McLaren
Prispevkov: 3434
Kraj: Cela EU
Cadillac CTS Coupe
Napisal/-a McLaren Sr jan 16, 2008 3:01 pm
Tomcatter
Prispevkov: 1236
Napisal/-a Tomcatter Sr jan 16, 2008 6:26 pm
v obliki coupeja je grd :x
Prispevkov: 11405
Napisal/-a martin_krpan Ne mar 02, 2008 8:20 am
CTS Coupe gre v serijsko proizvodnjo.
CTS Coupe Concept:
Prispevkov: 11405
Napisal/-a martin_krpan So mar 08, 2008 4:43 pm
Dodatne fotografije:
Thankfully, it appears that the majority of the CTS Coupe concept's lines have been faithfully duplicated on this production model. Some feared that the concept's radical fastback design might be watered down, revealing the Coupe's sedan roots, but our profile view proves these fears as unfounded. It appears that the production version may have a slightly more pronounced rear deck, but if that's so, it's not enough to significantly alter the concept's silhouette. The CTS coupe prototype retains a remarkably flat backlight.
The CTS Coupe prototype further separates itself from its sedan donor thanks to the elimination of a conventional door handle, adopting instead the concept's Corvette-style design which hides the door trigger behind the door's aft cut-line. The concept and production similarities continue with the Coupe's revised lower side sill, and the distinctively sculpted waistline, which begins at the A-pillar/fender vent, and narrows as it stretches rearward. The camouflage hides whether or not the line terminates into the concept's razor-sharp point at the C-pillar, but it looks likely that that's another design convergence between the show- and production cars. Earlier photos also confirmed that the concept's bold central exhaust will also reach showrooms.
There are some visible differences between the Detroit Show Standout and the production model. Cost and feasibility studies have killed the concept's glass-to-glass side windows, in favor of a visible B-pillar on the production model. The rest of the changes are found in front of the A-pillar. The concept coupe's large, CTS-V-style hood bulge is gone on this prototype (although we'd love to see it return on a future full-blow CTS-V coupe). And the show car's reshaped front fenders–which sweep more voluptuously to a revised front bumper, tweaked front ground-effects, and more dynamic headlight and fog-light clusters–appear to have been replaced with stock items from the CTS sedan. It looks to us like the CTS Coupe and sedan will share identical front fenders and front fascia designs. From there, back, however, the cars could scarcely be more different. The drama of the CTS Coupe concept is alive and well, and on its way to Cadillac showrooms.
http://www.leftlanenews.com/cadillac-cts-coupe.html
Prispevkov: 11405
Napisal/-a martin_krpan Sr apr 02, 2008 5:16 pm
Prispevkov: 11405
Napisal/-a martin_krpan To mar 24, 2009 6:30 pm
Prispevkov: 11405
Napisal/-a martin_krpan To jan 05, 2010 6:13 pm
Cadillac CTS-V Coupé
Art And Science: Cadillac Premieres 2011 CTS-V Coupe
* New CTS Coupe design combines with V-Series performance
* 556-hp (415-kW) supercharged 6.2L V-8
* Six-speed manual or six-speed automatic with paddle shift control
* Magnetic Ride Control and Brembo brakes
* New Saffron interior trim accent color
* On sale in early summer
DETROIT – Cadillac today announced the 2011 CTS-V Coupe, which debuts at the 2010 North American International Auto Show in Detroit. It combines the new CTS Coupe's dramatic design with the 556-horsepower (415-kW) supercharged V-8 engine from the CTS-V sedan. The result is a luxury sports coupe aimed at driving enthusiasts.
"The CTS-V Coupe marries our most potent and sophisticated technology with our most dramatic production design," said Bryan Nesbitt, Cadillac general manager. "This combination of visual and technical attributes is designed to create a very compelling choice for luxury sports car consumers."
The CTS-V Coupe begins production this summer. Its suite of technical and performance elements includes Magnetic Ride Control, racing-bred Brembo brakes and an available automatic transmission with paddle-shift control.
