dominic
Prispevkov: 655
Napisal/-a dominic Ne nov 15, 2009 7:27 pm
v takih avtih je.... sredinsko konzolo, ker ce bi si ga ze kupil...ti nudi drugacen uzitek...in si vrjetno osredotocen v druge parametre =)...
Dr.M3
Prispevkov: 1409
Napisal/-a Dr.M3 Ne nov 15, 2009 10:15 pm
p.s: Ob nekaterih komentarjih (=beri izbirčnosti) človk pomisli, da ste kle sami milijarderji, pa da vozite avte 200.000€+
Če bi imel in dal za avto 200k EUR (+) bi me to precej zmotilo. Kakšen občutek pa je to, da ti raja z avti za 15k EUR pritiska na iste komande klime/navigacije? :lol: :con
Zelo aristokratsko - NOT :lol:
Prispevkov: 11405
Napisal/-a martin_krpan Po mar 01, 2010 9:47 pm
Gallardo LP 570-4 Superleggera
Gre za ''shujšani'' Gallardo, ki tehta 1340 kilogramov, kar je 70 kil manj od normalnega modela. Superleggera je tako najlažji avto v Lambojevi ponudbi.
Lamborghini Press Release:
Even more dynamic, lighter, more powerful and stunning – the Lamborghini Gallardo LP 570-4 Superleggera
is the new top model in the Gallardo line-up. Its evocative “superlight” badge refers to a driving machine of true sporting character and describes a high-performance and lean automotive athlete. The Superleggera makes its entrance to continue the success of its predecessor, launched in 2007, of which Lamborghini produced and sold no less than 618 in just one year.
Compared with the already lean Gallardo LP 560-4, the weight of the Gallardo Superleggera has been trimmed by 70 kilograms (154 lb). The super sportscar from Sant’Agata Bolognese boasts a dry weight of no more than 1340 kilograms (2954 lb)
– the lightest road-going model in Lamborghini’s range, and a new arrival in one of the most exclusive market niche segments.
One key factor is the exterior and interior components made from carbon-fiber. Carbon-fiber is ideal for the manufacture of sportscars as its use allows for weight reduction and improved mechanical features. The car’s performance is thus enhanced thanks to a better weight-to-power ratio and reduced total mass, which means that CO2 emissions are also lower. Lamborghini has been at the forefront in this material’s application for many years, and now the brand is extending its leadership even further.
The V10 power unit with 5.2 liters (317,6 cu in) of displacement generates 419 kW (570 CV*) in the Gallardo Superleggera. This puts the weight-to-power ratio of the new top model at only 2.35 kilograms (5.18 lb) per CV and guarantees breathtaking performance. The Gallardo LP 570-4 Superleggera handles the dash from zero to 100 km/h (0-62 mph) in 3.4 seconds and flies past the 200 km/h (124 mph) mark only 10.2 seconds later, ultimately reaching 325 km/h (202 mph). The engine with “Iniezione Diretta Stratificata” gasoline direct injection also boasts an impressive degree of efficiency. Its fuel consumption and CO2 emissions have been reduced by 20,5 percent compared to the previous model.
The Gallardo Superleggera is an uncompromising driving machine. Its running gear, with its mighty braking system, has a dedicated and exceptionally precise set-up, while its 19-inch wheels, Pirelli P Zero Corsa, clad in Pirelli sports rubber, are extremely light. The Lamborghini Gallardo LP 570-4 Superleggera brings a whole new meaning to the term “super sportscar”.
Design and aerodynamics: The beauty of power
The elegance of every Lamborghini rests on both its extreme power and precise functionality. The Gallardo LP 570-4 Superleggera’s bodyshell is sculptured and completely free from stylistic additions. Dimensions define the contours of a dynamic wedge – 4.39 meters (172,7 in) long, 1.90 meters (74,8 in) wide, but only 1.17 meters (45,9 in) high.
Exterior modifications are all directed at increasing aerodynamic effects. Working closely with wind tunnel experts, the designers from Lamborghini’s Centro Stile remodeled the front bumper – three-dimensional, deeply recessed elements form trapezoidal frames for the large air intakes. Together with the V-shaped, sharply defined nose and the LED daytime running lights, the black elements give the front end a razor-sharp look, reminiscent of Lamborghini’s top model. The new design increases the supply of cooling air and improves the downforce on the front axle.
The modifications to the fully-covered underbody, which include new sill elements and a redesigned diffuser incorporating four large tailpipes, help to achieve better aerodynamic results. The Gallardo Superleggera sports a small rear spoiler as standard. A big rear spoiler is available as an option.
The bodyshell: Intelligent lightweight engineering
The model on which the Gallardo LP 570-4 Superleggera is based, the Gallardo LP 560-4, is already a prime example of Lamborghini’s lightweight engineering philosophy, with its dry weight of 1410 kilograms (3108.5 lb). Its bodyshell is made from aluminum, with moulded node elements and extruded parts forming an extremely stiff framework into which the aluminum panels are integrated. The spaceframe structure is impact-resistant and forms the basis for the super sportscar’s precise handling.
Against this background, the task of reducing the weight by a further 70 kilograms (154 lb) presented a huge challenge to Lamborghini engineers – the target figure, a weight-to-power ratio of 2.35 kilograms (5.18 lb) per CV, sets a new best among the competition. Lamborghini engineers handled the task as they usually do – with hi-tech competence and aesthetic flair.
The rear windshield and side windows are made from robust and resistant polycarbonate. The engine cover also includes a polycarbonate window, beneath which the V10 engine is displayed like a technical work of art. The long cover section runs from the roof to the rear of the vehicle and is made from carbon-fiber. Engineers also selected carbon-fiber for the rear spoiler, sills, diffuser, parts of the underbody paneling and the fine exterior mirror casings.
With its minimal weight and extremely high rigidity, carbon-fiber is the ideal material for a super sportscar. As far back as the 1980s, Lamborghini was already gathering experience in this field with the Countach. Today, some parts of the Murciélago’s structure are made from carbon-fiber. In order to secure this leading position even further, the brand from Sant’Agata Bolognese established a center of excellence for carbon-fiber materials, where specialists are developing components, working with efficient manufacturing technologies.
Lamborghini’s carbon-fiber strategy is further proven by its foundation of the “Automobili Lamborghini Advanced Composite Structures Laboratory” (ACSL) at the University of Washington in Seattle, USA. Lamborghini provides support to the facility and its long-term, co-operative research work in the fields of aeronautics and astronautics, together with the composite materials’ application within the automotive sector. Alongside the University of Washington, aircraft company Boeing is also among Lamborghini’s partners.
The aircraft manufacturer commands enormous expertise in the field of composite materials. With the new Type 787 Dreamliner, Boeing has developed the world’s first commercial aircraft built entirely from carbon-fibre. Thanks to its superior characteristics, it consumes around 20 percent less fuel than a conventional aeroplane.
The interior and the use of carbon-fiber
Altogether, carbon-fiber components make up 40 (88 lb) of the 70 kilograms (154 lb) saved on the Gallardo Superleggera. In the interior, too, engineers aimed to reduce weight as much as possible. The center tunnel cover, the door panels and the surround of the e-gear automated manual transmission lever are made from carbon-fiber. The high-end material is also used for the sports seats’ shells. They make a significant contribution to the overall weight reduction.
Just like the rest of the cockpit, the sports seats are clad in lightweight Alcantara instead of leather. At Lamborghini, weight reduction is in no way synonymous with sacrifice – the Gallardo LP 570-4 Superleggera is still equipped with air conditioning and electric powered windows as standard. Lamborghini has built on this strength – the interior is crafted with passionate attention to the tiniest detail; high quality materials indulge both visually and sensually.
The interior, including roof and mats, retains the Lamborghini Gallardo’s black finish. As a contrasting color for elements such as seat trims and stitching, customers can choose among green, yellow, orange and two shades of gray. They match exterior paint finishes in Verde Ithaca, Giallo Midas, Arancio Borealis, Grigio Telesto, Nero Noctis and Bianco Monocerus.
Power & transmission: The engine 10.2 seconds from zero to 200 km/h
In the Gallardo LP 570-4 Superleggera, LP stands for “longitudinale posteriore” and refers to the orientation of the V10 engine – which is mounted longitudinally behind the driver, just like every Lamborghini engine. The number 570 refers to the maximum power output in CV, which equates to 419 kW and is available at 8,000 rpm. Equally impressive is the pulling power – the torque curve peaks at 540 Nm (398,3 ft lbs) at 6,500 rpm. The increase of 7 kW (10 CV) is the result of the new dedicated engine management strategy.
The V10 has a displacement of 5204 cm3 and achieves a specific output of 80.5 kW (109.6 CV) per liter. Special features on this long-stroke engine with an aluminum crankcase include dry sump lubrication and a cylinder angle of 90 degrees. Both solutions lower the center of gravity, thus improving the handling dynamics. To ensure an ideal combustion chamber fill, the engine has an adjustable intake manifold and continuous control of the chain-driven camshafts.
The crankshaft is conceived as a dual-plane crank – the connecting rods of opposing pistons share one bearing. This configuration delivers alternating ignition intervals of 54 and 90 degrees; a unique sequence that is the reason for the compelling, racing car-like sound of the V10. As the revs rise, resounding bass notes are overlaid with razor sharp harmonics.
The powerful V10, combined with the model’s weight reduction, gives the Gallardo Superleggera LP 570-4 breathtaking performance. The car accelerates zero to 100 km/h (0-62 mph) in just 3,4 seconds, 0 to 200 km/h (0-124 mph) in 10,2 seconds – then continues relentlessly to its top speed of 325 km/h (202 mph).
The Gallardo Superleggera is also considerably more efficient – compared with its predecessor, its fuel consumption in the EU driving cycle is reduced by 3,5 liters per 100 kilometer (0,9 gal), or 20,5 percent, to 13,5 liters/100 km (16 mpg). This improvement is partly due to the “Iniezione Diretta Stratificata” gasoline direct injection, which injects fuel into the combustion chambers at pressures of up to 100 bar. The tumbling mix cools the combustion chambers, which enables a very high compression ratio of 12.5:1 which, in turn, increases efficiency.
Traction without compromise
The Gallardo LP 570-4 Superleggera comes with the e-gear transmission operated via steering wheel paddles, as standard. The automated system with electronic management shifts through its six gears extremely smoothly and far more quickly than could be achieved by human reflexes.
The e-gear control unit has three operating modes, two of which available in automatic. The “Thrust mode” delivers maximum off-the-line performance and is programmed to manage starting revs of around 5000 rpm with minimal wheel slip.
Every single kilometer in the new Superleggera is utterly thrilling – not least because of the relentless traction in practically every situation. This is largely attributable to the four driven wheels, as indicated by the number 4 in the model name. The permanent all-wheel drive integrates a central viscous coupling and a 45 percent limited slip differential on the rear axle. In normal circumstances, the power delivered by the V10 is channeled with a ratio of 30:70 to the front and rear axles. The weight distribution of the superlight Gallardo is 43/57 percent front/rear. In 1993, the Diablo VT was the first Italian super sportscar with an all-wheel drive set-up, and Lamborghini has been steadily consolidating its leadership ever since. In fact, thanks to the car’s superior traction, Lamborghini drivers can accelerate earlier out of a bend than drivers of rear-wheel drive cars.
The running gear: Even firmer, even more precise
The new Gallardo Superleggera is a highly-concentrated driving machine – it thrills with breathtaking cornering speeds and fast, immediate feedback. Its handling is always precise, stable and predictable. The running gear layout is derived directly from Lamborghini’s motorsport experience. The suspension is aluminum double wishbones. The precise rack and pinion steering keeps the driver very closely connected with the road. The shock absorbers are extremely firm, and the anti-roll bars and suspension mounts have been further reinforced: these features enable the running gear to reach its full dynamic potential. No other model in the Gallardo range is as close to a race car as this one. The development of the Superleggera was heavily influenced by experiences gained from the world’s fastest single-brand race series, the Lamborghini Blancpain Super Trofeo.
