Napisal/-a esem So jul 07, 2007 11:11 am
Prvi test M3
http://www.carmagazine.co.uk/first_driv ... 841&page=1 (9 strani)
And the V8 does significantly alter the M3’s character. Where before a creamy straight-six throatiness was followed by the trademark metallic rasp towards peak rpms, now a nice woofly warble under lighter throttle loads precedes a hard-edged – if more muted – charge for the redline. The spine-tingling zinginess of the E46 car is gone, replaced by a more mature, if still exhilarating, progression.
Tell me about the steering, ride and brakes
I will. As you’d expect, less focused handling does improve the ride quality significantly with the M3 soaking up bumps much better than its predecessor ever did. There are also three (optional) cockpit-adjustable suspension settings, so you can stiffen the dampers and reduce body roll for track work.
Is the E92 as easy to powerslide as its predecessors?
How childish of you. Once you’re sideways the E92 is an extremely easy, progressive car to hold in a drift (see p1), but it takes a little more determination to get it there in the first place thanks to that softer, woollier front end.
....Verdict
The M3 has grown up and lost a little of the E46’s edge to the more weight/more power vicious circle. But BMW has no doubt judged the market perfectly. The M3 is now a genuine volume seller and, last time, accounted for 13 percent of all UK 3-series sales. The new car needs to be a brilliant all-round package, capable of pleasing those who like the idea of the badge more than what it first stood for: track-honed thrills. And it is very, very good. This car is fast, practical, well built, comfortable and safe.
But in trying to hit so many targets, the E92 leaves purists wanting. So a CSL – a lightweight, more dynamically focused special edition – is now an absolute must and should form an integral part of the range going forward, filling the niche that the original E30 once satisfied in 1986. The good news is BMW’s top brass dropped some very large hints in the press conference, so the CSL sounds like a dead cert. We’d bet on it arriving in 2010.
If you want a great all-rounder and you don’t drive everywhere at ten tenths, the new M3 won’t disappoint. But if you crave trackday thrills, hold fire for a CSL.
vugy
Prispevkov: 687
Kraj: AT-SLO
Napisal/-a vugy So jul 07, 2007 12:21 pm
s tem kar si pa zdaj napisal pa se popolnoma strinjam, JE PA ŠKODA NJEGOVEGA TALENTA DA SE UKVARJA Z ŠEFI (AMPAK VE ZAGOVARJAT IN JIH ZATO TUDI PREPRIČA) Ne bom se odjavil, pač jaz sem tu da se menim in da izrazim svoje mnenje ne pa da mi bodo drugi vsiljevali mišljenje.Ker sem pa se šele zdaj prijavil pa sem zdaj napisal kako mnenje imam na vaše prejšnje komentarje. Meni pač odspredaj ni všeč bmw enka pa to še ne pomeni da je bangle slab oblikovalec, zato pa so ostali tolko boljši. Noben oblikovalec pa ne ustvarja le takih avtov da bi za vsakega rekli waw, je pa jih nekaj takih. Mislim pa da se bodo tudi po njegovi zaslugi bmwji še dalje dobro prodajali ;) ;)
Dejch
Prispevkov: 757
Napisal/-a Dejch So jul 07, 2007 1:57 pm
Coupe morm rect, da zgleda zelo dobro, sploh v zivo k ga vids, je res masivna, skladajoca zival. Kar se pa drugih modelov tiče pa bol tko tko. Serija 1 coupe mi tud ni slaba, 5 je vredu, ostalo pa ne morm prebavt. Nasploh pa, pri BMWjih je zdej najbol pomembno, da so cisto samosvoji, tezko jih zamenjas s kaksnim drugim dizajnom. Motorji so pa klasa zase.
vugy
Prispevkov: 687
Kraj: AT-SLO
Napisal/-a vugy So jul 07, 2007 7:21 pm
Saj to je za moje pojme pomembno, da so samosvoji. ;) ;) Ti na slikah so mi všeč tak da mi tudi v realnosti verjetno bodo. :D :D
vugy
Prispevkov: 687
Kraj: AT-SLO
Napisal/-a vugy Pe jul 13, 2007 3:17 pm
če koga zanima m3-ka naj gleda drugi teden motorvision na dsf -u, bodo meli track test pa malo o njem, prilagam pa dve sliki ki upam da še nista bli...meni je svetoven :P :P
bigturbo
Prispevkov: 766
Kraj: lj
Napisal/-a bigturbo Ne jul 29, 2007 5:09 pm
avto kot se šika 420ps 400nm navora 4.7s do sto v8,to so popdatki ki me zelo osrečujejo,avto je Petarda
biturbo SKN Project CT3 50
Spyker
Prispevkov: 2297
Kraj: okolica Ljubljane
Napisal/-a Spyker Ne jul 29, 2007 9:27 pm
Komej čakam da ga preizkusijo pri TopGearu :) Men avto izgleda svetovno, zmogljivosti pa naj bi tud bile na zavidajoči ravni :vrum
Če je ravno, ni zabavno.
Napisal/-a esem Sr avg 08, 2007 8:04 pm
še nekaj spy fotk nezakritega 4-vratnega sedana tu http://www.m3post.com/forums/showthread.php?t=77033
yigy
Prispevkov: 181
Pridružen: Če maj 17, 2007 6:36 pm
Kraj: Šentjur
Napisal/-a yigy Sr avg 08, 2007 8:20 pm
Men je to eden prvih BMW po dolgem casu ki mi je lep in ki bi ga dejansko imel. Govorim seveda o BMW 3 Coupe (E90) oz o njegovi M razlicici. Ne da bi drugim kaj pri mehaniki manjkal, je odlicna, toda ne prenasam dobro cudno oblikovanih avtomobilov, sploh ce jih na dan vidis na tisoce. :?
vugy
Prispevkov: 687
Kraj: AT-SLO
Napisal/-a vugy Sr avg 08, 2007 8:42 pm
No ker verjetno niste gledali ko je bla tema oddaje bmw m3.....oa je to video ki je del oddaje 8) 8)
Da bote vsaj nekaj videli če že ne na tv-ju
na desni strani je mala slikica...klikneš gor pa se že odpre predvajalnik......nevem skopirat direktno do videa....če kdo ve naj
http://www.sport1.de/de/extras/themen/auto-motor/auto-motor-main.html
Napisal/-a MacTron Sr avg 08, 2007 8:49 pm
vugy je napisal/-a:....nevem skopirat direktno do videa....če kdo ve naj
evo pomoc..
http://www.sport1.de/de/multimedia/Vide ... 18105.html BMW M3
napovedovalec pa je iz motorvison reportaz
vugy
Prispevkov: 687
Kraj: AT-SLO
Napisal/-a vugy Sr avg 08, 2007 9:06 pm
ja zej je po novem dsf motor.....sam sem bolj zaenkrat še navajen na motorvision...saj to je iz motorvision vun skopiran video :D :D mactron hvala
AudiBoy
Prispevkov: 1534
Kraj: Severna Primorska
Napisal/-a AudiBoy Sr avg 15, 2007 10:37 pm
zlo je lep...komi čakam da bo kej na fifth gear.. :D
andrej777
Prispevkov: 2102
Kraj: Telče (Sevnica)
Napisal/-a andrej777 Če avg 16, 2007 6:41 pm
AudiBoy je napisal/-a:zlo je lep...komi čakam da bo kej na fifth gear.. :D
Mene bolj zanima kako ga bo spet Clarkson v Top Gearu "sklincal" :D :D
M5-ko je klincal celih deset minut na koncu pa reče da je to eden najboljših avtov. 8) 8)
robek
Prispevkov: 207
Pridružen: Če sep 07, 2006 6:22 pm
Napisal/-a robek Če avg 16, 2007 7:20 pm
tisti rdec je prava zverina ;)
Prispevkov: 11405
Napisal/-a martin_krpan Če sep 27, 2007 5:37 pm
M3 limuzina in cabrio:
Prispevkov: 11405
Napisal/-a martin_krpan Pe okt 05, 2007 7:17 pm
Ilegalno pridobljene uradne fotografije M3 limuzine:
Avto je prevzel številne detajle iz kupeja in se precej razlikuje od običajnih limuzin.
maniaxxx
Prispevkov: 7338
Napisal/-a maniaxxx Pe okt 05, 2007 7:39 pm
http://www.carmagazine.co.uk/images/art ... _1_560.jpg
kak jezno zgleda na tej sliki :shock: :shock: :shock: hudoooo
maniaxxx
Prispevkov: 7338
Po forumu brska: Majestic-12 [Bot] in 14 gostov
