Prispevkov: 11405
2012 Mercedes A
Napisal/-a martin_krpan Če apr 07, 2011 1:55 pm
Zanimivo, da o novem A še ni teme na A.com. Avto se razvija že dalj časa, na salonu v New Yorku bo MB prikazal Concept A, ki napoveduje obliko novega razreda A. Kvazi enoprostorska zasnova se poslavlja, novi A bo šprtno oblikovana kombilimuzina. Mogoče bodo sledile tudi druge karoserijske različice (kot pri nastajajočem novem B).
World premiere at the New York Auto Show
Mercedes Concept A-Class: the beginning of a new compact generation
MONTVALE, NJ – The Mercedes-Benz Concept A-Class will make its debut at both the 2011 New York and Shanghai Auto Shows later this month. Looking as though it might have come from another planet, the Concept A-Class features an expressive and athletic design. Technical highlights include a new turbocharged four-cylinder gasoline engine, a dual clutch transmission and a radar-based collision warning system with adaptive Brake Assist.
The aggressive appearance of the Concept A-Class, with its long hood, low silhouette and slim side windows, is given depth by the interplay between lines and surfaces. Inspiration was drawn from the wind and the waves, as well as aviation engineering.
The Concept A-Class previews a new compact class era at Mercedes-Benz. This front-wheel drive model is powered by a four-cylinder gasoline engine from the new M270 series. It was designed for transverse installation and thanks to direct injection and turbocharging, offers high performance together with minimal emissions and fuel consumption. The Concept A-Class is equipped with the twoliter variant of the new engine, developing 210 hp. This BlueEFFICIENCY engine is mated to the new Mercedes-Benz dual clutch transmission.
As a world first in the compact class, the concept car features a radar-based collision warning system with adaptive Brake Assist, which lowers the risk of rearend collisions. This assistance system gives a visual and acoustic warning to an inattentive driver and prepares Brake Assist for a precise braking response. Braking is initiated as soon as the driver forcefully operates the brake pedal.
The exterior design of the Concept A-Class features the combination of defined edges and free interplay with the body surfaces that Mercedes-Benz first showed in the F800 Style. The side view is structured with three prominent lines: the front structural edge above the front fender forms a dropping line, while the prominent shoulder muscle above the rear axle underlines the car's coupe-like character. A further line extends upwards from the rear wheel arch in a sweeping curve.
The front end of the Concept A-Class immediately catches the eye with the Mercedes-Benz star logo surrounded by what looks like a star-filled sky. Where there are usually openings or louvers, the radiator grille consists of numerous metallic silver hexagons on black stems. This theme is reflected in the design of the wheels.
The headlights of the Concept A-Class continue this design element with innovative full-LED high-performance headlamps repeating the starry sky motif with numerous light points. The daytime running lamps consist of 90 optical fibers with aluminum sleeves which are arranged in a wing-shape within the headlamp.
In the interior, the eye is immediately drawn to the dashboard which has the shape of an aircraft wing and a translucent, stretchable fabric lining. This enables the bionic, cellular structure of the dashboard to remain visible.
The shape of the air vents in the dashboard is reminiscent of a jet aircraft. The prominent dials in the instrument cluster are in red, inspired by the afterburner of a jet engine. The center console is designed as a modern flight control panel, with the shift lever designed as a "reverse thrust control".
A smartphone is fully integrated into the Concept A-Class. All functions are shown in the display as applications, and can be operated using the rotary/push control. The visual presentation of the display screen elements is unique, with a deep, three-dimensional appearance created by laser-like magenta-colored lines.
http://www.autoweek.nl/autonieuws/16396 ... nders-doen
xandrej
Prispevkov: 2082
Kraj: Slovenija
Re: 2012 Mercedes A
Napisal/-a xandrej Če apr 07, 2011 2:51 pm
če bi bil tak kot ta bi bil prava lepota. Seda bo stvar po vsej vrjetnosti čisto drugačna v realnosti oz. na cesti.
~toMmy~
Prispevkov: 5806
Kraj: Vinica
Re: 2012 Mercedes A
Napisal/-a ~toMmy~ Če apr 07, 2011 3:44 pm
3. in 4. slika na hitro spominjata na pariško GTC-jko, drugače pa luštna zadeva. Upam, da le ne bodo pretiravali s stotimi prepletenimi linijami in dodatki na sprednji maski, kot se to rado dogaja pri sodobnih avtih.
