Prispevkov: 11405
2009 Toyota Matrix in Pontiac Vibe (ZDA)
Napisal/-a martin_krpan Če nov 01, 2007 11:43 am
Toyota je na letošnji SEMI predstavila dve ameriški premieri. Prva je nova Toyota Corolla limuzina, ki je, razen malenkosti, identična evropski. Druga pa je povsem novi Matrix.
Matrix I je bil predstavljen leta 2003 in je bil na Corolli temelječ križanec med kombilimuzino in enoprostorcem. Razvit je bil v sodelovanju z GM, ki je prodajal tudi svojo verzijo (Pontiac Vibe). Novi Matrix je v bistvu ameriška verzija Aurisa. Poganjata ga 1,8 in 2,4 litrski motorja, dobi se v treh paketih opreme (Standard, S in XRS). Menjalnika sta petstopenjski ročni in štiristopenjski avtomatik, ob katerem lahko izbereš tudi AWD. Najbolj nestrpni kupci se bodo vanj lahko usedli v prvi polovici 2008.
Matrix S:
XRS:
Stari model:
po prenovi:
Toyota Unveils All-New Corolla Matrix At 2007 SEMA Show
October 31, 2007 – Las Vegas - Toyota Motor Sales (TMS), U.S.A., Inc., unveiled the all-new second-generation Corolla Matrix at a press conference today at the 2007 Specialty Equipment Market Association (SEMA) Show.
The Toyota Matrix, the sporty five-door vehicle that helped redefine the concept of a crossover utility vehicle, has been redesigned for the 2009 model year to offer performance that matters for driver enjoyment.
"The Matrix concept was based on blending the functionality of an SUV, the style, image and performance of a sports car with the affordability of a subcompact sedan," said Tim Morrison, Toyota Division corporate marketing manager. "For 2009, it's all that, and more. It may have the body of a five-door hatch, but it comes with the soul of a two-door sports car."
Development of the 2009 Matrix focused on greater exterior coupe-like styling with enhanced interior utility and improved dynamic performance. It was made wider with a lower stance than the current model while maintaining its interior space. The result is a sporty, dynamic shape that contains room for five people to ride in comfort. As a result of significant changes to the Matrix's profile, the theme is flowing and dynamic. The design expresses a low center of gravity, and coupe-like style with a fun-to-drive image. From the rear, the Matrix has rounded rear windows and continuous character lines that run from the front grille to the A-pillar.
Matrix will be available in three grades – Standard, S and the XRS. And Matrix will offer the option of all-wheel drive (AWD) with the S grade. The S and XRS models integrate a front underbody spoiler with a large mesh fog lamp bezel and rear underbody spoiler. A rear deck spoiler will be standard for all XRS models.
The Matrix interior is completely redesigned to enhance driving enjoyment, comfort and utility.
Seats have been redesigned to accommodate the vehicle's new lower profile while maintaining the expected high comfort levels, and seat positions were lowered slightly to maintain appropriate headroom. As a result, cabin space remains equal to that of the previous Matrix.
A new three-spoke steering wheel enhances the rest of the new Matrix interior. XRS models come standard with a leather-trimmed steering wheel that also includes spoke-mounted audio controls and hands-free Bluetooth® capability when equipped.
The driver and front passenger are treated to comfortable new sport seats, with seat-mounted side airbags. A fold-down seatback table will be available for the front passenger's seat, enhancing interior utility on S and XRS. A movable and removable cup support element for the front center console helps provide versatile storage area and convenience. The cup holder area can be used as a tray when the divider is removed.
For rear-seat passengers, expanded front-to-back couple distance helps to provide additional room and comfort. A folding seat with a 60/40 split includes a middle-seat headrest for the fifth passenger.
The Matrix is equipped with a new, high-efficiency air-conditioning system with larger vents for directional accuracy and offers reduced power consumption and improved heating and cooling.
The 2009 Matrix offers the choice of two different engines, a five-speed manual transmission, and either four- or five-speed automatic transmissions.
A 16-valve, 1.8-liter four-cylinder engine will produce 132 horsepower at 6,000 rpm and 128 lb.-ft. of torque at 4,400 rpm. The engine will feature Dual VVT-i (Variable Valve Timing with intelligence) on both the intake and exhaust camshafts that helps it achieve outstanding performance and economy.
Estimated EPA fuel economy ratings are 26/32 city/highway mpg for manual transmission models and 25/31 for the automatic transmission model powered by a 1.8-liter engine.
For those who crave just a bit more horsepower and torque, the Matrix offers a 16-valve DOHC 2.4-liter four-cylinder engine with VVT-i that will produce 158 horsepower at 6,000 rpm and 162 lb.-ft. of torque at 4,000 rpm.
Matrix models powered by the 2.4-liter engine with five-speed automatic transmission will have an estimated EPA fuel economy of 21/29 city/highway mpg.
The Matrix's base wheel is a 16-inch steel unit with a six-spoke full wheel cover. A distinctive 17-inch five-spoke aluminum wheel will be available for the S grade, and an 18-inch aluminum alloy wheel with a twin five-spoke design will come standard on the XRS grade.
Dual-stage SRS airbags will be standard for the driver and front passenger. Front seat-mounted side airbags, two-row side curtain airbags and front active headrests are also standard.
Brake performance will be improved with standard front and rear disc brakes on all Matrix grades. Anti-lock brakes (ABS) with Electronic Brake Distribution (EBD) are also standard. Vehicle Stability Control (VSC) with TRAC and off switch will be standard on XRS and available as an option on all other models. VSC automatically adjusts engine output and the vehicle's braking force at each wheel when the vehicle experiences a loss of traction during cornering.
