Prispevkov: 11405
2009 Infiniti FX
Napisal/-a martin_krpan So jan 19, 2008 5:04 pm
Na ženevskem avto salonu spomladi bo Nissanova prestižna znamka predstavila prenovljeni luksuzni SUV FX. Trenutno se avtomobil uradno prodaja samo v ZDA, a tudi pri Infinitiju načrtujejo pohod na staro celino v prihodnjih letih. Zato tudi premiera novega FX pri nas.
At 2008 Geneva Motor Show, Infiniti will unveil completely redesigned FX. The FX will compete with Volkswagen Touareg, Porsche Cayenne and Lexus RX.
The 2009 FX will be available in two different choices: the FX37 and the FX50. As you suspect already one will be powered by a 3.7 liter and the other by a 5.0 liter engine.
The FX37 wil be powered by the same 3.7 liter VQ-series V6 engine engine used in the G37 Coupe and will deliver 300 hp. The FX50 will be powered by a 5.0 liter engine with an output of 390 hp and 369 lbs-ft.
The new VQ37VHR, first used in the G37 Coupe is based on the award-winning VQ engine series, named one of the "Ten Best Engines" by Wards Auto World magazine for 13 consecutive years. next to a bigger output, the FX37 will also use the new VVEL system which combines hydraulic-controlled variable valve timing and electronically controlled variable valve lift on the intake side to help improve performance and response. The VVEL system is also expected to improve emissions and fuel efficiency.
The 2009 FX will have the same dimensions as the current FX. Infiniti will use materials that will reduce weight, this is why the up-coming FX will be faster compared to the current model.
The biggest changes will be made to the front of the car. The exterior will be more sporty and modern.
The exterior highlights will include flowing front fender curves, expressive front fascia with Infinitis signature double-arch grille and L-shaped High-Intensity Discharge (HID) bi-xenon headlights with integrated fog lamps. Also the rear will feature large LED taillights  an Infiniti trademark, refined rear bumper and an integrated RearView Monitor camera. The camera will help you to have a 360 degree view of what was around you.
Two of the most modern features included in the upcoming FX are: Slow moving traffic cruise control, meaning that the car will slow down and speed up based on the car in front of you and mirrors that will auto adjust when you move in the seat.
Aktualni FX (zame še vedno eden najlepših takšnih vozil (poleg manjšega EX in Acure RDX):
davorz
Prispevkov: 604
Kraj: Velenje
Napisal/-a davorz So jan 19, 2008 5:10 pm
Trenutni model mi je veliko lepši!
podgurc
Prispevkov: 227
Napisal/-a podgurc So jan 19, 2008 6:12 pm
Men je tud ta model lepši, sm ta tud ni grd in bi ga z veselem meu :D :D
Dr.M3
Prispevkov: 1409
Napisal/-a Dr.M3 So jan 19, 2008 6:26 pm
Trenutni model mi je lepši od vse (evropske) konkurence.
Tudi ta ni slab, samo mi je pa stari lepši.
INFINITI
Prispevkov: 7259
Napisal/-a INFINITI So jan 19, 2008 7:43 pm
Meni je tudi trenutni lepši, bom pa raje počakal do končnega izgleda za produkcijo, preden podam finalno mnenje ;)
Prispevkov: 11405
Napisal/-a martin_krpan To mar 04, 2008 8:23 pm
Novi 2009 Infiniti FX.
http://www.infiniti.com/allnewfx/
Iz boka in zadka zagotovo med najlepšimi SUVi. Sprednji del se mi pa z zašiljenimi, majhnimi lučmi zdi malce zgrešen. Manjši EX je precej bolj skladen.
INFINITI
Prispevkov: 7259
Napisal/-a INFINITI To mar 04, 2008 11:36 pm
Bemti kaj so pa to spredaj naredili :?