Another special feature of the Gallardo Superleggera is the wheels. The 19-inch units are aluminum forged and are therefore extremely lightweight – saving 13 kilograms (28.6 lb). The wheel bolts are made from titanium and are also incredibly light and rigid. The tires are 235/35 ZR19 at the front and 295/30 ZR19 at the rear and come from the Pirelli P Zero Corsa series. Developed specifically for the new top model in the Gallardo range, they are closely related to pure race rubber.
Behind the huge wheels are brakes that serve to deliver uncompromising stopping power and are managed by the standard-fit ESP stability control system. The front wheels are served by aluminum eight-piston calipers, with four-piston units at the rear. The ventilated brake discs have a diameter of 365 and 356 millimeters (ø 14.37 x 1.34 in and 14.02 x 1.26 in) respectively. As an optional extra, Lamborghini can fit extremely fade-resistant and lightweight discs made from carbon-fiber ceramic with six pistons at the front. The front ceramic discs have a diameter of 380 millimeters (ø 15 x 1.5 in).
Equipment: Hi-tech for road and track
Alongside its specialized carbon-fiber lightweight components, the Lamborghini Gallardo LP 570-4 Superleggera is delivered ex-works with an array of other high-end features. Highlights include the e-gear transmission – a manual gearbox is also available at no additional cost – the dedicated set-up, the Pirelli sports tires and the sports seats. Alcantara upholstery and a hand-stitched steering wheel also set the interior ambiance. The range of special equipment is particularly sporty. It includes carbon-fiber ceramic brake discs, four-point seat belts, fire extinguisher and a steel roll cage. Visual impact can be further increased by a rear spoiler and the engine bay for the engine compartment – both from carbon-fiber – as well as colored brake calipers. For the interior, Lamborghini offers special floor mats and leather steering wheels, a storage package and an alarm system. An additional carbon-fiber package includes center console and instrument panel trim, the parking brake handle, parts of the steering wheel and the door handles. A LED light package illuminates the engine compartment, the interior, and the entry area.
Additional features of special equipment increase comfort, such as the multimedia navigation system, the lifting system which raises the front of the car to enable driving over obstacles, a remote control for opening garage doors and a rear view camera mounted beneath the rear spoiler. Customers who want to personalize their Gallardo LP 570-4 Superleggera, can use Lamborghini’s wide-ranging options of the “Ad Personam” individualization program.
http://www.zercustoms.com/news/Lamborgh ... ggera.html
CITROENAR ŠT 1
Prispevkov: 1483
Napisal/-a CITROENAR ŠT 1 Po mar 01, 2010 10:45 pm
:vrum
gecco
Prispevkov: 1726
Napisal/-a gecco Po mar 01, 2010 11:08 pm
Sliši/bere se super...ampak vsi tele podaljški me že malo motijo...original LP je bil čisto dovolj čudovit
Prispevkov: 11405
Napisal/-a martin_krpan Če jun 17, 2010 7:49 pm
Test Gallarda LP 570-4 Superleggera:
http://www.autoblog.com/2010/06/17/2010 ... rst-drive/
Prispevkov: 11405
Napisal/-a martin_krpan Po sep 27, 2010 7:03 pm
Lamborghini Gallardo LP570-4 Blancpain. Še ena limitirana serija v sodelovanju s prestižno urarsko firmo.
http://www2.uol.com.br/bestcars/un13/33 ... ncpain.htm
http://www.netcarshow.com/lamborghini/2 ... blancpain/
Prispevkov: 11405
Re: Lamborghini Gallardo LP560-4
Napisal/-a martin_krpan Sr nov 17, 2010 8:37 pm
Gallardo LP 570-4 Spyder Performante. Gre za Superleggera (manjša teža, izboljšana aerodinamika) verzijo Gallarda roadster.
