McLaren
Prispevkov: 3434
Kraj: Cela EU
2007 Cadillac Escalade
Napisal/-a McLaren Pe nov 11, 2005 3:28 pm
Superior craftsmanship and refinement permeate the all-new Escalade. In areas that can be seen and touched, as well as those that cannot, an unprecedented amount of engineering and design resources were devoted to developing cohesive, segment-leading levels of quality, quietness and attention to detail.
Tighter tolerances and higher quality materials provide visual and tactile examples of the vehicle’s craftsmanship, while a firmer, more robust chassis enables class-leading smoothness and quietness. In short, every aspect of Escalade’s performance – whether under the hood or inside the passenger compartment – is designed to reflect a new standard of Cadillac craftsmanship.
Exterior craftsmanship
Escalade has one-piece, body-color front and rear fascias that wrap around into the fenders, creating a sleeker, more integrated appearance. Chrome accents enhance the luxury appearance of the Escalade while adding distinction and exemplifying the vehicle’s attention to detail.
The fascias cover the bumper beams, eliminating the conventional SUV look of a bumper separated from other body components. This seamless design enables improved tolerances between components, such as the fascia and fenders. Hood-to-fender gaps also are reduced, as are the gaps surrounding the headlamps and grille components. While contributing to the Escalade’s more refined appearance, the tighter tolerances also enhance aerodynamics, which optimize fuel economy and reduce wind noise.
From the side, Escalade has a more integrated appearance . The doors extend down and wrap over the rockers for a cleaner, “one-piece” appearance, and the rearview mirrors are styled for improved aerodynamics and reduced wind noise. New grab-style door handles are designed to stand off from the edge of the vehicle and offer easier, refined actuation. Door closing is effortless and quiet, sealing with a reassuring sound that reinforces Cadillac’s quality reputation.
Standard running boards are integrated with the exterior design themes, and optional power articulating running boards (available later in the model year) automatically extend when the doors are opened. When not in use, the boards retract inward, giving the vehicle a sleeker, more refined appearance.
At the rear of the Escalade, gaps are reduced around the liftgate and fascia, creating a refined and precise appearance. The liftgate-to-quarter panel and liftgate-to-taillamp tolerances have also been reduced with a new, one-piece door ring – or “D-ring.” The quarter panels, underbody and roof are all welded to the D-ring, providing more precise fits and a stronger rear body. Also, the standard towing package receiver hitch features an Escalade-exclusive integrated hitch cover that is easily removable, but offers a smoother appearance when in place.
Interior refinement
The 2007 Escalade has an interior environment all its own. It benefits from the close attention to detail designed and engineered into every facet of the cabin and is highlighted by flush surfaces and tight tolerances on the instrument panel, center stack, clusters and other components.
Most gaps on the instrument panel and cluster have been narrowed to 0.5 mm or less. Some gaps have been totally eliminated. Flush-mounted accessories and controls, such as the climate control/radio center stack, create a seamless, more finished appearance – appearing as a single unit rather than components stacked together. Similar attention was given to concealing fasteners and metal structural components of all folding seats. New seat “close-outs” provide a more finished, crafted appearance to the seats when they are in a folded or tumbled-forward position. The seat tracks also are concealed with covers.
Large aluminum door sill plates greet occupants when they enter Escalade. The sill plates are longer and wider than previous models, providing more complete coverage of the sill area and a more finished appearance.
Both the Cocoa-on-Cashmere and Ebony-on-Ebony interior color schemes dramatically enhance the appearance and aura of the new Escalade’s interiors. The upscale styling is complemented by premium materials like brushed aluminum, wood and cast skin trim that are soft to the touch and have low-gloss finishes. Escalade’s instrument panel, upper door trim and armrests are covered and wrapped in a soft foam-backed cast skin covering that is durable and rich looking, while providing a luxurious, high-quality feel.
Also, the color and grain of materials were carefully selected to provide a premium look. Upscale details also include LED backlighting for instrumentation and chrome accents on gauges and vents. The comprehensive result of these elements is a rich, harmonious appearance throughout the interior. Escalade’s refinement also is evidenced in the operation of items such as glove box and center console lid doors, which are spring-damped. The center console’s cupholders are hidden, too, providing a cleaner interior appearance until they’re needed.
Mick Jerry
Prispevkov: 1259
Kraj: okolica Lj.
Napisal/-a Mick Jerry Pe nov 11, 2005 3:40 pm
Velik požrešen avto.Je pa res da ima "pimpish" serijske krom feltne(yeah). :roll:
Je pa tudi res da ima ogromne koloteke, tako da bodo lahko west customs, 50 Cent and Co. brez problem gor nataknil 26 colke kot na hummerja.No vsaj neki a ne?
A je sploh kej drastično drugačen od zdajšnega?Jst ne vidm kake hude razlike razen v lučeh in maski.
McLaren
Prispevkov: 3434
Kraj: Cela EU
Napisal/-a McLaren Pe nov 11, 2005 3:41 pm
Vglavnem.....meni je všeč vse na njem. Od notranjosti do zunanjosti. Popoln avto za moj okus.
Like the american way of thinking :D
Napisal/-a esem Pe nov 11, 2005 10:19 pm
niti ene slike ne vidim (drugje pa - torej niso moje nastavitve)
PuBBeC
Prispevkov: 466
Pridružen: Ne mar 13, 2005 1:57 pm
Napisal/-a PuBBeC Pe nov 11, 2005 10:38 pm
ja vidim ja da nekaj šteka :P
drugače pa klikni z desnim na tisto ikono pa klikni pokaži sliko!
če nebo delovalo pa pripnem sliko za lažjo predstavo!
PureTNT
Prispevkov: 814
Pridružen: Pe dec 10, 2004 10:36 pm
Napisal/-a PureTNT Pe nov 11, 2005 10:48 pm
Najboljša stvar pri tem vozilu (lepota sarkazma) je, da pri normalni vožnji porabi več goriva kot 700-konjski 911 Turbo pri polnem plinu (se preverjeno ne šalim). Da ne omenjam, da te na cilj ravno tako pripelje tudi kak Golf, pa ne dosti manj udobno. Ta avtomobil je le skrajni izraz izprijene ameriške mentalitete, ki se je pojavila v zadnjem desetletju. Na evropske ceste ne spada, še manj pa v naša mesta, ki takšnim mamutom niso namenjena.
Templar
Prispevkov: 1800
Kraj: Savinjska regija
Napisal/-a Templar Pe nov 11, 2005 11:50 pm
PureTNT je napisal/-a:Najboljša stvar pri tem vozilu (lepota sarkazma) je, da pri normalni vožnji porabi več goriva kot 700-konjski 911 Turbo pri polnem plinu (se preverjeno ne šalim). Da ne omenjam, da te na cilj ravno tako pripelje tudi kak Golf, pa ne dosti manj udobno. Ta avtomobil je le skrajni izraz izprijene ameriške mentalitete, ki se je pojavila v zadnjem desetletju. Na evropske ceste ne spada, še manj pa v naša mesta, ki takšnim mamutom niso namenjena.
Pozabil si še da ni nič drugega kot tovornjak s krom feltnami. Za razliko od ostalih SUV pa je na terenu bolj zbegan kot 5 let star otrok ki je ravno zalotil starša pri opravljanju zakonskih dolžnosti.
To je pimp mobil in nič drugega. Aja ta npva verzija je še grša od prejšnje!
Po forumu brska: luxxx7 in 36 gostov
