Prispevkov: 11405
2011 Ferrari 599 GTO
Napisal/-a martin_krpan Če apr 08, 2010 2:32 pm
Revealed on www.ferrari.com: the new 599 GTO - The fastest ever road-going Ferrari will be unveiled to the public at the Beijing Motor Show
Maranello, 8 April – Now available on www.ferrari.com are the first photos and information on the new 599 GTO, an extreme V12 berlinetta developed to a specific performance-oriented brief. The 599 GTO is, in fact, the company's fastest ever road car. It is an exclusive limited edition special which, in true Ferrari tradition, is a completely new concept, albeit inspired by a production car. In fact the 599 GTO is based on the 599XX, the advanced experimental track car, and can be considered almost a road-going version.
The 599 GTO is reserved for just 599 clients who seek the maximum expression of high-performance driving. The 599 GTO benefits directly from the technological transfer from racing and set a record lap time at Fiorano in 1'24".
The Fiorano lap time provides just one indication of the potential of this car. Just as significant are the technical specifications – 670 hp in a 1495kg car represents a weight-to-power ratio of just 2.23 kg/hp, and ensures a 0-100 km/h acceleration time of just 3.35" as well as a top speed of over 335 km/h.
Fundamental to the GTO's performance is the innovative approach to chassis development which, for the first time on a production car, saw the integration between a handling set-up tuned for a level of responsiveness that is close to the limit and highly sophisticated electronic controls. The result is the almost complete absence of understeer and a truly communicative chassis.
As is Ferrari's policy, every new Ferrari features new solutions for a road car. Thus the 599 GTO is equipped with the latest, second-generation carbon-ceramic brakes which are lighter and offer better performance, new aerodynamic innovations, such as the wheel doughnuts which increase aerodynamic efficiency as well as improve brake cooling, and the Supersport tyres developed by Michelin include a wider front tyre for greater roadholding. The driver-car interface is also new with the adoption of the Virtual Race Engineer (VRE) which provides the driver with instantaneous information on performance.
The 599 GTO's more aggressive character is also apparent in a number of styling elements that recall the 599XX and from the powerful sound of the V12.
The GTO (Gran Turismo Omologata) moniker instantly calls to mind two Ferraris that have entered the collective imagination as symbols of performance. After the 1962 250 GTO, which swept the boards in GT racing categories in the 1960s and is now a highly prized collector's car, came the iconic 1984 GTO, which basically invented the entire modern supercar genre.
The web special includes photos, videos and interviews on the new car, while an exclusive preview for a small number of Ferrari clients will be held on April 14th at the Military Academy in Modena. The public debut of the 599 GTO will instead be at the Beijing International Motor Show at the end of April.
599 GTO TECHNICAL CONTENTS
ENGINE AND GEARBOX
The 599 GTO's engine is directly derived from the 599XX unit implementing, however, the necessary modifications for road-going homologation. It thus complies with Euro 5 and LEV 2 standards. The 5999 cc 65-degree V12 engine punches out 670 CV at 8250 rpm with maximum torque of 620 Nm at 6500 rpm and there is a smooth, constant rush of power all the way to the redline with no loss of flexibility even at medium and low revs. This result was obtained by working on the fluid-dynamics and components to reduce internal friction and by adopting, amongst other things, the 599XX's redesigned crankshaft. The car also has a racing-type intake system with a new manifold with diffuser-type intake geometry and short inlet tracts designed to improve power delivery at high revs and reduce losses. To maximise volumetric efficiency per cylinder, a connection between the two plenums at the front compensates for variations in the volume. This is how the engineers managed to achieve maximum performance at high engine speeds. The engine sound inside the car is carefully controlled to balance the intake sound with the exhaust, which features a 599XX-derived 6-into-1 manifold.
The 599 GTO features the same, lower 60 ms shift times and the possibility to make multiple downshifts as on the 599XX.
VEHICLE DYNAMICS
One of the most significant innovations on the 599 GTO is the close correlation between the chassis set-up, which is close to the handling limit, and the input from the electronic controls which are developed to increase overall levels of performance.
Since the very earliest states of the two cars' development, Maranello's engineers worked to ensure that these two areas of the car would be seamlessly integrated thus pushing responsiveness to the limit. The result is, of course, superlative driving involvement as well as faster lap times. Apart from new springs and a stiffer rear anti-roll bar, the car also features a second generation magnetorheological suspension control system (SCM2). The suspension works in tandem with the VDC (Vehicle Dynamic Control) and latest-generation F1-Trac traction control. This makes the car extremely responsive to driver inputs - thanks in part to the adoption of a very direct steering ratio – but also very stable under braking, sharper on turn-in, more precise in cornering and quicker out of corners.