Lamborghini Gallardo LP 570-4 Spyder Performante
Less Weight, More Fascination
Sant'Agata Bolognese, November 18, 2010. With the new Gallardo LP 570-4 Spyder Performante, Lamborghini is setting a new benchmark in the most fascinating automobile segment of all – the open-top super sports car. As "Performante", the Gallardo Spyder is even lighter thanks to CFRP technology, even more agile and even more dynamic. The new Spyder Performante is an automotive high-performance athlete that combines sheer sporting excellence and extreme performance with that unique open-air feeling that only a soft-top spanning the ten-cylinder power unit can offer. Ultimately, every spin in the Spyder Performante is like a journey into the eye of the storm.
The Gallardo LP 560-4 Spyder is already at the peak of its game, bearing testament to the lightweight engineering approach pursued by the Lamborghini brand. Nevertheless, the engineers in Sant'Agata Bolognese managed to reduce the weight of the new Spyder Performante by a further 65 kilograms (143 lbs). The open super sports car tips the scales with a dry weight of no more than 1.485 kilograms (3.274 lbs) – a new best for that highly exclusive market segment occupied by Lamborghini.
Just like its "brother", the Gallardo LP 570-4 Superleggera, the light weight of the Spyder Performante is due in large part to exterior and interior components made from carbon-fiber. These carbon-composite materials are perfectly suited to super sports cars because they combine reduced weight with improved technical characteristics. Performance is optimized as a result of lower weight, while CO2 emissions are reduced. Lamborghini has been leading the industry for 30 years in the application of CFRP, and now the brand is expanding that lead even further.
The V10 power unit with a displacement of 5.2 liters generates 419 kW (570 hp) in the Spyder Performante and guarantees breathtaking performance – it catapults the open-top LP 570-4 from 0 to 100 km/h (0-62 mph) in a mere 3.9 seconds and keeps on going to a top speed of 324 km/h (201 mph). The engine with "Iniezione Diretta Stratificata" gasoline direct injection boasts extremely impressive pulling power and a virtually endless rev range that delivers a constant
supply of spine-tingling acoustics.
The Gallardo LP 570-4 Spyder Performante is an uncompromising driving machine. Its chassis, with its mighty brakes, is a work of great precision, while the new 19-inch wheels with Pirelli P Zero Corsa sports tires are extremely lightweight. The LP 570-4 Performante brings a new meaning to the term "Spyder".
The beauty of power
The elegance of every Lamborghini rests on its extreme power and precise function. The design of the Gallardo LP 570-4 Spyder Performante, too, concentrates on the sheer essence of the design language - the bodyshell is pure sculpture and free of superfluous decoration. Its profile follows the contours of a dynamic wedge measuring 4.39 meters long, 1.90 meters wide, but only 1.18 meters high. Open or closed, the top of the Spyder Performante can handle the very highest speeds.
From the very first glance, the Spyder Performante is clearly recognizable as the open-top counterpart to the highly acclaimed and successful Gallardo Superleggera. The exterior modifications are all directed at increasing the aerodynamic effect in comparison to the Gallardo Spyder. Working closely with wind tunnel experts, designers from Lamborghini's Centro Stile remodeled the front bumper – three-dimensional, deeply recessed elements form trapezoidal frames for the large air intakes. Together with the V-shaped, sharply defined nose and the LED daytime running lights, the black elements give the front end a razor-sharp look. The design also optimizes the supply of cooling air and improves the downforce on the front axle.
Modifications to the fully-covered underbody, new sill elements and a redesigned diffuser incorporating four large tailpipes also help to achieve better aerodynamic results. A large optional rear spoiler is also available for the Spyder Performante.
The bodyshell
Intelligent lightweight engineering with Carbon Fiber
Its bodyshell is made from aluminum, with cast node elements and extruded profile forming an extremely stiff framework into which the aluminum panels are integrated. The spaceframe structure is extremely impact-resistant and forms the basis for the super sports car's precise handling.
Against this background, the task of reducing weight by a further 65 kilograms (143 lbs) compared to the Gallardo Spyder presented a huge challenge to the engineers. The Lamborghini experts handled the task as they usually do – with hi-tech competence and aesthetic flair. With its minimal weight and extremely high stiffness, carbon-fiber is the ideal material for a super sports car. The large panel covering the soft-top, engine and transmission is a complex and extremely high-quality carbon fiber component. Engineers also selected carbon-fiber for the rear spoiler, sills, diffuser, parts of the underbody paneling and the fine exterior mirror casings.
Carbon-fiber materials in the interior
Altogether, carbon-fiber components make up around 40% of the 65 kilograms saved. In the interior, too, engineers aimed to reduce weight as much as possible. The center tunnel cover, the door panels and the surround of the e-gear automated manual transmission lever are made from carbon fiber. The high-end material is also used for the sports seats' shells, where they make a significant contribution to overall weight reduction.
Just like the rest of the cockpit, the sports seats are clad in lightweight Alcantara instead of leather. However, weight reduction at Lamborghini certainly does not mean sacrifice – the Gallardo LP 570-4 Spyder Performante still comes with air conditioning and electric windows as standard.
The extent to which Lamborghini values the very highest level of meticulous craftsmanship is immediately evident in the interior of the Spyder Performante. All parts are perfectly designed and assembled down to the very last detail; high-quality materials indulge the senses. The interior retains a sporty black finish in Alcantara. As contrasting colors for seat stitching, customers can choose from green, yellow, orange and two shades of gray. They match exterior paint finishes in Giallo Midas, Arancio Borealis, Grigio Telesto, Nero Noctis and Bianco Monocerus.
The engine
3.9 seconds from zero to 100 km/h
In the Gallardo LP 570-4 Spyder Performante, LP stands for "Longitudinale Posteriore" and refers to the orientation of the V10 engine – which is mounted longitudinally behind the driver, just like every Lamborghini engine. The number 570 refers to the maximum power output in hp, which equates to 419 kW and is available at 8,000 rpm. Equally impressive is the pulling power – the torque curve peaks at 540 Nm (398,3 ft lbs) at 6,500 rpm. The increase of 7 kW (10 hp) is the result of the new dedicated engine management strategy.
The V10 has a displacement of 5,204 cm3 and achieves a specific output of 80.5 kW (109.6 hp) per liter. Special features on this long-stroke engine with an aluminum crankcase include dry sump lubrication and a cylinder angle of 90 degrees. Both solutions lower the center of gravity, thus improving handling dynamics. To ensure ideal combustion chamber fill, the engine has an adjustable intake manifold and continuous control of the chain-driven camshafts.
The powerful V10, combined with the model's weight reduction, gives the Gallardo LP 570-4 Spyder Performante breathtaking performance. The sprint from zero to 100 km/h (0-62 mph) takes just 3.9 seconds. Drive continues relentlessly to a top speed of 324 km/h (201 mph).
Power transmission
The Gallardo LP 570-4 Spyder Performante comes with the e-gear transmission operated via steering wheel paddles, as standard. The automated system with electronic management shifts through its six gears extremely smoothly and far more quickly than could be achieved by
human reflexes.
The e-gear control unit has three operating modes, two of which are also available in automatic. The "Thrust mode" delivers maximum off-the-line performance and is programmed to manage starting revs of around 5,000 rpm with minimal wheel slip.
Every single kilometer in the Gallardo Spyder Performante is utterly thrilling – not least because of the relentless traction in practically every situation. This is largely attributable to the four driven wheels, as indicated by the number 4 in the model name.
The permanent all-wheel drive incorporates a central viscous coupling and a 45 percent limited slip differential on the rear axle. In normal circumstances, the power delivered by the V10 is channeled with a ratio of 30:70 to the front and rear axles. The weight distribution of the superlight Gallardo is 43/57 percent front/rear.
In 1993, the Diablo VT was the first Italian super sports car with an all-wheel drive set-up, and Lamborghini has been steadily consolidating its leadership ever since. In fact, thanks to the car's superior traction, Lamborghini drivers can accelerate earlier out of a bend than drivers of rear-wheel drive cars.
