Avdiofili, raj za vas...
wild_one
Prispevkov: 81
Pridružen: Sr nov 02, 2005 3:41 pm
pioneer 6400
Napisal/-a wild_one Po apr 03, 2006 8:18 pm
zanima me kako zamanjas osvetlitev tipk iz zelene na rdeco na pioneer 6400
subi92
Prispevkov: 1622
Napisal/-a subi92 Po apr 03, 2006 8:31 pm
Če ma tko k 7600 pol držiš en knof mislm da function ali audio pr ugasnjenem in nato uletiš v dodaten menu - nism pa stoprocentn, če pa ni te funkcije pri ugasnjenem probaj še pri prižganem.
wild_one
Prispevkov: 81
Napisal/-a wild_one To apr 04, 2006 1:41 pm
aha .hvala bom probal
wild_one
Prispevkov: 81
Napisal/-a wild_one Po apr 10, 2006 4:43 pm
ja sm probal pa ni..
jery
Prispevkov: 139
Pridružen: So nov 19, 2005 7:52 pm
Kraj: NM/LJ/NM
Napisal/-a jery To apr 11, 2006 9:02 am
Mora delat !
Sicer mam jst 6800 ampak vseen
subi92
Prispevkov: 1622
Napisal/-a subi92 To apr 11, 2006 10:00 am
Kje si pa slišal da to sploh ima, zdele šele vidm da maš 6400 in ne 6800, prjatu ma tadzga pa tega tud nima.
General Features
* MOSFET 50W x 4
* XM Satellite Radio Ready
o Controls optional GEX-P900XM or GEX-FM903XM Satellite Radio tuners (as External unit)
o 8-character display for XM Radio text (no scroll)
* Card Remote
* Rotary Volume Control (Pop-Up)
* EEQ Performance Chip
o 3-Band Parametric Equalizer (Adjustable Level, Frequency and Q Factor)
o Easy EQ (EEQ) switches 5 Factory, 2 User EQ Presets (Super Bass, Powerful, Natural, Vocal, Flat, Custom 1 and Custom 2)
o Source Custom EQ Memory (Independent Custom Memory for each source)
o Selectable Loudness Control (Low/Mid/High/Off)
* SFEQ (Sound Focus EQ)
o Additional Independent Bass / Treble Control for Front / Rear
* Subwoofer Crossover
o Selectable LPF (Low Pass Filter) (50/80/125Hz, -18dB/oct)
o Sub-Out Level (-12dB to +12dB) and Phase Control
* IP-Bus System Control
o MCD Control
o TV Tuner Control
o Auxiliary Input (CD-RB10 or CD-RB20 required)
o 2 External Unit Control
* S.L.A. (Source Level Adjustment)
* Selectable Fader Control
* RCA Preouts (x2 pair, Front & Rear or Front & Sub) (2V)
* Organic EL Display (128 x 33 pixel)
o Full-motion 3D graphic animations including
+ 2 screensavers (Dolphins, Racing)
+ 2 Level Meters
+ 4 background animations
+ Clock Display and Off (Text-only) modes
o 16-character text display capability
o Adjustable brightness level (16-mode)
* Cellular Mute Capability (CD-CM1 required)
* Clock
jery
Prispevkov: 139
Kraj: NM/LJ/NM
Napisal/-a jery To apr 11, 2006 10:49 am
Caki subi92 .. kaj nima? Zmanjavo osvetlitve?
Seveda mora met!
Ce mam jst pol mora met tut on :P
wild_one
Prispevkov: 81
Napisal/-a wild_one Pe apr 14, 2006 1:20 pm
ni .pridem mislim najdem meni ko je ugasnejn radio sma ni ic tam za osvetlitev zamenjat
subi92
Prispevkov: 1622
Napisal/-a subi92 Pe apr 14, 2006 1:33 pm
Jah žal ni enak 6800 kot 6400, že v opisu piše da ima nastavitev kontrasta osvetlitve...
wild_one
Prispevkov: 81
Napisal/-a wild_one Pe apr 14, 2006 1:47 pm
ok.hvala :)
