Avdiofili, raj za vas...
ultrasboy
Prispevkov: 19
Pridružen: Če jul 31, 2008 10:06 am
avtoradio pioneer DEH 4000USB-pomoč !
Napisal/-a ultrasboy Pe okt 17, 2008 12:03 pm
Bi prosu za pomoč !
Sem pravkar si dal noter omenjeni avtoradio in nikakor neznam dobit funkcijo za naštimat basse.Nisem kar se tiče teh reči "kamena doba":D ker mi je lgoično pač kako se gre z gumbi pa to + pomagu sem si z knjižico z navodili, sam piše površno glede bassov naštimat.
ostalo mi je jasno !
Hvala,Lp
dskrab
Prispevkov: 421
Pridružen: Sr maj 04, 2005 10:05 am
Napisal/-a dskrab Pe okt 17, 2008 12:15 pm
Z multi control gumbom poišči AUDIO funkcijo pol pa naprej kakor ti piše spodaj ...
Adjusting equalizer curves
The factory supplied equalizer curves can be
adjusted to a fine degree (nuance control).
1 Use MULTI-CONTROL to select
EQ SETTING 1.
2 Press MULTI-CONTROL to display the
setting mode.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
L (low)—M (mid)—H (high)
4 Turn MULTI-CONTROL to adjust the
level of the equalization band.
+6 to –6 is displayed as the level is increased
or decreased.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
# You can then select another band and adjust
Sej nimaš kej! Tko je pa nč drugač!
It`s not just JDM. It`s a LIFESTYLE !
Napisal/-a Slicker Pe okt 17, 2008 12:54 pm
OT: tale deh4000 je eden najbolj smotanih radiev kar sem jih kdaj nastavljal.
