Kmalu raznobarvni avto !
Napisal/-a esem Ne nov 11, 2007 5:56 pm
Že leta 2010 naj bi na trg prišla "paramagnetna" barva. S pritiskom na gumb se z malo pomoči elektrike spreminja položaj drobnih kristalov - delcev železovega oksida, nanešenega kot polimer na karoserijo, kar se na zunaj vidi kot spreminjanje barve. Možne bodo vse barve, avto (barva) pa bo pod stalno (majhno) napetostjo. Ko avto (in s tem elektriko) ugasneš, se barva povrne na prvotno belo. Komaj čakam....
MotorAuthority je napisal/-a:Paramagnetic paint changes color at the touch of a button
Posted on Wednesday 7 November 2007
One of the hardest decisions when picking a new car is choosing the right color but the day when cars will be available in multiple colors could be here sooner than you think. Scientists have developed a new coating called ‘paramagnetic’ paint that has the ability to change colors at the touch of a button. One carmaker looking into the technology is Nissan, which has already developed a self-healing paint.
Before the vehicle is painted, a special polymer containing the special ‘paramagnetic’ iron oxide particles is applied to the car’s body. An applied electric current then adjusts the spacing of small crystals within the iron oxide particles and therefore affects their ability to reflect light and change color.
The process is perfect for metal objects like cars because a continuous small current is needed to maintain the desired color. When the vehicle is switched off, the car returns to a default color of white.
The coating has the ability to reproduce any color visible to the human eye and it takes less than a second to change the entire car. The first commercial applications could be on the market as early as 2010.
Zadnjič spremenil esem, dne Po nov 12, 2007 12:37 am, skupaj popravljeno 1 krat.
Quik
Prispevkov: 395
Pridružen: So mar 15, 2003 2:34 pm
Kraj: Gorenjska
Napisal/-a Quik Ne nov 11, 2007 6:00 pm
Močno dvomim, da bodo take stvari v Sloveniji legalne ;)
blind3k
Prispevkov: 584
Kraj: Ljutomer,Koper
Napisal/-a blind3k Ne nov 11, 2007 6:02 pm
mislim da to ni stvar slovenije, ampak bo nekoč v prihodnosti to možno kupiti :)
Legoless
Prispevkov: 271
Pridružen: To avg 21, 2007 1:35 am
Napisal/-a Legoless Ne nov 11, 2007 6:09 pm
Hehe, kot v James Bondu tisti adaptive camouflage.. Bo projeciral drugo stran avtomobila na karoserijo in bo tako postal neviden :D
Napisal/-a esem Ne nov 11, 2007 6:21 pm
Legoless je napisal/-a:Hehe, kot v James Bondu tisti adaptive camouflage.. Bo projeciral drugo stran avtomobila na karoserijo in bo tako postal neviden :D
Recimo raje - ozadje, ki ga avto zakriva.
Točno to je ideja, ki jo že uresničujejo v VB - naredili bodo tank "neviden". V načrtih so tudi posebne obleke, ki bodo naredile nevidne tudi vojake, tudi po tej ideji. Svašta...
Neyo-Neyo
Prispevkov: 1064
Napisal/-a Neyo-Neyo Ne nov 11, 2007 6:27 pm
Zaminivo 8)
dj_em
Prispevkov: 2622
Napisal/-a dj_em Ne nov 11, 2007 6:30 pm
mislm da so zlo daleč od tega.. še posebi ne z Fe hehe..
Napisal/-a esem Ne nov 11, 2007 6:52 pm
Se ta tvoj "he he" nanaša na "rjo"? :lol:
Malo si za časom - znanstveniki izumljajo vse mogoče, tudi avto, ki bi se sam "popravil" po manjših nesrečah, poleg tega: spreminjajoče spojlerje in drugo aerodinamiko, gumbe, ročice, vse mogoče skratka.
