_VeNoM_
Prispevkov: 3086
Pridružen: To apr 29, 2003 11:30 pm
Kraj: Lj-Krško
Brabus: The World's Fastest Four-Door Coupe
Napisal/-a _VeNoM_ Po sep 12, 2005 6:40 pm
Specifikacije:
Engine
Type: V12, Twin-Turbo
Displacement cu in (cc): 380 (6233)
Power bhp (kW) at RPM: 730(537) / 5100
Torque lb-ft (Nm) at RPM: 974(1320) / 2100
Redline at RPM: n.a.
Brakes & Tires
Brakes F/R: ABS, vented disc/vented disc
Tires F-R: 255/35 ZR19 - 285/30 ZR19
Driveline: Rear Wheel Drive
Exterior Dimensions & Weight
Length × Width × Height in: n.a.
Weight lb (kg): n.a.
Performance
Acceleration 0-62 mph s: 4.0
Top Speed mph (km/h): 220 (350) - electronically limited
Fuel Economy EPA city/highway mpg (l/100 km): n.a.
The world's fastest four-door coupe comes from Brabus and celebrates its world premiere at the Frankfurt Motor Show IAA 2005 in Frankfurt. This automobile, built in small-series production based on the Mercedes CLS model series, is powered by a 730 bhp 6.3-liter twelve-cylinder twin-turbo engine, that was implanted with almost surgical precision into the engine bay of the four-door. The performance speaks for itself: 0 – 62 mph in 4.0 seconds, 0 – 125 mph in 10.5 seconds, 0 – 186 mph in 29.5 seconds are just as unique as is the electronically limited top speed of 350 km/h (220 mph).
At the heart of this new high-performance automobile lies the V12 twin-turbo engine from the SL 600. Brabus fits the engine with a special crankshaft, increases the cylinder bore and installs forged pistons, resulting in a displacement increase to 380 cu in. Further modifications include the optimization of the mixture flow in the intake and outlet manifolds of both cylinder heads as well as the installation of sport camshafts.
In addition the Brabus powerplant engineers equip the engine with custom-developed larger turbochargers, more efficient intercoolers and a stainless-steel high-performance exhaust system with low back pressure metal catalysts and four tailpipes. Newly programmed engine electronics coordinate all new components perfectly and contribute not only to maximum power yield but also to meeting all current legal emission limits.
After the engine conversion, now also available for all Mercedes-Benz 600 and 65 models with twin-turbo V12, the Brabus S V12 S Biturbo engine becomes the most powerful TÜV-tested engine from Germany. The engines puts out its maximum power of 730 bhp at 5,100 rpm. Peak torque is 973 lb-ft, limited electronically to 812 lb-ft, available from a low 2,100 rpm.
Power is transferred to the rear wheels via a modified five-speed automatic transmission and the Brabus locking differential.
Naturally it is essential that the unique performance the world's fastest four-door coupe is capable of can be safely controlled at all times. To do so Brabus has developed two special suspensions for the Rocket. The comfort version features air suspension with automatic ride leveling. The sport version comes with a height-adjustable coil-over suspension and gas-pressure shocks with six different settings for bound and rebound on front and rear axle.
Maximum size and state-of-the-art materials characterize the Brabus high-performance brake system of the Rocket. The front axle is fitted with vented ceramics discs in size 375 x 36 mm and 12-piston aluminum fixed calipers. The rear axle features steel discs in size 355 x 28 mm and 6-piston aluminum fixed calipers to round out the powerful and fade-resistant brake system.
The giant brakes and the enormous performance necessitate the use multi-piece Brabus Monoblock S light-alloy wheels with 19-inch diameter. The Brabus technology partners Pirelli and Yokohama provide the high-performance tires suitable for these highs speeds. The optimal tire/wheel combination for the Brabus Rocket are 8.5Jx19 wheels in front with 255/35 ZR19 tires and 10Jx19 with 285/30 ZR19 on the rear axle.
