Caterham Superlight R500
Napisal/-a esem So apr 12, 2008 3:00 am
Caterham Superlight R500 (derivat sedmice) je uradno predstavljen. Imel bo 506 kg (516 kg s sekvenčnim menjalnikom) in 263 KM (navit Ford Duratec), kar da 520 KM/t mase. Pospešek je ustrezen - okoli 2,9 s do 100 km/h.
Je že v prodaji, cena je 37000 funtov. Za dvajsetino cene Veyrona praktično isti pospeški (in večji užitki)!
Caterham je napisal/-a:Press Release
THE NEW CATERHAM R500 – HARDER, BETTER, FASTER, STRONGER
* 520bhp-per-tonne
* 0-60mph in 2.88 seconds
* 2.0 litre Ford Duratec engine tuned to produce 263bhp
* All-new electronic dashboard including keyless ignition
* Optional upgrade sequential gearbox & launch control
For those really serious about their driving, the famous supercar-slaying R500 moniker is back with the arrival of the all-new Caterham Seven Superlight R500.
The latest model from the British sportscar manufacturer takes the minimalist, lightweight Seven philosophy to a new level with more power, sharper handling and for those venturing on track the option of launch control and the Caterham Motorsport engineered sequential gearbox.
Weighing just 506kg and producing 263bhp, R500 is the most potent race-tuned production Seven yet.
The Series 3 chassis flagship model blasts out 520bhp-per-tonne and is capable of propelling itself from 0-60mph in 2.88 seconds, delivering a pure adrenalin fix for those committed enough to strap themselves into the Kevlar race seats.
The original R500 was legendary, with the old Rover K-series powered machine rewriting performance records for 0-60mph and 0-100-0mph times. This new variant has been equipped to supersede its predecessor by embracing the very latest in lightweight engineering techniques and technology.
Lurking under the lightened bonnet is the all-alloy 2.0 litre Ford Duratec engine. Fed by its roller barrel throttle bodies, the normally aspirated, four-cylinder mill is tuned by Caterham Powertrain (CPT) to unleash a monster; 263bhp with a heaving 177 lb-ft of torque transmitted to the rear wheels. The relentless acceleration is transmitted through each ratio by either the standard 6-speed gearbox or the optional Caterham Motorsport engineered sequential transmission.
To help reign in such extreme performance are race-developed Avon CR500 tyres and a suspension set-up that includes weight saving aero wishbones and fully adjustable dampers. Bringing things ferociously to a halt are four-piston calipers clamping on vented discs at the front and lightweight twin piston rear calipers.
Performance upgrades for the R500 aimed squarely at the track day market include a sequential transmission, launch control, a gulping Carbon Induction Airbox and Eibach Springs and dampers derived from the Caterham C400 race series.
The R500 isn’t just about big performance statistics though; refinements and Seven firsts feature throughout and help distinguish it from its stablemates.
In true Colin Chapman spirit, engineers sought to add lightness to the chassis in order to improve the overall performance.
To shed a massive 9kg from the already featherlight chassis utilised by the R400, Caterham left no bolt unscrewed - more carbon and Kevlar feature than previously, thinner body panels have been utilised right through to aluminium rear light housings.
Discreet exterior styling tweaks carried over from the flagship CSR models offer both form and function - the carbon winglets increasing downforce and the cat’s tongue grill aiding cooling and aerodynamics. A carbon leather boot cover and clear rear lights are also new.
Housed within the revised chassis is keyless ignition, a quick-release Momo steering wheel with integrated indicator switches and an innovative dashboard featuring flush fitted switchgear, ACES sequential gear change lights and a new Stack display with scrolling text. The carbon dash is also finished with a detailed engraved plaque to show each car’s number.
On sale immediately, the factory built Superlight R500 starts at £36,995,
Caterham Superlight R500 Technical Specification
Engine 2.0-litre Caterham Powertrain (CPT) Ford Duratec
Max Power 263bhp @ 8500rpm
Max Torque 177 lbsft @ 7200rpm
0-60mph (claimed) 2.88 seconds
Top Speed 150mph
Wheelbase 2225mm
Overall length 3100mm
Overall width 1575mm
Height 800mm
Ground clearance 80mm
Kerb Weight 506kg (516kg sequential gearbox)
Standard Equipment
* 2.0-litre Caterham Motorsport Ford Duratec
* 6 Speed Caterham Gearbox
* Limited Slip Differential
* Superlight Suspension (wide track front and de Dion rear with Watts linkages)
* Carbon dash, nose cone, rear and front cycle wings
* ACES change-up lights
* Ventilated front brake discs with 4 pot calipers
* 13” Anthracite eight-spoke alloy wheels with Avon CR500 tyres
* Carbon interchangeable wind deflector
* 4 point Road Harnesses
* Quick-release Momo Steering Wheel with integrated indicator switches
* Carbon Kevlar seats
Optional Performance Upgrades
* Sequential Gearbox - £2950
* Launch Control - £350
* Carbon Induction Airbox - £450
* Suspension package consisting Eibach Springs and dampers derived from the C400 race series - £1250
JEREMIJA79
Prispevkov: 1235
Napisal/-a JEREMIJA79 So apr 12, 2008 7:38 am
Uf De Dion-ova prema tole se pa drži ceste... :bow
mire
Prispevkov: 2110
Kraj: koper
Napisal/-a mire So apr 12, 2008 8:15 am
uuuuuuuuuu kaksen strup res je hud :D
rocna - bok - streha
Pravopis spreglej
Slavc
Prispevkov: 149
Pridružen: So maj 13, 2006 1:19 pm
Kraj: Koroška
Napisal/-a Slavc So apr 12, 2008 8:51 am
Zakom zadeva :) bi ga bilo zanimivo peljat. Imel bi ga za kako nedeljo popoldan, tam po kosilu.
Sprednje luči me pa spominjajo na luči od Tomo Vinkoviča :D
kar je dobro ni slabo ... :)
3furious
Prispevkov: 119
Pridružen: Sr maj 25, 2005 9:13 pm
Napisal/-a 3furious So apr 12, 2008 11:37 am
Nekaj mi ni jasno pri teh slikah. Avto ima gumb za brisalce, pranje in ogrevanje šipe, spredaj se vidi posodo z tekočino za pranje, nima pa nobenih stekel. :shock: :D
Mazda 3 G165
primozek69
Prispevkov: 330
Pridružen: Ne nov 04, 2007 2:43 pm
Napisal/-a primozek69 So apr 12, 2008 11:44 am
Misliš tisto,k ma roza tekočino noter? En namig: antifriz
Pavel_P
Prispevkov: 742
Pridružen: To jun 26, 2007 8:47 am
Kraj: Kr&Lj
Napisal/-a Pavel_P So apr 12, 2008 12:03 pm
primozek69 je napisal/-a:Misliš tisto,k ma roza tekočino noter? En namig: antifriz
Če ma pranje stekel, potem ma najbrs tudi tekočino za pranje :)
primozek69
Prispevkov: 330
Napisal/-a primozek69 So apr 12, 2008 2:26 pm
Pa tist je posoda za hladilno tekočino,jao ste... Zakaj je pa povratek nazaj spelan?? Aja,še za butalce: tud če bi bla za šipe prat,bi jo za photoshoot vsaj do vrha nalil.
Pavel_P
Prispevkov: 742
Kraj: Kr&Lj
Napisal/-a Pavel_P So apr 12, 2008 2:45 pm
pa sej nihče ni rekel da ni hladilna :) (jao ste..)
ti si samo rekel da če misli da ima pranje šip zaradi tiste posode, da se moti, jaz sem pa napisal še ta drugo opcijo, ki tega ne izključuje ;)
primozek69
Prispevkov: 330
Napisal/-a primozek69 So apr 12, 2008 2:48 pm
Ne ne, on je vidu knof na dashboardu plus tisto posodo je omenu ,kot da je za pranje stekel.
Pavel_P
Prispevkov: 742
Kraj: Kr&Lj
Napisal/-a Pavel_P So apr 12, 2008 2:55 pm
No sej. Če ma knof v kabini, pol je verjetno uporaben, pa če se na slikah vidi posoda ali pa ne. Je pa spet čist odvisno. Namreč!
faceless
Prispevkov: 99
Pridružen: Pe feb 15, 2008 10:08 am
Napisal/-a faceless So apr 12, 2008 3:55 pm
Ta avtomobil jih nima. Se pa lepo vidi da je narejena predpriprava za vgradnjo (predzadnja slika). Tudi sipa se bo verjetno dala dokupiti. Kot pri drugih njihovih modelih ki so precej legokockasti.
Dejch
Prispevkov: 757
Napisal/-a Dejch So apr 12, 2008 4:17 pm
To ti je cisti pure track car. :bow Ce kdo zna, znajo to britanci. Sicer grd k smrt, ampak ce hocs track car, kup to.
Blinder
Prispevkov: 3934
Kraj: Obala
Napisal/-a Blinder So apr 12, 2008 4:37 pm
177 lb-ft je 245 nm,
funt pa je vreden 1.25-1.3 euro
bass
Prispevkov: 3140
Napisal/-a bass So apr 12, 2008 5:53 pm
Performanse so sicer brutalne, a kje bom to izkoristil? Za ta denar raje nekaj bolj "civilnega", kakšen exige ali pa sagaris...
menjekul
Prispevkov: 2635
Pridružen: Sr jan 01, 2003 8:14 pm
Napisal/-a menjekul So apr 12, 2008 8:06 pm
sicer mi je exige S najljubši ampak takšnih in drugačnih primerkov za track day-e se človek nikoli ne more naveličati. blagor tistim, ki imajo lahko te igrače 8)
snikerson
Prispevkov: 1376
Napisal/-a snikerson Ne apr 13, 2008 12:44 am
pure fun :D
