s line
Prispevkov: 226
Pridružen: Ne nov 13, 2016 5:16 pm
1.2 in 1.4 TSI ali MB A 180 in 200
Napisal/-a s line Ne feb 12, 2023 4:54 pm
Nakupujem nek vredu avto, da ni nekih problemov
Audi /Mercedes
Veliko sem bral o teh TSI, TFSI motorjih, in imajo kar nekaj problemov, če ne delaš z njim kot s pereščkom. A to je zato ker so Turbo bencinarji.
Tudi drugi avti imajo Turbo bencinarje pa nimajo takih problemov.
Kako pa je z mercedesi razred A 200 ali A180 letnik 2014 bencinarji, pa imajo tudi malo porabo.
Ali se je bolje odločiti za mercedesa manj problemov oz. Nič problemov napram Vag grupi...
Pa zakaj se nekateri bencinski avtomobili tsi in tudi drugi prodajajo zelo dolgo, celo po več mesecih so po avtonetu.
Hvala
limas
Prispevkov: 2360
Re: 1.2 in 1.4 TSI problemi (novo - anketa)
Napisal/-a limas Ne feb 12, 2023 6:10 pm
It was jointly developed by the Renault–Nissan–Mitsubishi Alliance and the Mercedes-Benz Group, and is the successor to the 1.6L variant of the M270 engine.
Mercedes-Benz M282 engine.
Power output 80–120 kW (109–163 PS; 107–161 hp).
Motor ima direkten vbrizg in turbino.
Koliko zdržijo ti motorji?
How many miles will a Mercedes petrol engine last?
Mercedes-Benz Vehicle Can Drive Over 1,000,000 Miles
vir: Wiki.
s line
Prispevkov: 226
Napisal/-a s line Ne feb 12, 2023 6:30 pm
A mercedes A 200, 2014 letnik, bencinar ima tudi turbino? Sploh ne vem ker se naslavlja samo A 180 ali A200.
Samo, če je tko je pol vse to isto samo, da je pri audi marketing TSI pri mercedes pa nekaj drugega ali se motim.
Kateri je potem bolj zanesljiv VAG TFSI
Ali ta mercedes, kje bo več težav.?
Kristjan123
Prispevkov: 872
Napisal/-a Kristjan123 Ne feb 12, 2023 7:27 pm
The engine
Both the Mercedes A180 and the A200 are equipped with the same 1.3-liter inline-four turbocharged petrol engines. However, the A180's engine is software-limited to produce 136 horsepower and 200 Nm, while the A200's engine is unrestricted and produces 163 horsepower and 250 Nm.
Blinder
Prispevkov: 3934
Kraj: Obala
Napisal/-a Blinder Ne feb 12, 2023 7:50 pm
s line je napisal/-a:Veliko sem bral o teh TSI, TFSI motorjih, in imajo kar nekaj problemov, če ne delaš z njim kot s pereščkom.
sej ni da ki če delaš lepo z njimi da se ne kvarijo.
En vir informacij o teh avtih je wikipedia: https://en.wikipedia.org/wiki/Mercedes-Benz_A-Class#Third_generation_(W176;_2013)
Porabo goriva lahko brskaš po spritmonitor: https://www.spritmonitor.de/en/search.html
Natančnejše podatke, vključno z deklarirano porabo goriva, najdeš naprimer tu:
https://www.quattroruote.it/listino/mercedes/classe-a-5p
če ne znaš italjansko uporabi Google Chrome in uporabi opcijo, da ti prevede celotno stran.
s line
Prispevkov: 226
Napisal/-a s line Ne feb 12, 2023 8:02 pm
Kristjan123 je napisal/-a:The engine
OK to razumem
Kateri je pa potem boljši turbo
TFSI ali od mercedesa A
Kakšna je kaj razlika v tem.
Napisal/-a IcEm4n Ne feb 12, 2023 9:57 pm
To si citiral za aktualno generacijo. On pa sprašuje za prejšnjo generacijo. Tam se pa pod oznako 180 in 200 nahaja 1.6 litrski turbak.
Re: 1.2 in 1.4 TSI ali MB A 180 in 200
Napisal/-a pskoda Po feb 13, 2023 5:05 pm
Če kupuješ mercedesa kupi mercedesov motor ne renojev
Po forumu brska: Google [Bot] in 66 gostov
