-a CERES Če dec 28, 2006 3:21 pm
Eazy-O je napisal/-a:Jao je tale 2007 ena zmeda elementov... :shock:
To pa si dobr povedal :lol: Meni se zdi da so v želji da bi nekaj naredili kot revolucijo da so enostavno pregoreli. Mislim da preveč modelov delajo iz enega avtomobila. Tukaj mamo navadni,pol karavan,cc, pa še tale 2007... :roll: ne vem točn kaj mislijo ampak za mene je izgubilo smisel ravno pri tej 2007. Sej ne rečem da avto ni lep 207 sam kaj ko moraš skoraj poseči v žep in dati na plan skoraj 5M. In to se mi zdi zgubljena filozofija. Mar bi dali ljudstvu avto ki bi imel vse kar rabi in normalno ceno :roll: Ne vem raje za teh skoraj 5M kupim astro,307,leona ali pa dam še 1M zraven pa imam normalno družinsko limuzino ;)
LudiLimun
Prispevkov: 620
Pridružen: So avg 19, 2006 3:50 pm
Napisal/-a LudiLimun Če dec 28, 2006 4:30 pm
CERES je napisal/-a:. ... in dati na plan skoraj 5M. In to se mi zdi zgubljena filozofija. Mar bi dali ljudstvu avto ki bi imel vse kar rabi in normalno ceno :roll: Ne vem raje za teh skoraj 5M kupim astro,307,leona ali pa dam še 1M zraven pa imam normalno družinsko limuzino ;)
Sej to je problem oz. dilema pri vsakem modelu (tut clio RC, pa še velik se jih najde), pa naj se gre za nižji, srednji, višji, al pa Ž razred. jebiga! če ti je avto ušeč, pa bi meu rd mal močnejšo verzijo boš tolk dal :P
207: grd, še posebej tiste verzije k nimajo športne oz. GT opreme ---> sprednja maska je za popizdit grda. zgleda k ena napihnjena krota. se strinjam z enim k je napisu, da od faceliftane 307 gre lepota samo še navzdol!
2007: za tisto sliko pa predn začnete komentirat; poglejte si jo pa presodite če ta avto res obstaja; če ste odgovorili z da, mislim da imajo pri okulistih še vedno novoletni popust :twisted:
CERES
Prispevkov: 439
Kraj: Gorenjska
Napisal/-a CERES Če dec 28, 2006 4:48 pm
LudiLimun je napisal/-a:
Ha :lol: Jest še dobro vidim in upam da bom tudi na stara leta dobro vidu :-P . Zakaj pa misliš da Peugeot ne bi naredu 2007? Sej so dejansko začeli z 1007,en? In gotovo bodo končali z 4007 ;) Za moje pojme je to prava mala zmešnjava teh številk :roll:
LudiLimun
Prispevkov: 620
Napisal/-a LudiLimun Če dec 28, 2006 4:53 pm
nisem izrazil dvoma v izdelavo 2007, čeprav ne vem kdo ga bo kupil, ampak sem izrazil dvom v obliko ki je prikazana na sliki (zelen 2007). pač je očitno da en ni mel preveč cajta k je tole chopu :lol:
