Ivan36
Prispevkov: 4577
MPM PS160
Napisal/-a Ivan36 Sr mar 07, 2018 9:14 pm
MPM PS160 11.490 €
Prvič vidim in berem o tej znamki?
http://www.avto.net/Ads/details.asp?id= ... Mitsubishi - MPM PS160
http://www.mpm-motors.com/en/
DIMENSIONS
Total length: 4684 mm
Overall width: 1860 mm
Overall height: 1383 mm
Ground clearance: Rear: 315 mm / front: 223 mm
Wheelbase: 2750 mm
Fuel tank capacity: 55 liters
Luggage compartment: 380 liters
Curb Weight: 1225 kg
ENGINE
Traction
Mitsubishi, petrol
4G18S 100ch 1.6L, 4 cylinders in line
Compression ratio: 10.0: 1
Weight: 197 kg.
1584 cm3
Engine torque : 138 Nm at 3000 rmp
Power consumption: 7.2 L / 100 km
CO2 : 158 g CO2/km
Euro 6
Skyen
Prispevkov: 203
Pridružen: Pe nov 29, 2013 1:56 pm
Re: A je to resno? MPM PS160 11.490 €
Napisal/-a Skyen Sr mar 07, 2018 10:50 pm
Ruski avto, ki ga gradijo v Franciji. Recept za.. uspeh? Kolikor sem bral mu očitajo varnostne probleme (crash teste na njihovi spletni strani so delali sami, 1 airbag ipd).. Mogoče idealen za amaterski track car?
Ivan36
Prispevkov: 4577
Napisal/-a Ivan36 Sr mar 07, 2018 11:29 pm
Je zanimivo, ker ne dobiš Clio za ta denar. Nekaj že mora biti, da se še ni slišalo za to znamko. :roll:
serjiska oprema :DDD
STANDARD EQUIPMENT
18inch aluminum wheels
Sports bucket seats
Heated mirrors
Air conditioner
Anti pollen filter
MP3 audio system HiFi 4 speakers ALPINE Audio
Driver airbag
Radio CD MP3, LCD and USB port
LED Daytime Running Lights
Anti Fog lamps
Theft system approved THATCHAM
Anti intrusion, movement sensor system
Neiman
Electric front and rear windows
Windows with child safety
Isofix
Ivan36
Prispevkov: 4577
Napisal/-a Ivan36 Sr mar 07, 2018 11:32 pm
Okvir
FRAME
Its unique design for a production car that combines tubular frame and composite body, (Design used mainly in motorsport).
Our vehicles are 10 to 25% lighter than their counterparts in the same categories which gives it sporty dynamics and an attractive power to weight ratio.
Zadaj
Števci od Chevi Nubira :shock:
Zadnjič spremenil Ivan36, dne Sr mar 07, 2018 11:43 pm, skupaj popravljeno 1 krat.
Ivan36
Prispevkov: 4577
Napisal/-a Ivan36 Sr mar 07, 2018 11:40 pm
edit mod
Zakaj citiraš, če citat s tvojim odgovorom nima čisto nobene zveze? Ne najdeš gumba "odgovori" ali kaj?
Našel malo več. Tudi v D registrirane.
http://boitierrouge.com/2017/11/26/mpm- ... francaise/
Še nemški
http://www.auto-motor-und-sport.de/news ... arktstart/
nered
Prispevkov: 489
Pridružen: Ne jul 26, 2015 3:40 pm
Napisal/-a nered Sr mar 07, 2018 11:58 pm
Odpad. Komu je to sploh namenjeno in pa lol 11.490 EUR za odpad z 1.6 107KM motorjem z 12.3s do 100km/h lol z vprasljivo varnostjo in zanesljivostjo.
Opel Corsa 1.4T 150KM 8.9s do 100km/h, 11.360 z vec opreme, solidno varnostjo in zanesljivostjo.
Kohec
Prispevkov: 747
Napisal/-a Kohec Če mar 08, 2018 10:35 am
Meni pa je vizualno všeč. Kakšna je pa tehnika in varnost je pa že vprašanje.
Napisal/-a esem Če mar 08, 2018 7:07 pm
@nered
Primerjaš corso z avtom, ki je 60 - 70 cm daljši. :roll:
plinaš
Prispevkov: 1227
Napisal/-a plinaš Če mar 08, 2018 9:56 pm
nered je napisal/-a:Odpad. Komu je to sploh namenjeno in pa lol 11.490 EUR za odpad z 1.6 107KM motorjem z 12.3s do 100km/h lol z vprasljivo varnostjo in zanesljivostjo.
:lol:
drugače pa - coupe je dvovraten 2+2 sedežnik.. 4 vratni niso kupeji temveč fast ali liftback-i... pa po novem jim rečejo tudi sportback-i..vse ostalo so izmišljotine novinarjev in proizvajalcev ..
naj mu vzamejo stran zadnja vrata , skrajšajo za 35 cm ,olajšajo za 170kg in pocenijo za 1500e pa bo top avtoček za mlade..
old school mitsubishi agregat - miljonkrat preverjen .. ok sopotnikov airbag naj dodajo za 200e..
Zadnjič spremenil plinaš, dne Če mar 08, 2018 10:09 pm, skupaj popravljeno 2 krat.
plin je cnej k bencin
1992Diavolo1992
Prispevkov: 352
Pridružen: Pe sep 13, 2013 6:49 pm
Napisal/-a 1992Diavolo1992 Če mar 08, 2018 9:57 pm
"Sportnik" za reveze.
Napisal/-a pskoda Če mar 08, 2018 10:17 pm
Grd in že od deleč se vidi, da je ceneno.
