swoop
Prispevkov: 151
Pridružen: To feb 17, 2004 1:50 pm
Shayton Equilibrium
Napisal/-a swoop Sr feb 16, 2011 8:29 pm
The following is an introduction to a conceptual car brand via the brand’s first virtual auto. The name of the brand is Shayton®, a word that comes from the Sioux word for falcon (Chayton pronounced Shay-ton.) The car that’s being presented is the Shayton® Equilibrium. To describe Shayton® as a brand, the Equilibrium is described as the world’s first hyper-car. Because this car aims to display “pure hedonism, perversion on four wheels,” Shayton the brand can be easily seen as a niche brand that wishes to become the top tier.
To create such a car as this, one whose goals are to push the boundaries of abstract concepts were born in childhood fantasies, a company must dedicate themselves not only to creating a solid foundation in a strong story, but also to competing with the leading brands who’ve been sparking the imaginations of designers and car enthusiasts for generations. Can the balance inherent in this car, the Shayton® Equilibrium, bring the conceptual auto brand Shayton to the forefront of the auto world before it even becomes a reality?
Have a peek at the Equilibrium below, and you be the judge.
text via YankoDesign
V imenu našega podjetja PROVOCO vam predstavljamo naš lasten projekt v nastajanju.
Razvijamo ekskluzivno avtomobilsko znamko Shayton®, ter avtomobil Shayton® Equilibrium.
Projekt nastaja v tajnosti ze kar nekaj casa, vednar je koncno nastopil trenutek, ko ga lahko pokazemo javnosti.
Je plod slovenskega oblikovanja.
Ko prehajamo v fazo izdelave prototipa, se za investicje dogovarjamo s potencialnimi partnerji iz razlicnih koncev sveta. Vrata so
absolutno odprta tudi interesantom iz Slovenije. Stremimo k temu, da bi v razvoj vkljucili kar najvec slovenskega znanja.
Kratek opis materialov in komponent:
All carbon-fibre bodywork, carbon-titanium monocoque chassis, monolitic wheels forged in aluminium and magnesium, v12 engine, Sequential gearbox ,Ohlins suspension components, Akrapovic custom exhaust, Brembo carbo-ceramic brakes - self ventilated with hydraulic servo brake... opis se nadaljuje skorajda v neskoncnost, vendar je cilj narediti avtomobil iz najboljsih materialov in komponent na voljo.
Zavedamo se,da pot do realizacije ne bo enostavna, da je višina investicijie za marsikoga nepredstavljiva, vendar je naš cilj se povzpeti in osvojiti sam vrh avtomobilske perverzije kjer vladajo imena predvsem italjanskih butičnih izdelovalcev, ter sem in tam kakšni švedskih in nemških.
Pri PROVOCO ne delamo kompromisov in čas je,da se svetu pokaže, da tudi tako majhna dežela kot je Slovenija, lahko močno zamaje volan prestižnim in uveljavljenim imenom butične in pregrešne maloserijske avtomobilske industrije.
Vec o znamki Shayton® in avtomobilu Shayton® Equilibrium na http://www.shayton.eu
Slike so prikazane nekaj objav nizje, saj jih v prvi objavi ne prikaze celih. Kot pravijo, je napaka na forumu.
Zadnjič spremenil swoop, dne Sr feb 16, 2011 10:22 pm, skupaj popravljeno 1 krat.
swoop
Prispevkov: 151
Re: Shayton Equilibrium
Napisal/-a swoop Sr feb 16, 2011 8:32 pm
Se kdo drug vidi samo polovicne slike? Razlog?
Lep pozdrav,
Andrej
Kegl
Prispevkov: 1781
Kraj: okolica Ljubljane
Napisal/-a Kegl Sr feb 16, 2011 8:32 pm
swoop je napisal/-a:Se kdo drug vidi samo polovicne slike? Razlog?
Lep pozdrav,
Andrej
x2
swoop
Prispevkov: 151
Napisal/-a swoop Sr feb 16, 2011 8:41 pm
Kaj bi lahko bilo narobe? Bi zelel takoj popraviti.
Hvala za odgovore.
Napisal/-a dobek Sr feb 16, 2011 8:43 pm
kot ze ime firme govori..je to samo razvoj blagovne znamke (ideje)? al je to evolucija K1 sasije (Tusek/Golja)?
swoop
Prispevkov: 151
Napisal/-a swoop Sr feb 16, 2011 8:56 pm
Po eni strani poteka razvoj blagovne znamke ( ena ekipa ), na drugi strani pa razvoj popolnoma novega avtomobila. Nima nobene povezave z K1.