Cobra1
Prispevkov: 137
Pridružen: Po jul 24, 2006 7:52 am
Napisal/-a Cobra1 To mar 04, 2008 11:41 pm
sn se že vozu z FX 35 nora stvarca
Prispevkov: 11405
Napisal/-a martin_krpan Ne jul 20, 2008 12:38 pm
tomson
Prispevkov: 1386
Kraj: LJ / MB
Napisal/-a tomson Ne jul 20, 2008 1:13 pm
A ne bi bil taki lepši? :)
Dr.M3
Prispevkov: 1409
Napisal/-a Dr.M3 Ne jul 20, 2008 1:33 pm
Keri nor avto :bow Tako zunaj kot znotraj.
Impozanten kot nek batmobil. 8)
fastmaniac
Prispevkov: 30
Pridružen: Po jun 18, 2007 5:54 pm
Napisal/-a fastmaniac Ne jul 20, 2008 3:19 pm
Zakon zgleda tak zunaj kot znotraj. :shock:
Prispevkov: 11405
Napisal/-a martin_krpan So sep 13, 2008 7:27 pm
Posebej za Evropo: FX37.
V ZDA ima FX dva motorja, 3,5 litrski V6 s 303 KM in petlitrski V8 s 390 konji. Izkjučno za Evropo pa so manjšem motorju povečali prostornino na 3,7 litra in moč na 320 konjev. Na izbiro bosta dve verziji, X37 GT in FX37 S.
Avto bo premierno prikazan v Parizu, zato so trenutno znane cene za francoski trg. Od 55.950 EUR dalje.
robertos_664
Prispevkov: 1244
Napisal/-a robertos_664 So sep 13, 2008 10:57 pm
zakon avtek. Meni se pa dopade sprednji del.
martk
Prispevkov: 837
Pridružen: Ne jun 27, 2004 9:26 pm
Napisal/-a martk Ne sep 14, 2008 8:41 am
INFINITI je napisal/-a:Bemti kaj so pa to spredaj naredili :?
Nekam je treba motor stlačit ;) Lepo pa res ni.
Martin
bl leti bl se zdi
To je posilstvo! Prav, kam pa greva?
benf1
Prispevkov: 226
Pridružen: Po jun 18, 2007 1:47 pm
Kraj: Šentjernej
Napisal/-a benf1 Ne sep 14, 2008 9:50 am
avto je eden najlepših, sam kaj ko to požre tuk bencina d glava boli :?
Prispevkov: 11405
Napisal/-a martin_krpan Po feb 01, 2010 10:00 pm
Infiniti FX Limited Edition izdelan posebej za Zahodno Evropo v omejeni seriji 100 primerkov.
http://www.netcarshow.com/infiniti/2010 ... d_edition/
rok46
Prispevkov: 2861
Napisal/-a rok46 Po feb 01, 2010 10:23 pm
tole je pa lepota od avtomobila 8) en dobr dizel mu manjka :)
pa ne se spet zaganjat v dizla :lol:
CITROENAR ŠT 1
Prispevkov: 1483
Napisal/-a CITROENAR ŠT 1 Pe feb 05, 2010 12:23 am
Meni je ta Infiniti FX res lep avtomobil, se spomnim ene 2 leti nazaj, ko sem ga videl (takrat seveda še neprenovljenega) sem ga gledal dokler je bil v mojem vidnem polju, tudi zato, ker jih pri nas skorajda ni. Mi je res prijetno drugačen od nemške, korejske,... konkurence in kar bi res rabil, se tu popolnoma strinjam s tabo rok46 ne en, pač pa ene par dobrih dizlov, pa tudi kaj večjo izbiro bencinskih motorjev, menjalnikov,... tu tekmeci prednjačijo še pa še, vsaj zaenkrat. ;)
Dr.M3
Prispevkov: 1409
Napisal/-a Dr.M3 Pe feb 05, 2010 12:26 am
Pravi doberman med Suv-i. :con :wink:
