Prispevkov: 11405
2009 Volkswagen Phaeton facelift
Napisal/-a martin_krpan Sr okt 08, 2008 7:05 am
http://www.omniauto.it/awpImages/photog ... 8_58.jpgZa modelno leto je VW diskretno preuredil svojo admiralsko ladjo. Kljub slabim prodajnim rezultatom se tovarna, ne namerava še tako hitro umakniti iz luksuznega razreda.
http://www.zercustoms.com/news/2009-Vol ... aeton.html
http://thecarfanatic.com/wordpress/2008 ... #more-1952
Volkswagen Press Release:
A new infotainment system (RCS 810 and RNS 810) as well as an efficient V6 gasoline direct injection engine, now with 206 kW / 280 PS, characterize the Phaeton of model year 2009 that has been perfected in numerous details. For example, all engines satisfy the Euro-5 emissions standard in the new model year. Other modifications include: three new types of alloy wheels (17, 18 and 19 inch), a slightly modified radiator grille, three new car colors
(“Silver leaf metallic”, “Beryllium grey metallic” and “Mocca-anthracite pearl effect”), the new leather color “Corn Silk”, the new wood accents “Poplar grain latte macchiato“ and “Vavona”, switch illumination that is now white throughout instead of red, accent and switch trim in new “Warm grey” color, an upgraded car key, makeup mirror in the rear of the long version, dampers optimized for low-friction, ceramic brakes (front) for the Phaeton W12 as well as a rearview camera (Rear Assist). The new version of the high-tech sedan is being shown for the first time in the world at the Paris Motor Show. First deliveries of models are already slated for this year.
Control of climate control system and infotainment redesigned
The most in-depth revision on the Phaeton is a completely new center console design. A key component here: the new, standard RCD 810 infotainment system (radio variant) or the also new RNS 810 (optional navigation system variant).
To integrate the Phaeton’s new infotainment systems in a style that is as balanced as the prior
model’s solution, the center console was fully redesigned. This also involved changing controls for the four-zone automatic climate control (Climatronic): the tempe­rature is now set by rotary dial and is continuously displayed digitally above the control panel. The keys controlling individual ventilation functions were also redesigned. The intuitive control panel for climate control continues to be located beneath the infotainment system.
Newly developed: RCD 810 and RNS 810
The RCD 810 and RNS 810 infotainment systems with high-resolution 8-inch touchscreen in 16:9 format were redeveloped for the Phaeton. Take the example of the RNS 810: it unites numerous
multimedia functions such as an auxiliary TV hybrid tuner (option) and the “Premium” prep for Bluetooth mobile telephone with a very quickly responding navigation system, which accesses an integrated 30-Gigabyte hard drive. Furthermore, it is simple and easy to modify general vehicle settings via the touch­screen monitor. The higher-level menus are selected by eight additional keys to the left and right of the touchscreen. The signal of the optional rearview camera is also transmitted to the screen.
The integrated DVD drive can read out all commonly used audio formats and – when the vehicle is stationary – video films can also be played back over the monitor in brilliant image quality. There is also a slot for SD memory cards on the front of the unit. External MP3 players and similar data media can be interfaced via the MEDIA-IN (MDI) media socket. A Dynaudio system with an acoustic power of 1,000 Watt provides for exceptionally good sound.
As mentioned, the new RNS 810 unit’s range of use has been extended with a TV hybrid tuner. It enables reception of both analog and digital broadcasting stations (DVB-T). Its digital reception has an especially high image quality. In addition, the latest news can be called up via the integrated video text feature. TV reception is available as a special option on the RNS 810.
In combination with the optional “Premium” prep for a Bluetooth mobile telephone, the RNS 810 also makes telephoning easier. It is operated conveniently by pressing the “Phone” key on the left side of the 8-inch display. Further control, such as scrolling through the phone number memory or speed dialing can be performed via the 10-key numeric keypad shown on the screen. As an alternative, the telephone may be operated with ease from the multifunctional steering wheel, by voice control or an auxiliary mobile unit.
New V6 FSI, full conformance to Euro-5 standard
A new V6 gasoline engine being used in the Phaeton is an FSI engine (direct gasoline injection); it has 3.6 liter displacement and 206 kW / 280 PS. This engine is replacing the 3.2 liter V6 with 177 kW / 241 PS. The comfortable FSI develops a maximum torque of 360 Newton-meter, which is constantly available between 2,500 and 5,000 rpm and guarantees impressive high-torque performance. The maximum power of the twenty-four valve six cylinder is output at 6,250 rpm.
Powered in this way, the luxury sedan – with its standard 6-speed automatic, 4Motion all-wheel drive and electronically controlled air suspension – exhibits agile driving performance. The Phaeton V6 FSI reaches the 100 km/h mark from a stop in 8.6 seconds, and its top speed is electronically limited to 250 km/h. Its average fuel consumption is 11.7 liter Super. CO2 emissions were reduced from 288 g/km to 273 g/km.
Besides the new 3.6 liter FSI, the two other more powerful V8 and W12 gasoline engines with 246 kW / 335 PS and 331 kW / 450 PS, respectively, already satisfy the Euro-5 emissions standard that takes effect in September 2009. It was one of the first engines in the world to conform to this standard at the beginning of 2007, due to its extremely fuel-efficient V6 TDI with 3.0 liters displacement and common rail direct injection (171 kW / 233 PS).
