tomson
Prispevkov: 1386
Kraj: LJ / MB
Napisal/-a tomson Po avg 24, 2009 5:33 pm
Fenomenalen je. Končno so izboljšali dizajn notranjosti.
Barracuda1
Prispevkov: 138
Pridružen: Po jan 07, 2008 12:58 pm
Napisal/-a Barracuda1 Po avg 24, 2009 8:00 pm
Res zgleda fantastično! Je znana mogoče cena te izvedenke?
chgotom
Prispevkov: 646
Pridružen: Sr mar 14, 2007 6:33 am
Kraj: Chicago, USA
Napisal/-a chgotom Po avg 24, 2009 9:19 pm
Barracuda1 je napisal/-a:Res zgleda fantastično! Je znana mogoče cena te izvedenke?
Za cene poglej na http://www.fordvehicles.com/trucks/f150/
To so neto cene tukaj v ZDA za 2010 modele F-150.
Koncno ceno v evrih v Sloveniji dobis, ce pomnozis neto amerisko ceno v USD s faktorjem 1.4.
USD$30K neto USA = 42K evrov koncna v Sloveniji na cesto.
LP iz Chicaga!
Prispevkov: 11405
Napisal/-a martin_krpan Če sep 24, 2009 5:25 pm
2011 Ford Super Duty z novim dizelskim motorjem: 6,7 V8 Scorpion.
http://www.autoblog.com/2009/09/24/2011 ... o-new-eng/
ALL-NEW POWERTRAINS, CLASS-LEADING CAPABILITY REINFORCE 2011 FORD SUPER DUTY'S TOUGH TRUCK STATUS
* The 2011 F-Series Super Duty boasts all-new powertrains, led by the Ford-designed, Ford-engineered and Ford-built 6.7-liter Power Stroke® V-8 turbocharged diesel engine, which delivers significantly improved torque and horsepower as well as class-leading fuel economy while maintaining best-in-class towing and payload capability; new engine also has biodiesel compatibility up to B20
* A new 6.2-liter V-8 gasoline engine also is added to the lineup; it also delivers significantly improved torque and horsepower as well as class-leading fuel economy; new gas engine can run on regular-grade gasoline, E85 or any blend in between
* An all-new 6R140 heavy-duty TorqShift® six-speed automatic transmission gets the new diesel engine's low-end torque to the ground faster; the six-speed transmission has full SelectShift™ capability, giving customers the convenience of a manual gearbox
* Available Ford Work Solutions™ plus a new flow-through console with 110-volt inverter, new seats and locking underseat storage add even more productivity in the Super Duty's role as office on wheels; new 4.2-inch LCD Productivity Screen delivers array of information
* The new 6R140 transmission is available with segment-exclusive Live Drive Power Take Off (PTO) with the new diesel
DALLAS, Sept. 24, 2009 – Ford Super Duty customers expect and demand capability from the best-selling heavy-duty truck in America. For most Super Duty owners, it's the core asset of their business. Day after day, year after year, it's expected to deliver results in the most demanding situations. No nonsense. And never any excuses.
"Our Super Duty customers do some of America's toughest jobs," said Mark Fields, Ford president of The Americas. "Every day they're out there working with little fanfare and all they ask is the right tool for the job. The new 2011 Super Duty offers them a truck with best-in-class towing and payload, all-new powertrains and even more capability than ever to help them do their jobs."
Ford's F-Series has been the best-selling line of trucks in the U.S. for 32 straight years. The new Super Duty further underscores Ford's Built Ford Tough legacy.
"The 2011 Super Duty offers the widest array of solutions for the widest array of heavy-duty work truck customers," said Chris Brewer, chief engineer. "The Super Duty lineup offers a variety of body styles and powertrains, from diesel and gasoline engines, each with a new six-speed transmission, to pickup trucks and chassis cabs, each with the towing and payload capabilities that define Super Duty."
New diesel and gasoline engines deliver improved torque, horsepower, fuel economy
For 2011, Super Duty features both an all-new diesel and gasoline engine that are mated to a new transmission. The new diesel, the 6.7-liter Power Stroke V-8 turbocharged diesel engine, was designed, engineered and built by a Ford team dedicated solely to delivering this class-leading diesel engine to the next-generation Super Duty to enable continued best-in-class towing and payload.
Benefits of the new 6.7-liter Power Stroke diesel engine:
* First use of a compacted graphite iron (CGI) engine block in a Super Duty-class vehicle in North America; CGI is stronger than cast iron, and Ford successfully has used the material in engine blocks in products around the world. The block structure was optimized for reduced weight and maximum strength to meet the demands of higher torque and more horsepower and enable class-leading fuel economy.
* Unique inboard exhaust and outboard intake architecture, an automotive-industry first for a modern production diesel, reduces overall exhaust system volume, which leads to better throttle response; a reduced exhaust system surface area minimizes heat transfer to the engine compartment and improves NVH (noise, vibration and harshness).