The running gear
The Gallardo Spyder Performante is a highly-concentrated driving machine – it thrills with breathtaking cornering speeds and fast, immediate reflexes. Its handling is always precise, stable and predictable.
The running gear layout is derived directly from motorsport. The suspension features aluminum double wishbones, while the precise rack-and-pinion steering keeps the driver closely connected with the road. Its specific set-up enables the running gear to reach its full dynamic potential.
Another special feature of the Gallardo Spyder Performante is the incredibly light 19-inch wheels – identical to those on the Gallardo Superleggera – which save 13 kilograms (28.6 lb). The wheel bearings and bolts are made from titanium and are also incredibly light and stiff. The tires are 235/35 at the front and 295/30 at the rear and come from the Pirelli P Zero Corsa series. Developed specifically for the new top model in the Gallardo range, they are closely related to pure race rubber.
Behind the huge wheels are brakes that deliver uncompromising stopping power and are managed by the standard-fit ESP stability control system. The front wheels are served by aluminum eight-piston calipers, with four-piston units at the rear. The ventilated brake discs have diameters of 365 and 356 millimeters (ø 14.37 x 1.34 in and 14.02 x 1.26 in) respectively. As an optional extra, Lamborghini can fit extremely fade-resistant and lightweight discs made from carbon-fiber ceramic with six-piston calipers up front. The front ceramic discs have a diameter of 380 millimeters (ø 15 x 1.5 in).
Equipment
Alongside its specialized carbon-fiber lightweight components, the Lamborghini Gallardo LP 570-4 Spyder Performante is delivered ex-works with an array of other high-end features. Highlights include the e-gear transmission – the manual gearbox is available at no additional cost – the dedicated chassis set-up, the Pirelli P Zero Corsa sports tires and the sports seats.
Alcantara upholstery and a hand-stitched steering wheel clad in suede set accents in the interior. The range of special equipment is quite particular. For the interior, Lamborghini offers special floor mats and leather steering wheels, a storage package and an alarm system. An additional carbon-fiber package includes center console and instrument panel trim, the parking brake handle, the lower part of the steering wheel and the door handles.
Further special equipment enhances comfort and convenience - the multimedia navigation system, the lifting system for raising the front of the car, a garage door opener and a rear view camera. Customers wanting to personalize their Gallardo LP 570-4 Spyder Performante can refer to the wideranging options of Lamborghini's "Ad Personam" individualization program.
Competence
New development center for carbon-fiber technology
With this year's presentation of the best-in-class Gallardo LP570-4 Superleggera at the Geneva Auto Salon and the unveiling of the ultra-light Sesto Elemento at the Paris Motor Show, Lamborghini has again displayed its clear leadership in the field of carbon fiber technology. Here, Lamborghini is building on a thirty-year history – in 1983, Lamborghini used carbon fiber reinforced plastics to build the famous Countach. The engine cover panel of the Gallardo Spyder and Spyder Performante is one of the largest CFRP components with class A surface quality in the automotive world. As a 100 percent subsidiary of AUDI AG, the Italian super sports car manufacturer further benefits from the lightweight construction competence of its parent company.
The company is now working steadily to expand its worldwide leading position.
In the new Advanced Composites Research Center (ACRC) at company headquarters in Sant'Agata Bolognese, Automobili Lamborghini S.p.A. is working on innovative construction and production methods for carbon-fiber elements in automobile design.
The Advanced Composite Research Center in Sant'Agata Bolognese secures leadership in the research into innovative materials and production methods for carbon-fiber reinforced plastics with low production volumes. More than 30 experts work here on the development of vehicle components of all types and sizes. The specialists build prototypes and their associated tools, and devise optimum production methods. With sophisticated systems developed largely in-house, engineers can precisely and reliably simulate the technical characteristics and collision behavior of the components. Thanks to the extensively patented "RTM Lambo" process, Lamborghini is able to manufacture CFRP parts to the highest quality, precision and surface finish under low pressure and at relatively low temperatures. Higher process speeds, lower costs and simple tooling are further benefits.
