Prispevkov: 11405
2018 Peugeot e-Legend (koncept)
Napisal/-a martin_krpan Sr jul 02, 2008 9:06 pm
Nov Peugeotov šef oblikovanja Jerome Gallix je v intervjuju napovedal številne novosti v paleti te znamke. Med njimi obljublja tudi novi 504 kupe, nekakšno nadomestilo za trenutni dvovratni 407.
The renaissance starts here! That’s the dramatic promise from Peugeot’s new design boss, Jerome Gallix.
In an interview with Auto Express’s German sister title, Auto Bild, Gallix said he’d use the firm’s heritage to create a fresh family of cars. And he’s starting with the luxurious 504 coupé.
This exclusive Gallix sketch shows exactly how such a model could look. Although technical details are scarce at the moment, it’s thought the newcomer is similar in size to the current 407, and has a bold nose and curving waistline inspired by its predecessor.
Mechanicals are likely to be shared with Citroen’s C5, so the car could get a powerful 2.7-litre V6 diesel and air-suspension.
But Gallix’s plans for making the most of Peugeot’s past won’t stop there. He also admitted he is a fan of the original 204 and the 205. Successors to both these models could be essential to Peugeot’s future as it strives to become one of the leading manufacturers of low-CO2 cars.
The first Peugeot designed under the influence of Gallix was the sleek 308 RC Z concept, which was widely acclaimed on its debut at 2006’s Paris Motor Show. The two-seater will be seen in production form at the Frankfurt exhibition in 2009, and will arrive in showrooms here the following year.
http://dikarockz.blogspot.com/2008/07/h ... t-504.html
simimedi
Prispevkov: 338
Pridružen: So jan 14, 2006 12:14 am
Napisal/-a simimedi Sr jul 02, 2008 9:10 pm
Sicer mi je lep, sam prvo ko sem zagledal sliko sem pomislil na Mustanga.
LP Simimedi
Napisal/-a Joie de vivre! Sr jul 02, 2008 9:16 pm
Bilo bi res lepo, da bi po četici "gay" retro avtomobilov tudi Evropejci dobili eno "hetero" retro mašino a la mustang, camaro in challenger :twisted:
RobberDuck
Prispevkov: 283
Pridružen: Če mar 27, 2008 6:33 pm
Napisal/-a RobberDuck Sr jul 02, 2008 9:44 pm
res je. kar se zadnih modelov tice, mi je vse bl mim.. razn 407 je kr vredu. Je bil pa 406 coupe zadn "bl zaresn" avto - peugeot. ostalo so vse k igrače. neki dost se ne vid iz slike, je pa že dost vzpodbudno, da je nov dizajner.
Re: Peugeot 504 coupe
Napisal/-a Lignage Sr jul 02, 2008 10:13 pm
martin_krpan je napisal/-a:Slika
Tole kar je na tej sliki je prava usmeritev za bodočnost te francoske znamke. Torej bo to tudi naslednik sedanjega 407 v limuzinski izvedbi. Ne bi moralo biti boljše za moj okus :)
Peugeot mora biti oblikovan klasično in bolj zadržano in ne tako kot sedaj, ko so vsi preveč razvlečeni.
Napisal/-a esem Sr jul 02, 2008 10:22 pm
Glede na previse in glede na uporabo "504" imena je morda možno celo, da bo imel zadnji pogon?
Nixxon
Prispevkov: 3646
Kraj: Vrhnika
Napisal/-a Nixxon Če jul 03, 2008 7:33 am
Da bi ga razvijali samo za en model? Morda če bi povzeli od koga drugega, ali pa zadevo razvili tudi za druge modele, čeprav si sedaj ne morem misliti za katere.
Mick Jerry
Prispevkov: 1259
Kraj: okolica Lj.
Napisal/-a Mick Jerry Če jul 03, 2008 9:17 am
Upam, da veste da je dotični dizajn zelo podoben Audijevemu? :lol:
Ne pravim kopija, ker to seveda ni, ima pa takšne ostre poteze, pa bočna linija je zakrivljena kot pri A5.
Všečen voz, samo proporce pri zadnjem kolesu bi kazalo popraviti.
Napisal/-a Joie de vivre! Če jul 03, 2008 9:22 am
MJ, čisto NIČ ni podoben audiju, ampak je podoben samo 504 coupe, vključno z vsemi ostrimi potezami in proporci:
Mick Jerry
Prispevkov: 1259
Kraj: okolica Lj.
Napisal/-a Mick Jerry Če jul 03, 2008 10:10 am
Čakaj malo :D
Da ne bo zdaj kateri skočil v zrak in rekel da hočem klobasat o kopiranju, ker to ni moj namen, ker kopiranja ni.
Hočem opozoriti na nemškost dizajna na tejle skici, ki se je pojavila.
Se mi zdi kot da ima tamle ledice v lučeh :lol:
Napisal/-a Joie de vivre! Če jul 03, 2008 10:14 am
MJ, P504 je nastal 40 let pred A5 in tale "New 504" originalu sledi do zadnjega detajla, podobnost z Audijem je torej zgolj naključna.
Napisal/-a dobek Če sep 20, 2018 11:22 am
hmmm?
Re: 2018 Peugeot e-Legend (koncept)
Napisal/-a Lignage Če sep 20, 2018 6:45 pm
@dobek: Sem tale tvoj prispevek združil s tole deset let staro temo, ker je bil že takrat prvi zametek obujanja starega 504 coupé, ki se je zdaj realiziral v konceptnem modelu e-Legend:
Vir: NetCarShow.com
alexwell
Prispevkov: 736
Napisal/-a alexwell Če sep 20, 2018 7:34 pm
kot kaže so tudi klasičnim armaturnim ploščam šteti dnevi, vsaj pri tem konceptu :-P https://www.youtube.com/watch?v=UHD7eVhUibU
tha_man
Prispevkov: 1008
Napisal/-a tha_man Če sep 20, 2018 7:54 pm
Zgleda noro. Vseskupaj je kot iz kakega zf filma.
Napisal/-a dobek Če sep 20, 2018 9:44 pm
zadnji del me sicer bolj na kako Fulvio spomni, pa kljub temu... samo :o
whitee
Prispevkov: 907
Kraj: Kozje
Napisal/-a whitee Če sep 20, 2018 10:04 pm
Zgodovina s prihodnostjo. Fenomenalen koncept.
Napisal/-a dobek Ne sep 23, 2018 6:46 pm
pa bemumilu, da moder zamet ze zelo dolgo ni tako dolgo tako hudi izgledal (niti v zdaj precej polnoletni lancii kappi ne)