* The turbocharger features an industry-first dual-sided compressor wheel that works in a single housing. The unit is uniquely center-mounted on a pedestal low in the back of the valley for improved NVH. The design allows the single unit to deliver the advantages of a twin-turbocharger system in a smaller, more efficient package, combining the benefits of a small turbocharger (faster response) and a large turbocharger (ability to compress and force more air into the engine for more power) in one unit.
* The high-pressure fuel system injects fuel at more than 29,000 psi. The system delivers up to five injection events per cylinder per cycle using eight-hole piezo injectors to spray fuel into the piston bowl. The direct-injection system is calibrated and phased for optimum power, fuel efficiency and NVH.
* Aluminum cylinder heads for reduced weight; the mid-deck construction with dual water jackets provides increased strength and optimal cooling; six-head bolts, instead of four as found on other engines, help improve sealing and maintain cylinder integrity even with the higher firing pressures.
* Compatible up to B20 fuel, allowing greener fueling options of up to 20 percent biodiesel and 80 percent petroleum diesel.
"Developing the new 6.7-liter Power Stroke V-8 turbocharged diesel engine was an awesome endeavor," said Adam Gryglak, lead 6.7-liter diesel engineering manager. "After all the engineering and testing, we're confident this engine will ensure the new Super Duty continues its leadership in capability, reliability and productivity."
The engine and aftertreatment system for the 6.7-liter Power Stroke V-8 turbocharged diesel powertrain ably meets the new, more stringent 2010 federal emissions requirements for nitrogen oxides (NOx), which have to be lowered by approximately 80 percent.
New gasoline engine delivers more torque, horsepower than outgoing model
Ford tapped into a bit of its proud racing heritage to create the new 6.2-liter V-8 gasoline engine, which uses big-bore architecture to produce horsepower and class-leading fuel economy. The V-8's large bore (102 mm) allows for larger intake and exhaust valves for improved engine breathing, and the short stroke (95 mm) allows higher engine speed for increased horsepower.
Benefits of the new 6.2-liter V-8 gasoline engine include:
* SOHC valvetrain with roller-rocker shafts: The single overhead camshaft (SOHC) per cylinder head design results in a stiff valvetrain that allows optimized camshaft lift profiles and results in great low-speed torque. The roller-rocker shafts allow valve angles to be splayed, resulting in optimized intake and exhaust port layout for better breathing.
* Dual-equal variable cam timing: Intake and exhaust valve opening and closing events are phased at the same time to optimize fuel economy and performance throughout the engine speed range and throttle positions.
* Two spark plugs per cylinder: Due to the large bore size, two spark plugs per cylinder are used to more efficiently burn the fuel-air mixture in the combustion chamber, enabling better fuel economy and increased engine torque. The twin plugs also help the engine maintain a smooth, stable idle.
* Dual knock sensors: A knock sensor on each bank of cylinders of the V-8 engine allows the spark timing of each of the cylinders to be individually optimized real time, throughout the engine speed range. The engine learns the optimum timing via an adaptive algorithm.
* Better engine crankcase "breathing" and efficiency: Significant development work and computer-aided engineering optimized the cylinder block for more efficient airflow in the crankcase as the pistons move up and down in the bores, resulting in improved torque at higher engine speeds. Piston-cooling jets squirt oil on the underside of the pistons to keep the piston crowns cool under extreme operating conditions. The cooling jets also allow for a higher compression ratio for better engine efficiency and faster engine oil warm-up on cold starts, also improving fuel economy.
New TorqShift transmission harnesses and manages the power; Live Drive PTO available
The all-new 6R140 heavy-duty TorqShift six-speed automatic transmission was designed to manage the high low-end torque produced by the new diesel engine. The same basic transmission also is mated to the new gasoline engine, giving customers of either engine the ability to efficiently get the increased torque and horsepower to the ground. Engineered for greater efficiency and fuel economy, improvements include refined architecture to provide relatively low clutch speeds, which result in lower drag losses, and optimized fluid levels and drainback to reduce churning of fluid while also providing superior lubrication.
In addition to hardware-based improvements, the new transmission features enhanced Tow Haul with integrated engine exhaust braking and SelectShift Automatic capability, which includes Progressive Range Select and a manual mode, allowing customers to select the gear to suit their needs.
The new TorqShift transmission also enables the first application of Live Drive PTO (Power Take Off) in a Super Duty-class vehicle. On 2011 Super Duty diesels with the PTO prep option, the PTO output gear is linked through the torque converter to the engine crankshaft. This allows the transmission to power auxiliary equipment such as snowplows, aerial lifts, tow truck lifts, cement mixers or dump trucks. The power is available any time the engine is running.
Pioneered on agricultural applications, the Live Drive feature is particularly useful when mobile PTO function is required during start-stop operations, such as salt spreading or snow plowing. "A fully functional Live Drive mobile PTO will allow Super Duty customers to take full advantage of the equipment on their trucks," said Al Bruck, 6R140 transmission engineering manager.
