mistervegas
Prispevkov: 863
Pridružen: Sr sep 15, 2004 12:45 am
Kraj: Ptuj, okolica
prihaja novi CRX!
Napisal/-a mistervegas Po dec 06, 2004 1:59 pm
kaj mislite bo honda naredil še crxa za evropo ?
concept
While Honda thinks about reintroducing one of its most glorious models, we can't help but blurt out our full support, - this is a no-brainer, guys.
The CRX was brilliant when Honda developed it almost 20 years ago, and the tearaway combination of light and potent hasn't lost its appeal. Honda is believed to be seriously considering developing a two-seat sports car with those qualities, using its new Global Small Platform. The car, which Honda insiders are already calling the CRX, could appear in late 2004 or early 2005.
For the Japanese market, the CRX will exist in two forms: an entry-level model with a 1.0-litre DOHC VTEC triple producing appoximately 74 kW (the engine derived from the block used in Honda's Insight hybrid coupé), and a hardcore 1.6-litre DOHC four cylinder engine (also with VTEC) generating 110-115 kW. Not incredible, until you realise that the target weight for the four-cylinder coupé is said to cut under 800 kg. Put it this way - that's 200 kg less than the Mini and 175 kg lighter than an MR2.
This gives the 1.6-litre variant a tidy 7.27 kg/kW ratio in the worst case. By comparison, a 225 kW VXII SS Commodore has a kilogram-to-kilowatt ratio of 7.52. So, if Honda builds it, the little CRX will stand-out quick. Transmissions proposed are a five-speed manual for the 1.0-litre three cylinder, and a six-speed manual for the 1.6-litre. Use of Honda's CVT is said to be under study, but is not yet an official part of the programme.
The new two-seater is small, and information from Honda indicates a wheelbase in the 2250 to 2350 mm range, overall length of less than 3650 mm, width of 1690 mm and height below 1270 mm. This makes it a strictly a two-pew affair.
najšo
http://www.crxsi.com/resources/CRX_concept/
Asterix
Prispevkov: 1385
Napisal/-a Asterix Po dec 06, 2004 2:01 pm
Oni bi ziher vedel... :twisted:
eXtreme
Prispevkov: 722
Pridružen: So feb 15, 2003 9:22 pm
Napisal/-a eXtreme Po dec 06, 2004 2:09 pm
Vsak drugi mesec nekdo to vpraša. Odgovor najdeš, le search uporabi ;)
Slide
Prispevkov: 4349
Napisal/-a Slide Po dec 06, 2004 3:23 pm
Tole je sicer staro ko zemlja...ker lahko opaziš še testiranje novega "Z3-ja" za katerga se je izkazal da je bil potem Z4....torej je to ZELOOOO staro ;)
INFINITI
Prispevkov: 7259
Napisal/-a INFINITI Po dec 06, 2004 6:21 pm
bosa je tale novica - bullshit!
mistervegas
Prispevkov: 863
Kraj: Ptuj, okolica
Napisal/-a mistervegas Po dec 06, 2004 9:54 pm
ja ni novo ne če je neki 02/03
samo kolko jaz vem pride novi crx konca 2006. upam da lahko v naslednja 1-2 tedna slike zrihtam
don CONSIGLIO
Don med moderatorji
Prispevkov: 2232
Kraj: Nova Gorica
Napisal/-a don CONSIGLIO To dec 07, 2004 4:44 pm
Načeloma jebla Honda S2000 ob svoji predstavitvi označena za naslednico CRXa. Ne bi rekel, da ima Honda res kakšen namen delati še en tako športen avtomobil...
LP,
don CONSIGLIO
ThARippA
Prispevkov: 317
Pridružen: Ne apr 11, 2004 7:44 pm
Napisal/-a ThARippA To dec 07, 2004 10:38 pm
Novi CRX če bo bo narejen na osnovi civica in bo prišel nekje 2006.
INFINITI
Prispevkov: 7259
Napisal/-a INFINITI To dec 07, 2004 10:43 pm
don CONSIGLIO je napisal/-a:Načeloma jebla Honda S2000 ob svoji predstavitvi označena za naslednico CRXa. Ne bi rekel, da ima Honda res kakšen namen delati še en tako športen avtomobil...
