Ali bi ga imeli?
Da
32
68%
Ne
15
32%
Skupaj glasov : 47
Mih@
Prispevkov: 404
Pridružen: So okt 18, 2003 3:41 pm
Kraj: Smlednik
McLaren F1
Napisal/-a Mih@ So okt 18, 2003 3:51 pm
Kaj bi dau da bi meu ta avto! :roll: Poglejte te podatke (ne da se mi prevajat):
DIMENSIONS
LENGTH 4288mm
(168.8")
WIDTH 1820mm (71.6")
HEIGHT 1140mm (44.8")
GROUND CLEARANCE 120mm (4.7")
WHEELBASE 2718mm (107.0")
FRONT TRACK 1568mm (61.7")
REAR TRACK 1472mm (57.9")
KERB WEIGHT 1140kg (2508lb's)
WHEELS
Magnesium 17" (432.8mm)
FRONT
9" (228.6mm) wide
REAR
11.5" (292.1mm) wide Centre lock with reatining pin
TYRES
Front- Goodyear F1 235/45 ZR17
Rear- Goodyear F1 315/45 ZR17
Unidirectional with asymmetric tread pattern
GENERAL
ELECTRICS
12 Volt system with high capacity battery & 160 amp alternator speed ,Chassis ECU,Engine ECU, DC/DC convertor for heated glass
TRANSMISSION
Transverse unit with high speed bevel gears and spur final drive. All synchro constant mesh six limited slip differential Air/Oil radiator pumped lubrication system
OIL TANK
6 ltr (1.3 gallon) Aluminium
Shell Helix Ultra lubricant
FUEL TANK
90 ltr (19.8 gallon) Safety fuel tank, 98 ron unleaded
COOLING SYSTEM
Twin aluminium water radiators and oil/water heat exchanger
FUEL SYSTEM
Flexible safety fuel cell with in-tank high pressure
CLUTCH
AP Triple plate carbon/carbon 200mm (7.87") diameter, remote actuation(hydraulic)
AERODYNAMICS
C.D - 0.32 Frontal area 1.79 M2 Full underbody air management (fan assisted) Driver selectable high downforce mode. Automatic brake and balance aerofoil system
TYPE NUMBER
S70/2 VIEW ENGINE
CONFIGURATION
V12
V-ANGLE
60° DEG
DISPLACEMENT
6,064 CC
STROKE
87.00mm
COMPRESSION RATIO
11:1
IGNITION SYSTEM
Transistorised with 12 individual coils
INDUCTION SYSTEM
12 single throttle valves, carbon composite airbox
VALVE TRAIN
Chain driven double overhead camshafts with continuously variable inlet valve timing
ENGINE BLOCK Cast Aluminium 60 V12
CYLINDER HEADS 4 valves per cylinder, cast aluminium alloy
FLYWHEEL Aluminium
CAM CARRIERS/COVER
Cast Magnesium
EXHAUST EMISSION CONTROL
4 Catalytic convertors with Lambda sensors, secondary air injection
ALTERNATOR
160 Amp
LUBRICATOR SYSTEM Dry Sump, magnesium casting with four scavenge pumps and one pressure pump
FUEL 95-98 RON Unleaded
OIL Shell TMO synthetic 5W40
POWER 627 bhp @ 7,500 rpm
TORQUE
480 lb/ft @ 5,600 rpm
MAX RPM
7,500 rpm
SUSPENSION
FRONT
Double wishbones,
Ground Plane Shear centre sub frames, light alloy dampers /co-axial coil springs, anti roll bar
REAR
Double wishbones, inclined Axis Shear mounting system, light alloy dampers/co-axial coil springs, toe-in/toe-out control links
BRAKES
FRONT 332mm diameter x 32 (13.07" x 1.26") ventilated disc four piston monobloc light alloy caliper
REAR 332mm diameter x 26mm thick (12.01" x 1.02") ventilated disc four piston monobloc light alloy caliper
PARKING BRAKE
Rear, mechanical light alloy caliper
BRAKE AND BALANCE FOIL Automatic computerised control system
BRAKE COOLING
Pa še hitrosti:
Price: $890,000
Miles Per Gallon: 12 mpg
Curb Weight: 2840 lbs
Layout: Mid-Engine/RWD
Transmission: 6-Speed Manual
Engine
Type: V12
Displacement: 6064 cc
Horsepower: 627 bhp @ 7400 rpm
Torque: 479 lb-ft @ 4000 rpm
Redline: 7500 rpm
Performance
0-60 mph: 3.2 sec
0-100 mph: 7.7 sec
Quarter Mile: 11.6 sec @ 125 mph
Skidpad: .86g
Top Speed: 240 mph
Braking, 60-0 mph: 127 ft
Slalom Speed: 64.5 mph
Ampak kaj k jih je blo sam 64 narejenih. :( Tle mate pa še fotogalerijo http://www.fast-autos.net/mclaren/mclarenf1.html
http://mr.si/
MGsax
Prispevkov: 3380
Napisal/-a MGsax So okt 18, 2003 8:08 pm
anketa se mi zdi neumna ker tisti ki reče da ga nebi imel laže.
imel bi vsak avto če bi mi ga kdo dal.
kupil pa tistega katerega si lahko privoščim
Stran za najmočnejše
McLaren
Prispevkov: 3434
Kraj: Cela EU
Napisal/-a McLaren So okt 18, 2003 8:08 pm
Itaq, da ga bi mel.....mislim kakšno vprašanje :wink:
.::GTR::.
