TooOldVehicle
Prispevkov: 250
Pridružen: Sr mar 21, 2007 7:25 pm
Avto.net NE DELA
Napisal/-a TooOldVehicle Ne dec 09, 2007 3:46 pm
a še komu to napiše
Server Error in '/' Application.
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File -->
<configuration>
<system.web>
<customErrors mode="Off"/>
</system.web>
</configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<configuration>
<system.web>
<customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/>
</system.web>
</configuration>
TooOldVehicle
Prispevkov: 250
Napisal/-a TooOldVehicle Ne dec 09, 2007 3:51 pm
ne vem kaj točno se je zgodil, se mi zdi da so nekej naslov spreminjal, ker mi ga pod zaznamkami ni hotel zagnat, sm na googlu zagnal pa dela.
TooOldVehicle
Prispevkov: 250
Napisal/-a TooOldVehicle Ne dec 09, 2007 3:54 pm
PureTNT je napisal/-a:Preveri sistem z antivirusnim programom.
a misliš da je bla težava pr men, da mam kak virus?
RS-sport
Prispevkov: 156
Pridružen: To avg 29, 2006 10:22 am
Napisal/-a RS-sport Ne dec 09, 2007 4:21 pm
TooOldVehicle je napisal/-a:
men tud ne dela :oops: napiše mi pa isto kot pa tebi ;)
RS-sport
Legoless
Prispevkov: 271
Pridružen: To avg 21, 2007 1:35 am
Napisal/-a Legoless Ne dec 09, 2007 4:38 pm
Meni normalno dela.
acid
Prispevkov: 1910
Kraj: Vuzenica/MariboR
Napisal/-a acid Ne dec 09, 2007 4:42 pm
Meni dela čisto normalno, sem skoz gor :)
RS-sport
Prispevkov: 156
Napisal/-a RS-sport Ne dec 09, 2007 4:59 pm
men preko mozille ne odpre.... z explorerjem pa normalno :D nč jasn :roll:
RS-sport
tomson
Prispevkov: 1386
Kraj: LJ / MB
Napisal/-a tomson Ne dec 09, 2007 5:02 pm
men tud dela :roll:
H2
Prispevkov: 1189
Napisal/-a H2 Ne dec 09, 2007 5:24 pm
Meni nedela če vtipkam samo avto.net
če pa dam www.avto.net je pa ql
Lumpy_
Prispevkov: 2821
Kraj: Miklavž pri Mb
Napisal/-a Lumpy_ Ne dec 09, 2007 7:36 pm
Meni špila, bilokaj vtipkam v zvezi z avto.net
Spyker
Prispevkov: 2297
Kraj: okolica Ljubljane
Napisal/-a Spyker Ne dec 09, 2007 9:03 pm
Poglejte da niste vtipkali avtonet.com tko kot je zadnjič moj kolega, nato je pa pizdoliral da mu ne dela :D :D
ps.: meni avto.net dela
Če je ravno, ni zabavno.
TooOldVehicle
Prispevkov: 250
Napisal/-a TooOldVehicle Po dec 10, 2007 9:10 am
jest sm včeraj, kot že dve leti do sedaj, kliknil na "avto.net", ki sem ga imel med zaznamki na internetu, pa mi je napisalo to kar sem zgoraj navedel, potem sem pa šel na google in vtipkal avto.net in "voila" stran se odpre, ne vem kaj se je zgodil da mi ga na zaznamkih ni več odpiralo...
4vale6
Prispevkov: 572
Kraj: Notranjska
Napisal/-a 4vale6 Sr jan 07, 2009 5:32 pm
A še komu avto.net najde sam 3 golfe V če klikne iskanje? (brez kakršnih koli dodatnih kriterijev)
http://www.avto.net/2004/osebna/zadetki.asp
Ne razumem,a majo kak bug z bazo al kko. od učeri se pojavla ta napaka, medtem ko na beta verziji strani najde normalno... Sm pa vidu da beta verzija nima golfe po mk(I, II,... ,V) ampak sam po letnikih določiš,so mogoče bazo prestrukuriral? Ma še kdo to težavo?
207cc
Prispevkov: 279
Napisal/-a 207cc Če jan 08, 2009 7:51 am
Tut jest sm opazu, da pri peugeotih npr. ni več coupejev in CC-jev ločeno :? kje je poanta tega pa res nevem
4vale6
Prispevkov: 572
Kraj: Notranjska
Napisal/-a 4vale6 Če jan 08, 2009 9:20 am
To je kr neki,isti shit k autoscout, če neveš točnega letnika je đabe,pa itak da večinoma nevemo vsi vseh letnikov, vseh znamk.... krneki :?
Pol so pa še ta modelna leta k maš zdej npr. golfa V in VI 2008 letnik pa si pomagej pol...
Doche
Prispevkov: 1975
Kraj: Ried
Napisal/-a Doche Če jan 08, 2009 11:38 am
Meni se zdi to po novem tud bedarija. Prej recimo je blo za Clio-te, ko si nisi točno določil omejitev in je blo preko 1000 rezultatov. Zdaj pa recimo da iščeš nekega golfa II, pa nima napisanega letnika, ampak samo pač Golf II, ga ne moreš najt če daš tam opcijo glede na letnik :?
gecco
Prispevkov: 1726
Napisal/-a gecco Če jan 08, 2009 1:40 pm
dela vse normalno prek vseh brskalnikov
Doche
Prispevkov: 1975
Kraj: Ried
Napisal/-a Doche Če jan 08, 2009 2:22 pm
gecco je napisal/-a:dela vse normalno prek vseh brskalnikov
Sej dela ja, nihče ne govori, da ne. Ampak pri iskanju so med modele vozil dali spremembe.
gecco
Prispevkov: 1726
Napisal/-a gecco Če jan 08, 2009 2:38 pm
Doche je napisal/-a:
aja, ups...tist so bli še stari posti :)
ja tist pa res nardi mal bolj tečno brskanje
Doche
Prispevkov: 1975
Kraj: Ried
Napisal/-a Doche Po jan 12, 2009 2:33 pm
Če nam prej ni bla beta po godu, je pa zdaj "štartala" na polno. Se bo še treba navadit na nov look. :x