WEIGHT REDUCTION
The 599 GTO inherits much of the development work - using the same principles as employed in F1 - that went into making the 599XX such an extreme performance car. Reducing weight was a vital objective and the result was the widespread use of composites and components manufactured with technologies more akin to racing specifications. The areas involved include the bodywork and greenhouse (with thinner gauge aluminium and thinner glass), the brakes, transmission and exhaust system. The result is a dry weight of 1495 kg and a weight-to-power ratio of just 2.23 kg/hp, a very significant figure that underlines the GTO's performance potential.
AERODYNAMICS
The 599 GTO's aerodynamics have benefited significantly from Ferrari engineers' experience in F1 and with the 599XX which allowed downforce to be greatly increased without impacting on drag. Thanks to solutions transferred from the track car to the road-going version, the GTO generates downforce of 144 kg at 200 km/h. The entire car was honed, including the front, the sides, the flat underbody and cooling flows. In the latter instance, the GTO can count on improved ducting to the brake discs and pads, and the adoption of wheel doughnuts – a disc positioned outside the brake disc that ensure that hot air exiting the wheelarch stays as close to the body of the car as possible to reduce drag.
Work on the nose of the car was aimed at reducing the width of the wake generated by the front and thus reduce drag. The front spoiler incorporates a separate lower wing that increases downforce at the front of the car and increases the flow of cooling air to the oil radiator. On the flanks there's a new sill design with a more pronounced leading edge that improves the efficiency of the central section of the underbody. The underbody itself incorporates a new, lower front section with diffusers ahead of the front wheels to optimise downforce, and a new double-curve rear diffuser.
WHEEL RIMS AND TYRES
Here the difference in size between the front and rear tyres has been changed. The GTO's front tyres are now 285/30 on a 9.5'' channel with 315/35 on an 11.5'' channel at the rear. The 599 GTO has 20'' rims. Roll rigidity is greater at the rear to minimise understeer. These solutions guarantee improved lateral grip and quicker turn in.
BRAKES
The new CCM2 braking system is lighter and even more consistent in high performance situations. Its consistent coefficient of attrition meant that the ABS could be calibrated to a particularly high performance level, further reducing lap times, thanks to improved deceleration and shorter stopping distances. In fact, the 599 GTO boasts an excellent 100 to 0 km/h braking distance of just 32.5 metres. As well as their role in improving aerodynamics, the Formula 1-derived wheel doughnuts also improve braking efficiency by optimising brake cooling.
CAR-DRIVER INTERFACE
The car-driver interface was designed to maximise car and driver performance with a layout of the main commands that ensures absolute efficiency and minimum distraction. The Racing manettino also puts the emphasis firmly on sporty, track-specific driving settings by offering the driver full choice with regard to the electronic control parameters. The ICE position on the 599 GTB Fiorano has been replaced by CT-Off (traction control off). The GTO is also fitted with bespoke, longer carbon-fibre F1 paddles for easier use in high-speed driving. In addition the GTO also features the Virtual Race Engineer, a system that monitors the status of the car and gives the driver immediate visibility of vehicle performance.
599 GTO technical specifications
DIMENSIONS AND WEIGHT
Length: 4710 mm (185.4 in)
Width: 1962 mm (77.2 in)
Height: 1326 mm (52.2 in)
Wheelbase: 2750 mm (108.3 in)
Front track: 1701 mm (67.0 in)
Rear track: 1618 mm (63.7 in)
Dry weight*: 1495 kg (3296 lbs)
Kerb weight*: 1605 kg (3538 lbs)
Weight distribution: 47% front – 53% rear
Fuel tank capacity: 105 litres (27.7 US gal/23.1 UK/gal)
Boot volume: 320 litres (11.3 cu ft)
ENGINE
Type: V12 – 65°
Bore & stroke : 92 x 75.2 mm (3.62 x 2.96 in)
Unitary displacement: 499.9 cc (30.51 cu in)
Total displacement: 5999 cc (366.08 cu in)
Compression ratio: 11.2:1
Maximum power: 500 kW (670 CV) at 8250 rpm
Maximum torque : 620 Nm (457 lbs/ft) at 6500 rpm
GEARBOX
F1 6–speed + reverse
SUSPENSION
SCM2 – Magnetorheological Supension Control
TYRES
Front: 285/30 ZR20''
Rear: 315/35 ZR20''
CARBON-CERAMIC BRAKES
Front: 398 x 38 mm (15.7 x 1.5 in)
Rear: 360 x 32 mm (14.2 x 1.3 in)
ELECTRONIC CONTROLS
CST with F1-Trac: Traction and stability control
TPTMS: Tyre pressure and temperature monitoring system
PERFORMANCE
Maximum speed: over 335 km/h (over 208 mph)
0-100 km/h (0-62 mph) : 3.35 sec
FUEL CONSUMPTION
Combined cycle (ECE)*: 17.5 l/100 km
CO2 EMISSIONS
Combined cycle (ECE)*: 411 g/km
*European version
http://www.autoweek.nl/autonieuws/13977 ... rrari-ooit
carloabarth
Prispevkov: 1059
Napisal/-a carloabarth Če apr 08, 2010 5:53 pm
Hudobija :twisted:
Fiat klub Slovenija
FLINK
Prispevkov: 1065
Pridružen: To jul 29, 2003 3:34 pm
Napisal/-a FLINK Če apr 08, 2010 6:32 pm
Poezija 8) 8) Karkoli pride ven, so samo zelje.... :shock:
_BANDIT_
Prispevkov: 1111
Napisal/-a _BANDIT_ Če apr 08, 2010 6:38 pm
Lep je.
http://www.zup-racing.com/
simply
Prispevkov: 3065
Kraj: Nova Gorica
Napisal/-a simply Če apr 08, 2010 6:47 pm
Čista erotika.
Matey_
Prispevkov: 1477
Kraj: Postojna
Napisal/-a Matey_ Če apr 08, 2010 7:22 pm
Zadnje čase sem že biu malo zazočaran nad Ferrarijem (California in Italia), ker so se mi zdeli nekako preveč pomehkuženi (predvsem California) ... but the lunacy is back =P
Res meni osebno veličasten Ferrari :D
Like it a lot =P
Matej
bam88
Prispevkov: 511
Pridružen: To jan 09, 2007 10:20 pm
Napisal/-a bam88 Če apr 08, 2010 8:32 pm
zgleda ko corvette
Renault Clio 1.8 16V l. 1993
M156
Prispevkov: 159
Pridružen: Če apr 10, 2008 11:44 pm
Napisal/-a M156 Če apr 08, 2010 10:24 pm
eden najlepših in najboljših Ferrarijev :D
edina stvar ki me moti pri Ferrariju je njihova nezanesljivost in ranljivost kar se tiče požara...uničenje menjalnika, strojelom, slaba kvaliteta izdelave :roll:
Drgač pa lep in močan...za v zbirko :D
takojšna klasika je tole 8)
pikoli
Prispevkov: 41
Pridružen: Pe jan 08, 2010 4:10 pm
Napisal/-a pikoli Če apr 08, 2010 11:53 pm
M156, kje si pa ti gor rasu?
De_Tomaso
Prispevkov: 963
Pridružen: Pe mar 12, 2004 1:02 am
Napisal/-a De_Tomaso Pe apr 09, 2010 6:18 am
Glede na to kako ribajo motorji poršejem, mislim da se ferrari zaenkrat nima še česa bati :lol:
Vprašanje podnebnih sprememb zaradi naše potrošnje ni vprašanje stroškov, ampak vprašanje naše morale.
King1
Prispevkov: 4317
Kraj: Vzhodno od Domžal
Napisal/-a King1 Pe apr 09, 2010 6:50 am
Hudo hudo dober stroj izgleda tole. :shock: 8)
Tattoo-
Prispevkov: 1318
Kraj: Circuit de la Sarthe
Napisal/-a Tattoo- Pe apr 09, 2010 8:40 am
M156 je napisal/-a:edina stvar ki me moti pri Ferrariju je njihova nezanesljivost in ranljivost kar se tiče požara...uničenje menjalnika, strojelom, slaba kvaliteta izdelave :roll:
pikoli je napisal/-a:M156, kje si pa ti gor rasu?
De_Tomaso je napisal/-a:...mislim da se ferrari zaenkrat nima še česa bati :lol:
Kar se kvalitete Ferrarija tiče vse le ni tako rožnato, kot ste nekateri očitno tako sveto prepričani...
Auto Motor und Sport je napisal/-a:Und es gibt weitere Kritikpunkte: Der Auspuff dröhnt zwischen 1.500 und 2.500/min, der linke Außenspiegel zittert, aus dem schlecht eingepassten Dach dringen Geräusche, das Lenkrad steht schief, der Fensterheber-Schalter springt beim Ziehen heraus, der Tankdeckel klemmt, und die serienmäßige Keramikbremse arbeitet zwar hervorragend, macht jedoch durch Schaben auf sich aufmerksam.
Auto Motor und Sport: Ferrari California
Uribobo
Prispevkov: 455
Napisal/-a Uribobo Pe apr 09, 2010 9:17 am
zdej si pa predstavlej da daš 200K eurov za tak avto pol ti pa knofi stan padajo
:jao: :/:o:/ :ne
Misak
Prispevkov: 809
Kraj: Grosuplje
Napisal/-a Misak Pe apr 09, 2010 10:31 am
Ampak Ambi Pura nimaš pa nikamor postavit... Vse kar ti pustijo je dišeča smrekca : 8)
Bemti je lep... Če pa knofi odpadajo, mislim da se ne bi preveč sekiral, večina ljudi namreč ta avto še vedno vidi samo z zunanje strani :D Tam je pa :yum
In ženskam bencin!
