Prispevkov: 11405
Subaru Exiga
Napisal/-a martin_krpan To jun 17, 2008 5:27 pm
Subaru je razširil svoj proizvodni program s sedemsedežnim enoprostorcem povsem lastnega razvoja. Lahko bi rekli, da je avto naslednik neuspešnega Traviqa, ki pa je bil samo preoblečena Opel Zafira.
http://www.subaru.jp/exiga/exiga/
Subaru on Tuesday took the wraps off its new seven-seat Exiga crossover. The new model should slot between the Legacy and the Tribeca. Power will come from two engines: either a naturally aspirated 2.0-liter flat-four good for 146 horsepower or a turbocharged version of the same engine producing some 222 hp.
The top-rung 2.0GT Turbo will get standard all-wheel drive and a five-speed automatic transmission exclusively, while base-engine models will use a 4-speed auto with a choice of front or all-wheel drive.
At 186.6 inches long and nearly 70 inches wide, the Exiga is over 7 inches longer and nearly as wide as the 2009 Forester — on whose platform it’s based — and the wheelbase is likewise stretched by a little more than 5 inches. Because of this, we doubt the crossover will lose its seven seats if or when the car comes Stateside, as some reports previously suggested.
The name Exiga, which is a mishmash of Exciting and Active, would also likely be replaced by the Outback moniker for the North American market. Engines would also be swapped for the 2.5-liter flat fours Subaru uses in its offerings on this side of the pond, with the 2.0L turbodiesel eventually expected to join the range, at least in markets such as Europe. Toyota’s upcoming Venza would likely be the main competitor the Exiga/Outback would face.
dodatne fotografije:
http://www.leftlanenews.com/subaru-exiga.html
Zadnjič spremenil martin_krpan, dne To jun 17, 2008 5:31 pm, skupaj popravljeno 1 krat.
denis099
Prispevkov: 780
Pridružen: Po apr 21, 2008 7:00 pm
Napisal/-a denis099 To jun 17, 2008 5:31 pm
mater mi je grd. vrjamem da ma vrhunsko kvaliteto pa use,sam oblikovanje bi pa mogl dat italijanom( bertone,pininfarina,giugaro itd)..
denis
Nixxon
Prispevkov: 3646
Kraj: Vrhnika
Napisal/-a Nixxon Sr jun 18, 2008 10:04 am
Se strinjam. Pri meni proti Fordovim 7-sedežnikom (S-Max, Galaxy) in še kakšnim drugim nimajo šans.
frgo
Prispevkov: 555
Pridružen: So sep 18, 2004 5:11 pm
Kraj: Trebnje
Napisal/-a frgo Sr jun 18, 2008 10:50 am
Subaru za nekoga, ki favorizira forda pač ni. Niti za onega, ki avto sodi skozi dizajn.
denis099
Prispevkov: 780
Napisal/-a denis099 Sr jun 18, 2008 11:10 am
frgo je napisal/-a:Subaru za nekoga, ki favorizira forda pač ni. Niti za onega, ki avto sodi skozi dizajn.
ja za koga je pa pol :D :D :D :D
denis
Dejch
Prispevkov: 757
Napisal/-a Dejch Sr jun 18, 2008 11:22 am
Za une k cenijo tehnično dovršnost mogoče?
AgitatoR
Prispevkov: 4443
Kraj: Rbn 104
Napisal/-a AgitatoR Sr jun 18, 2008 11:32 am
Kaj pa je toliko drugačen od vseh tistih ameriških enoprostorskih grdob, ki so vam pa vse kul ?
denis099
Prispevkov: 780
Napisal/-a denis099 Sr jun 18, 2008 11:32 am
skoraj pri vseh znamkah( vsaj pri evropskih in japonskih) je tehnična dovršenost v vsaki znamki
denis
im nobody
Prispevkov: 3321
Kraj: laško
Napisal/-a im nobody Sr jun 18, 2008 12:59 pm
men je pa prav lep
passat 1.9 tdi 110,235 nm
Na levi pas...do konca gas
frgo
Prispevkov: 555
Kraj: Trebnje
Napisal/-a frgo Sr jun 18, 2008 1:55 pm
Pri malo podobnih avtomobilih je na voljo tako kvaliteten 4 kolesni pogon in bokser motor :) Subaru je pač nekaj posebnega, pa naj bo zaradi mene še oblikovno.
Prispevkov: 11405
Napisal/-a martin_krpan Sr okt 21, 2009 7:28 pm
Exiga, po tem, ko jo je v roke vzel hišni tuner STI, kar pomeni modifikacije podvozja, aerodinamike in notranjosti.
Exiga 2.0GT:
Pod motornim pokrovom se nahaja 221 konjski turbo motor.
http://paultan.org/2009/10/21/subarus-s ... -in-tokyo/
Prispevkov: 11405
Napisal/-a martin_krpan So nov 28, 2009 9:52 pm
