Prispevkov: 11405
novi Renault Symbol/Thalia
Napisal/-a martin_krpan Po avg 18, 2008 1:18 pm
Predstavljen bo na salonu v Moskvi. A bo to tudi Dacia XL?
NEW RENAULT SYMBOL:
ELEGANCE AND SEDUCTIVE APPEAL:
Renault will shortly be releasing a new three-box model which features expressive, flowing lines. New Renault Symbol exudes an elegance that is underpinned by the status-enhancing design of its front end, as well as by its harmonious styling which is worthy of that of a prestigious saloon. Inside, the driver and passengers will appreciate the comfortable, carefully-appointed cabin. The range of sprightly petrol and diesel engine is at the market's leading edge when it comes to low fuel consumption, while the suspension and running gear have been engineered for comfort and efficiency.
The public will be given an opportunity to see New Renault Symbol at the
forthcoming Moscow Motor Show which opens on August 26.
Elegant, status-enhancing lines:
New Renault Symbol is a new three-box car that boasts expressive lines and seductive appeal.
Its length of 4.26 metres and height of 1.43 metres ensure nicely balanced proportions, while the design of the headlamps emphasizes the front end's status enhancing styling.
The harmonious side view is that of a prestigious saloon, while the robust lines of the rear are also suggestive of status. The presence of chrome trimming for the grille and rear panel adds a further note of refined distinction. The newcomer's seductive appeal and perceived quality are immediately apparent inside the cabin, too. New Renault Symbol also provides generous boot space which is as ideally suited to professional use as it is to a weekend in the country.
Economical to run and excellent roadholding:
New Renault Symbol is powered by a range of latest-generation engines, all of which combine performance, low fuel consumption and respect for the environment. These powerplants – whether petrol or diesel – are the most fuel efficient of this three-boxcar's category and make it truly economical to run. The front end's distinctive looks point to the vehicle's outstanding on-road performance and travelling comfort. New Renault Symbol benefits from the same suspension as Clio II which is acclaimed for the quality of the balance it strikes between comfort and roadholding and the quiet ride it delivers.
New Renault Symbol has plenty of arguments in its favour to win over families in Central and Eastern Europe, Russia, Turkey and the Maghreb countries. The first public airing of the latest addition to the line-up outlined in the Renault Commitment 2009 plan will be the forthcoming Moscow Motor Show, which opens its doors on August 26.
a_sist
Prispevkov: 1530
Napisal/-a a_sist Po avg 18, 2008 1:22 pm
Ojej :? Že Thalia je bla estetski polom.. To je pa polom2.
benf1
Prispevkov: 226
Pridružen: Po jun 18, 2007 1:47 pm
Kraj: Šentjernej
Napisal/-a benf1 Po avg 18, 2008 1:33 pm
avto se ne bo prodajal v SLO. drugače pa zgleda veliko lepše kot stara :D Po mojem bo na tej osnovi nastala tudi Dacia Logan "XL"
AudiFreak
Prispevkov: 1257
Kraj: Ried im Innkreis
Napisal/-a AudiFreak Po avg 18, 2008 1:36 pm
Na tem avtu je lepo oblikovana le mrežica v zračnikih spredaj in pa značka (reno) :P
frgo
Prispevkov: 555
Pridružen: So sep 18, 2004 5:11 pm
Kraj: Trebnje
Napisal/-a frgo Po avg 18, 2008 1:37 pm
Lepotec res ni, tako grd kot thalia pa vseeno ni. To je v osnovi clio 3?
Prispevkov: 11405
Napisal/-a martin_krpan Po avg 18, 2008 1:42 pm
Ne, ampak clio II:
New Renault Symbol benefits from the same suspension as Clio II...
Torej tehnično enak stari Thalii, ne? Samo karoserija je drugačna.
Polo78
Prispevkov: 1995
Kraj: Cockpit
Napisal/-a Polo78 Po avg 18, 2008 2:09 pm
Prvo ko sem videl slike sem pomislil, kot da bi gledal neko sodobno verzijo Renaulta 12, še sam nevem točno zakaj. :)
Antiznačkar po prepričanju
Napisal/-a Joie de vivre! Po avg 18, 2008 2:10 pm
Zakaj nismo tole objavli pod že obstoječo temo o Loganu XL, ki bi jo lahko samo preimenovali?
Prispevkov: 11405
Napisal/-a martin_krpan Po avg 18, 2008 3:54 pm
Ker nisem bil prepričan, če gre za enak avto kot Dacia XL. A ko gledam spy fotke Dacie, mislim, da bo res samo rebadged Thalia.
Predlog: izbriši tole mojo zadnjo objavo ter združi obe temi.
Napisal/-a Joie de vivre! Po avg 18, 2008 4:26 pm
Saj to bi naredil, itak, samo se ne da. Daj tam še enkrat objavi slike in dodaj tale link, ki ga bomo zaklenili.