De_Tomaso
Prispevkov: 963
Napisal/-a De_Tomaso Pe apr 09, 2010 7:20 pm
@M156
Lahko ti iz prve roke povem, da je pri 996tkah in 997kah še manj rožnato, pa si vzami kakor si hočeš. Lahko tudi kaj brskaš po netu in boš tudi na to temo kaj našel ali pa vprašaj kakšnega lastnika, ki ti bo upal po resnici povedat.
dav911
Prispevkov: 107
Pridružen: Ne mar 02, 2008 12:39 pm
Napisal/-a dav911 Sr apr 21, 2010 8:29 pm
Glede kvalitete izdelave Ferrari še dolgo (nikoli) ne bo ujel Porscheja. Imamo doma 997, izdelava je vrhunska...ne vem od kje vam ta podatek za 997...za 996 je pa drugačna zgodba ja :)
Pa mi je Ferrari zelo všeč...sam ne basat v 3 krasne...Ferrari ima svoje prednosti, Porsche pa svoje (in tu je definitivno tudi kvaliteta!)
Vsak avto je ql...no skoraj :)
nalcoq4
Prispevkov: 515
Pridružen: Sr jul 15, 2009 6:58 pm
Kraj: Ljubljana - Bežigrad
Napisal/-a nalcoq4 Sr apr 21, 2010 8:50 pm
Sam Ferrari je Ferrari...kar daje največji imiđ v avtomobilski industriji...enostavno sinonim avtomoblilizma to se vidi tudi pri cenjenosti rabljenih vozil ali oldtimerjev. Sicer pa newem od kje vam ideje da ferariji niso neki kvalitetni.Z japoncem ga res ne morš glih primerjat glede zanesljivosti...ampak s poršom je kr tm tm + to da so ferarri-ji dost bolj naviti. ;)
pinny
Prispevkov: 2597
Kraj: Šoštanj
Napisal/-a pinny Sr apr 21, 2010 8:53 pm
pornič 8)
ku bi ga lehk kdaj, bi ga kr zapelu kak krog al dva 8)
jebemti Ambipur, kdo to sploh še uporabla :D
dav911
Prispevkov: 107
Napisal/-a dav911 Sr apr 21, 2010 9:44 pm
@nalcoq4: se popolnoma strinjam s tabo. Ferrari ima največji imiđ definitivno...za moje pojme ga tu ne prekašata niti npr. Aston Martin ali Lamborghini...
Ferrari je zanesljiv in hiter na dirkalni stezi, kjer je asfalt lep, brez lukenj itd itd. Porsche je pa zanesljiv hiter na dirkalni stezi in na navadni cest, z lunkjami in ostalimi preprekami, kjer se Ferrari ne odreže tako zelo dobro :) To ti lahko potrdi vsak Profi dirkač :)
Porsche 997 GT3 RS : 450hp iz 3,8 L , 6 cilindrov boxer motor
Ferrari 430 Scuderia: 510hp iz 4,3 L ,V8 motor
Ne vem kdo je tukaj bolj navit ;) ...pa tudi zanesljivost (vedno bi stavil na Porscheja ;)
M156
Prispevkov: 159
Napisal/-a M156 Če apr 22, 2010 12:01 pm
da ima Ferrari največji imidž??? naj vas vprašam ste kdaj slišali za Bugatti?
sicer pa to sploh ni važno, ker Ferrari ima tudi tak imidž da so njihovi lastniki največji bebci in prepotentneži med vsemi lastniki superšportnih avtomobilov :?
Poleg tega nihče nemore zanikati tega, da je Ferrari preveč izpostavljen okvaram in tudi preobčutljive motorje imajo...skratka zraven vseh presežnikov, ki jih dodajamo Ferrariju ga vedno spremlja tudi NEZANESLJIVOST!
Osebna izkušnja, ki sem jo imel nazadnje z Ferrarijem pa je kakovost izdelave...notranjost je pod nivojem značilnim za ta razred :roll:
F430 Scuderia naprimer ima notranje materiale tako grdo skupaj zlepljene in povsod se vidijo zašvasani deli. Kaj takega pri Porsche GT3 ni bilo videti, ravno tako pri GT3 RS.
Da ne omenjam kako zelo Ferrari potrebuje servis vsakih nekaj 1000kilometrov (če se že ravno ne vžge prej)...verjetno takrat gledajo če je kje že skoraj prišlo do samovžig :twisted:
No kakorkoli, lepi pa so...predvsem tale 599 GTO je 8)