Best-in-class towing and payload; new towing options
Putting all that power to work is what defines Super Duty. The 2011 Super Duty features increased towing and payload capability, extending its best-in-class rating, and also offering more towing from inside the bed. New is the first-ever factory-installed and warranted fifth wheel and gooseneck substructure directly attached to the frame.
"Our system is factory-installed and with a limited warranty from Ford. The electrical connection is mounted in the side of the bed wall, providing a clean installation," said Peter Frantzeskakis, vehicle engineering manager.
Particularly noteworthy are productivity enhancements to the F-450 pickup to benefit the heaviest-duty trailer tow customers. Unneeded weight was shed, helping to improve fuel economy and top speed. Even with these changes, the Super Duty F-450 pickup maintains its class-leading gross combined weight rating of 33,000 pounds.
Addition of Trailer Sway Control leads safety enhancements
Ford's lauded Trailer Sway Control (TSC) system joins the Super Duty lineup, giving those customers segment-first capability. TSC is integrated with AdvanceTrac® with Roll Stability Control™, which now is standard on all single rear wheel (SRW) configurations.
The AdvanceTrac control module uses additional software to monitor the truck's motion when a trailer is attached. Trailer Sway Control can determine from the yaw motion of the truck if the trailer is swaying and take measures – such as applying precise braking or reducing engine torque – to help reduce the trailer sway.
For further peace of mind, the available integrated trailer brake controller, factory-installed and covered by a Ford limited warranty, offers smoother and safer operation due to its ability to interface with multiple vehicle systems.
Normal braking is proportional to driver brake pressure for smooth brake stops at all speeds. If the vehicle's Anti-lock Brake System (ABS) is engaged, the special trailer brake kicks in to minimize the potential for trailer wheel lock up. In Super Duty trucks with Trailer Brake Control towing trailers with electric brakes, the Ford system can, during a sway event, also apply brakes to the trailer to help stabilize it.
Other enhanced towing, off-road control features and safety improvements include:
* Hill Start Assist, which applies brakes to prevent rollback
* Hill Descent Control™, which uses the accelerator and brake to set, and then hold, the speed
* Electronic Locking Differential, which provides maximum traction by forcing the rear wheels to turn at the same speed
* Standard tire pressure monitoring system on all SRW (single rear wheel) models
* Optional side air bags and air curtains
* A new available 4.2-inch LCD screen includes information on specific features such as Trailer Brake Control and Tow Haul
Improved ride, handling and steering for a more comfortable experience
In addition to increased towing and payload capability and improved fuel mileage enabled by the new powertrains, customers of the next Super Duty also will benefit from improved ride, handling and steering. For 2011, the engineering team optimized the frame and suspension of the current Super Duty, particularly the leaf springs and spring rate, as well as adjusting the internal valving in all the shock absorbers to enable greater towing and payload capability with further ride refinement.
The steering gear also is new. The 4x2 F-250 and F-350 Super Duty feature modified steering system geometry to take better advantage of the twin I-beam suspension, which combines the performance of an independent suspension with the durability of a beam axle suspension. Improved response, precision and better on-center steering and control come from making the steering gear symmetric left to right.
The result is greater customer comfort, confidence and control in all situations.
"A big part of the comfort in Super Duty trucks comes through controllability," said Dan Gompper, vehicle dynamics supervisor. "No matter if the truck is loaded or unloaded, full trailer or empty trailer, customers can be fully confident."
Bold exterior, new flow-through console highlights interior
The new hood of the 2011 Super Duty, with its prominent inverted power dome, complements the new diesel and gasoline engines lurking beneath. "Super Duty" is stamped on the upper grille, with a larger Ford oval proudly gracing the front.
Inside, customers will benefit from a new reconfigurable flow-through console that improves the functionality of the truck. Storage space is increased about 60 percent, and at least 70 different configurations are possible. A 12-volt powerpoint is available at the rear of the console and another is located inside the main bin, which is lockable. A 110-volt power inverter is standard with all console configurations.
Improved productivity through Ford Work Solutions
For many customers, the Super Duty cab also serves as a mobile office. Industry-exclusive Ford Work Solutions is part of available technology to help customers stay connected with their business from the job site and track tools.
A new available 4.2-inch LCD Productivity Screen allows customers to take full advantage of the 2011 Super Duty's capabilities; an off-road message center has been added as well. The five-way button on the steering wheel allows customers to navigate through various menu options – several relating to fuel economy and towing convenience – never before available on a Super Duty truck.
Continuing the legacy of quality
With all-new powertrains enabling greater towing and payload capability, safety enhancements such as Trailer Sway Control added and greater functionality with available Ford Work Solutions, the new 2011 Ford Super Duty is poised to continue its legacy as America's premier work truck.
