Mitsuoka: Orochi, Galue 204 etc
Napisal/-a esem Sr okt 04, 2006 12:32 am
Še en Mitsu - tokrat Mitsuoka.
Orochi (osemglava kača iz japonske folklore - zato tudi Kabuki na predstavitvi!) je sedaj dokončan in predstavljen v produkcijski verziji. Koncept je bil zunaj že davnega 2001, avto je sicer ekskluziven (v naslednjih 4 letih jih bodo naredili 400) in eksotičen po dizajnu, ni pa superšportnik, kar je sicer sedaj že kar navada.
Carview je napisal/-a:The 3.3L V6 mounted aft of the passenger compartment is Toyota's well-known 3MZ-FE, which sees duty in the Camry, Solara, Sienna, Highlander, and Lexus RX (hybrid and standard versions). It makes around 230 horsepower and is connected to a Toyota 5-speed automatic. The decision was made to place efficiency and ease of use ahead of high performance.
Speaking of performance, no numbers were released along with the technical specifications, but don't expect anything earth-shattering. The car's average power, combined with a weight of approximately 3,400 pounds (around 100 less than a Solara), is not a recipe for big-time track numbers. In Japan, though, exclusivity seems to trump all, and that's a commodity the Orichi has in abundance. So what if it has just 230 horsepower? In Japan, arriving anywhere in one of these will bestow instant superstar status upon the driver.
400 Orochis will be built over the next four years, each costing ¥10,500,000 (around $89,000 USD). Orders can be placed beginning today with the first deliveries taking place in January 2007.
[Source: Carview (translated)]
nekaj iz njihove zgodovine (sori, ker ne razumem japanski lenguić)
Še osnovni tehnični podatki
Technical Specifications:
Total length / Width / Total height = 4560mm / 2035mm / 1180mm
Wheelbase: 2600mm
Ground Clearance: 130mm
Vehicle weight: 1580kg
Passengers: 2
Engine: 3.3L V6DOHC (Toyota 3MZ-FE)
Max output: 233ps (172kW) at 5600rpm
Max torque: 33.4kg-m (328Nm) at 4400rpm
Fuel capacity: 60 liters (unleaded premium)
Transmission: 5-speed AT (Toyota)
Drive system: Mid-engine/rear drive
Suspension: front and rear double wishbone
Tires: Front: 245/45ZR18, Rear: 285/40ZR18
Body: hand made FRP make body
Door: side impact door with built-in steel beams
Chassis: handmade steel space frame
Equipment:
Low-beam side HID, motorized door mirror, airbags, automatic A/C, the Panasonic HDD Navigation, power windows, immobilizer, and full leather interior all standard
tako je zgledal koncept 2001
tako pa je zgledal koncept 2005
za resne dodajam še (free!??) telefon
* [orochi] private free dial 0120-676-244
* [orochi] private home page www.mitsuoka-orochi.com/
Zadnjič spremenil esem, dne Sr feb 06, 2008 3:19 am, skupaj popravljeno 1 krat.
ThugBoy
Prispevkov: 534
Pridružen: To feb 24, 2004 10:18 pm
Kraj: Morje
Napisal/-a ThugBoy Sr okt 04, 2006 5:56 am
ma men je spredi ful hecn, zgleda ko da se smeje :D
Even When They Kill Me They Can't Never Take A Game From Young G
zupi13
Prispevkov: 3297
Kraj: CE
Napisal/-a zupi13 Sr okt 04, 2006 7:17 am
ThugBoy je napisal/-a:ma men je spredi ful hecn, zgleda ko da se smeje :D
saj bi ga verjetn sam od uzadi za trenutek vidu..... :P
zanimivi karoserijski detajli. kot bi bil kak morski pes z bojnimi ranami...
sandek
Prispevkov: 1043
Kraj: maribor-metropola
Napisal/-a sandek Sr okt 04, 2006 8:44 am
japonski slr :bow :bow
TUNING_BOY
Prispevkov: 1440
Napisal/-a TUNING_BOY Sr okt 04, 2006 8:56 am
Men zgledaker fajn! Ni tak da bi zgledal kov vsi ostali, ki so si skoraj podobni! ;)
__+__ 2FAST 4YOU__+__
Prispevkov: 11405
Napisal/-a martin_krpan Pe okt 06, 2006 6:55 pm
89.000 USD za avto z 230 KM.
:roll: :ue :nae
INFINITI
Prispevkov: 7259
Napisal/-a INFINITI Pe okt 06, 2006 10:08 pm
Mitsuoka: naredi HARAKIRI in nehaj sramotit japonsko avtomobilsko industrijo!!! You ugly f*** ;)
Bel-Tirid
Prispevkov: 1547
Pridružen: Po feb 09, 2004 7:52 pm
Kraj: Bled
Napisal/-a Bel-Tirid Ne okt 08, 2006 2:33 pm
:D
sploh neveš kaj bi lohk napisov
men je bedn
Slika Slika
tha_man
Prispevkov: 1008
Napisal/-a tha_man Ne okt 08, 2006 3:39 pm
Spredaj zgleda kot sploščena multipla :vc
Coleman
Prispevkov: 282
Pridružen: So jun 12, 2004 3:42 pm
Napisal/-a Coleman Ne okt 08, 2006 3:52 pm
To je neka mešanica med CLR MERDO(luči), avto ob strani podoben Saleen S7, odzadi je kot Ferrari Enzo, sprednja maska je pa podobna mogoče Maseratiju :D
When size equals knowledge I'll be a one big muthafucka!
