http://www.autoblog.com/2009/10/23/2010 ... n-pricing/
Fuel capacity has also been added - lots. Total capacity can now reach up to 170 gallons by means of a second frame-mounted fuel tank as well as a third, optional bed-mounted auxiliary tank. That means fueling up would cost up to around 750 dollars given current gas prices in the U.S.
Read more: http://www.worldcarfans.com/11105033305 ... z1Lw0VG5nj
MajkOly je napisal/-a:Še eno "malenkost" si pozabil (bolj kot zanimivost):Fuel capacity has also been added - lots. Total capacity can now reach up to 170 gallons by means of a second frame-mounted fuel tank as well as a third, optional bed-mounted auxiliary tank. That means fueling up would cost up to around 750 dollars given current gas prices in the U.S.
http://www.cruisers-nation.com http://www.cruisers-austria.com
Bucko99 je napisal/-a:Gledamo lahko... to je pa tut vseNOR avto !
ejsim je napisal/-a:Bucko99 je napisal/-a:Gledamo lahko... to je pa tut vseNOR avto !
x2
lumberjack je napisal/-a:Me zanima kako se bo obnesel 8 stopenjski menjalnik potem ko boš v keson naložil slabo tono in pripel 5 tonsko prikolico. Ali kdo ve zakaj imajo amerikanci tako majhno nosilnost npr dodge ram 1500 2012 ima največjo nosilnost 700 kg medtem ko ima mazda bt-50 1100 kg.