Prehod iz dosedanje filozofije (oblikovno nezanimiv, predrag avto glede na konkurenčne praktične (male) avtomobile) na to novo, bo verjetno dobrodošlica za oko in za njihove prodajne številke. Nekako pozno se se vključili v ta boj, nenazadnje se gre za zelo zastopan segment. Mogoče po dolgih letih prvi Mercedes izven AMG sekcije, ki mi bo zanimiv.
Zadnjič spremenil ~toMmy~, dne Če apr 07, 2011 5:42 pm, skupaj popravljeno 1 krat.
BlazR
Prispevkov: 321
Re: 2012 Mercedes A
Napisal/-a BlazR Če apr 07, 2011 5:37 pm
Zelo lep avtomobil. Sem bil vesel že, ko so se začele govorice, da ne bo več enoprostorec, ker njegov predhodnik je biu res zgrešen, kar se mene tiče. Zdj pa vidm, da so se tut zelo potrudl z obliko in če ostanev serijski proizvodnji podoben temu, mislm da bo zelo uspešen. Audija A1 precej prekaša po obliki, bo pa zanimivo vidt, če se bo tut bmw kj odzvou v nižjem razredu. Edin mal bo težko številčno umestiu tak avtomobil v svojo ponudbo, ker ma serijo ena v nižjem srednjem razredu. No mogoče bo pa serija 0. :D
CITROENAR ŠT 1
Prispevkov: 1483
Re: 2012 Mercedes A
Napisal/-a CITROENAR ŠT 1 Če apr 07, 2011 8:20 pm
Mercedes A Class 2012: The first sketch
March 12, 2011 at 17:00.
Maybe we can discover it as a concept car in five weeks at the show in Shanghai and it certainly will be a feature of school, particularly at the IAA in September, I mean the next Mercedes A Class which should change his appearance to look away from minispace in favor of an appearance may be more common sedan compact in the manner of an A3, a Golf or DS4.
Mercedes also to prepare for the arrival of this car on the market, offers two skits as an opening teaser that shows us what could be the 3-door version. More dynamism and sportiness are planned for this future Class A who should enjoy some of the current engines, plus some new features, including a hybrid version and an AMG version which is said already the largest property and giving the power aimed at would between 310 and 330 hp ... probably best to hunt or RS3 serie1 million. More news to follow in the coming weeks and / or next month.
Via Mercedes Benz.
http://blogautomobile.fr/mercedes-classe-a-2012-premiers-sketchs-105099#axzz1IbH0JRRz
Peter Pirkovič (Avtomanija) je napisal/-a: 11. marec 2011 | 16:02:22
Besedilo: Peter Pirkovič Foto: Mercedes
Mercedes A bo slovenskih zamisli
Mercedes je na spletu objavil prvi skico nastajajočega Mercedes razreda, pri kateremu ima prste vmes Slovenec Robert Lešnik.
Novo generacijo razred A bo dopolnjeval mladostniški videz, ki meji skoraj na kupejevsko linijo, z nekaj vložki študije F800. Projektu poveljuje Slovenec Robert Lešnik, ki je pri Mercedesu zadolžen za zunanji dizajn. Prvo študijo na to temo bo mogoče v živo videti na salonu avtomobilov v Šanghaju, čez dober mesec.
http://www.avtomanija.com/default.asp?rb=3&id=6683
No, lepo, da tudi Mercedes vstopa v kompaktni segment, bo pa čas pokazal iz kakšneg testa so. Mi pa bo vsekakor mnogo bolj všeč kot BMW 1 pa tudi A3, in CT, če bo seveda čim bolj zadržal to izrazitost prototipne oblike, kar pa žal ni ravno pogosta praksa. Bomo videli.
BlazR
Prispevkov: 321
Re: 2012 Mercedes A
Napisal/-a BlazR Če apr 07, 2011 9:14 pm
Ugotavljam, da sm očitno naredu napako, ko sm ga primerjal z audijem a1, ker ga v člankih uvrščajo v kompaktni razred. No, tudi od serije 1, audija a3 in lexusa ct mi je lepši, čeprou mi je vseen čudn, da se a klasa uvršča v c segment, ker ne vem, kam se bo pol b klasa.