The V-Series Coupe includes a unique grille that doubles the car's air intake volume, an important enabler for its high-performance capabilities. It is also visually identified by a raised center section of the hood that provides clearance for the supercharger, as well as specific front and rear fascias. Like the CTS Coupe, its exhaust is centered inside the rear fascia, but with unique twin outlets. The car rolls on 19-inch cast aluminum wheels, available in either painted or polished finishes, and Michelin Pilot Sport 2 performance tires.
The CTS-V Coupe's rear track is nearly an inch wider than the CTS-V Sport Sedan, adding to the car's aggressive stance and enabling an extra measure of handling capability. The current CTS-V Sport Sedan has quickly established itself among the world's highest performing luxury sedans, becoming the first production four-door on street tires to break the legendary 8-minute barrier at Germany's famed Nürburgring. The new V-Series Coupe's sleeker shape and slightly lower mass ensure a similarly high level of performance.
Inside, the 2+2 cabin combines performance and luxury. A new Saffron interior trim color is offered, with contrasting microfiber seat inserts and stitching on the upper trim areas.
Form follows function
The CTS-V Coupe's design is a clear visual statement of the technical precision and performance intent of the car.
The Coupe has the same wheelbase as the CTS-V Sport Sedan, but its overall height is about two inches (51 mm) lower and its overall length is two inches (51 mm) shorter. The two models share only the instrument panel, console, headlamps, front fenders and grille.
Key design features include:
* Classic hardtop styling, with no conventional B-pillar
* Touch-pad operation for the doors removes the need for conventional door handles
* Faster windshield angle (62.3 degrees) and a nearly horizontal backglass enable an aerodynamic profile
* Signature vertical lighting, highlighted with LED light pipes
* Signature center high-mounted stop lamp functions as a rear spoiler
* Aerodynamic roof-mounted antenna for OnStar and XM Satellite Radio
Supercharged powertrain
The CTS-V Coupe employs the LSA 6.2L supercharged V-8 engine also found on the CTS-V Sport Sedan. Rated at 556 horsepower (415 kW) and 551 lb.-ft. of torque (747 Nm), it is the most powerful engine offered in Cadillac's history and propels the CTS-V Coupe from 0-60 mph in 3.9 seconds.
The LSA engine features an intercooled Eaton supercharger system, premium aluminum-alloy cylinder heads and numerous details designed to ensure it makes its power as quietly and smoothly as possible. The supercharger, for example, has a unique, four-lobe rotor design that enhances quietness while also optimizing the performance parameters of the engine.
A pair of six-speed transmissions is offered in the CTS-V Coupe: a Tremec TR6060 six-speed manual with a dual-disc clutch and a Hydra-Matic 6L90 six-speed automatic with paddle-shift control. Performance Algorithm Shifting is part of the 6L90's programming and provides a performance-oriented shift pattern during sustained high-performance driving. As with many Cadillac models, the driver needs only to slide the shifter into the manual "gate" to put the transmission into that more aggressive mode.
The paddle shift control requires no shift lever movement. Steering wheel thumb controls allow immediate and quick tap up/tap down gear selection.
The V-Series reaches elite levels of road-holding performance, but also maintains the poise of a luxury car in "regular" driving conditions. The technical enabler of that dual-mode driving character is Cadillac's landmark Magnetic Ride Control. It is standard on the CTS-V Coupe and is the world's fastest-reacting suspension technology. It uses shocks controlled by advanced magneto-rheological technology, rather than mechanical valves, to greatly accelerate response time and precision.
Electronic sensors at all four wheels literally "read the road" every millisecond, making constant adjustments to damping to create virtually instantaneous and extremely precise control of body motions. This is of particular benefit for a high-performance car because it helps keep the car very composed during hard cornering, acceleration, braking and other dynamic maneuvers.
The Magnetic Ride shocks also enable a broader range of damping control to optimize the ride and handling for all driving conditions. In the CTS-V Coupe, an extra measure of control is offered, with two selectable modes (Tour and Sport), enabling the driver to tailor the suspension for grand touring or more spirited performance driving.
Braking and tire systems
CTS-V includes sophisticated braking and tire systems, in partnership with two companies renowned for high-performance technology: Brembo and Michelin. Brembo brakes are at all four corners and include powerful, six-piston calipers in the front and four-piston calipers in the rear.
Slotted and vented rotors enable strong initial braking force while optimizing heat resistance and eliminating fade. The brake rotors from Brembo employ a "dual-cast" technology that combines cast iron and aluminum, resulting in excellent performance and weight reduction. CTS-V also includes an electric parking brake, enabling more legroom for the driver, key for high-performance driving.
Michelin partnered with Cadillac engineers to develop its acclaimed Pilot Sport PS2 summer tire for CTS-V and its exclusive 19-inch alloy wheels. The tires support high levels of grip in track conditions, while also affording good performance on the road.
Interior amenities
Recaro performance driving seats are optional in the CTS-V Coupe and provide excellent support for spirited driving. These 14-way adjustable performance seats include pneumatic bolster controls in the seat cushions and backrests.
The CTS-V Coupe also includes an exclusive new Saffron color option for the interior, providing a contrasting color accent carried on the seat inserts, as well as the stitching, which highlights the craftsmanship of the instrument panel, center console, door trim and seats.
The steering wheel, seat inserts and shifter are covered in microfiber, providing the luxurious character of suede without suede's inherent drawbacks of difficult care and moisture sensitivity. These accents are standard, elegant to the touch and help support high-performance driving.
The car's integrated center stack is trimmed in Obsidian black material that is also applied to the center console and door trim. Just like every CTS, the V-Series includes a hand-stitched instrument panel, door trim and center console. Leading-edge infotainment features extend to the V-Series. They include a 40-gigabyte hard drive, advanced navigation system with a deployable screen and Bose digital surround audio, as well as factory-installed Bluetooth phone integration, all standard features on the V-Series.
http://www.auto-news.de/auto/news/anzei ... n_id_26006
PIKSNA007
Prispevkov: 1161
Napisal/-a PIKSNA007 To jan 05, 2010 7:09 pm
Ja to pa bo stroj ane :D 550 konjev :D fajn fajn :) tudi oblika mi je zelo všeč sploh, ker je bolj škatlast oz. masiven izgled ima. Kar mi je na avtu všeč.
CITROENAR ŠT 1
Prispevkov: 1483
Napisal/-a CITROENAR ŠT 1 Ne jan 10, 2010 12:44 am
Lep ko strela, ki prinaša svežino v ta razred, ampak kaj ko ga po vsej verjetnosti ne bo v Evropo. :sadd :evil:
Prispevkov: 11405
Napisal/-a martin_krpan Po jun 21, 2010 6:17 pm
AgitatoR
Prispevkov: 4443
Kraj: Rbn 104
Napisal/-a AgitatoR To jun 22, 2010 4:01 pm
Je pa nastavil rit kot da je goneča se psica.
bass
Prispevkov: 3140
Napisal/-a bass To jun 22, 2010 5:26 pm
Zanimiva oblika, črna mu sicer ne paše. Števci so zelo urejeni. Izstopa tudi postavitev ekrančkov za klimo. All in all - zanimivo. Kakšne bodo cene?
INFINITI
Prispevkov: 7259
Napisal/-a INFINITI Pe jun 25, 2010 8:09 am
INFINITI
Prispevkov: 7259
Napisal/-a INFINITI Ne avg 08, 2010 12:21 pm
~toMmy~
Prispevkov: 5806
Kraj: Vinica
Re: Cadillac CTS Coupe
Napisal/-a ~toMmy~ Če jan 20, 2011 6:59 pm
Zanimivo, nekaj posebnega s temi ostrimi linijami!
simply
Prispevkov: 3065
Kraj: Nova Gorica
Napisal/-a simply Pe jan 21, 2011 6:46 pm
Če je že kdo bil v USA ve, kako se vozijo te mašince.
:lol:
xalfist
Prispevkov: 882
Pridružen: To sep 02, 2008 3:26 pm
Kraj: maribor
Re:
Napisal/-a xalfist Pe jan 21, 2011 6:56 pm
INFINITI je napisal/-a:Testni video:
http://www.youtube.com/watch?v=0tCWBNRk ... eature=sub
Na tem posnetku, ko ga kaže spredaj od blizu nekje pri 50s se vidi kot da blatnik štrli preko odbijača?
Alfa romeo 147