New ‘smart’ materials to revolutionize car design
Posted on Wednesday 7 March 2007
General Motors recently demonstrated its latest development in the field of smart materials during a media event at its R&D center. New technologies such as shape memory alloys and polymers are just some of the new materials that GM is investigating for future use in its cars. The materials get their name from their ability to change shape, stiffness or strength when either heat, stress, electric current or a magnetic field is applied and can then return to its former state when the stimulus is removed.
These new materials could eventually lead to many possible movable features in cars, and we may even see the first production examples as early as 2010. Such possibilities include buttons and handles that automatically pop out when required, active surfaces that can move depending on vehicle speed to aid aerodynamics, and light-weight actuators and sensors that could replace the heavy motors and hydraulic systems found in today’s cars.
GM’s executive director of R&D Alan Taub also hinted at the possibility of vehicles that can self-heal in the event of damage, or can be designed to change color or appearance at the touch of a button.
In to samo GM, kje so še vsi ostali + "neavtomobilski" znanstveni razvoj.
blind3k
Prispevkov: 584
Napisal/-a blind3k Ne nov 11, 2007 6:54 pm
npr. barva ki se sama pobarva je že tudi en čas. Za majnše praske rabi 1dan, za večje praska do 1teden.
industrija se razvija in to zelo hitro, tako da nekaj takega pride na trg je še samo odvisno od časa
Napisal/-a Joie de vivre! Ne nov 11, 2007 7:43 pm
Ko bo to imel eden na vasi, bo kul, ko bodo l. 2017 imeli vsi, bo spet brezveze.
TooOldVehicle
Prispevkov: 250
Pridružen: Sr mar 21, 2007 7:25 pm
Napisal/-a TooOldVehicle Ne nov 11, 2007 8:02 pm
ravno zaradi tega to pač ne bo legalno, tko da fantje sprjaznte se, nč ne bo, mislte da ti bo država dovolila se furat okol "Fully KAMUFLAŽd" he he pa tud da bi ti spreminju barvo avta ne bodo pustil ti povem, se bodo že kej zmislil, matr jim
drgač pa huda zadeva.....
RED_line
Prispevkov: 670
Kraj: Markovec City
Napisal/-a RED_line Ne nov 11, 2007 8:52 pm
in kako bo izgledalo ko bodo policaji lovili nek avto? lovimo rdečo, ne plavo, ne zeleno hondico ki ... je ne vidimo več!
spremeniš bravo odkriješ tablice in ti nikakor ne morejo dokazat da si ti naredil neko pizd**. ne vem jz.
gassssssssssssssssss
Napisal/-a adis Ne nov 11, 2007 9:05 pm
ah ja v kakem filmu prej kot pa v realnosti, sicer kot je že sam @red_line povedal kako bo vse izgledalo ob pregonu nekega avta....
im nobody
Prispevkov: 3321
Kraj: laško
Napisal/-a im nobody Ne nov 11, 2007 9:17 pm
hja glede nevidnega avta....bogi peščci :roll: plus ostali udeleženci ko se bomo zaletaval :twisted:
passat 1.9 tdi 110,235 nm
Na levi pas...do konca gas
SpunkyRacer
Prispevkov: 1205
Kraj: Logatec
Napisal/-a SpunkyRacer Ne nov 11, 2007 9:19 pm
kr neki :roll: :roll:
INFINITI
Prispevkov: 7259
Napisal/-a INFINITI Ne nov 11, 2007 9:29 pm
Še najbolj zabavno bo ko bo lokalni ličar dobil avto za pofarbat, po kaki nesreči - lol
W|zz
Prispevkov: 2410
Napisal/-a W|zz Ne nov 11, 2007 9:34 pm
Od kje vam da bojo nevidni avti na cestah? :)
Legoless
Prispevkov: 271
Napisal/-a Legoless Ne nov 11, 2007 10:17 pm
Premal nesreč :D
Napisal/-a dobek Ne nov 11, 2007 10:46 pm
pa se poceni alternativa izpred ene 10 let, brez elektrike in prasicje drage specialne barve:
:EE :EE :EE
Napisal/-a adis Ne nov 11, 2007 10:59 pm
buahahahah ker polo buhahahah :lol:
