CupraR
Prispevkov: 4634
Napisal/-a CupraR Sr feb 11, 2009 8:39 pm
Pa se treba vedno obešat na besed posameznikov, ki ne vidijo 2 cm pred havbo?? Boli te k. za te butle. Vozjo 1.4 golfa pa sanjajo o GTI-ju :lol:
BTW, v tej temi, je kkšn VW fan začel omenjat konkurenco?? Ostali so spet začeli sr. in kot ponavadi namesto da bi bila debata o modelu, se spet začne prepucavanje.
In to kot vedno pride od ljudi, za katere še enkrat napišem da znajo sama številke pa filmčke gledat (večina, ne vsi). Pol se pa gre kaj je bolše :roll: :roll:
TomyBoy2
Prispevkov: 823
Pridružen: To jul 15, 2003 9:40 pm
Napisal/-a TomyBoy2 Sr feb 11, 2009 9:32 pm
Meet the new R-series Golf. It will feature basically the same direct-injection 2.0-liter turbocharged gasoline engine that you find in the GTI, tuned to an impressive 270 hp. Power will be transmitted to all wheels. Zero-to-60 times should be in the low- to mid-fives, and while the regular GTI tops out at a drag-limited 149 mph, the new R version will hit its governor at 155, with a theoretical top speed 10 mph or so higher.
Unlike the R32, the new R model will offer performance greater than the GTI’s, with the slightly increased weight and resistance of the AWD system easily offset by the leap in power and torque. We expect a choice of manual and dual-clutch transmissions, each with six forward ratios.
Essentially, the Golf R features the Audi S3’s powertrain. We have driven that car extensively; think WRX performance combined with Audi refinement. It’s worth noting that the new Golf MkVI, upon which this R version will be based, is more sophisticated than the Audi A3/S3.
The exterior of what we believe will be called R20 Turbo is distinguished from the GTI by an even more aggressive front spoiler, complete with three distinct air intakes, a more aggressive rear spoiler, and two center-exit exhaust pipes. Three doors will be standard, but VW will most likely also offer a five-door variation. Our artist’s renderings show a possible look for the three-door R20.
This ultimate Golf will go on sale in Germany in late 2009
VW will first show the R-series Golf on May 21 at the ADAC 24-hour race at the Nürburgring Nordschleife. Volkswagen will also launch an R version of the sporty, Golf-based Scirocco. Equipped with the same engine as the R20, it will be front-wheel-drive. Torque steer will be managed by an electronic differential VW calls XDS—and a prayer.
Glede cene omenjajo 25.000 funtov. Če je nekje osnovni pri njih 20k, je to ca 25 % več. Sigurno ca. 40.000 EUR za DSG pri nas. :shock:
Malce dilema, ker sem ravno pred nakupom "navadnega" in sedaj tole. Pa še vprašanje kdaj se začne prodaja.
RSR-jeva predelava bo dala na klasišnem GTI-ju ca.20konjev manj. Res je tu štirikolesni pogon, nekaj čisto drugega, dejansko spravi vso to moč na tla, pa pač body kit, podvozje malo izboljšano. Sprašujem se če je smiselno dati 9k več, ker takšna cena sigurno zna biti pri nas ? Ne vem ?
Za to razliko dobiš še en manjši avto zraven. :)
CupraR
Prispevkov: 4634
Napisal/-a CupraR Sr feb 11, 2009 9:56 pm
Za tak denar morš bit res ornk VW fan. Kokr sm reku, Cupra, konzolo rešiš z navi, pa si še vedno pod 30.000€.
TomyBoy2
Prispevkov: 823
Napisal/-a TomyBoy2 Sr feb 11, 2009 9:59 pm
CupraR je napisal/-a:Za tak denar morš bit res ornk VW fan. Kokr sm reku, Cupra, konzolo rešiš z navi, pa si še vedno pod 30.000€.