Za moj okus je zadaj grd in tudi noter je revščina, da o motorju sploh ne govorim
Jaz ga ne bi kupil
nered
Prispevkov: 489
Napisal/-a nered Če mar 08, 2018 11:12 pm
esem je napisal/-a:@nered
Kaksne veze ima +60-70 cm ? Oglasevan kot ugodni sportni avto, poln zastarele in cenene opreme, poddhranjen in neuporaben motor itd... Moje vprasanje je bilo komu je to sploh namenjeno, kdo si rece hmm zelim si sportni avto za 12.000 EUR in se odloci za ta odpad.
Pac Corso sem dal kod primerjavo. Tale avto ni vreden 1000 EUR ne pa 12.000 EUR.
Napisal/-a pskoda Pe mar 09, 2018 5:34 am
18 letni pobci, ki ne marajo starih bmwjev, audijev za podoben denar
Ivan36
Prispevkov: 4577
Napisal/-a Ivan36 Pe mar 09, 2018 7:27 am
Baje je to predserjiski model? Kakšen bo pa serjiski, pa še ne vemo, verjetno bojo notranjost bolj dodelali? Neki nizkocenovnik verjetno in z leti pa več prodaje se bo izboljšal. Podobno, kot prve DACIA Logan. Saj preizkušene komponenete niso zanič plus še poceni so.
Drugače je stal celi Twingo le 3000€ na komcu izdelave v revozu tako, da je tukaj še rezerva verejtno. Bi pa jaz za recimo vstopni model imel zadaj stekla samo na pantograf odpiranje na ven enako imata C Caktus in DS 4 in samo max 2 barvi pa tudi zadaj bucket sedeže 2x tako bi bil še lažji od sedanjih 1250 kg. 8)
chad
Prispevkov: 234
Pridružen: So jun 27, 2015 2:22 pm
Napisal/-a chad Pe mar 09, 2018 9:32 am
To je sigurno una varjanta, ko se zaleti s 65kmh in zmečka pol kabine. Taki na eu trgu ne morejo biti v uporabi.
TrijoAdijo
Prispevkov: 4168
Napisal/-a TrijoAdijo Pe mar 09, 2018 12:42 pm
Tut od močne švabe pri trku v lokalno slivo pri 65km/h ostane bolj malo uporabnega. Pljuvatorji po zastareli opremi se ne zavedajo, da je nova, nepreizkušena fensi šmensi super duper touch oprema vredna malo manj kot 1/2 kozarca deževnice...ker rada crkuje...Namreč,stara tehnika, ki je preizkušena, je velik boljša...pa še poceni je. Zadnč en dan je bila neka oddaja, ko so enga od Dacie vprašal, zakaj dajejo not staro tehniko in da jim očitajo,da so zadaj tri leta napram ostalim proizvajalcem. Tip je odgovoru,da je tako zanalašč, ker je stara tehnika preizkušena in deluje. Drgač, men ta bolid ne zgleda švoh, je po mojem okusu,ker ima švoh opremo, ampak....ja...moti me francosko poreklo...
Ivan36
Prispevkov: 4577
Napisal/-a Ivan36 Pe mar 09, 2018 1:42 pm
Še Video
http://www.youtube.com/watch?v=-4qrxiPUppo
http://www.youtube.com/watch?v=gx4lFAmhxM8
Ob ogledu drugga video sem opazil, da je pocen zato, ker ima tudi panele samo privite na vrata z 3 vijaki pa čepki gor in 4 smerokazi je tipka za traktor pasqali :lol: :DDD Torej malo Korejca Francoza pa Japonca.
nered
Prispevkov: 489
Napisal/-a nered Pe mar 09, 2018 2:38 pm
Pac odpad, niti priblizno vreden 12.000 EUR. Se vedno ne vem komu je to sploh namenjeno.. Kdo si rece hm imam 12.000 zelim 'sportni' avt, izbiro imam skoraj neskoncno od rabljenih do novih od priznanih znamk ampak to je bedarija vzel bom 'sportni' avto neznane znamke z zastarelim motorjem, ki komaj diha, fake ferrari izgledom, z opremo iz 1980, z privat opravljenim ncap ratingom, ki ima 12.6s/100.
Propadel ruski projekt, ki pa ga je sedaj nekdo prevzel v Franciji in jih izdeluje iz garaze xD Ce so Rusi dvignal roke od tega potem mu ni velik upanja.
McLaren
Prispevkov: 3434
Kraj: Cela EU
Napisal/-a McLaren Pe mar 09, 2018 6:07 pm
Lepo si povzel to. Ce nekdo to kupi se mora resno povprasat o svojem zdravju. Edino ciljno skupino vidim kake 18 letnike, ki hocejo sporten avto ampak je zavarovanje za mladega voznika prevec stane (UK ma recimo zelo visoke cene ce je voznik zacetnik) in pol si to kupijo ker kao "zgleda". Samo jst rajsi pes hodim kot da bi se s tem okol prevazal
J1897
Prispevkov: 179
Pridružen: So avg 29, 2009 7:45 pm
Napisal/-a J1897 Pe mar 09, 2018 7:03 pm
nered je napisal/-a:Pac odpad, niti priblizno vreden 12.000 EUR. Se vedno ne vem komu je to sploh namenjeno.. Kdo si rece hm imam 12.000 zelim 'sportni' avt, izbiro imam skoraj neskoncno od rabljenih do novih od priznanih znamk ampak to je bedarija vzel bom 'sportni' avto neznane znamke z zastarelim motorjem, ki komaj diha, fake ferrari izgledom, z opremo iz 1980, z privat opravljenim ncap ratingom, ki ima 12.6s/100.
Saj ne, da me to čudo zanima, ampak povej mi koliko priznanih znamk ponuja nov avto take velikosti za take dnarje?