The Brabus designers custom-developed a front apron for the Rocket with large air inlets for optimal cooling of oil and water radiators. The shape of the front spoiler and of all other Brabus aerodynamic-enhancement parts was fine-tuned in the wind tunnel. Not only did Brabus succeed in reducing lift on the front axle, but also in optimizing aerodynamic drag.
The aerodynamic counterpart to the front spoiler in the rear is the Brabus rear spoiler lip which emphasizes the rounded design of the rear. But that's not all: In combination with the new front apron the spoiler lip reduces aerodynamic lift, thus further improving directional stability.
Integrated entrance lights are the dominant feature of the Brabus door sills and the Brabus rear apron. Pushing a button on the keyless-entry remote or pulling on a door handle activates five LED lights on each side and in the rear. They illuminate the ground behind and on either side of the vehicle to further improve user-friendliness.
The Brabus rear apron is the perfect backdrop for the four tailpipes of the Brabus high-performance exhaust system. Its integrated diffuser also contributes to the refined Brabus aerodynamics concept for the Rocket.
The interior of the Brabus Rocket also meets the highest expectations of the distinguishing customers of one of the world's most exclusive automobiles. Soft and breathable Brabus Mastik leather and Alcantara are part of the exclusive Brabus ambiance as is the ergonomically shaped Brabus sport steering wheel and the speedometer with 360-km/h scale.
rok46
Prispevkov: 2861
Napisal/-a rok46 Po sep 12, 2005 7:03 pm
damn you've been faster than me :oops: ampk tole je pa hudo,hudooooo :shock:
dj_em
Prispevkov: 2622
Napisal/-a dj_em Po sep 12, 2005 7:04 pm
ja kaj čmo mercedes vedno lepo preseneti :P
mel bi ga! 8)
Tomaz_
Prispevkov: 121
Pridružen: To sep 06, 2005 12:45 pm
Napisal/-a Tomaz_ Po sep 12, 2005 7:05 pm
se mi pa zdi da je 1001 Km bugati precej hitrejši
od 0-100 2,7 s
Tomaz_
Prispevkov: 121
Napisal/-a Tomaz_ Po sep 12, 2005 7:06 pm
Tomcatter
Prispevkov: 1236
Napisal/-a Tomcatter Po sep 12, 2005 7:09 pm
WOW :shock: :shock:
Sam mogu bi bit crn da bi se ujemu s feltnami
:P
kljukec
Prispevkov: 3380
Napisal/-a kljukec Po sep 12, 2005 7:14 pm
Tomaz_ je napisal/-a:se mi pa zdi da je 1001 Km bugati precej hitrejši
od 0-100 2,7 s
a ti morm prevest?
uglavnem strup od avta- za familijo vozt majka
sam glede na to da so v drugi temi (''MB slavospevu'') rekl da konji niso nič in da so taki avti brezveze ... - jst jim ne vrjamem - ta avto je za nekega poslovneža optimum
ha ha spet ga el. omejitev jebe- ''sam'' 350 gre lohka
Spyker
Prispevkov: 2297
Kraj: okolica Ljubljane
Napisal/-a Spyker Po sep 12, 2005 8:54 pm
Ja hitrost so na 350 km/h omejili verjetno zaradi varnosti, nad to hitrostjo se avto verjetno nebi več obnašal tako kot se bi moral... drugače je pa avto strup čeprav mene tele črne feltne na nobenem avtomobilu ne prepričajo :?
Med vožnjo če bi ga na hitro pogledal bi zgledalo kot da se vozi z železnimi črnimi feltnami :P
Če je ravno, ni zabavno.
Biskvitek
Prispevkov: 582
Pridružen: Ne apr 25, 2004 9:05 pm
Kraj: Grosuplje
Napisal/-a Biskvitek Po sep 12, 2005 8:59 pm
Fak, kaka zverina, najbolj so me impresioniral podatki do 200 pa do 300 km/h, sam kaj mora to delat menjalniku, čudn da ga tok navora ne zmelje.....