The accolades the current Super Duty has received, based on 2009 model year GQRS (Global Quality Research System) data, include:
* Best-in-Class TGW (Things Gone Wrong) for All Pickup Truck Segments
* Best-in-Class Customer Satisfaction among Heavy Duty Pickups
"With all-new powertrains and increased capability, the 2011 Super Duty improves on its proud heritage as the ultimate work truck," said Brewer.
cruiser1
Prispevkov: 2683
Napisal/-a cruiser1 Če sep 24, 2009 5:31 pm
Kva ma hudo masko!! :shock: ZAKON!! 8)
tomson
Prispevkov: 1386
Kraj: LJ / MB
Napisal/-a tomson Če sep 24, 2009 5:31 pm
Živela Amerika. :shock: Hud je.
Prispevkov: 11405
Napisal/-a martin_krpan So nov 07, 2009 9:22 am
Eno leto po predstavitvi Raptorja, je Ford prikazal še hujši Raptor, opremljen s 6,2 litrskim V8 motorjem, ki razvija 411 konjev. Od šibkejšega brata bo dražji za 3.000 USD.
Enak motor ima tudi Ford Racing Raptor XT, ki je kopija dirkalnega Raptorja, s katerim so tekmovali na Baja 1000 a z bolj civilizirano notranjostjo. XT-jev bodo izdelali 50 in ni street-legal.
PRESS RELEASE:
LAS VEGAS, Nov. 3, 2009 – Just one year after Ford unveiled the 2010 F-150 SVT Raptor at the SEMA show, Ford today is announcing the long-anticipated power figures for the all-new 6.2-liter premium V-8 engine now available in this ultimate high-speed off-road performance truck.
When this optional powertrain in the Raptor arrives in showrooms in early 2010, the 6.2-liter V-8 will produce 411 hp and 434 ft.-lb. of torque, making Raptor the most powerful half-ton pickup available. Customers will now have the choice of two V-8 engines in the Raptor, Ford's proven 5.4-liter Triton V-8 or the new 6.2-liter V-8, which can be ordered beginning Dec. 1, with an MSRP of $41,995 including destination and delivery.
The F-150 SVT Raptor, launched in August with Ford's proven 320-hp 5.4-liter Triton V-8, is off to a strong start. Orders for the Raptor equipped with the standard 5.4-liter stand at more than 3,000, and the plant is at maximum capacity producing the ultimate high-speed off-road truck. In addition, Ford Racing will soon offer the 2011 FR Raptor XT, making Raptor even more capable in the rough stuff, but without giving up the control and comfort found in the production Raptor.
Considered an off-road-only pre-runner, the FR Raptor XT from Ford Racing builds upon the production Raptor's already impressive capabilities. The FR Raptor XT is nearly the same truck that finished the 2008 Tecate SCORE Baja 1000, but with all the comfort and convenience you'd find in a production Raptor. Essentially, FR Raptor XT is a turnkey professional pre-runner.
Key specifications of the FR Raptor XT include:
* 500-hp (est.) 6.2-liter naturally aspirated engine
* Six-speed automatic transmission
* Electronically selectable 4x4; 4.56 gear sets; front and rear e-lockers
* A-arm with uni-ball front; four-link RR suspension
* 15-inch front/18-inch rear wheel travel
* Coil-over with bypass shocks front and rear
* Chromoly "4130" rollcage; extensive skid plating
* Full featured interior, including power windows/windshield and air conditioning
* Factory seating with five-point restraints
* Off-road beadlock wheel/tires
* Unique appearance package including tubular front and rear bumper and integral lighting
The FR Raptor XT joins Ford Racing's successful turnkey race Mustangs available only from Ford dealers. There will be a production run of 50 units carrying a price of $99,950. The FR Raptor XT is not street legal, and is intended for off-road use only. Production timing will be announced at a later date.
http://www.caranddriver.com/news/car/09 ... auto_shows
PIKSNA007
Prispevkov: 1161
Napisal/-a PIKSNA007 So nov 07, 2009 11:34 am
Tale ford je pa res hud ane :shock:
King1
Prispevkov: 4317
Kraj: Vzhodno od Domžal
Napisal/-a King1 So nov 07, 2009 11:39 am
PIKSNA007 je napisal/-a:Tale ford je pa res hud ane :shock:
Se strinjam, res je prava hudobija tale zadeva.
Prispevkov: 11405
Napisal/-a martin_krpan Po mar 08, 2010 6:43 pm
Prispevkov: 11405
Napisal/-a martin_krpan Pe sep 03, 2010 4:03 pm
F-150 SVT Raptor od sedaj na voljo tudi s štirimi vrati (SuperCrew). Za ML 2011 je Raptor izgubil osnovni 5,4 V8 motor, edina možnost je močnejši 6,2 V8. Dobil je novo barvo (srebrno metal), nalepke za motorni pokrov in še par malenkosti.
