Prispevkov: 11397
2012 BMW serije 1 in 2
Napisal/-a martin_krpan Pe maj 16, 2008 5:09 pm
Testna mula nove serije 1.
http://i217.photobucket.com/albums/cc12 ... le_004.jpg
http://i217.photobucket.com/albums/cc12 ... le_002.jpg
http://i217.photobucket.com/albums/cc12 ... le_005.jpg
BMW released an updated version of the 1-series compact late last year but a suspicious prototype of the hatch is still running around German streets. At first appearance the car looks like an ordinary 1-series hatchback but look closer and you’ll notice several key features that reveal this is something very different.
The car pictured here is in fact an early test-mule for the next-generation 1-series hatch due most likely due in late 2011 or early 2012. Makeshift fender flares reveal the new model will sport a widened track both front and rear, confirming the next 1-series will be bigger than the current model. The larger footprint will also improve the car’s dynamics and road-holding abilities.
Earlier this month BMW CEO Norbert Reithofer revealed that the four-cylinder engines used in the next-gen 1-series will be the same compact units developed jointly by BMW and France’s PSA Peugeot-Citroen for the Mini and a number of French models. The engines will range from 1.4 to 2.0L in displacement and will be available in both turbocharged and naturally aspirated forms. Expect to see BMW’s award-winning straight six engines also appear in the line-up.
The current 1-series has often been criticized for having a back seat no full-sized adult would be comfortable in, however the rear seat room in this new model is expected to be much improved. This will also allow BMW to finally release a hatchback version of the 1-series in the all-important US market. This 1-series should also help boost BMW’s sales in emerging markets due to its low entry price.
Expect to see stop-start and electrical-regenerative systems carry over into the new series as well as possible new EfficientDynamics technologies such as heat-recovery systems and solar panels. BMW revealed yesterday that initial testing of thermoelectric generators and solar panels on its cars showed savings of up to 5% in fuel consumption.
http://www.motorauthority.com/news/hatc ... test-mule/
Zadnjič spremenil martin_krpan, dne Sr dec 19, 2012 7:39 pm, skupaj popravljeno 2 krat.
FBR
Prispevkov: 1768
Napisal/-a FBR Pe maj 16, 2008 5:19 pm
In kaj je tle novga? :roll:
M-jack
Prispevkov: 157
Pridružen: Po mar 24, 2008 6:10 pm
Napisal/-a M-jack Pe maj 16, 2008 5:24 pm
FBR je napisal/-a:In kaj je tle novga? :roll:
leto idzdelave pa se mi zdi da je zadnji del malo spremenjen
davorz
Prispevkov: 604
Kraj: Velenje
Napisal/-a davorz Pe maj 16, 2008 5:32 pm
pa sj to ni dokončna oblika :roll: to je samo mula. Testirajo verjetno začetno fazo razvoja podvozja pa to..
Medosna razdalja ostaja enaka? torej avto ne bo nič "zrasel"?
Prispevkov: 11397
Napisal/-a martin_krpan Če nov 06, 2008 6:19 pm
mire
Prispevkov: 2110
Kraj: koper
Napisal/-a mire Če nov 06, 2008 6:34 pm
ne zgleda slabo
rocna - bok - streha
Pravopis spreglej
Slavc
Prispevkov: 149
Pridružen: So maj 13, 2006 1:19 pm
Kraj: Koroška
Napisal/-a Slavc Če nov 06, 2008 7:15 pm
Če bo tak, bo fenomenalen :). Vsaj za mene so bmw-ji, kar se designa tiče, eni najlepših avtov.
kar je dobro ni slabo ... :)
gecco
Prispevkov: 1726
Napisal/-a gecco Če nov 06, 2008 7:16 pm
sploh ne zgleda slabo :D
podgurc
Prispevkov: 227
Napisal/-a podgurc Če nov 06, 2008 7:43 pm
Matr mi je lep, zadi spominja mau na Z3 coupe :D :D :D :woohoo
Cyrus
Prispevkov: 428
Pridružen: To feb 08, 2005 2:00 pm
Napisal/-a Cyrus Če nov 06, 2008 8:21 pm
Čas je že, ker zdejšna enka je tehnično odličen avto ampak žal tako grd za moj okus, da ga nikakor ne bi mel. Dokaj čudno glede na to, da sta mi 3 coupe in X5 ena od top 5 najlepših avtov. Tko, da če bo nova enka vsaj približno podobna temu zgoraj, potem se bo to tut kr precej na prodaji verjetno poznal.
AudiBoy
Prispevkov: 1534
Kraj: Severna Primorska
Napisal/-a AudiBoy Če nov 06, 2008 10:40 pm
To bi morala bit "nova" Z3 coupe :)
Zois
Prispevkov: 988
Kraj: Slovenska Bistrica
Napisal/-a Zois Pe nov 07, 2008 8:56 am
lepo zgleda
Slika pugi.si
Napisal/-a Lignage Če jan 22, 2009 1:14 pm
S prihodom naslednje generacije serije 1, naj bi na trg prišla tudi športna različica, ki naj bi se zgledovala po nekdanjem modelu 2002 Turbo iz sedemdesetih let prejšnjega stoletja:
Vir: AutoBild.de
BlazR
Prispevkov: 321
Napisal/-a BlazR Če jan 22, 2009 7:28 pm
A tole nj bi bla špotna verzija coupeja serije 1 al povsem samostojn model?
Napisal/-a Lignage Pe jan 30, 2009 3:47 pm
BlazR je napisal/-a:A tole nj bi bla špotna verzija coupeja serije 1 al povsem samostojn model?
Prvo!
__________________________
Še ena slika iz autobilda:
fiatpowered
Prispevkov: 474
Napisal/-a fiatpowered Pe jan 30, 2009 4:35 pm
Če bodo pa takšnale minimalistične sprednje luči začeli dajati na bemfle, bo pa to fenomenalno, tale vijolčen zgleda naravnost izjemen !
W|zz
Prispevkov: 2410
Napisal/-a W|zz Pe jan 30, 2009 4:43 pm
Uf, bogi tisti strastni bmw-jevci, ki so qrcali nove audijeve luči in poveličevali svoje angel eyes :)
Kar všeče drugače :)
Prispevkov: 11397
Napisal/-a martin_krpan Pe jan 30, 2009 4:51 pm
Po mojem so Autobildovci pretiravali in serijski ne bo niti podoben tej risbi.
simply
Prispevkov: 3065
Kraj: Nova Gorica
Napisal/-a simply Pe jan 30, 2009 6:37 pm
Se strinjam s predhodnikom.
Dvomim, da bo takšen.
Nixxon
Prispevkov: 3646
Kraj: Vrhnika
Napisal/-a Nixxon To feb 03, 2009 11:42 am
Huda barva.