LP,
don CONSIGLIO
Mislim da ne ravno Honda S ima zgodovino bolj konkretno je naslednik S800
Bi pa bilo super če bi honda poštekala da si mlad folk želi novo verzijo CRX, nekaj izredno lahkega in izredno navitega za pol manj denarja od S2000, to bi bila prodajna uspešnica
mistervegas
Prispevkov: 863
Kraj: Ptuj, okolica
Napisal/-a mistervegas Sr mar 23, 2005 7:15 pm
jutri v novem AutoBild je nekaj o CRX objavleno
link: http://www.autobild.de/aktuell/neuheite ... 289a0ab35c
spodi piše " Der CRX kommt wieder "
bo ju3 menda kaki scan če bo kaj pametnega
INFINITI
Prispevkov: 7259
Napisal/-a INFINITI Sr mar 23, 2005 7:19 pm
mistervegas je napisal/-a:jutri v novem AutoBild je nekaj o CRX objavleno
Pol bo pa spet neka risbica in ugibanja, no ja pustimo se presenetiti
mistervegas
Prispevkov: 863
Kraj: Ptuj, okolica
Napisal/-a mistervegas Sr mar 23, 2005 7:43 pm
INFINITI je napisal/-a:
ja saj, autobild nic bojsega nebo naredo si mislm
prstko
Prispevkov: 443
Pridružen: Sr feb 23, 2005 6:55 pm
Napisal/-a prstko Če mar 24, 2005 8:44 am
honda crx more vn pridt nujno zato k to je najboljši avto. nvem kaj pr hondi misljo da že tok časa čakajo. no jst bi sam to reku da če so pamtni nej jo dajo vn!!
mistervegas
Prispevkov: 863
Kraj: Ptuj, okolica
Napisal/-a mistervegas Če mar 24, 2005 10:51 pm
to piše pa ena mala slikica
"friseusen-ferrari, sekretärinnen-porsche - der crx hatte böse namen, aber viele fans. wieviele, spürte honda erst, als das kliene coupe 1999 ersatzlos auslief. nun kommt der crx zurück, da honda sich wieder seiner sportlichen wurzeln besinnt. und die könnten aussehen wie diese zeichnung auf basis des nächsten civic. tatsächlich befeuern den zweisitzer, der 2007 auf den markt kommen wird, die beziner des civic bis zum r-type motor mit über 200 ps. da redet niemand mehr von friseusen..."
quelle autobild 12/05
ThaRippa je imel prav :)
Zadnjič spremenil mistervegas, dne Če mar 24, 2005 10:54 pm, skupaj popravljeno 1 krat.
Forsythe
Prispevkov: 98
Pridružen: So okt 12, 2002 9:34 pm
Napisal/-a Forsythe Če mar 24, 2005 10:54 pm
Zaenkrat se še o novem CRXu nic ne govori in so vse skupaj ugibanja. Dvomim pa da bo prisel ven novi CRX...
mistervegas
Prispevkov: 863
Kraj: Ptuj, okolica
Napisal/-a mistervegas Če mar 24, 2005 10:56 pm
Forsythe je napisal/-a:Zaenkrat se še o novem CRXu nic ne govori in so vse skupaj ugibanja. Dvomim pa da bo prisel ven novi CRX...
žal bo prišel na osnovi novega civica in to ca 2007, njammy Type R 200km+ na pod 1000KG.
crx čakam te
mistervegas
Prispevkov: 863
Kraj: Ptuj, okolica
Napisal/-a mistervegas Če mar 24, 2005 10:57 pm
kar duplo
prstko
Prispevkov: 443
Napisal/-a prstko So apr 16, 2005 12:58 pm
Comeback CRX
Michele Lupini - Cars in Action
Posted Tue, 08 Jun 2004
Honda is set to unleash an all-new Civic range around 2006, and to the delight of V-TEC fundis, Honda is planning to revive the CRX nameplate for a sporty three-door hatch flagship.
As a successor to today�s Type R, a model we�re still patiently waiting for, CRX will be a real pocket rocket with in excess of 150kW on tap from a new V-TEC motor.
mojster
Prispevkov: 946
Pridružen: Ne jul 25, 2004 11:16 am
Napisal/-a mojster So apr 16, 2005 2:40 pm
ne bo več podobna del-sol :(
Doc_
Prispevkov: 1783
Kraj: Nekje na Primorskem
Napisal/-a Doc_ So apr 16, 2005 3:45 pm
Ja sam ni slaba :D sam sm pričakavu dvosed... to pa nevem kaj je