Lesane Parish Crooks
Prispevkov: 927
Napisal/-a Lesane Parish Crooks Po sep 12, 2005 9:05 pm
ekzotik erotik hudo :twisted:
M3
Prispevkov: 1931
Napisal/-a M3 Po sep 12, 2005 9:12 pm
ne črnih felten :cry: :cry: :cry:
dj_em
Prispevkov: 2622
Napisal/-a dj_em Po sep 12, 2005 9:27 pm
mal za predstavo krom feltne WTF :shock: :shock: :shock: :shock:
Spyker
Prispevkov: 2297
Napisal/-a Spyker Po sep 12, 2005 9:28 pm
DJ E.M. that's what i'm talkin about :tomidelej:
RoBBiE`
Prispevkov: 275
Pridružen: Pe feb 11, 2005 2:31 pm
Napisal/-a RoBBiE` Po sep 12, 2005 9:38 pm
ufffff to je to an :!: jest uglavnem ne rabm bolsi druzinski avto :D fuuuul lep,pa tem krom feltne so mi tud bol usec :shock:
don CONSIGLIO
Don med moderatorji
Prispevkov: 2232
Kraj: Nova Gorica
Napisal/-a don CONSIGLIO Po sep 12, 2005 10:16 pm
M3 je napisal/-a:ne črnih felten :cry: :cry: :cry:
Evo, točno na to sem pomislu. Po mojem bi mu ful pašale v pulver barvi. Avto je pa itak zakon ;)
LP,
don CONSIGLIO
AuDi_
Prispevkov: 323
Kraj: Novo mesto /Mb
Napisal/-a AuDi_ To sep 13, 2005 10:36 am
:shock: hudoo, ful lep, še lepši pa z krom feltnami :)
danes brez podpisa
swifthead
Prispevkov: 335
Pridružen: Po sep 20, 2004 4:39 pm
Napisal/-a swifthead To sep 13, 2005 2:26 pm
jjjjjjjjjjiiiiiiiiiihhhhhhhhhhhaaaaaaaaaaa, dost mam zdj ga bom pa resnično zdrkal, faaaaakkkk teli Nemci so res norci (samo Švabi, d nau pomote ne Bavarci)!!!!!!
tole je kot bi rekl Amerikanci če bi tak avto mel ˝ KING OF THE HIGHWAY ˝ k res z tem navorom je vseen če pospešuješ od 100 al pa od 200, prbije te na zic (pa še 3 sopotnike) pa greste čez 300 pa se smejite Enzotu k nima blokirane končne!!!!
blokirana je pa zato (ne da avto pr višjih hitrostih nebi mel obnašanja) ker ni gum na svetu ki bi vozilo te teže pri tej hitrosti še vzdržale da jih neb razgnal!!!!
Spyker
Prispevkov: 2297
Napisal/-a Spyker To sep 13, 2005 3:23 pm
swifthead je napisal/-a:blokirana je pa zato (ne da avto pr višjih hitrostih nebi mel obnašanja) ker ni gum na svetu ki bi vozilo te teže pri tej hitrosti še vzdržale da jih neb razgnal!!!!
Kako potemtakem Veyron zdrži hitrost nad 400 km/h? Pa ima 2 tone kar ni tako malo.
Pa zakaj se moraš vedno v vsakem postu obnašat kot totalno navdušen 10-leten otrok ki je prvič videl en avto ki je (resnici na ljubo) DOBER avto :?:
YOC
Prispevkov: 887
Pridružen: Pe feb 14, 2003 10:53 am
Kraj: Spredi levo (LJ)
Napisal/-a YOC To sep 13, 2005 3:31 pm
Ful lepo dodelana notranjost samo zanima me kako se sproži sovoznikov airbag, ne da bi ti prletu karbon v ksiht :?
Bolje 10 konjev premalo pod haubo, kot en osel preveč za volanom!!!
WWWWRRRRRRRRUUUUUUUMMMMMMMMM..........
kljukec
Prispevkov: 3380
Napisal/-a kljukec To sep 13, 2005 3:42 pm
Spyker je napisal/-a:
sej tud zarad gum se je projekt veyron zavlekel- ma posebne gume prov za njega
