PRESS RELEASE:
Tokyo, October 21, 2009 - Lexus announces today the official launch of the LFA, a two-seat supercar scheduled to go into production at the end of 2010 as the pinnacle of the Lexus "F" premium sports car series. Pre-sales start today.
Ultra-responsive and extremely stable even when taken to the edge, the LFA creates a sense of reassurance that opens up a new world of driving emotion, exhilarating the senses to move the driver in more ways than one.
The LFA combines high output, superb chassis design and meticulous aerodynamics to achieve instantaneous total-vehicle response characterized by high-rev, seamless acceleration echoed by a self-defining resonance from its 4.8-liter V10.
Only 500 units of the LFA are to be produced and sold worldwide.
A prototype of the LFA is now on display at the 41st Tokyo Motor Show, which is open to the general public from October 24 to November 4 at Makuhari Messe in Makuhari, Chiba Prefecture.
1. Packaging brings out the most in fundamental performance
Strong and light
The newly developed 4.8-liter V10 engine boasts exceptional power, while lightweight materials (aluminum alloy, magnesium alloy and titanium alloy) and a very compact size (smaller than a conventional V8) allows for optimal weight distribution and an exceptional power-to-weight ratio.
Carbon fiber reinforced plastic (CFRP) cabin enhances high body-rigidity and reduces weight. This unique cabin is 100kg lighter than a comparable aluminum cabin. Detailed analysis and precise matching of CFRP materials allows for high rigidity and low weight. LFA CFRP production technology, including unique CFRP-to-metal joining, was completely developed by Lexus.
Balanced
Relatively higher weight components such as the engine and transmission are placed within the wheelbase. A low center of gravity is made possible by the use of dry sump lubrication1, along with placing peripheral components (oil pump, water pump) behind the engine. Furthermore, optimal placement of the transmission and the fuel tank in front of the rear axle adds to this application of centralized mass. This minimizes weight shift during cornering and contributes to outstanding performance and stability. Lighter weight components, like the radiator and electric fans, are placed behind the rear axle.
Combined with a front-engine and rear-wheel-drive configuration, the short, wide and low body allows the LFA to achieve its target front-to-rear weight distribution of 48:52.
Driver-centered
The driver's seat is positioned near the LFA's center of gravity. The centralized seating concept (with the seat between the front and rear axles and closer to the left–right center) is made possible by the use of a rear transaxle and vertically stacked torque tube and exhaust pipes reducing the width of the center tunnel. The driver placement is aimed to provide maximum car-to-driver feedback, especially under sport or high G-force driving conditions.
2. Emotive performance embodies an extraordinary driving experience
High–rev engine
Titanium valves, ultra–light weight rocker arms with a diamond–like coating and a fully integrated lower crankcase that reduces pumping losses at high RPMs combine to provide the driver with overwhelming acceleration right up to the 9,000rpm redline. The LFA's purpose-built V10 delivers 90% of its peak torque between 3,700rpm and 9,000rpm.
Precise Response
Independent, electronically controlled throttle bodies ensure precise air-feed to each of the 10 cylinders, enabling immediate engine response from the accelerator pedal. The engine response time is approximately half the normal response time of a single-throttle valve.
The six-speed ASG transmission features heavy-duty synchronizer rings and a newly developed gearshift actuator, providing the driver with a very direct shift feel. Four selectable driving modes and a seven-stage shift-speed selector that results in upshift speeds down to 0.2 seconds provide a higher level of driver control.
Track-sized high-performance (Carbon Ceramic) CCM brake discs and Electronically Controlled Braking system generate ultra-powerful yet stable braking.
Responsive handling and engaging dynamics
The very light and rigid CFRP cabin, combined with a front double-wishbone suspension and a rear multilink suspension, result in a very stable, controlled ride. Detailed aerodynamic engineering results in elements such as a flat underbody, a diffuser and a speed-controlled rear wing, which allows precise vehicle response at all vehicle speeds, thus creating unity between driver and machine.
Vehicle Dynamics Integrated Management integrates numerous vehicle dynamic functions that provide a high level of vehicle stability and preventative safety without interfering with the driver's intentions, especially when sport driving.
Exciting engine sound and L-finesse2 design
Equal-length exhaust manifolds combined with an equal-length dual exhaust system routed through a multistage titanium main muffler fine tunes the exhaust note.
An acoustically tuned surge tank linked to 10 individual throttle bodies creates a powerful induction sound. The coordination of intake and exhaust sounds overlap at various RPMs to create a unique, exciting and inspired soundtrack.
The exterior design includes carefully tuned aerodynamics and airflow management. The use of CFRP, in addition to strength and weight advantages, frees up the design of the exterior panels allowing a fresh supercar L-finesse design. The interior design combines state-of-the-art instrument-panel design and technology, along with a variety of custom-tailored interior trim packages to suit the most discerning driver.
M156 je napisal/-a:stroj ki ga bo konkurenca težko dohitevala!
če se ne motim je hitrejši od F458 Italia, Lambo Gallardo LP560, Porsche 911 GT2, Mercedes-Benz SLS AMG, Corvette Z06, AM V12 Vantage, nenazadnje tut Nissan GT-R...sicer jasno ima največ konjev ampak vseeno se vidi da je avto prou za progo narejen!
Pravi bolid from Japana
PIKSNA007 je napisal/-a:Se opravičujem, slišal sem narobeno kakor koli pogledamo je zelo drag
Lexus LFA Nürburgring Edition: Nice but still more expensive
March 16, 2010 at 2:33
While the brand will be present again this year and for the third time, the 24 Hours of Nürburgring (but with real race drivers and engineers of non-testers), Lexus unveiled a first series limited its LFA supercar.
The LFA is thus equipped with a blade spoiler in carbon fiber, a fixed rear spoiler is the same material, new lighter wheels and a lowered suspension and adjustable. Chapter mechanics, LFA Nürburgring Edition sees the V10 slightly evolve and gain 10 horses to go from 560 to 570 horses. The automated gearbox is also evolving and sees the speed of passage of the report reduced to 0.2 seconds just 0.15 seconds.
This special series will be offered in 4 colors including:
Blanc de blanc (white pearl gender or pearled)
Black, Matte Black
Orange
The car will be available to customers beginning in 2012 at a price unreasonably frankly about € 400,000! But despite the prohibitive price already on version noramle, the series of 500 copies is exhausted or nearly so for a limited series, fans will not count.
Via TheLexusEnthusiast.
