Prispevkov: 11392
Napisal/-a martin_krpan Sr avg 05, 2009 4:57 pm
Bom kar napisal v tej temi.
Tole je poskenirana brošura prenovljenega manjšega Land Cruiserja za leto 2010, poimenovanega tudi Prado ali serija 120. Na Japonskem bo predstavljen septembra, potem pride tudi drugam.
Pri pomlajevanju so se zgledovali po večjem, zgoraj omenjenem Land Cruiserju 200.
dosedanji model:
Prispevkov: 11392
Napisal/-a martin_krpan Po sep 14, 2009 3:40 pm
MajkOly
Prispevkov: 44
Pridružen: Če mar 30, 2006 9:29 pm
Kraj: Blizu Medvod
Napisal/-a MajkOly Po sep 14, 2009 6:43 pm
A to je samo facelift ali je mišljen kot nov? Upam da je to samo facelift.
Prispevkov: 11392
Napisal/-a martin_krpan Ne sep 20, 2009 3:46 pm
Po trditvah tovarne gre za novo generacijo.
TOYOTA UNVEILS THE NEW GENERATION LAND CRUISER
World debut at Frankfurt motor show
KEY POINTS
* All-new Land Cruiser builds on six decades of worldwide success
* Advanced, user friendly technology increases off-road capability and driver assistance
* More refined on-road performance
* Improved equipment specifications
* UK range to feature single powertrain:3.0-Litre D-4D diesel engine with five-speed automatic transmission
* Five-door model with five or seven seats
* On sale in UK from 1 December 2009
With a heritage reaching back almost 60 years and with five million customers in 176 countries around the world, the Toyota Land Cruiser has become an icon of the 4WD market, its name synonymous with Toyota's core values of quality, durability and reliability.
That peerless pedigree provides the platform for the debut of a new generation Land Cruiser at the Frankfurt motor show, a model that goes further than ever before to deliver true go-anywhere toughness and on-road driving poise.
Land Cruiser's reputation has been built on its ability to meet owners' demands for a vehicle that is utterly reliable in even the harshest off-road conditions, yet offering performance and refinement appropriate for day-to-day driving.
With its new model Toyota has extended Land Cruiser's off-road capabilities with a higher level of on-board guidance and technical support for the driver. New, user-friendly functions have been introduced that can help make tricky routes passable, over terrain on which even accomplished off-road drivers might feel challenged.
The quality and scope of these new features help make the all-new Land Cruiser one of the most technically advanced but enjoyable and easy to drive off-road vehicles in the world.
Style and comfort are important to 4WD customers, too, hence Land Cruiser combines it off-road toughness with pleasing on-road driving characteristics and higher standards of quality and comfort.
Bodystyle and powertrain
In the UK new Land Cruiser will be offered exclusively as a five-door model with seven seats (LC3 model has five seats with optional third row), powered by a revised 171bhp 3.0-litre D-4D diesel engine with five-speed automatic transmission. A three-door model and a 4.0-litre V6 Dual VVT-i petrol engine will be available in other European markets, but there are no plans for these to be offered in the UK. Combined cycle fuel economy is a best-in-class 34.9mpg and CO2 emissions are 214g/km, improvements of 5.1 and 4.5 per cent respectively on current Land Cruiser performance.
Suspension, ride and handling
The rigidity of the body-on-frame construction has been increased by 11 per cent and insulating frame-to-body mounts have been added to absorb engine, drivetrain and road noise, and to improve ride comfort.
The front independent double wishbone and rear four-link lateral rod suspension systems have been revised for extra comfort and steering feel. LC4 and LC5 models grade models are equipped with a new electronic Kinetic Dynamic Suspension System (KDSS), which adjusts the front and rear anti-roll bars for optimised on and off-road performance.
The flagship LC5 version benefits from Toyota's Adaptive Variable Suspension (AVS) system with Roll Posture Control, which lets the driver tune the ride characteristics with a choice of three damper settings. An electronically controlled rear air suspension system works with the AVS, providing an auto-levelling function and switchable height control. The air suspension is also effective in absorbing high frequency vibrations and reducing road-generated NVH.
Off-road technology
A new feature launched by Toyota in the new-generation Land Cruiser is Multi-terrain Select, which automatically controls power and braking to optimise performance for different types of off-road surfaces. At the same time, the Multi-terrain Monitor feeds real time images from around the vehicle from a network of four cameras to provide the driver with more information about the immediate surroundings. The new Steering Angle Display shows the position of the vehicle's wheels and its predicted path, further helping the driver plot a safe route.
The Crawl Control feature lets the driver choose from five different setting to optimise vehicle set-up to tackle even extreme conditions with precision and control, without having to use the throttle or brake pedals. Crawl Control will also help the driver free the vehicle, should it become stuck in mud or sand.
Interior packaging
New Land Cruiser has a more spacious and refined cabin with accommodation for seven in three rows. The second row seats have a sliding range of 135mm and a more flexible 40:20:40 configuration, with reclining seatbacks. A walk-in, slide and tilt function gives easy access to the third row seats.
