Mitsubishi Motors lineup at 2008 Geneva International Motor Show
Tokyo, February 26, 2008 —
Mitsubishi Motors Corporation is to give the Prototype-S sport hatchback concept its global debut at the 78th Geneva International Motor Show which runs from March 4 through March 16 at the Geneva Palexpo exhibition and conference complex (opening to the general public on March 6). Also included in Mitsubishi Motors' 16-model stand (13 on Press Days) are: the i MiEV (dubbed the i-EV in Europe) and the Lancer Evolution (Lancer Evolution X on the Japanese market). The i MiEV is a new-generation electric vehicle under evaluation for export to international markets and currently undergoing fleet monitoring in Japan; Lancer Evolution is a new-generation high-performance 4WD sedan that allows all drivers to experience enjoy the highest levels of fun-to-drive performance safely and with confidence.
Making its global debut at the Geneva Show, the Prototype-S is derived from the Lancer sports sedan (Galant Fortis on the Japanese market) currently on sale in most Mitsubishi Motors markets worldwide.
Distinguished by the inverted-slant nose with trapezoidal grille front fascia that comprise the Mitsubishi Motors new design identity, and with purposeful, wide-and-low proportions; Prototype-S uses exterior lines to craft a shape that is powerful and sporty. The use of 215/45R19 tires on 19-inch 5-spoke alloy wheels adds to the tautly muscular and road-hugging image the styling projects.
Prototype-S uses a new 2.0-liter MIVEC*1 4-cylinder DOHC intercooled / turbocharged engine, developing maxima of 240 PS and 35 kg-m that will also power the Lancer Ralliart due to go on sale in North America in the summer of 2008. The power unit is mated to Mitsubishi Motors's high-efficiency Twin Clutch SST*2 automated manual transmission that gives the driver simple control of and feel-good access to the car's exhilaratingly sporty performance. The full-time 4WD driveline features Mitsubishi Motors' Active Center Differential (ACD) that uses an electronically controlled multi-plate hydraulic clutch to optimally tailor front / rear drive torque vectoring to different driving conditions and deliver the best balance between steering response and traction.
*1 MIVEC : Mitsubishi Innovative Valve timing Electronic Control system
*2 SST : Sport Shift Transmission
Prototype-S specification
Length (mm) 4,585
Width (mm) 1,760
Height (mm) 1,480
Wheelbase (mm) 2,635
F/R track (mm) 1,530/1,530
Occupants 5
Engine 2L MIVEC 4-cylinder DOHC with intercooler/turbocharger
Max. output 177 kW (240ps)
Max. toque 343 Nm (35kgm)
Driveline Full-time 4WD (with ACD)
Transmission Twin Clutch SST
Tires 215/45R19
Mitsubishi Motors unveils Lancer Sportback at Paris Motor Show
— Lancer Ralliart 4WD sports sedan also on display —
Tokyo, June 11 2008 — Mitsubishi Motors Corporation will unveil, for the first time at an international motor show, the Lancer Sportback at the Le Mondial de l'Automobile 2008 (Paris Motor Show 2008) being held in Halls 1-8 of the Paris Expo Porte de Versailles from October 2 (October 4 for the general public) through October 19. The Lancer Sportback will have its European launch this fall with a phased introduction into the various countries in the region.
The company will also be displaying the Lancer Ralliart and Lancer Sportback Ralliart models that are based on the Lancer*1 sports sedan and Lancer Sportback. These models are powered by a turbocharged engine mated to Mitsubishi's Twin Clutch SST (Sport Shift Transmission) and delivering power to all four wheels through an Active Center Differential.
*1 Named the Galant Fortis in Japan
With its inverted-slant nose and trapezoidal grille that defines the Mitsubishi Motors design identity the sporty Lancer Sportback is a 5-door sport hatchback, a body type that is very popular in Europe. The model is available in versions powered by 1.5-liter (109PS) or 1.8-liter (143PS) gasoline engines or by a 2.0-liter (140PS) turbo diesel engine. The Lancer Sportback offers an "auto-folding function" which enhances luggage compartment convenience through adjustable rear floor height and rear seatbacks that can be tipped forward via a lever located in the luggage compartment. The series is due to be joined by a model powered by Mitsubishi Motors' new diesel engine in spring of 2009.
The Lancer Ralliart and Lancer Sportback Ralliart models use a new turbocharged 2-liter 4-cylinder DOHC MIVEC*2 engine [maximum output 177 kW (240PS), maximum torque 343 Nm (35 kgm)]. This is mated to Mitsubishi's high-efficiency Twin Clutch SST transmission with an Active Center Differential, for extremely responsive steering and traction through tailoring the amount of torque fed to each wheel to optimally suit driving conditions. Also helping to significantly raise the basic performance attributes of these cars over the Lancer base model are 2-pot caliper front brakes and a larger brake master cylinder.
*2 Mitsubishi Innovative Valve lift and timing Electronic Control system