Prispevkov: 1156
Pridružen: So mar 15, 2003 1:59 pm
Kraj: Gorenjska
Napisal/-a .::GTR::. So okt 18, 2003 8:16 pm
bi. šu bi na en test drive poj bi ga pa koj prodov.
Mih@
Prispevkov: 404
Kraj: Smlednik
Napisal/-a Mih@ So okt 18, 2003 10:31 pm
Sam pazi to mašino! Slika Že taka mašina gre 390 km/h kva šele če bi jo mau napilu pa kakšn NOS sistem! Sam preden bom tok našparu! :( Mogl bi jih bit več da bi bli cenejš! Al pa da ga Rowanu Atkinsonu spizdiš :lol: To tut nom naredu! Ja no! Bill Gates Help! F1!
http://mr.si/
CupraR
Prispevkov: 4634
Napisal/-a CupraR So okt 18, 2003 10:35 pm
Un od Rowanu Atkinsona se ne splača spizdit-je bil že razsut :lol: :lol:
just_in
Prispevkov: 2119
Pridružen: Pe jun 27, 2003 11:40 am
Kraj: gorenjska :)
Napisal/-a just_in So okt 18, 2003 10:41 pm
FUEL TANK
90 litrov x 185,7 sit/liter = 16713 sit :shock:
da greš enkrat tankat... :cry:
po ti pa prasc še ful kur... :) jao , drag avto bi bil ja... :P
R52RBO
Prispevkov: 37
Pridružen: Po sep 15, 2003 11:45 pm
Kraj: celje
Napisal/-a R52RBO Ne okt 19, 2003 2:13 pm
Če bi ga po kakšni neumnosti dobil, bi se potrudil, da bi ga čimprej prodal ( glej ceno !!!!! ). Pol pa za lep čas roke za vrat in noge u zrak.......... ( kar mi gre že zdaj prav doboro od rok :lol: :lol:
Omelo
Prispevkov: 2051
Napisal/-a Omelo Ne okt 19, 2003 2:36 pm
just_in... tankat moraš 98... tko da 191 :)
GIA
Prispevkov: 271
Pridružen: Če okt 09, 2003 5:04 pm
Napisal/-a GIA Ne okt 19, 2003 3:16 pm
:o :o huda makina...
Miha sorry,sam jst mislm,da neboš našparu tok dnarja...
če pa boš,pa mislm,da ti bo škoda vse vršt za en avto..lahk kupš 3.. :?
Crazy Fighter
Prispevkov: 117
Pridružen: Pe okt 03, 2003 12:54 pm
Napisal/-a Crazy Fighter Ne okt 19, 2003 3:31 pm
slaba anketa....tudi ce ga bi dubil kaj naj z njim???.....ni dnarja za tankat kaj sele za servise...hm...pa registracija...am....nebi ga mel :oops:
BaSe
Prispevkov: 1350
Pridružen: Če dec 26, 2002 2:47 am
Napisal/-a BaSe Ne okt 19, 2003 3:47 pm
just_in je napisal/-a:
FUEL TANK
Ja kolko pa pije, 40l na 100Km :?: :? :?
alexM
Prispevkov: 599
Pridružen: To sep 02, 2003 6:43 pm
Napisal/-a alexM Ne okt 19, 2003 5:13 pm
Najlepse na motorju .BMW M POWER :D
Basist
Prispevkov: 224
Pridružen: To jul 15, 2003 10:01 am
Napisal/-a Basist Po okt 20, 2003 2:37 pm
lp,
Gregor
Sometimes I'm good... But when I'm bad I'm even better!!!!!!!
Sportivo
Prispevkov: 1762
Kraj: Cerkno
Napisal/-a Sportivo Če nov 06, 2003 8:20 pm
FUEL TANK
Ta stari jaguari so mel dva po 75l.
Shatzy
Prispevkov: 700
Pridružen: So apr 19, 2003 11:40 am
Napisal/-a Shatzy Če nov 06, 2003 8:32 pm
hm...neki mi ne gre v glavo...zakaj na Mclarnoumu motorju piše mbw m power?!? A ni mclaren v navezi z mecami? :?:
Drgač bi ga pa meu ja...pa še eno naftno vrtino bi si kupu...
mitja320
Prispevkov: 327
Pridružen: Pe avg 29, 2003 2:15 pm
Napisal/-a mitja320 Ne nov 23, 2003 3:12 am
Shatzy je napisal/-a:hm...neki mi ne gre v glavo...zakaj na Mclarnoumu motorju piše mbw m power?!? A ni mclaren v navezi z mecami? :?:
Ta motor je sestavljen iz dveh E36 M3 motorjev (3.0), podobno kot BMW 850 (mislim da CSI) iz dveh 2.5.
perimund
Prispevkov: 633
Pridružen: Po sep 08, 2003 3:23 pm
Kraj: Monaco
Napisal/-a perimund Po nov 24, 2003 12:26 am
slurp
:shock:
sanje vsakega BMWjaša!
