Prispevkov: 11392
Novosti iz Mahindre
Napisal/-a martin_krpan Ne jan 18, 2009 1:02 pm
Indijska Mahindra je predstavila Xylo - multi-activity vehicle oz. križanec med enoprostorcem (za sedem oseb) in terencem. Seveda samo za domači trg.
Mahindra's all new people mover the Xylo hits showrooms today. Here's everything you need to know about it.
Styling:
The Xylo plays safe with its traditional two-box MPV design. Mahindra have probably avoided the mono-volume design keeping Indian tastes in mind. The Xylo is more like a SUV fused with a van. The front end though is quite quirky. The kinky headlamps top off a fussy and not so attractive face. We think the Xylo's most pleasing angle is the chunky rear.
Interiors & Equipment:
The Xylo comes loaded with great interior space and ground three rows of seats. You can choose between 7 or 8-seat configurations. The well-designed seats offer the right amount of cushioning and support. Four variants are on offer E2, E4, E6 and E8. Amongst other things the Xylo offers park sensors, a central information display (speed, current gear, temperature, humidity, distance to empty, average speed, speed limit alarm.. and more) and air-conditioning for all 3 rows of seats. Notably ABS and airbags are not on offer at the time of launch.
Engine:
The Xylo comes with the new mEagle engine. It is a 2.5litre CRDe engine that's been re-engineered from the 2.6CRDe unit seen on the Scorpio. The engine offers class leading 112bhp of power and 24kgm of torque, but refinement and NVH still isn't up to the mark. The gearbox is more precise though a bit of effort is still required. Interestingly the much more expensive 2.2 litre mHawk engine package is expected at a later date.
Ride and Handling:
The Xylo's soft suspension set up shows a clear bias towards in town passenger comfort. It glides over potholes and broken roads at low speeds but gets unsettled as speed builds up. The long wheelbase and soft suspension create a "swing" movement when changing lanes. But the suspension is more sorted and stable than the Scorpio; once again thanks to Lotus Design.
Pricing:
The Xylo aims to fill the gap between the Bolero and the Scorpio. Prices range from Rs 6.24 lakhs for the entry level E2 variant, going all the way up to Rs 7.69 lakhs for the top of the line E8 variant (ex-showroom Delhi). This makes the Xylo a great value proposition for Indian families and the tourist taxi segment in India.
http://www.zigwheels.com/cars_in_india/ ... 0113--1--1
http://www.zigwheels.com/b2cam/slideSho ... eShow=Xylo
http://worldcarinfo.com/Mahindra-XYLO/c ... -1459.html
One of the most revolutionary features of the XYLO is the tech-savvy Digital Drive Assist System (DDAS). An alphanumeric display in the centre panel, the DDAS has features such as an onboard computer to calculate mileage and distance permissible. The system is easy to read and provides useful data at a quick glance. Standard information available includes date, time, inside and outside temperature and relative humidity. It also lets you know exactly which direction your Mahindra XYLO is headed in. Press a button and you are informed of your gear position and speed. The DDAS will even tell you how long your fuel will last and share information on your average speed and the instant mileage clocked by you. All of which ensures that you derive optimum mileage from your Mahindra XYLO.
od kdaj je BC s kompasom takšna revolucionarna novost...
Prispevkov: 11392
Napisal/-a martin_krpan Pe feb 27, 2009 6:46 pm
Xylo napoveduje tudi novo Mahindrino govorico. Njegov obraz bodo postopoma dobili tudi drugi avtomobili. Prvi je na vrsto prišel terenec Scorpio, prenovljen za leto 2009.
http://autoindia.org/scoop-mahindra-sco ... vealed.htm
Napisal/-a Joie de vivre! Pe feb 27, 2009 11:04 pm
Glede na konfiguracijo svetil bi si upal trditi, da je tale Mahindra pripravljena na ameriški trg.
sandek
Prispevkov: 1043
Kraj: maribor-metropola
Napisal/-a sandek Pe feb 27, 2009 11:33 pm
pa to kdo sploh kupi? (upam da nisem koga s tem užalil) :oops:
en klub-ena čast________nk maribor
ESTEMP
Prispevkov: 684
Kraj: gorenjska
Napisal/-a ESTEMP So feb 28, 2009 12:01 am
Za to znamko avtomobila pa prvic slisim.V notranjosti mi materijali delujejo zelo ceneni :?