Registerske ne mislim menjat, tako da more biti isti avto...... :P :lol: :lol:
CupraR
Prispevkov: 4634
Napisal/-a CupraR Sr feb 11, 2009 10:03 pm
Pol pa začni fajn šparat :P
PRODRIVE
Prispevkov: 2657
Napisal/-a PRODRIVE Sr feb 11, 2009 10:08 pm
lEPA HUDOBIJA,MLJASK ;)
CARPE IMPREZAM
simply
Prispevkov: 3065
Kraj: Nova Gorica
Napisal/-a simply Sr feb 11, 2009 10:37 pm
Ah dvomim, da bo 40k EUR. Tam okrog 36k EUR pa sigurno.
TomyBoy2
Prispevkov: 823
Napisal/-a TomyBoy2 Sr feb 11, 2009 10:59 pm
CupraR je napisal/-a:Pol pa začni fajn šparat :P
Nimam kej šparat. Moj letošnji kronometer in specijalka sta skupaj več vredna kot tale stari GTI. :P
simply je napisal/-a:Ah dvomim, da bo 40k EUR. Tam okrog 36k EUR pa sigurno.
Sej tega se malo potihem sedaj bojim, 5k bi pa še bilo sprejemljivo, bomo videli, če bodo do spomladi imeli kaj več infa na VW-u.
Sarge
Prispevkov: 193
Pridružen: Po dec 15, 2008 1:05 pm
Napisal/-a Sarge Sr feb 11, 2009 11:22 pm
Bravo! Dali bojo stvari iz Audija S3. Haldex :twisted: Megane je že zmagal :twisted:
Vive Le Sport!
HaMzO
Prispevkov: 1164
Pridružen: So sep 30, 2006 1:05 am
Napisal/-a HaMzO Sr feb 11, 2009 11:47 pm
prija, clo mene mika tole :D
kdaj pride ta avto vn?
Media3
Prispevkov: 537
Pridružen: Po jan 03, 2005 8:49 pm
Napisal/-a Media3 Sr feb 11, 2009 11:56 pm
Sarge je napisal/-a:Bravo! Dali bojo stvari iz Audija S3. Haldex :twisted: Megane je že zmagal :twisted:
Megan coupe je lep, to je pa tudi vse!
Pollo
Prispevkov: 2190
Napisal/-a Pollo Sr feb 11, 2009 11:59 pm
tle mas pa si ga pejt na roko vržt
kaj ma renault v tej temi tud nevem
Lesane Parish Crooks
Prispevkov: 927
Napisal/-a Lesane Parish Crooks Če feb 12, 2009 12:34 am
Pollo je napisal/-a:
looooooooooooooooooooooooooooooool
to si mi z jezika vzel!!!! :D
Psepi
Prispevkov: 563
Pridružen: Pe okt 12, 2007 7:31 am
Napisal/-a Psepi Če feb 12, 2009 1:14 am
Zelo všečen Golf. 8) Focus RS je že na cesti? In pa počakati je treba še Megana RS (nisem fan Renojev, a mislim da športnosti ne gre očitati Renaultu v RS in GT izvedbah).
tomson
Prispevkov: 1386
Kraj: LJ / MB
Napisal/-a tomson Če feb 12, 2009 8:44 am
Si ti nek infantilnež.
kolesar
Prispevkov: 2913
Kraj: štajerska
Napisal/-a kolesar Če feb 12, 2009 9:28 am
TomyBoy2 je napisal/-a:
za bicikla daš več ko maš avto vredn :twisted:
M156
Prispevkov: 159
Pridružen: Če apr 10, 2008 11:44 pm
Napisal/-a M156 Če feb 12, 2009 1:32 pm
snikerson je napisal/-a:
M156 je napisal/-a:Ja zanimiv bo ko se bodo tolkli tale Golfič pa novi Megane RS, pa Mazda 3MPS je zunaj ter Focus RS (300konjev!!!)!
Opelica zna tut met strupeno OPC čez kako leto čisto novo seveda!
Super bo...kralj hatsch-ov bo pa itak RS3 ki bo imel 2.5L vrstni 5-valjnik in 350konjičev :))) Pa seveda tut po ceni bo najdražji! Čeprav js bi to bol pol uvrstiu med BMW 135i, še bolj pa med Imprezo WRX Sti in Lancer EVO hatcback
kje si pa to zvedel za RS3? maš kak link, za ttja sem slišal, da naj bi mel 5valnjega turbaka, za trojko pa še ne...
From MotorAutority
With only a 10hp boost in power over the current model and no change in torque implemented for the next-generation Volkswagen Mark VI Golf GTI, fans of the hot-hatch would understandably be less than impressed with the new car’s numbers.
According to latest reports, however, VW won’t be neglecting its much admired Golf GTI. Sources in Germany familiar with the carmaker’s plans have revealed to Auto Motor and Sport that the GTI will be expanded into a small family of performance models, rather than remaining just a single car. Thus the model being shown next week at Paris will just be the entry level GTI, with much more potent offerings from VW set to follow soon afterwards.
For 2009, Golf GTI fans can expect to see a new sports diesel model, going under the GTD moniker. Essentially the GTD will be running on the same chassis as the GTI but will feature a fuel efficient 2.0L common-rail diesel with around 170hp and 350Nm, expected to be good for an 8.2 second sprint to 62mph - not lightning quick, but sure to be popular with those compromising between drivability and fuel efficiency. This model will also likely come with a six-speed manual as standard, with a DSG transmission as an option.
The next model up in the new GTI family will be the GTI 'Plus', which is expected to clash heads with the likes of BMW's 135i and Audi's S3. The car is expected to feature a 270hp output, Haldex AWD system and an uprated DSG transmission with seven-speeds.
Joining the new diesel and Plus models, will be a successor to the R32 due in 2010. As most manufacturers are doing these days, VW will likely downsize the R32’s V6 engine into a turbo five-cylinder variant, which is also expected to make its way into the Audi TT-RS and the Audi RS3 eventually. This twin-turbo five will be putting out around 350hp from its 2.5L of displacement.
M156
Prispevkov: 159
Napisal/-a M156 Če feb 12, 2009 1:35 pm
hehe tle se kregajo Nemci in Francozi
na konc ga bodo pa vsi povlekl Japončkom in Italijnčkom :)))
hint: nova Alfa Milano (149) GTA in pa športni HB-ji od vsake japonske firme!
sašo5
Prispevkov: 5085
Kraj: Brežice
Napisal/-a sašo5 Če feb 12, 2009 1:36 pm
Sarge je napisal/-a::roll: ? Zelo odraslo, zdej se poslužujete primitivnih izjav in primerjav, ker nimate kaj pametnega povedat.
s primerjavami si ti prvi začel(kot že mnogokrat, ter sprožil prepir, drugi so bili pa sankcionirani) - vendar tega "moderatorji" ne vidijo, osebno mislim, da si že zdavnaj zrel za "terme" :arrow: tiste v Prekmurju, po imenu Banovci.....
Tattoo-
Prispevkov: 1318
Kraj: Circuit de la Sarthe
Napisal/-a Tattoo- Če feb 12, 2009 2:30 pm
M156 je napisal/-a:na konc ga bodo pa vsi povlekl Japončkom in Italijnčkom :)
Aha...približno tako, kot je dolgo časa po različnih forumih "kraljevala" Alfa 159 GTA, za katero smo morali poslušati, kako suvereno bo pometla z BMW M3 / MB C AMG / Audi S4 in ostalo konkurenco...na koncu je pa od Alfe 159 GTA ostalo samo nekaj slik testne mule na Nurburgringu! :lol: :roll: :lol:
Najprej naj Alfa Romeo da na trg vsaj kakšen (konkreten) nov avto, potem se bomo pa začeli pogovarjati...