http://www.blogcdn.com/www.autoblog.com ... static.jpg
http://www.blogcdn.com/www.autoblog.com ... action.jpg
2011 FORD F-150 SVT RAPTOR ADDS SUPERCREW OPTION, MORE TECHNOLOGY, TOWING, STANDARD 6.2-LITER ENGINE
• Ford F-150 SVT Raptor again is raising the bar for high-speed off-road performance trucks by adding a SuperCrew option and more standard power and towing capability for 2011
• The previously optional 6.2-liter V8 engine, which produces 411 horsepower and 434 lb.-ft. of torque, now comes standard for 2011, making Raptor the most powerful half-ton pickup on the market
• Upgraded technology content, including a standard 4.2-inch LCD productivity screen and SelectShift Automatic™ transmission, keeps customers more in tune with their trucks, while
a new graphic and color choice gives them more options
DEARBORN, Mich., Sept. 3, 2010 – A new standard 6.2-liter V8 engine pumping out 411 horsepower, new technologies and a newly available SuperCrew option that gives Raptor customers more choices in cab size all ensure the 2011 Ford F-150 SVT Raptor will remain the off-road performance truck champion in the new model year.
"When we launched the F-150 SVT Raptor, consumers were blown away with the capability of the vehicle," said Jost Capito, director of global performance vehicles and motorsports business development. "By adding the SuperCrew, we have expanded the versatility of Raptor, and now even more enthusiasts will be able to experience the no-compromise off-road performance that only Raptor delivers."
The F-150 SVT Raptor is the first-ever high-speed off-road performance truck offered by any manufacturer and highlights 33 years of Ford truck sales leadership by emphasizing F-150's Built Ford Tough durability, innovation and engineering. Developed with the DNA of an off-road pre-runner, comprehensive modifications focused on chassis and suspension enhancements.
The F-150 SVT Raptor is 7 inches wider than a base F-150 to make room for the additional suspension components that give Raptor its unparalleled off-road abilities. The wider stance also gives the truck an aggressive appearance. Internal triple-bypass shocks by FOX Racing Shox – the first on a production truck – provide position-sensitive damping and extra suspension travel for extreme off-roading and a smooth ride on the road.
Raptor also has unique cast-aluminum front control arms and SVT-tuned 35-inch BFGoodrich® All-Terrain TA/KO 315/70-17 tires. These components give Raptor 11.2 inches of front suspension travel and 12.1 inches of rear suspension travel on either SuperCab or the new SuperCrew.
The new available 145-inch-wheelbase SuperCrew offering with a 5.5-foot box adds to the extensive list of F-150 SVT Raptor features. While contributing additional space and flexibility for the customer, the SuperCrew delivers performance as well.
Applying lessons learned from the SuperCab F-150 SVT Raptor, engineers were able to tune the truck to handle off-road events with ease. The 12-inch-longer wheelbase on SuperCrew also delivers the benefit of a more comfortable ride, especially in rough off-road situations.
"We spent a lot of time getting the ride and suspension characteristics of the SuperCrew similar to that of the SuperCab, and we were successful in getting the same character and flavor out of the SuperCrew," said Jamal Hameedi, SVT chief nameplate engineer. "While the SuperCab and SuperCrew both have different strengths, each is worthy of the Raptor nameplate."
A larger 36-gallon fuel tank and increased towing capability – rated at 8,000 pounds – keep F-150 SVT Raptor SuperCrew a mainstay in the desert environment, with capabilities as a chase or tow truck.
Revved up and ready
The previously optional 6.2-liter V8 engine, which produces 411 horsepower and 434 lb.-ft. of torque, will now be the standard engine for the 2011 F-150 SVT Raptor, the most powerful half-ton pickup on the market.
The Ford powertrain team performed extensive testing to ensure the engine would live up to the Built Ford Tough promise. Hundreds of additional tests beyond the normal verification of truck engines, as well as vehicle testing on a 62-mile durability loop in the desert that simulates the Baja 1000, validated the performance of the engine for reliability and longevity in the harshest conditions.
New color and graphic options
Raptor's exterior also receives some new touches for 2011, in the form of an additional paint color – Ingot Silver Metallic – that will be available with the standard black interior, or the optional Molten Orange Interior Accent Package.
A new optional hood graphic adds a personalized and functional touch to F-150 SVT Raptor. Inspired by older off-road racing Ford Broncos, matte black accent graphics – including the F-150 SVT Raptor logo – run along the hood, also helping to reduce glare. The Raptor logo in the graphic is done in body-color bleed-through, similar to "SVT" on the side vent. "F-150" and "SVT" are written in dark gray. The graphic is available with or without the box side graphics.
More capability, more technology
Key to helping customers take advantage of all the capability offered by the F-150 SVT Raptor is a standard 4.2-inch LCD (liquid crystal display) productivity screen that is integrated in the center of the new instrument gauges, which have a black face, red pointers and ice blue daytime lighting. Also used on the all-new 2011 Super Duty, the technology was specifically tailored for off-road use with Raptor.
The screen includes a unique welcome animation and offers menu options giving the customer important information related to off-road and towing performance. A truck application screen provides vehicle status information for important off-road parameters such as off-road mode, Hill Descent Control™, electronic locking differential settings and AdvanceTrac® with RSC® (Roll Stability Control™).
An off-road screen informs the customer about steering wheel angle and vehicle angle on a grade during off-road maneuvers. The menu is navigated through a five-way button on the steering wheel and is positioned between the tachometer and speedometer.
"The productivity screen is a great solution for our off-road customers," said Hameedi. "With one glance, they can tell exactly what settings are enabled on their truck and what the driveline
is doing."
For the customer who wants more control of transmission gear selection, SelectShift Automatic transmission functionality also is introduced on Raptor. A toggle switch located on the console shift lever engages the mode, where the transmission doesn't second-guess the driver, giving him or her total control over gear selection and performance feel. Upshifts, for instance, are not commanded at redline, and downshifts are allowed at the lowest gear possible as defined by the engine speed.
A Raptor Plus Package debuts for 2011, offering the rear view camera and trailer brake controller. The Raptor Luxury Package also receives additional features, with folding power exterior mirrors and Remote Start System with integrated key fob added to the list.
New standard technology features for 2011 include:
• Perimeter alarm
• Integrated spotter mirror
• Express up/down driver and passenger front windows
• 110 V power inverter in the center console
• Head restraint for second-row middle seat
• Telescoping steering wheel
2010 Raptor equals hot seller
Sales of the truck are off to an impressive start, selling four times quicker than the average F-150, with the 2010 F-150 SVT Raptor equipped with the 6.2-liter engine selling within 11 days of arriving at dealerships. In fact, 2010 F-150 SVT Raptor sales are set to exceed the highest model year sales of the F-150 SVT Lightning.
Dealers will start taking orders for the 2011 F-150 SVT Raptor today, and the trucks will be available in dealerships late this year.
MORE POWER COMES STANDARD ON 6.2-LITER V8 ENGINE ON TAP FOR MORE CAPABLE 2011 FORD F-150 SVT RAPTOR
• New for 2011, the Ford F-150 SVT Raptor delivers a standard 6.2-liter V8 engine with
class-leading 411 horsepower and 434 lb.-ft. of torque, powering customers through almost any off-road terrain they encounter
• The engine and truck were tested in the Baja 1000 and on a unique desert loop designed
to prove out the durability that high-performance, off-road enthusiasts demand
• Core features of the new 6.2-liter engine include cast-iron engine block and four-bolt main bearing caps, aluminum cylinder heads, a single overhead camshaft with roller-rocker shaft drivetrain and dual-equal variable cam timing
DEARBORN, Mich., Sept. 3, 2010 – The Ford F-150 SVT Raptor, already known for its unrivaled capability, is ensuring customers have even more power on demand for their off-road adventures by making the previously optional 6.2-liter V8 engine standard for 2011.
With 411 horsepower and 434 lb.-ft. of torque, the engine makes the F-150 SVT Raptor the most powerful half-ton pickup on the market, giving customers new levels of capability. Low-speed maneuvers, such as rock crawling, driving up a grade or accelerating through deep sand, require much less throttle input because of the engine's increased torque.
The exhaust for the 6.2-liter engine was uniquely tuned to deliver the performance-oriented, high-horsepower sound customers want. Additionally, a unique firing order gives the 6.2-liter a distinctive roar.
The 6.2-liter V8 is similar to the engine used in the all-new 2011 Super Duty, but features unique tuning and a special cam profile to produce more horsepower and torque. It's similar to the race-prepped engine that powered Raptor R to a podium finish at the 41st Tecate SCORE Baja 1000 in 2008 and completed every mile of the grueling 2009 Best in the Desert series.
Testing in the heat
The engine was put to the test in its element – the desert of Borrego Springs, Calif. Important factors such as engine cooling were tested on the 62-mile loop designed by Ford's Special Vehicle Team.
"We spent a lot of time developing our desert durability test so that it's very close to replicating the Baja 1000," said Kerry Baldori, global performance chief functional engineer. "Desert testing proved to be a very quick way to learn about the reliability of the truck, and it put another level of extreme loads on the engine that our normal durability testing doesn't need to cover."
Engine cooling is key on Raptor – when the truck is in a desert environment, the hot weather and deep sand put a heavy load on the vehicle, and the engine has to exert maximum power to keep the truck powering on.
There also is more airflow through the radiator at low speeds, and a large and effective cooling system is required for this extreme environment. To improve airflow to the engine, grille openings were increased by 20 percent.
Features of the new 6.2-liter V8 engine include:
• Cast-iron engine block with bay-to-bay breathing and four-bolt main bearing caps with additional cross bolts for durability
• Aluminum cylinder heads, with two valves per cylinder and two spark plugs per cylinder to more efficiently burn the fuel-air mixture in the combustion
• Single overhead camshaft with roller-rocker shaft drivetrain, which creates a stiff valvetrain that allows optimized camshaft lift profiles and results in better low-speed torque. The roller-rocker shafts allow valve angles to be splayed, resulting in optimized intake and exhaust port layout for better engine breathing
• Dual-equal variable cam timing means intake and exhaust valve opening and closing events are phased at the same time to optimize fuel economy and performance throughout the engine speed range and throttle positions
Core to the improvements is using a larger bore and shorter stroke. This approach to creating power has its roots in storied Ford racing engines from the past. The large bore (102 millimeters) allows for larger intake and exhaust valves for improved engine breathing, and the shorter stroke (95 millimeters) allows higher engine speed for increased horsepower. Still, peak horsepower is generated at a relatively modest 5,500 rpm. Piston-cooling jets squirt oil on the underside of the pistons to keep the piston crowns cool under extreme operating conditions.
Crankcase breathing also is improved to reduce windage losses and oil aeration levels at very high speeds. "That really helps get a robust lubrication system for the engine," Baldori said. "It allows us to endure a lot of time at extreme high speeds – and that's a must-have for customers."
http://www.autoblog.com/2010/09/03/offi ... crew-lose/
Prispevkov: 11405
Re: 2009 Ford F150
Napisal/-a martin_krpan Pe mar 09, 2012 6:37 pm
F-Series Super Duty Platinum
More Luxurious Than Ever: 2013 Ford F-Series Super Duty to Offer Platinum Series, SYNC with MyFord Touch
2013 Ford F-Series Super Duty brings no-compromise truck luxury to the market with the first-ever Platinum heavy-duty pickup, complete with unique design cues inside and out
Super Duty Platinum will offer a wealth of standard features including SYNC®, MyFord Touch®, navigation, rear view camera, Remote Start System, power-telescoping mirrors and power-adjustable pedals
For the first time, the 2013 F-Series Super Duty will also be available with a truck-specific version of SYNC with MyFord Touch, offering tactile button controls and large rotating knobs to accommodate truck users who may be wearing work gloves
DEARBORN, Mich., March 9, 2012 – Ford F-Series Super Duty customers demand a truck with toughness and capability, yet they still appreciate the amenities that make their driving experience more enjoyable. The 2013 F-Series Super Duty offers both, with a first-ever Platinum series model and the addition of SYNC® with MyFord Touch®.
"The F-Series Super Duty Platinum is the latest expression of Built Ford Tough truck luxury," said Brian Rathsburg, F-Series Super Duty Marketing manager. "It has a distinct appearance and a long list of features to deliver a superior experience. Along with that, it has all of the capability F-Series trucks are famous for."
Building on the success of the F-150 Platinum light-duty series that debuted in 2009, the F-Series Super Duty Platinum offers customers the ultimate in truck luxury.
Ford pioneered the high-end luxury truck segment in 1999 when it introduced the special-edition 2000 Harley-Davidson F-150. In 2003 the first King Ranch Super Duty arrived, followed by the 2004 Harley-Davidson Super Duty. Today, Ford sells a rich mix of high-end Lariat and King Ranch Super Duty models; the new Platinum will further meet the growing luxury needs of customers and dealers.
Available only in the Super Duty crew cab, it can be ordered as an F-250, F-350 or F-450 pickup and with the Ford-designed and Ford-built 6.7-liter Power Stroke® diesel engine or the 6.2-liter V8 gas engine.
The Platinum series makes a bold statement with a grille that features a satin chrome surround highlighted by perforated mesh inside. The updated grille is enhanced by a monochromatic bumper and chrome tow hooks.
The exterior of the Super Duty Platinum is lavished in chrome, including the door handles, mirror caps, running boards and exhaust tip. The boxside on both sides of the truck sports the "Platinum" name in chrome letters and the tailgate is trimmed with a satin chrome appliqué, similar to the one used on the F-150 Platinum. Twenty-inch polished-aluminum wheels with painted black inserts round out the stunning exterior design of the Super Duty Platinum.
The interior showcases luxury in the form of unique wood grain appliqués. The steering wheel is heated and leather-wrapped, with genuine wood accents. The instrument panel, center stack and door trims are wrapped in premium wood grain. A new storage area on top of the dash includes two USB ports, audio-video connections, SD card slot and a 12-volt charging port for cell phones and other digital devices.
The driver's seat has 10-way power-adjustable seating and both captain's chairs are upholstered with softer, premium leather, which is also used on the armrests and console. Other evidence of fine craftsmanship includes the seats and floor mats, which feature the embroidered "Platinum" logo.
Other standard features include:
Navigation System
Power-adjustable pedals
Rear view camera
Remote Start System
Universal garage door opener
Power-telescoping mirrors
Super Duty Platinum is available in Ruby Red, Kodiak Brown, Tuxedo Black, Ingot Silver and White Platinum. Interior color offerings include Pecan and Midnight Black. Another new exterior color, Blue Jean Metallic, will be available for Super Duty models other than Platinum.
Working harder and smarter
Unlike the past when a truck was often little more than a spartan work vehicle, today's truck customers won't compromise, and they expect capability, efficiency and refinement. The 2013 F-Series Super Duty eliminates any thought of compromise.