Napisal/-a esem So feb 28, 2009 12:14 am
ESTEMP je napisal/-a:Za to znamko avtomobila pa prvic slisim.V notranjosti mi materijali delujejo zelo ceneni :?
Obstajajo že več kot 50 let!
http://en.wikipedia.org/wiki/Mahindra_% ... ra_Limited
Pred dobrim letom so dobili japonsko nagrado za kvaliteto za kmetijsko mehanizacijo
http://machinist.in/index.php?option=co ... 4&Itemid=2
Ivan36
Prispevkov: 4577
Napisal/-a Ivan36 To mar 03, 2009 6:59 pm
sandek je napisal/-a:pa to kdo sploh kupi? (upam da nisem koga s tem užalil) :oops:
Ja fant to je za nijh X5 ali pa MB ML tko je kaj čemo. :D samo, da peš ne
hodijo .
Evo pri naših sosedih so novi http://www.autoscout24.it/Details.aspx?id=152671849
http://www.autoscout24.it/Details.aspx?id=134794515 to je razviti trg za delo so odlični .
http://www.autoscout24.it/Details.aspx?id=155079049 2.5CRDe 2008 :D :idea:
evo slika ene z snorklom http://www.autoscout24.it/AllImages.aspx?id=149432556#
Napisal/-a Joie de vivre! Sr mar 04, 2009 5:25 pm
Kolikor sem prebral vtisov, gre za precej kvaliteno robo, ki se je na da primerjati z raznimi kitajskimi kopijami isuzuja.
Prispevkov: 11392
Napisal/-a martin_krpan Sr okt 28, 2009 7:45 pm
Mahindra je predstavila novi majhen tovornjak Gio. Po njihovih trditvah gre za prvi štirikolesni tovornjak v kategoriji nosilnosti pol tone (konkurenca ima kolo manj). Tudi Gio je nastal iz Mahindrinega trikolesnika Champion.
http://www.cubiccapacity.com/mahindra-l ... act-truck/
Konkurenco mu predstavljata večja Tata Ace in Force M4.
Zadnjič spremenil martin_krpan, dne Sr mar 17, 2010 10:05 am, skupaj popravljeno 1 krat.
PIKSNA007
Prispevkov: 1161
Napisal/-a PIKSNA007 Če okt 29, 2009 4:16 pm
Hvala enako meni se tudi ne zdi niti malo všeč :?
Prispevkov: 11392
Napisal/-a martin_krpan Po apr 05, 2010 4:47 pm
Mahindrina novost v 2010 je Thar - čistokrvni terenec, kopija legendarnega Jeepa. Narejen je predvsem za evropske države (prodaja se tudi v domovini), poganja pa ga 2,5 litrski TD s 107 konji. Dimenzije so (d*š*v) 392 * 171 * 193 cm. V Italiji na primer stane malček nad 17.000 EUR.
Prispevkov: 11392
Napisal/-a martin_krpan Po okt 11, 2010 6:27 pm
2011 Bolero Attitude. Tudi za najslabše, kar indijske ceste lahko ponudijo.
http://www.autoblog.com/2010/10/07/mahi ... -its-name/
CITROENAR ŠT 1
Prispevkov: 1483
Napisal/-a CITROENAR ŠT 1 Če okt 21, 2010 9:56 pm
Eksotika, ni kaj ;)
Prispevkov: 11392
Re: Mahindra Xylo in ostale novosti
Napisal/-a martin_krpan Ne jan 30, 2011 10:22 am
Novi Mahindra Genio, pick-up na osnovi Xylo. Nosilnost 1,25 tone. Motor je 75 konjski 2,5 CRDI. Serijska oprema je skroman, vključuje pa metal barvo.
http://indianautosblog.com/2011/01/mahi ... nformation
http://www.team-bhp.com/forum/indian-ca ... india.html
Prispevkov: 11392
Napisal/-a martin_krpan Sr jul 13, 2011 8:38 pm
Indijci so sedaj prikazali še Genio z dvojno kabino (štirimi vrati) in petimi sedeži:
Malce prej pa je bil predstavljen novi Maxximo Mini Van. Gre za kombi z 8 sedeži, narejen za podeželje, kar je razvidno iz same oblike in špartanske notranjosti. Poganja ga dvovaljni dizelski motor z 25 konji.
Črno pokrivalo sredinskega bočnega okna je iz skaja in se lahko dvigne (kot pri soft top terencih):
http://www.team-bhp.com/forum/attachmen ... window.jpg
Zadnje steklo se lahko rahlo odpre navzven (kar je novost v tem razredu):
http://www.team-bhp.com/forum/attachmen ... erfuly.jpg
Sprednja sedeža ne nudita nikakršne bočne opore:
http://www.team-bhp.com/forum/attachmen ... s-seat.jpg
Takšni avtomobili niso naprodaj v večjih mestih, saj ne zadovoljujejo emisijskih predpisov, ki veljajo za urbana področja.
Več na:
http://www.team-bhp.com/forum/commercia ... -lacs.html
Napisal/-a Joie de vivre! Po jul 18, 2011 10:36 pm
martin_krpan je napisal/-a:Indijci so sedaj prikazali še Genio z dvojno kabino (štirimi vrati) in petimi sedeži:
Tale zadek me spominja na VW T3, samo tako, by the way:)
Mi je pa všeč, ker Indijci sledijo svoji filozofiji, imajo svoje znanje in svoj dizajn. Vsa čast jim.
Prispevkov: 11392
Napisal/-a martin_krpan Če sep 08, 2011 6:20 pm
Bolero, Mahindrin najbolje prodajani proizvod (in hkrati najbolj priljubljen SUV v Indiji) je prenovljen.
stari model:
http://indianautosblog.com/2011/09/mahi ... d-brochure
Prispevkov: 11392
Napisal/-a martin_krpan Če sep 29, 2011 6:19 pm
Mahindra je včeraj predstavila svoj prvi moderni SUV poimenovan XUV 500. Namenjen je tudi izvozu in temu primerno opremljen - LED dnevne luči, ESP, 6 zračnih blazin,... Motor je 2,2 mHawk iz Scorpia.
Glede na dosedanje izdelke te tovarne je XUV 500 več kot solidno oblikovan. Všeč mi je predvsem športna bočna linija. Ne vem pa, kaj je zadelo oblikovalce med oblikovanjem sprednjega dela. Že maska izgleda kot tujek, o vdolbinah (imitaciji rež za zajemanje zraka) na odbijaču pa je škoda besed. Z minimalnimi popravki bi občutno izboljšali obliko. Notranjost ima preveč rjave barve in umetnega lesa za moj okus. Poleg črne plastike je moč izbrati tudi beige.
več fotografij in podatkov na:
http://es.autoblog.com/2011/09/29/ofici ... ra-xuv500/
http://www.zigwheels.com/news-features/ ... ure/9792/1
http://www.cartradeindia.com/car-bike-n ... 14647.html
Prispevkov: 11392
Napisal/-a martin_krpan So okt 15, 2011 7:59 am
XUV500 je z atraktivno ceno povzročil vliko zanimanje med indijsko javnostjo, narašča tudi število prednaročil. BHP ga je že testiral:
http://www.team-bhp.com/forum/official- ... eview.html
še nekaj zanimivosti.
LED lučke (ki pa nimajo funkcije dnevnih luči):
logotip na steklu zadnjih luči:
ambientalna osvetlitev v sprednjih vratih:
infotainment sistem z zaslonom, občutljivim na dotik:
Zois
Prispevkov: 988
Kraj: Slovenska Bistrica
Re: Novosti iz Mahindre
Napisal/-a Zois So jan 28, 2012 6:28 pm
Kaj genio pa maximo serijsko niti gretja nimata ?????
Slika pugi.si
Po forumu brska: 0 registriranih uporabnikov in 132 gostov