Napisal/-a IcEm4n Sr feb 16, 2011 9:18 pm
Problem je v tem, ker v 1. postu vsake strani še vedno "odreže" zaradi oglasa (ki pa ga zdaj že nekaj časa ni več).
swoop
Prispevkov: 151
Napisal/-a swoop Sr feb 16, 2011 10:21 pm
Upam, da bo zdaj prikazalo cele slike. Ce drzi kot je napisal kolega zgoraj, bi moralo delovati.
Shayton Equilibrium
tha_man
Prispevkov: 1008
Napisal/-a tha_man Sr feb 16, 2011 10:34 pm
Veliko uspeha s projektom, zgleda odlično!
swoop
Prispevkov: 151
Napisal/-a swoop Sr feb 16, 2011 10:48 pm
tha_man je napisal/-a:Veliko uspeha s projektom, zgleda odlično!
Hvala!
Bat_zajla
Prispevkov: 505
Pridružen: Če dec 09, 2010 10:32 pm
Napisal/-a Bat_zajla Sr feb 16, 2011 10:52 pm
V dizajnu se vidi elemente iz veliko znanih supercarov, ampak nič zato, ker kot celoza izgelda fenomenalno. Veliko bolje kot marsikater drug prototip. Če se boste držali tega dizajna, bo to super. Kdaj pa pričakujete uradno predstavitev prvega modela (če ne upoštevamo zamude glede financ)?
Switch
Prispevkov: 10
Pridružen: Pe feb 29, 2008 6:46 pm
Napisal/-a Switch Sr feb 16, 2011 11:35 pm
Ime podjetja se mi zdi malo ponesrečeno - saj spominja oz. se izgovori podobno kot (ali je bila to tudi inspiracija za ime?):
Shaitan (Islam) is often simply translated as "The Devil," but can refer to any of the beings who rebelled against God. Shaytan has a similar meaning and origin to the English word Satan.
swoop
Prispevkov: 151
Napisal/-a swoop Sr feb 16, 2011 11:42 pm
pomeni pa lahko oboje ;) In verjemi, ime je premisljeno in je bilo skrbno izbrano.
swoop
Prispevkov: 151
Napisal/-a swoop Sr feb 16, 2011 11:45 pm
Bat_zajla je napisal/-a:V dizajnu se vidi elemente iz veliko znanih supercarov, ampak nič zato, ker kot celoza izgelda fenomenalno. Veliko bolje kot marsikater drug prototip. Če se boste držali tega dizajna, bo to super. Kdaj pa pričakujete uradno predstavitev prvega modela (če ne upoštevamo zamude glede financ)?
Vsekakor je namen ohraniti ta dizajn. Malenkostne spremembe bodo nastale po testiranjih v vetrovniku, vendar ne bodo omembe vredne.
Predvideni plan je predstaviti vozen prototip proti koncu 2012, v kolikor ne bo zamud tako na financnem podrocju kot tudi razvojnem. Bi rekel, da je to zelo optimisticna ocena.
Shadez
Prispevkov: 139
Pridružen: So maj 15, 2010 5:57 pm
Kraj: Lost in stereo
Napisal/-a Shadez Sr feb 16, 2011 11:46 pm
Če bi bil avto dejansko tak,kot na slikah, potem res svaka cast :DDD
PS: Že kakšne okvirne cene? :)
Patience is something you admire in the driver behind you and scorn in the one ahead.
tomson
Prispevkov: 1386
Kraj: LJ / MB
Napisal/-a tomson Če feb 17, 2011 12:35 am
Kdo vam mašino dobavlja? Al jo boste sami izdelali?
Mal več podatkov o mašini, performance-u, ceni itd.
Pa ime mi ne paše, osebno mnenje.
R 26
Prispevkov: 631
Kraj: dolenjska je moja mati
Napisal/-a R 26 Če feb 17, 2011 1:03 am
Vsaka čast, upam da vam uspe. Kot celota je oblika veliko lepša kot večina superšportnikov. Sem pogledal na vašo stran, pa vidm da ste kr optimistični....
-1084 BHP
-top speed: 400+ km/h
-0-100km/h: 3,1 s
Pa tista spletna strn je tam z razlogom. ;) Za vse, ki jih še zanima cena, začetna cena naj bi bila miljon €
a_sist
Prispevkov: 1530
Napisal/-a a_sist Če feb 17, 2011 7:46 am
Uf, ste pogumni za tak projekt.. pohvalno!
..komaj čakam da ga Stig zapelje po Top Gear stezi ;)
odprti clio
Prispevkov: 1550
Napisal/-a odprti clio Če feb 17, 2011 9:57 am
Uf, sam res - šejtan; če ga ne bodo Arabci kupil, ga pa bodo Bosanci :lol: Šalo na stran, če vam uspeva, kapo dol :!:
more
Prispevkov: 121
Pridružen: Ne sep 17, 2006 11:26 pm
Napisal/-a more Če feb 17, 2011 10:44 am
Huuud!! :DDD :bow