Napisal/-a Slicker Sr okt 08, 2008 7:18 am
še em vrhunski izdelek. zame poleg cls mercedesa najlepši avto v tem razredu.
sašo5
Prispevkov: 5085
Kraj: Brežice
Napisal/-a sašo5 Sr okt 08, 2008 8:57 am
Piechovo maslo..... :roll: da pa prinaša milijon eur. izgube letno, pa nobenega ne zanima(bodo pa delavce odpustili, ter pri izdelavi novih cenejših modelov malo "škrtarili" na materialih........
Najbolje bi bili, če bi ga že "včeraj" nehali delat; kdo pa hoče tako limuzino, ima pa na voljo A8 ali alternativno A6.....
Legoless
Prispevkov: 271
Pridružen: To avg 21, 2007 1:35 am
Napisal/-a Legoless Sr okt 08, 2008 9:11 am
Grd. Grde linije, vse štirikotno in volan kot šlepar..
Dr.M3
Prispevkov: 1409
Napisal/-a Dr.M3 Sr okt 08, 2008 11:23 am
Zadevo je že malo načel zob časa. Predvsem zunaj. ;)
ps: volan se mi pa res dopade, čeprav je kopija tistega iz 7ice.
Žumi
Prispevkov: 95
Pridružen: Pe maj 11, 2007 12:47 pm
Napisal/-a Žumi Sr okt 08, 2008 11:43 am
avto ok za MESARJA iz VASI
:D
VW luxus --> no way
Shebo
Prispevkov: 1740
Kraj: Nuclear City
Napisal/-a Shebo Sr okt 08, 2008 11:55 am
S|icKeR je napisal/-a:še em vrhunski izdelek. zame poleg cls mercedesa najlepši avto v tem razredu.
Če pa ti vidiš CLSa in Phaetona v istem razredu :bonk
Hja, žal je bil ta avto velik kiks, saj se prodaja izredno slabo. Avto nima imidža in to ga najbolj tepe. Drugače je pa slišati, da je od ABM trojice najkvalitetneje sestavljen. Oblika je konzervativno lepa...
Tomcatter
Prispevkov: 1236
Napisal/-a Tomcatter Sr okt 08, 2008 1:20 pm
Preden je prisla ven nova 7ica jo je prehitel po prodaji. Se vedno enostavno lep.
martk
Prispevkov: 837
Pridružen: Ne jun 27, 2004 9:26 pm
Napisal/-a martk Sr okt 08, 2008 2:18 pm
Hja, na zunaj nič pretresljivega, klasična limuzina višjega razreda z vnebovpijočo ceno. Predsedniški avto, pač. Notranjost mi pa izgleda (spredaj) kot mrliška vežica. Samo še kaka ikebana manjka.
Martin
bl leti bl se zdi
To je posilstvo! Prav, kam pa greva?
rok46
Prispevkov: 2861
Napisal/-a rok46 Sr okt 08, 2008 2:23 pm
res dobr avto,samo kot so rekl, j**e ga znamka, ker se večina odloči za A8, katera naj bi bla tud malo bolše narejena, pa boljša za vozit
saj tko je oče od punce mi povedou, k je vozu oba dva.
5.0TDI pa itq trga gate :)
Mick Jerry
Prispevkov: 1259
Kraj: okolica Lj.
Napisal/-a Mick Jerry Sr okt 08, 2008 2:53 pm
Hu, sm pa že mislu, da so obupal s tem in so ga nehal delat. So pa vztrajni, ni kej :D
splash
Prispevkov: 2352
Napisal/-a splash Sr okt 08, 2008 3:13 pm
odlično!
koga pa briga če imajo tolko zgube z njim....
a slučajno koga briga, ker imajo na enem veyronu 5,5 mio € izgube? a to pa ni važno?
ne se hecat pa primerjat tole s skretom od a6. (a6 je dober avto, samo proti temu, je totalen sekret) iz prve roke vam rečem lestvico... s-klasse, phaeton, a8, serie 7 (za nemške) drugače pa se ls lexus, za moje pojme z lahkoto postavi ob bok s klassi
Napisal/-a IcEm4n Sr okt 08, 2008 5:10 pm
kje ma pa reže za zrak na armaturki?
splash
Prispevkov: 2352
Napisal/-a splash Sr okt 08, 2008 5:12 pm
ko prižgeš ventilacijo, se reže pokažejo ko se lesena panela odpre navzgor pod armaturo, in ko ugasneš, se panela spet zapre zaradi izgleda
ijuvan
Prispevkov: 398
Kraj: SG
Napisal/-a ijuvan Sr okt 08, 2008 5:24 pm
splash je napisal/-a:ko prižgeš ventilacijo, se reže pokažejo ko se lesena panela odpre navzgor pod armaturo, in ko ugasneš, se panela spet zapre zaradi izgleda
Koga pa zanima izgled armature, ko je avto ugasnjen in ni nobenega not :? razen za folk, ki tišči glave na okno pa zija not.
Dr.M3
Prispevkov: 1409
Napisal/-a Dr.M3 Sr okt 08, 2008 5:27 pm
Še ena stvar, ki bo problem pri nakupu 10 let starega voza in ki se lahko pokvari. :P
splash
Prispevkov: 2352
Napisal/-a splash Sr okt 08, 2008 5:33 pm
tko kot pri novem M3 bmw-ju, napihljive blazine v sedežih
mgost
Prispevkov: 16
Pridružen: Če jul 24, 2008 5:35 am
Napisal/-a mgost Sr okt 08, 2008 5:34 pm
Fenix_
Prispevkov: 212
Pridružen: Če apr 21, 2005 10:05 am
Kraj: Obala
Napisal/-a Fenix_ Sr okt 08, 2008 5:37 pm
TO JE ROČNA NA NOGO
mgost
Prispevkov: 16
Napisal/-a mgost Sr okt 08, 2008 5:38 pm
hvala :)
