INFINITI
Prispevkov: 7259
Nova generacija QUATTRO sistema
Napisal/-a INFINITI Sr mar 02, 2005 6:52 pm
TUCSON, AZ – Audi AG unveiled in Germany this week a new-generation version of its landmark quattro all-wheel-drive system engineered to impart Audi’s AWD vehicles with handling that more closely replicates that of rear-wheel-drive vehicles.
New quattro system launches with high-performance Audi RS4 in Europe.
The new quattro system – launching with the high-performance RS4 sport sedan in Europe – under normal driving conditions “biases” 60% of drive torque to the rear axle and 40% to the front. Since quattro’s inception in 1980, Audi maintained a balanced 50/50 front/rear default torque distribution that it said imparted a high level of security and dynamic stability.
But the traditional 50/50 torque split also imparts quattro-equipped Audis with an inherent and safe understeering handling character that long has been judged dynamically inferior to vehicles – primarily luxury sport sedans – whose rear wheels do 100% of the driving.
Audi engineers, anxious to achieve dynamic parity with its RWD Mercedes and BMW (and now Lexus, Infiniti and Cadillac) rivals, have reengineered the quattro system to send 60% of engine power to the rear wheels, which they say is enough to deliver RWD-like handling while retaining the stable chassis dynamics and all-weather traction ability that were quattro’s original reason for being.
Audi hallmark Torsen center differential reconfigured for rear torque bias.
And although the new quattro system debuts for the European RS4 that will not reach North America until 2006, Audi officials here for the launch of the redesigned A4 say U.S. buyers nonetheless will be some of the first to get a taste of the new, rear-biased quattro drivetrain: The ’05 Audi S4, due to hit the U.S. in April, also will be fitted with the new-generation quattro system.
Marc Trahan, Audi of America Inc. director-product management and quality, tells Ward’s the ’05 S4, a 340-hp, 4.2L V-8 equipped variant of the A4 that is a rung lower than the 420-hp RS4, will be the only U.S.-specification Audi to boast the new-generation quattro system until mid-2006, when all ’07 quattro-equipped Audis will be fitted with the new rear-biased architecture.
“The rear-bias (quattro system) fits well into our new, sporty direction (for the Audi brand),” Ulrich Hackenberg, head of concept development and body engineering for Audi AG, tells Ward’s here.
The new quattro system, though changing to the new 40/60 front/rear fixed torque bias for normal dry-road driving, still will retain the quattro design’s primary feature: the ability to apportion the optimum amount of torque between the front and rear axles when wheels lose traction.
The ability to apportion a variable amount of drive torque to either axle in reduced-traction conditions is enabled by the Torsen-design center differential, which has been the heart of the all-mechanical quattro system since Audi adopted the technology in 1987.
http://subscribers.wardsauto.com/micros ... 022505.gif
http://subscribers.wardsauto.com/micros ... ial_05.gif
De_Tomaso
Prispevkov: 963
Pridružen: Pe mar 12, 2004 1:02 am
Napisal/-a De_Tomaso Sr mar 02, 2005 7:35 pm
Kdo je že to naredil pred audijem :lol: :lol: :lol:
Torsen C pa kakšna Q4 oznaka na zadku. 8)
BTW: Zdaj ko je Audi kopiral sistem, so k sreči nekje to že pokapirali in sedaj ponujajo v svojih avtomobilih enak pogon s to razliko, da ima tudi na zadnji osi samozaporni diferencila Torsen. Spodobilo bi se da bi pri 420Ps tudi pri Audiju pomislili na to. 8)
Vprašanje podnebnih sprememb zaradi naše potrošnje ni vprašanje stroškov, ampak vprašanje naše morale.
andrej777
Prispevkov: 2102
Kraj: Telče (Sevnica)
Napisal/-a andrej777 Sr mar 02, 2005 8:41 pm
Podobno parazdelitev moči ima tudi BMW xi in X-drive. So že vedl zakaj je bolš dat več moči na zadnja kolesa. :lol: :lol: :lol: tako de nebi preveč razpravljal o sistemu quatro in kolk je bolši od konkurence. Je pa to sigurno zelo pametna poteza.
Slide
Prispevkov: 4349
Napisal/-a Slide Sr mar 02, 2005 9:11 pm
Vsak pogone je dober za nekaj...ne začnite se spet kregat, alfin je boljši bmw-jev je boljši, vsak ima prednosti in slabosti, vsak ima svoje meje. ČE gledaš tko potem je wrangler rubicon in njegov 4x4 boljši od vseh teh treh skupaj...(sicer samo na terenu ampak...) važno da je boljši...da se sosedov franc lojzetu pohval da ma bemfa ali spačka in da ma boljši pogon, pa čeprav le v...kdo ve čem :roll: Ni to čist tko ne? ;) Nehite s provokativnimi primerjavami no...
De_Tomaso
Prispevkov: 963
Napisal/-a De_Tomaso Sr mar 02, 2005 10:10 pm
Nisem mislil primerjati, samo dopolnil sem temo s tem, da Audi ni naredil nekaj povsem novega. ;)
Slide
Prispevkov: 4349
Napisal/-a Slide Sr mar 02, 2005 10:12 pm
De_Tomaso je napisal/-a:Nisem mislil primerjati, samo dopolnil sem temo s tem, da Audi ni naredil nekaj povsem novega. ;)
To je pa vsekakor res...govoril sem splošno, ker kmalu bi se pa kdo najdu, ki bi trdil, da quattro pa sux, xdrajv ali pa 4motion pa rulz, zato ker pač prisega na znamko, pa niti približno ne ve kako deluje, ne to kaj je, v življenju pa še za volan ni prijel...ampak to ne leti ne nate ne na andreja...na splošno...
De_Tomaso
Prispevkov: 963
Napisal/-a De_Tomaso Sr mar 02, 2005 10:15 pm
Se posipam s pepelom, dostikrat žal tudi sam preveč zapadem v primerjave.
Vsekakor se zasluži, da dodam da menim, da je Quatro (in vsi sistemi s sredinskim Torsnom) vsekakor eden najboljših, če ne kar najboljši sistem 4X4 pogona. Seveda pa ni popoln, tako kot noben ni.
Tattoo-
Prispevkov: 1318
Kraj: Circuit de la Sarthe
Napisal/-a Tattoo- Sr mar 02, 2005 10:26 pm
