drugmirko
Prispevkov: 2762
Citroen C-Metisse dizelski hibrid
Napisal/-a drugmirko Ne sep 03, 2006 5:51 pm
An International Motor Show in Paris without a futuristic concept from Citroen is like having a romantic dinner for two without a bottle of Chardonnay. Beside it's all new medium sized MPV C4 Picasso Citroen will also present at the Paris Show the C-Metisse Concept: a stunning GT with 4 gullwing type doors that looks like it came straight back from the future.
But this futuristic sport GT isn't just about style as Citroen has given it a hybrid powertrain that consists of PSA Group's 205 Hp 3.0 V6 HDi diesel engine and two electric motors. This is not the first time that Citroen has been playing around with diesel-hybrids as a few months ago the French carmaker unveiled the C4 Hybrid HDi.
živeo drugmirkooooo!!!!
Napisal/-a Lignage Ne sep 03, 2006 6:41 pm
:shock:
Tole pa jemlje sapo...
Kje so še slike :?: :!:
lp, mm
Napisal/-a dobek Ne sep 03, 2006 7:23 pm
Lignage je napisal/-a:Kje so še slike :?: :!:
ni, ni..noben press kit se ni omenil tega cuda :shock:
Napisal/-a esem Ne sep 03, 2006 8:17 pm
naj nekdo popravi naslov - Citroem .
Dr. Mirko, je Metisse ali Matisse?
Napisal/-a Joie de vivre! Ne sep 03, 2006 8:29 pm
Napoveduje to C5??
Drugače pa, kako bo z imeni pri novi generaciji? Upam, da ne bomo doživeli NEMŠKEGA sistema in da bo odslej C3 II, C3 III itd... Tega pri Citroënu nikoli v zgodovini ni bilo, prvi temačni kazalec je Jumper II...
Super zanimiva bi bila imena C-Airdream, C-Airplay, C-...
drugmirko
Prispevkov: 2762
Napisal/-a drugmirko Ne sep 03, 2006 10:15 pm
esem je napisal/-a:naj nekdo popravi naslov - Citroem .
eh... hvala dobrotljivemu lektorju za popravo zatipkanega imena... :oops: drugač pa je definitivno Metisse. no, vsej prodaja se po netu s tem imenom, zasigurno bomo pa visli ob objavi uradnih slikic.
kaj napoveduje je pa teško reč, ker smo v zadnjih par letih vidli že vsej tri al pa štiri različne dizajne sprednjega konca na Citroenovih konceptih! in za čist vsakega od C-Airlongea pa do C-Sportloungea... al pa tega gor je škoda, da ni al pa še ni v proizvodnji!
kar se pa imen tiče, meni za zdej paše C klasifikacija... je jasna in enostavna pa še lep poklon njihovi bogati zgodovini je istočasno! koncepti majo pa itak imena kot spada! nezamnljiva s čimerkoli in rahlo nedosegljivega zvena... kot se za koncept spodobi...
Napisal/-a Lignage Sr sep 06, 2006 1:46 pm
Besedilo:
Citroen bo v Parizu predstavil kupe za tri potnike. Na krovu je obilica tehnike, med drugim šestvaljni dizel in dva elektromotorja.
V konceptu je Citroenu uspelo zajeti vse, od prestiža, udobja in športnosti. Prednji del je zelo agresiven, medtem ko zadek deluje umirjeno, prav plemenito, streha pa se vanj spusti zelo nizko. Impresivna so tudi dvižna vrata, ki se dvignejo navzgor in naprej nad prednje steklo. Svetlobni snop na prednjem delu se vzpenja od motornega pokrova pa vse do spodnjega dela odbijača in je zapolnjena z LED diodami.
Kot je pri Citroenovih konceptih že navada, je aerodinamika izpopolnjena do potankosti. Količnik zračnega upora c znaša samo 0,30.
C-Metisse v dolžino meri 4,74 metra, širok je 2 metra in visok borih 1,24 metra. Medosna razdalja meri kar tri metre in prinaša veliko prostornost.
V notranjosti je prostora za tri potnike, vsak ima svoj sedež z lastnim klimatskim sistemom. Volan ima fiksni center, kot ga poznamo pri C4 in je seveda nabasan s funkcijami, od upravljanja računalnika, avdia pa do prestavnih lopatk za njim. Za zagon avta skrbi start-stop gumb, ki je nameščen na strop vozila.
Prava poslastica je pogon. Zadnji kolesni par poganja V6 HDi z 208 KM ob pomoči dveh elektromotorjev, nameščenih v kolesih, vsak od njiju zmore 20 KM in kar 400 Nm navora.
Avto za 100 km/h z mesta potrebuje samo 6,2 sekunde, dinamika med 80 in 120 km/h pa je impresivnih 4,2 sekunde. Hibrid naj bi porabil samo 6,5 litra na 100 prevoženih kilometrov.
In še ena slika:
lp, mm
Napisal/-a dobek Sr sep 06, 2006 3:09 pm
evo, se malo za slinit
AgitatoR
Prispevkov: 4443
Kraj: Rbn 104
Napisal/-a AgitatoR Sr sep 06, 2006 3:37 pm
Dvočrkovne oznake so bile najboljše.
Tomcatter
Prispevkov: 1236
Napisal/-a Tomcatter Sr sep 06, 2006 5:26 pm
Sam to mi je pa že smešn mal. Na prvi sliki je bil izredno lep, zgledu kot en PS, sploh nisem verjeu da bi kej tazga obstajal, od tm naprej pa mi je ful grd.
Dizel hibrid pa je dobra ideja
drugmirko
Prispevkov: 2762
Napisal/-a drugmirko Sr sep 06, 2006 7:19 pm
Napisal/-a esem So sep 16, 2006 11:29 pm
4-minutni video (dober sneg so si naredili)
http://www.infomotori.co.uk/a_12_EN_17951_1.html
dulle_
Prispevkov: 6
Pridružen: Sr okt 04, 2006 10:21 am
Kraj: prlekija
Napisal/-a dulle_ Sr nov 29, 2006 11:00 am
Pa se predstavitev v nemscini:
C-metisse
