berlonso
Prispevkov: 1162
Napisal/-a berlonso Po mar 02, 2009 11:38 am
jutri se odpre ufičale stran od novega Megana RS! :twisted:
CupraR
Prispevkov: 4634
Napisal/-a CupraR To mar 03, 2009 12:51 pm
Sej ne morm verjet da ni še noben nič gor dal:
http://www.renault.com/en/Vehicules/Pages/nouvelle-megane-renault-sport.aspx?initCO2=219
Zanimiva zadeva ni kej, vendar vsaj men ta rumene ne sede preveč. Preveč je "rumene", premalo črne, sploh s strani..
Powerful
New Mégane Renault Sport is powered by a new-generation 2-litre 16-valve turbocharged petrol engine which boasts maximum power of 250hp (184kW) at 5,500rpm and peak torque of 340Nm from 3,000rpm. The sum of the different improvements made to this engine has produced a gain of 20hp and 40Nm over Mégane R26.R which itself emerged as the yardstick in the world of performance hatches. The Renault Sport 2.0 T engine's twin-scroll turbo is exceptionally responsive and is particularly flexible at lows revs, with 80 per cent of maximum torque available from 1,900rpm. Its broad useful rev band makes it a genuine joy to drive in everyday use, and the pleasure remains all the way up to the rev-limiter whenever it is pushed a little harder. The engine of New Mégane Renault Sport drives through a six-speed manual gearbox.
Work has also gone into the acoustics of the Renault Sport 2.0 T engine to produce a telltale sporty pitch audible inside the cabin under acceleration.
berlonso
Prispevkov: 1162
Napisal/-a berlonso To mar 03, 2009 1:11 pm
in v tadrugem videu so že razkriti scenic in megane grandtour. vredno ogleda. :twisted:
drugmirko
Prispevkov: 2762
Napisal/-a drugmirko To mar 03, 2009 1:23 pm
uradne za Scenica.... kje je že un, ki je komentiral tiste rdeče špijune popolnoma odkritega Scenica, ki sem jih postal pred cajtom,
da so slabi fotošopi in da ziher nebo tak... evo ti na P :
živeo drugmirkooooo!!!!
labello20
Prispevkov: 23
Pridružen: Po jan 12, 2009 10:50 am
Napisal/-a labello20 To mar 03, 2009 1:30 pm
5 sedežni je vspreda lepši,7 sedežni pa vzada
fastmaniac
Prispevkov: 30
Pridružen: Po jun 18, 2007 5:54 pm
Napisal/-a fastmaniac To mar 03, 2009 2:02 pm
V glavnem Megane RS raztura. Scenic je tud krasen, sploh pa se mi dopade krajši, notranjost pa je tud napredovala napram prejšnemu. Mislim da so na dobri poti. :lol: :twisted:
dominic
Prispevkov: 655
Napisal/-a dominic To mar 03, 2009 2:12 pm
lepo dodelan tale RS...in pri nakupu definitivno cup verzija, ki ima pri opremi zraven vkljucen dif...ob izgledu, mislim da bo lepo prisel do izraza se rdec, ter beli...crni bodo prevec monotoni in skriti...vendar kljub temu zverine na cesti...
ali se mi samo zdi ali je v videu podtaknjen zvok, pri meganu, ker mi zlo slici na zvok od nissan-a - stare 34gtr :) poslusajte...ker ce ima avto taksen zvok...svaka cas inzinerjem...
ob tem avtu bi spremenil le to da bi ga pribil na tla...
lp, dominic...
podgurc
Prispevkov: 227
Napisal/-a podgurc To mar 03, 2009 3:19 pm
labello20 je napisal/-a:5 sedežni je vspreda lepši,7 sedežni pa vzada
Mam isto mnenje.
Pa tudi noter je zelo lep. Pa čeprav je to top oprema, ampak mislim da bo tud v različicah s skromnejšo opremo notranjost vseno zelo lepa.
dragon22
Prispevkov: 263
Pridružen: So dec 15, 2007 6:00 pm
Napisal/-a dragon22 To mar 03, 2009 4:16 pm
Megane RS je pa čisto razočaranje, prejšnji model je bil veliko lepši in tud bolj je odstopal od navadnega modela, pa sredinski izpuh kot pri astri opc mi tud ni všeč.
Konkurenca, mazda 3mps in focus rs sta veliko lepša oblikovno in tudi motorji so boljši.
labello20
Prispevkov: 23
Napisal/-a labello20 To mar 03, 2009 4:19 pm
lep je tale rs,pa tud konkurence mislim da ne bi imel prave(250km+verjetno najboljša lega od konkurentov)
dominic
Prispevkov: 655
Napisal/-a dominic To mar 03, 2009 4:46 pm
motorji so boljsi...po cem sklepas to?? mislis da ves o cem govoris??
odstopanja, in koliko odstopanja potrebujes da je avto drugacen...razlika je ocitna, povdarjeni blatniki, cisto nov desing sprednjega odbijaca, lita platisca, zadek...?? avto zelo odstopa od obicjane različice, za moje pojme celo bolj kot pri prejsni različici, kjer je bilo spremenb le za oddtenek...in ti niso toliko padle v oko...tega bos na cesti od dalec locil od ostalih meganov...
simply
Prispevkov: 3065
Kraj: Nova Gorica
Napisal/-a simply To mar 03, 2009 5:32 pm
Tale megane mi izgleda zelo Vag-ovsko. Mi je všeč, kljub temu preferenciram VAG.
Sedaj je pomembna tudi cena in vzdržljivost.
Me pa čudi, da ni večjega odziva tu na forumu nanj.
Ali mislite, da so naredili podoben zvarek kot Honda pri novem Civicu, ko je športnost malenkost potisnjena v ozadje?
Veyron
Prispevkov: 98
Pridružen: To okt 21, 2008 12:20 pm
Napisal/-a Veyron To mar 03, 2009 6:12 pm
Zanimiv, ta rs različica ni tako bolj vpadljiva od navadnega k prejšnja. Verjetn že zaradi tega, ker že navadni coupe deluje dosti športno.
Enako je tudi pri civic.
benf1
Prispevkov: 226
Pridružen: Po jun 18, 2007 1:47 pm
Kraj: Šentjernej
Napisal/-a benf1 To mar 03, 2009 6:43 pm
men je Megane RS zakooon! edino kar me mot je to, da ma samo eno izpušno cev :? Scenica sta mi tut všeč oba, še posebno spredni del 5sedežnika :D notranjost pa itak 8)
Prispevkov: 11393
Napisal/-a martin_krpan To mar 03, 2009 7:35 pm
še karavan, zame najlepša karoserijska izpeljanja.
http://www2.uol.com.br/bestcars/un13/29 ... tourer.htm
in RS. Takšni bi mirali biti spredaj vsi kupeji- brez tistega aluminijastega ''cross'' dodatka
http://www2.uol.com.br/bestcars/un13/29 ... ane-rs.htm
dominic
Prispevkov: 655
Napisal/-a dominic To mar 03, 2009 8:51 pm
en hiter chop..hehe
Clio III
Prispevkov: 37
Pridružen: Sr maj 03, 2006 7:40 pm
Napisal/-a Clio III To mar 03, 2009 9:27 pm
tole me samo na eno čebelo spominja. Če bi vsaj taspoden konec odbijača dal v črno, ne bi tako visoko zgledou. drgač pa 250km pa spredn pogon :?
podgurc
Prispevkov: 227
Napisal/-a podgurc To mar 03, 2009 9:38 pm
Clio III je napisal/-a:tole me samo na eno čebelo spominja. Če bi vsaj taspoden konec odbijača dal v črno, ne bi tako visoko zgledou. drgač pa 250km pa spredn pogon :?
Men to tud čuden zgleda k je taspodnji del zadnjega odbijača rumen, se mi zdi da bi biv črn lepši.
dominic
Prispevkov: 655
Napisal/-a dominic To mar 03, 2009 9:55 pm
in kaj je 250km ob taksni tezi avta in prirejenem podovzju, ter pri cup verzijo se celo dif...?? in kako bi zlgedalo, ce bi bil tale spodnji dela crn...kaj pa ostali deli avta...celotno linijo bi zjebalo...
CupraR
Prispevkov: 4634
Napisal/-a CupraR To mar 03, 2009 10:03 pm
Z lahkoto, kaj šele z difom. Probaj pa pol dajaj neumestne..