The two third row seats (an option on the five-seat LC3 model) are full-size with integral headrests and they fold completely flat into the loadspace floor when not required. The footwell floor has been lowered by more than 38mm for a more comfortable seating position and, thanks to the slide adjustment of the second row seats, legroom extends to more than double that in the current Land Cruiser.
The left and right hand seats can be raised and lowered independently, using the Toyota Easy Flat system; LC4 and LC5 grade models this function is power-controlled at the touch of a button. Controls are handily located both inside the tailgate and behind the second row seats.
The flexibility of the seating is complimented by numerous, practical storage spaces, including a compartment with a USB port for simultaneous connection and charging of portable music players, and a large centre console box that can be fitted with a compact fridge unit.
Equipment features
Land Cruiser benefits from a range of high-tech, user-friendly systems to make life on board easier and more comfortable. The Smart Entry and Start system works in conjunction with sequenced lighting, and at the rear the tailgate has a top-hinged glass section that allows access to the load space even in tight parking spaces. Everyone can enjoy a comfortable cabin environment thanks to a separate air conditioning unit for the rear, giving new Land Cruiser a triple-zone climate control (LC4 and LC5 models only).
A multi-information switch on the steering wheel brings together several features under a single control, and the cameras used by the Multi-terrain Monitor also provide Wide-view Front, Side and Back Guide Monitors for easier manoeuvring in tight spaces and visibility at blind junctions.
Land Cruiser LC4 and LC5 models are equipped with a 14-speaker JBL Synthesis Premium Surround Sound System, giving 7.1 channel sound from compatible CDs and DVDs. It features an 11-channel, 605W Digital Signal Processing amplifier and, using the navigation system's Hard Disc Drive (HDD), offers a "sound library" facility, capable of transferring and storing up to 2,000 tracks from CDs.
Grade structure and outline equipment specifications
New Land Cruiser will be available in the UK in three equipment grades: LC3, LC4 and LC5. Equipment highlights are provided in the table below, with additional features across the board compared to current Land Cruiser specifications.
JDM verzija:
http://www.carview.co.jp/magazine/photo ... prado/386/
Skladno s tradicijo bo kmalu na trgu tudi trivratni (krajši) LandCruiser.
simply
Prispevkov: 3065
Kraj: Nova Gorica
Napisal/-a simply Ne sep 20, 2009 5:40 pm
Xenon mu res manjka. :(
BlazR
Prispevkov: 321
Napisal/-a BlazR Ne sep 20, 2009 11:29 pm
Oblikovno je tole zame korak nazaj. Trenutn je bolj elegantn, predvsem pri maski in zadnjih lučeh.
Sj gre tuki za navadn land cruiser in ne za tistga povečanga, ker za tistga bi bla tale oblika napredek?
xc70 2.5t
Prispevkov: 33
Pridružen: So nov 11, 2006 3:42 pm
Napisal/-a xc70 2.5t To sep 22, 2009 6:16 pm
Huda zadeva ni kej!!
Po frankfurtu bodo sprejemal prva naročila.... Moj oče ga bo naročil komaj čakam prvo vožnjo!!!
volvo cross country 2.5T AWD
chan
Moderator | Naj pisec
Prispevkov: 1620
Napisal/-a chan Sr sep 23, 2009 7:37 am
Glede na cenovni rang vozila absolutno preplastična notranjost (posebej neposrečena imitacija lesa) - osebno moteč faktor pri avtomobilu, ki se ceni na +50.000€: digitalna ura na sredini armaturne plošče, kot spominek na 80-leta. Konkurenca je tukaj napredovala bistveno dlje: npr novi Discovery 4 (tudi z otipljivo boljšimi materiali). Naslednja minus točka je motorna izbira, saj ostaja na 4 cilindrskem 173km dieslu, brez opcije 6 cilindrskega.
Subjektivno, gledano v živo, me zunanjost ni prepričala, predhodnik je ob predstavitvi 6 let nazaj vzbujal "lepše" občutke.
Se pa bo zaradi imena prodajal itak sam od sebe, design gor ali dol - čeprav Toyota v zadnjih letih oblikuje svoje avtomobile v nekih čudnih, evropskemu okusu nenavajenih, japonsko - baročnih oblikah. Toyota je znala v preteklosti že lepše oblikovati svoje modele.
xc70 2.5t
Prispevkov: 33
Napisal/-a xc70 2.5t Če sep 24, 2009 3:09 pm
to zgleda samo na slikah tako, vendar so notranjosti toyot( v milslih imam LC in RAV) na koncu ene najbolših v razredu: Poglejte samo novo LC 200 (V8) ki na slikah zgleda bogo, plastično ko se pa v njo usedeš pa opaziš da ima same najbolše materijale( usnje plastika končna obdelava, spoji,les...),boljše kot pri konkurenci,
enako je blio tudi z LC 120 v katalogu zgleda vse podpovprečno ko se pa vsedš v njo so materijali in počutje eno najbolših.
Mogli bi se naučit pri MB kako se dela katalog. Na slikah notranjost ML zgleda vrhunsko ko se pa vsedeš v njega pa notranja konzola razočara sama boga plastika(povrhu pa še spoji med radijem in kozolo zgleda kod bi bili vzeti iz drugega avtomobila), samo sedeži so izjema ki so vrhunski kot se za zvezdo spodobi
chan
Prispevkov: 1620
Napisal/-a chan Pe sep 25, 2009 7:23 am
xc70 2.5t je napisal/-a:to zgleda samo na slikah tako, vendar so notranjosti toyot( v milslih imam LC in RAV) na koncu ene najbolših v razredu: Poglejte samo novo LC 200 (V8) ki na slikah zgleda bogo, plastično ko se pa v njo usedeš pa opaziš da ima same najbolše materijale( usnje plastika končna obdelava, spoji,les...),boljše kot pri konkurenci,
Žal sem si vse ogledal na licu mesta (Frankfurt) ter istočasno primerjal s konkurenco. ;) Katalogi so pač nemerodejni pri oceni avtomobila. Ocena je sicer subjektivna, vendar me je neposredna konkurenca bolj prepričala (LC Discovery 4, pogojno prenovljeni RR Sport, GC v Overland verziji,...). Čeprav ni neposredna konkurenca, vendar je občutek v BMW X5 ali v MB ML neprimerno drugačnejši, z občutkom za detajle (koliko je to vredno pri preplačilu v končni ceni, pa itak vedo samo kupci sami).
Da ne bo pomote, z materiali me je razočaral tudi novi Lexus RX, druga zgodba pa je novi LC V8 (čeprav prihajata iz istega hleva ter s končno podobno MPC).
Novi RAV 4 je v ožjem družinskem krogu, ob predstavitvi pred 3 leti je veljal za spodobno opremljenega, danes pa ga žal že načenja konkurenca.
Toyota ima druge kvalitete, sami materiali v notranjosti ter finese končne izdelave žal nimajo primata med konkurenco! Kot že omenjeno pa ima LC dovolj dober image iz preteklosti, da se tovarni ni poptrebno bati za nadaljno prodajo modela.
Prispevkov: 11392
Napisal/-a martin_krpan Sr okt 07, 2009 5:15 pm
Prispevkov: 11392
Napisal/-a martin_krpan So nov 21, 2009 10:01 pm
Predstavljen je bil tudi Lexusov klon novega Prada - 2010 Lexus GX 460. Notranjost je povsem spremenjena in bolj luksuzna.
http://es.autoblog.com/2009/11/21/se-fi ... us-gx-460/
ma5t3r
Prispevkov: 36
Pridružen: Ne jul 10, 2011 6:37 pm
Re:
Napisal/-a ma5t3r To jul 26, 2011 8:16 pm
martin_krpan je napisal/-a:Uradne fotografije
a ni to Toyota LC 200 ne pa 100?? http://www.google.si/search?um=1&hl=sl&biw=1680&bih=925&q=toyota+land+cruiser+200&gs_sm=e&gs_upl=14761l15096l0l16119l3l3l0l0l0l0l206l561l0.2.1l3&ie=UTF-8&tbm=isch&source=og&sa=N&tab=wi
drugač pa kaj gdo mogoče ve gdaj pride naslednja generacija LC200-ke?? Lp.
Prispevkov: 11392
Re: 2008 Toyota Land Cruiser/Lexus LX 570
Napisal/-a martin_krpan Po dec 26, 2011 5:56 pm
2012 Land Cruiser 200 facelift:
old vs new:
vir:
http://www.drive.ru/toyota/news/2011/12 ... enniy.html
Marek_
Prispevkov: 2207
Napisal/-a Marek_ Po dec 26, 2011 6:17 pm
Z vsako novo generacijo oz. faceliftom ga naredijo bolj zastarelega in manj prijetnega za oko.
Rajmond
Prispevkov: 418
Pridružen: Po nov 08, 2010 11:02 pm
Napisal/-a Rajmond Po dec 26, 2011 9:29 pm
Ovo sam vozil 2009, novi LC V8 diesel
nastavak na sliku...+300.000 pregleda
http://www.youtube.com/watch?v=hxpwKQ5N ... ature=plcp
Onda ovo...
A ovo 2010 :)
A ovo za sezonu 2011/2012
Next Grobnik Track Day - 01.6.2014.!!!
Rajmond
Prispevkov: 418
Napisal/-a Rajmond So dec 31, 2011 8:47 am
30.12.2011.
Prispevkov: 11392
Napisal/-a martin_krpan Po jan 09, 2012 8:40 pm
Kot pričakovano Land Cruiserju sledi tudi prenovljeni LX 570
http://es.autoblog.com/2012/01/09/detro ... x570-2012/
Prispevkov: 11392
Napisal/-a martin_krpan Če jun 21, 2012 6:36 am
Prispevkov: 11392
Napisal/-a martin_krpan Pe avg 23, 2013 8:44 pm
Po forumu brska: 0 registriranih uporabnikov in 122 gostov