Form, fun and functionality will be in abundance with an array of standard convenience features across all three grades. Base equipment on all Matrix models include power color-keyed outside rearview mirrors, power steering, tilt and telescopic steering wheel, daytime running lights, heavy duty rear window defogger, intermittent windshield wipers, 12-volt power outlet, four cupholders, auxiliary audio input jack, front center console box and an engine immobilizer.
The S grade adds standard power door locks and windows with one-touch down driver-side, 115-volt power outlet, cruise control, intermittent rear window wiper, fold-flat front passenger seat, remote keyless entry, AM/FM/CD with MP3 capability and six speakers, front and rear underbody spoilers and fog lamps.
In addition to these features, the XRS grade features standard P215/45 R18 tires on 18-inch alloy wheels, sport strut tower brace, VSC with TRAC and off switch, and a three-spoke leather-trimmed steering wheel with audio steering wheel controls.
In addition to the array of standard equipment, an impressive list of optional comfort and utility features are available to further enhance the Matrix driving experience. Available options will include an AM/FM/CD with six-speaker system with DVD navigation with XM NavTraffic® capability, alloy wheels, power heated outside rearview mirror, intermittent rear window wiper, cruise control, power door locks, power windows, and remote keyless entry.
The all-new Matrix will hit Toyota dealerships in February 2008.
2009 MATRIX PRELIMINARY SPECIFICATIONS
POWERTRAIN
132 hp @6,000 rpm
128 lb.-ft. of torque @ 4,400 rpm
Five-speed manual and Four-speed automatic transmissions
158 hp @ 6,000 rpm
162 lb.-ft. of torque @ 4,000 rpm
Five-speed manual and four and five-speed automatic transmissions
DIMENSIONS (inches)
Overall Length: 173.0 (S and XRS grades)
171.9 (Standard grade and S all-wheel-drive grade)
Overall Width: 69.5
Overall Height: 61.4 (XRS and S all-wheel-drive grades)
61.0 (Standard grade and S)
Wheelbase: 102.4
Ground clearance: 5.3 (S and XRS grades)
5.8 (Standard grade)
Zadnjič spremenil martin_krpan, dne Sr nov 07, 2007 7:13 am, skupaj popravljeno 1 krat.
Napisal/-a adis Če nov 01, 2007 1:08 pm
ker grd menjalnik pri s verziji :lol:
GregaST
Prispevkov: 418
Pridružen: Pe feb 09, 2007 3:55 pm
Kraj: Medvode
Napisal/-a GregaST Če nov 01, 2007 2:01 pm
Zadek spominja na novo imprezo wrx.
Eazy-O
Prispevkov: 1119
Napisal/-a Eazy-O Če nov 01, 2007 2:09 pm
Zdi se, da so se malce obračali na staro Toyoto Will VS. Pa ne vzemite tega dobesedno, ampak če bi sparili starega Matrixa in VS pa malo zategnili facelift... Dokaj logična poteza, glede na to da je bil VS kar popularen, pa so ga nehali delat. Čeprav, popularen je bil zaradi radikalnega dizajna za tiste čase (2001), kar pa se na Matrixu ravno ne kaže... Oh well...
Prispevkov: 11405
Napisal/-a martin_krpan Sr nov 07, 2007 7:13 am
Uradna predstavitev tudi GM-jevega klona - Pontiac Vibe.
Pontiac’s all-new Vibe small crossover has officially been released, with details and the previously promised high-resolution press shots. A variety of more powerful engine options, new interior and exterior design plus the return of the GT and AWD models give the new lineup some zing.
The base model comes standard with an increased-output 132hp 1.8L four-cylinder motor, but can be upgraded to the 2.4L 158hp motor that is standard on the GT and AWD models. A four-speed auto is also standard on AWD models, while the base and GT models can choose between a five-speed manual or an all-new five-speed electronically controlled automatic with Direct Shift Control (DSC).
Fuel economy is as good as you’d expect for a small car with a moderately powerful engine, with the 1.8L model providing 26/32mpg city/highway and the 2.4L engine yielding 21/28mpg city/highway when paired with the five-speed automatic. The four-speed automatic with AWD and 2.4L engine gives 20/26mpg city/highway.
Ride and handling have been improved to give a more responsive experience and chassis control systems have been employed as well. Suspension is standard econo-box fare with McPherson struts up ront. Base models get a torsion-beam rear suspension (sure to induce some understeer) but the GT and AWD models get a multi-link independent rear suspension that will yield better handling.
On the outside, the new Vibe is a bit leaner and more aerodynamic-looking. Gaps have been narrowed to give a more polished look and bigger wheels fitted for a more aggressive stance. Cues unique to the AWD model include a roof-mounted rack, while the GT gets a special front fascia and rocker moldings plus a roof spoiler and exhaust tip.
Osebno mi je Toyota lepša. Pontiac izgleda bolj enoprostorsko in kakor da gre samo facelift starega modela, ne pa za povsem nov avtomobil.
Stari:
Prispevkov: 11405
Re: 2009 Toyota Matrix in Pontiac Vibe (ZDA)
Napisal/-a martin_krpan Sr feb 09, 2011 6:56 pm
Pravkar se dogaja 2011 Chicago show, na katerem lahko Američani vidijo številne novosti, predvsem prenove in nove različice. Mednje sodi tudi osveženi Matrix. Spremembe so majhne in vključujejo spremembe na odbijačih, start-stop sistem, nove barve ter nekaj sprememb v notranjosti s kvalitetnejšimi materiali.
http://www.motortrend.com/auto_shows/ch ... index.html
http://www.motorauthority.com/blog/1055 ... ota-matrix
Po forumu brska: Google [Bot] in 25 gostov