The Lamborghini Advanced Composite Structures Laboratory (ACSL) at the University of Washington tests the behavior of a range of materials and technologies in line with the principles adopted by the aviation industry. Scientists in Seattle are working closely with the Technical Development Department at Lamborghini headquarters in Sant'Agata Bolognese.
At the 2010 Paris Motor Show, Lamborghini once again demonstrated its outstanding expertise in carbon-fiber lightweight engineering with the Sesto Elemento concept car – the extent of the application of innovative materials is unparalleled. The overall weight of the Sesto Elemento – despite its V10 power plant and all-wheel drive – was limited to just 999 kilograms. Every new Lamborghini will benefit from the advanced technologies in the Sesto Elemento.
The myth lives on –
The open-top super sports cars from Lamborghini
The history of open-top Lamborghinis began with small volumes. In 1965, the company built just two of the 350 GTS, the open-top version of the first model to be produced in Sant'Agata Bolognese. Even more tragic from today's perspective is that only one copy of the exquisite P400 Miura Roadster from 1968 was ever built. Lamborghini unveiled its first series production open-top in 1976 with the Silhouette – its V8 mid-engine with 250 hp offered refined performance, while a removable roof delivered that topless feeling. Its successor was the Jalpa Speedster, which was launched in 1986. The V8 power unit with a 90-degree cylinder bank angle was once again mounted behind the seats, albeit enlarged to 3.5 liters – which, with the same output, guaranteed much better torque.
In 1992 it was an open-top Lamborghini that was anointed the hero of the Geneva Motor Show – low-set with a sharply angled windscreen and an amazingly powerful looking rear end, the Diablo Roadster cut an impressive figure on the Lamborghini stand. The series production version came in 1995 – with its 5.7 liter twelve-cylinder and all-wheel drive, it was a true super car. Its output of 492 hp ensured it a top speed of 323 km/h with the roof open or closed. The rear-wheel drive Diablo SV Roadster followed in 1998. Finally, the Murciélago Roadster made its appearance in 2005 as a super-modern interpretation of the open-top twelve-cylinder.
The true hero among the open-top Lamborghinis, however, is by far and away the Gallardo Spyder – at least, when it comes to the number produced. The first generation appeared in 2006, with a ten-cylinder engine, 520 hp and an electro-hydraulic roof engineered for high-speed driving. The second generation followed in 2008 – the Gallardo LP 560-4 Spyder. Its designed had been sharpened even further, its output increased to 560 hp and many detail improvement made throughout, demonstrating the dedication that Lamborghini applies to perfecting its super sports cars.
http://www.gtspirit.com/2010/11/17/offi ... rformante/
Prispevkov: 11405
Napisal/-a martin_krpan To sep 13, 2011 6:35 pm
Gallardo LP570-4 Super Trofeo Stradale - namočnejši Gallardo do sedaj. Motor je V10 (570 konjev), teža avta znaša 1340 kg. Naredili jih bodo 150, cena nja bi znašala okoli 1,9 mio EUR.
http://auto.blog.rs/blog/auto/noviteti/ ... o-stradale
Prispevkov: 11405
Napisal/-a martin_krpan Po nov 21, 2011 6:15 pm
Lamborghini Gallardo LP550-2 Spyder. Gre za Valentino Balboni (pogon samo na zadnji kolesi) s pomično streho.
http://paultan.org/2011/11/21/lamborghi ... s-rwd-fun/
Prispevkov: 11405
Napisal/-a martin_krpan Pe sep 28, 2012 4:58 pm
the_red
Prispevkov: 258
Pridružen: Ne mar 23, 2008 1:03 pm
Napisal/-a the_red Po okt 01, 2012 2:27 pm
Kaj ima Audi s temi trikotnimi odprtinami v prednjih odbijačih? (A3, RS4, Lamborghini Gallardo) :D Gallardo pa odlično skriva svoja leta, saj ga z malimi popravki delajo že od 2004.
Briši, ide Micubiši !!!