Standard Ford SYNCbrings award-winning voice-controlled connectivity into the cab of the most capable heavy-duty trucks available. With SYNC, Super Duty drivers can connect compatible mobile phones and media players via Bluetooth® or USB to make calls and play back music using voice control. In addition, drivers will get access to Vehicle Health Report and 911 Assist®, both no-charge lifetime features, and SYNC Services including traffic alerts, business search and more – all while keeping their hands on the wheel and eyes on the road.
The 2013 F-Series Super Duty builds on the foundation of SYNC with MyFord Touch, which is available for the first time. A new 8-inch, high-resolution touch screen display gives drivers easy access to phone, climate control, entertainment and navigation features along with a dramatically expanded voice control vocabulary.
The 8-inch display screen also provides a large, clear view behind the truck when in reverse to help drivers maneuver in tight spaces or line up conventional trailers with the truck's hitch.
Unique to Ford F-Series, designers have optimized the physical interface for MyFord Touch to accommodate truck users who may be wearing work gloves by providing easy access to climate controls and audio presets on the center stack. For video of MyFord Touch in Super Duty, click here.
The latest example of F-Series leadership in truck design, innovation and technology can be found in the 2013 Super Duty Platinum, available later this year.
http://www.autoblog.com/2012/03/09/ford ... an-ever-b/
berlonso
Prispevkov: 1162
Re: 2009 Ford F150
Napisal/-a berlonso Pe mar 09, 2012 6:47 pm
beštja!
kolko so velike gume na tem velikanu? zgleda kot da so od karjole glede na velikost kamiona seveda :lol:
=ZiAn=
Prispevkov: 1007
Re: 2009 Ford F150
Napisal/-a =ZiAn= Ne mar 11, 2012 1:05 pm
Tole so originalne opcije 265/70-17, 275/65-18, 275/55-20. Niso ravno majhne ampak na takem monstrumu, pa delujejo kar malo miniaturne.
cruiser1
Prispevkov: 2683
Re: 2009 Ford F150
Napisal/-a cruiser1 Ne mar 11, 2012 6:07 pm
Pa kaj vam je s temi gumami in feltnam? Te originalne dimenzije so čisto v redu in ne vidim razloga po večjih. Bolje, kot pa prevelike feltne, ki si jih vsi tlačite na svoje avtomobile in izpadejo, kot kolesa od lojternega voza :roll:
Prispevkov: 11405
Re: 2009 Ford F150
Napisal/-a martin_krpan Po jun 04, 2012 5:39 pm
Prispevkov: 11405
Re: 2009 Ford F150
Napisal/-a martin_krpan Če jun 27, 2013 6:07 pm
F-150 Tremor
All-New 2014 Ford F-150 Tremor Is World's First EcoBoost-Powered Sport Truck
2014 Ford F-150 Tremor comes standard with the company's powerful 3.5-liter EcoBoost® engine, offering V8 performance, V6 fuel economy and a launch-optimized 4.10 rear axle with electronic locking differential
Short-wheelbase, regular-cab Tremor offers stylish FX Appearance Package and functional features that include a floor shifter, class-exclusive HID headlamps and standard SYNC® with MyFord Touch® connectivity system
All-new truck's distinctive looks are complemented by unique boxside Tremor graphics and custom-inspired interior
DEARBORN, Mich., June 27, 2013 – The 2014 Ford F-150 Tremor is the first-ever EcoBoost®-powered sport truck that addresses the needs of street truck enthusiasts looking for high-performance V8 power with V6 fuel economy.
The short-wheelbase, regular-cab Tremor goes on sale this fall delivering distinctive looks and performance. The all-new truck couples the style of the FX Appearance Package with an EcoBoost engine and a launch-optimized 4.10 rear axle – the shortest final drive ratio offered in an EcoBoost F-150 – helping provide customers with fast acceleration.
Tremor signals its sport truck capabilities with a custom-inspired FX Appearance Package featuring stealthy, flat-black accents that include unique 20-inch flat-black wheels, stylized bodyside graphics and black badges with red lettering.
Tremor is the only regular-cab F-150 offering a flow-through center console and bucket seats. Interior touches include black leather seating surfaces with red piping, brushed-metal accents and a red-stitched steering wheel. Alcantara seat inserts add texture and style as well.
"The new Tremor gives F-150 customers yet another option to drive a highly capable, distinctive performance truck with features typically found only in the aftermarket," said Brian Bell, F-150 product marketing manager. "Plus, the Built Ford Tough EcoBoost engine is available for the first time in a short-wheelbase F-150."
F-150 Tremor is powered exclusively by Ford's groundbreaking 3.5-liter EcoBoost engine, which features:
365 horsepower at 5,000 rpm on regular fuel
420 lb.-ft. of torque at 2,500 rpm
Twin independent variable camshaft timing for improved performance and fuel economy
Up to 90 percent peak torque available from 1,700 rpm to 5,000 rpm
An electronic locking rear differential that's standard for both two- and four-wheel-drive versions helps deliver the power to the pavement by improving traction during takeoff.
http://www.autoblog.com/2013/06/27/2014 ... things-up/