CITROENAR ŠT 1
Prispevkov: 1483
Re: 2012 Mercedes A
Napisal/-a CITROENAR ŠT 1 Če apr 07, 2011 9:44 pm
Hja, moram reči, da sem tudi jaz mislil, da bo novi kompakt ala CT,... in da bo novi A kaj manjšega ala ne vem, DS3 ipd. OK, pač ni, sem prepričan, da bomo ob pravem času izvedeli kaj iz Stuttgarta pripravljajo kot novi B. ;)
Drugače pa še ene par fotkic + 2. videa:
Mercedes-Benz.tv: Concept A-CLASS Teaser
Mercedes-Benz.tv: I Like - Concept A-CLASS
http://blogautomobile.fr/mercedes-class-a-concept-rivale-prochaines-serie1-a3-108189#axzz1IbH0JRRz
Hmm, Robert Lešnik mogoče že ima kaj prstov vmes, vendar očitno nima glavne vloge, sodeč po 2. videu.
Prispevkov: 11405
Re: 2012 Mercedes A
Napisal/-a martin_krpan Sr maj 11, 2011 6:58 pm
patentne risbe novega A:
http://www.blogcdn.com/www.autoblog.com ... awings.jpg
Oblika avta je preveč nemercedesovska, sploh zadek (ki je povrhu še precej grši kot pri konceptu). Če odrežeš sprednji del (ki ima za moj okus še prevelike luči in masko in izgleda kot na silo zaliman na preostanek avta), dobiš Japonca.
http://www.autoblog.com/photos/2012-mer ... s/#4125703
Re: 2012 Mercedes A
Napisal/-a Lignage Sr maj 11, 2011 10:25 pm
V bistvu nisem nekaj preveč negativno presenečen, ker vem da pri mercedesu ni ravno dobro oblikovanje doma :) ...oziroma, da ne bom izpadel nesramen, bom raje rekel da imajo nekaj res zelo perfektnih izdelkov na pogled, vendar pa se jim po drugi strani preveč hitro rado zgodi, da jim kaj ne uspe. In to bo očitno tipičen primer.
zany
Prispevkov: 1035
Re: 2012 Mercedes A
Napisal/-a zany Če maj 12, 2011 4:02 pm
meni pa se dopade, čeprav je res netipično oblikovan za mercedesa :)
Marek_
Prispevkov: 2207
Re: 2012 Mercedes A
Napisal/-a Marek_ Če maj 12, 2011 4:34 pm
Meni je zelo všeč, je pa res, da zadaj deluje vse drugo kot MB. V kateri razred sploh spada oz. kateri so mu konkurenti? Za trenutnega ne najdem nobenega konkurenta (med premium in kvazi premium znamkami).
rok46
Prispevkov: 2861
Re: 2012 Mercedes A
Napisal/-a rok46 Če maj 12, 2011 4:55 pm
zadi je kot DS3...ampk mi je lep
tlusin
Prispevkov: 6
Pridružen: Sr avg 25, 2010 10:30 pm
Mercedes Benz A & B class 2012
Napisal/-a tlusin Sr jun 15, 2011 1:48 pm
Zdravo,
ali ima kdo kakšno informacijo kdaj bo pri nas na voljo novi Mercedes razreda A oz. razreda B ter kolikšna bo vsaj okvirna cena. Hvala za info. Tomaz.
Marek_
Prispevkov: 2207
zany
Prispevkov: 1035
Re: 2012 Mercedes A
Napisal/-a zany Sr sep 21, 2011 1:58 pm
A ujet na testiranju. Torej prihaja resen konkurent bmw-jevi enici :) In avto je izjemno podoben tistemu na patentnih fotografijah :)
Bližnjice!!!
Renault VG
Prispevkov: 1529
Renault VG
Prispevkov: 1529
Re: 2012 Mercedes A
Napisal/-a Renault VG Če feb 02, 2012 7:18 am
zany
Prispevkov: 1035
Re: 2012 Mercedes A
Napisal/-a zany Če feb 02, 2012 3:05 pm
Tole izgleda fantastično :shock:
zany
Prispevkov: 1035
Re: 2012 Mercedes A
Napisal/-a zany Če feb 23, 2012 1:34 pm
Prve slike notranjost; pričakovano;
drugmirko
Prispevkov: 2762
Re: 2012 Mercedes A
Napisal/-a drugmirko Pe mar 02, 2012 4:58 pm
oooo.... sicer bo v živo verjetno čist drugač ampak za zdej mam res občutek, da bi nekdo resno rad bil iz ene "druge nemške štalice" =P.
http://4.bp.blogspot.com/-XJYrFnIUSPs/T ... atch-0.jpg
živeo drugmirkooooo!!!!
