Dr.M3
Prispevkov: 1409
Napisal/-a Dr.M3 To feb 12, 2008 5:56 pm
Pri avtomobilih za 30,40k EUR smo seveda lahko precej bolj kritični. Saj se od teh avtomobilov tudi več pričakuje.
faceless
Prispevkov: 99
Pridružen: Pe feb 15, 2008 10:08 am
Napisal/-a faceless Pe feb 15, 2008 10:16 am
Seveda, da je sramota....
Ceprav po tolikih kiksih in skandalih mb-ja v zadnjem casu, me niti ne cudi prevec.
Napisal/-a esem So apr 12, 2008 1:40 am
MB je prestavil nov 4-valjni dizel, s katerim so med drugim izboljšali trenuten rekord navor/prostornina, ki ga je prej imel novi FIAT-ov dizel. 2143 kubičen motor bo imel v najmočnejši konfiguraciji (250 CDI) 204 konje in 500 Nm navora, v 220 CDI bo 170 KM in 400 Nm, v 200 CDI bo 136 KM in 330 Nm navora. Najmočnejši pride jeseni v MB C, kjer bo imel porabo 5,4 litra (-0,5 glede na prejšnji motor) in pospešek 7,7 do 100, 220 CDI bo imel v MB C porabo le 5,1 (-0,8!). Common Rail je četrte generacije.
Precej slik novega motorja tu , kjer je tudi daljši PR s podrobnim opisom tehničnih značilnosti motorja.
Z druge strani PR-a - glavne novosti
MB-jev trahtarski oddelek je napisal/-a: * Two-stage turbocharging ensures high power output and optimum torque delivery.
* Fourth-generation common-rail technology with a rail pressure that has been increased by 400 bar to 2000 bar, plus a new piezoelectric injector concept featuring direct injector needle control creates the ideal basis for more flexible injection timing, leading to smoother engine running, lower fuel consumption and reduced emissions.
* The maximum ignition pressure is 200 bar which also contributes to the high output.
* Both the oil-spray nozzles and the water pump are activated in accordance with requirements to save energy.
* The camshaft drive is positioned at the rear in order to enhance running refinement and satisfy the exacting pedestrian protection requirements.
* The engine block is made from cast iron, the cylinder head from aluminium.
* Two water jackets guarantee maximum cooling even at the points of greatest thermal radiation; it is this that enables a ignition pressure of 200 bar and such a high power-to-displacement ratio.
* The aluminium pistons slide up and down in cast-iron barrels for minimum frictional resistance.
* The connecting rods are made from forged steel, and their weight has been optimised by the Mercedes engineers.
* In the interests of vibrational comfort, the forged crankshaft with its eight counterweights turns supported by five bearings. The radii of the crankpins are rolled for high strength.
* To compensate for the free vibration moments which are inherent to four-cylinder inline engines there are two Lanchester balancer shafts at the bottom of the engine block running in low-friction roller bearings rather than conventional plain bearings.
* A two-mass flywheel, featuring a primary flywheel mass fixed to the crankshaft that is connected to the secondary flywheel mass on the transmission by means of springs (technical term: spring-mass system), isolates the crankshaft's vibration stimuli from the drivetrain, thereby contributing to the engine's excellent smoothness.
vsi sestavni deli (ista slika v večji resoluciji)
ESTEMP
Prispevkov: 684
Kraj: gorenjska
CITROENAR ŠT 1
Prispevkov: 1483
Napisal/-a CITROENAR ŠT 1 Pe jul 09, 2010 8:55 pm
ESTEMP je napisal/-a:Konec?
Me ne bi šokiralo in se popolnoma strinjam s Joie de vivre! glede dizajna. Tega se preprosto ne dela, sploh pa taka prestižna znamka. Predhodnik, torej C-Sportcoupe mi je bil svoje čase fenomenalen, ta CLC je pa metanje peska v oči.
Seveda so samo ljudje pri MB-ju C4V4L13R, vendar pa bi to pričakoval ne vem, .... do Dacie mogoče ipd. ne mpa MB-ja. Mislim, lepo prosim, če znajo narest lepe kupeje, vsaj npr. E-Coupe, CLS I. in II:, CL, in še dejstvo, da so prestižna znamka, potem mislim, da so pričakovanja jasna, se ti ne zdi. ;)
Mislim, da bi bilo bolje za MB, da ga čim prej ukine in naredi novo generacijo s bombastično obliko, polno elegance, nekaj, kar ne uspeva vsem znamkam. Talent, znanje in sredstva imajo tako, da kar za risalne mize,... MB. :pray: :wink:
maliBobi
Prispevkov: 256
Pridružen: Če jun 03, 2010 6:02 pm
Napisal/-a maliBobi Pe jul 09, 2010 9:27 pm
Ta avto sem vozil.
- trd neudoben
- sedi se previsoko (očitno je delan za ženski del populacije)
- nikamor ni šel 150km diesel (verjetno slabost avtomatskega menjalnika)
- grd (pač stvar okusa)
Sem pa vozil rezred E (prejšnji model) in tisto je tisti ta pravi mercedez 8)
CITROENAR ŠT 1
Prispevkov: 1483
Napisal/-a CITROENAR ŠT 1 To avg 03, 2010 6:58 pm
Upajmo, da bo vsaj naslednik boljši v vseh pogledih. ;)
jurre
Prispevkov: 380
Pridružen: Po avg 01, 2005 10:37 pm
Napisal/-a jurre Če avg 05, 2010 11:29 pm
vceraj sem na Grossglocknerju srecal eno testno mulo... nov cls? oops
(se opravicujem za slabo kvaliteto slik, je bilo ze temno)
CITROENAR ŠT 1
Prispevkov: 1483
Napisal/-a CITROENAR ŠT 1 Pe avg 06, 2010 8:36 pm
Jep, če drugo ne, je videt po stranski liniji in po številu vrat, da je novi CLS. Lep kamufliran ulov ;)