dunker
Prispevkov: 560
Pridružen: To apr 27, 2004 12:54 pm
Napisal/-a dunker Ne okt 08, 2006 3:53 pm
Tud men je grd. :D Pa odločno pretežak za svojo podhranjeno konjušnico ... :D
Za primer: Brera ima nekako podobno razmerje med močjo in težo, pa baje ni nič kaj poskočna ... ampak za razliko od tele spake je vsaj prelepa na pogled in mnogo cenejša. ;)
eentox
Prispevkov: 1374
Napisal/-a eentox Ne okt 08, 2006 3:56 pm
Poleg Multiple najgrši avto kar sem jih videl :P
Napisal/-a esem Ne okt 08, 2006 4:53 pm
Saj avto ni namenjen evropskemu trgu.
Ekskluzivnost prinaša tudi visoko ceno (in obratno), motor ni nikoli bil nujen za ekskluzivnost (čeprav lahko temu močno pripomore). Tisti, ki hoče dirkat, ga bo pač stunal, pa je. Za kaj takega je vsekakor dobra osnova.
Mislim, da je za japonski trg dizajn nekaterim zelo posrečen - gotovo je tam dosti takih, ki jim ni všeč kot tudi dosti takih, ki jim je zelo všeč - po moje več kot prvih. To se lahko sklepa že po tem, da je proizvodni avto praktično nespremenjen glede na koncept pred petimi leti, kar kaže, da so ga fani tam odlično sprejeli in ga torej želijo takega, kot je. Morda bi se debata iz povdarjanja, kako grd je, raje razvila v primerjavo različnosti okusov.
Če pa je kje na forumu kdo, ki obvlada japonsko, naj prosim malo prečekira odziv na njihovih forumih in nam to v par besedah posreduje, če se mu da. Hvala
tha_man
Prispevkov: 1008
Napisal/-a tha_man Ne okt 08, 2006 8:22 pm
Meni sicer ni grd, po svoje je simpatičen, tako kot Multipla. Problem je le, da simpatičnost ni ravno vrlina, ki jo iščem pri športnih avtih :roll:
Ekskluziven bo definitivno, in poglede bo tudi privabljal. Če bodo to pogledi občudovanja, al bo povzročil salve smeha, je pa odvisno od publike.
kljukec
Prispevkov: 3380
Napisal/-a kljukec Ne okt 08, 2006 8:57 pm
kakšne pa ma tale stvor pospeške pa končno?
gor pr karakteristikah ni al sm pa spregledal :oops:
Napisal/-a esem Če dec 07, 2006 1:53 pm
Avto dobiva nagrade na Japonskem - toliko o različnosti okusov itd
Sicer pa delajo predvsem priredbe (še prej pa replike) klasičnih angleških avtov, kot npr.:
Če hoče kdo pogledat ostale modele iz prodajne palete, jih najde tu:
http://www.mitsuoka-motor.com/english/lineup/index.html
Zdaj so začeli prodajati K-4 - mini mestni avto (2,5 X 1,3 m) z Nissanovim zračno hlajenim 50 ccm motorjem, ki rabi 3 l /100 km. Avto ima avt. sekv. menjalnik, gre 50 km/h tehta 180 kg in stane na Japonskem skoraj naših 5000 eu. Seveda, če ga kupite v paketu (z natančnimi navodili) in ga v treh dneh sestavite. Avto je tudi prestal japonske varnostne teste (verjetno prilagojene velikosti?),
Prispevkov: 11405
Napisal/-a martin_krpan Če apr 12, 2007 6:03 pm
Najnovejši model tovarne - Galue Convertible tokrat ne temelji na Japoncih, ampak na... mislim, da fotografije povejo dovolj ;)
http://www.mitsuoka-motor.com/lineup/ga ... index.html
INFINITI
Prispevkov: 7259
Napisal/-a INFINITI Če apr 12, 2007 6:16 pm
Hehe a to so mustanga sunl al kaj - ojej kake gljive ludare jejo njihovi dizajnerji :lol:
Jorgi
Prispevkov: 1934
Kraj: zabji raj
Napisal/-a Jorgi Če apr 12, 2007 6:18 pm
Kva pa je to za en spak ... Slika
menjekul
Prispevkov: 2635
Pridružen: Sr jan 01, 2003 8:14 pm
Napisal/-a menjekul Če apr 12, 2007 8:17 pm
zgleda, da ima tudi japonska svojega "TVR"-a ... "poseben" za "poznavalce in ljubitelje" :lol:
sprednji del tega belega (ob katerem stoji ona maškara) spominja na morskega psa kladivarja :D
