Kateri avto bi izbrali, če bi bila cena podobna?
207
11
46%
307
13
54%
Skupaj glasov : 24
Media3
Prispevkov: 537
Pridružen: Po jan 03, 2005 8:49 pm
Peugeot 307 vs 207
Napisal/-a Media3 Sr avg 08, 2007 7:22 pm
Živjo!
Pozimi oz. spomladi bom kupil drug avtomobil.
Ker imam priložnost, preko vez kupiti peugeota. Se bom verjtno odločil za to firmo avtomobila.
Sedaj je v mojem ožjem izboru peugeot 307 oz 207.
Za 307 bi se odločil:
-večji
-velika izbira rababljenih
-bolj moški avto :D
-cena
Za 207
-povsem nov model
-nekoliko mi je lepši.
Oba avta bosta eno leto stara. Imela pa bosta še 12 mesecev garancije.
Motor bi bil 1.6 hdi (90 oz 110 km).
Zanimajo me še kakšne so napake teh avtomobiliov in motorjev.
Napisal/-a adis Sr avg 08, 2007 8:13 pm
207: je od letnika 2006 naprej
What's Bad
Original 110 bhp 1.6 16v replaced by new chain cam 120 bhp 1.6 16v from March 2007. As with 307, 'clap hands' wipers leave unswept vertical area about 4" wide next to screen pillar. RT3 satnav infuriatingly slow to input town names because it does a predictive search after every letter. Needs a software modification so it only becomes predictive after three or four letters. GT THP 175 has only a space saverspare wheel to cut down on weight, only a 5-speed gearbox and suffers torque steer absent from GT THP 150. Owner/driver feedback welcome. First UK deliveries of new chain cam 1.4 delayed to September/October 2007.
What to Watch Out For
More Feedback welcome. One report of rear damper failure on 207 1.6 16V SE 5 door after 3 months and 1,100 miles, not speed hump related. Also driver's window closing noisily and morning brake grind from rust on the discs. End of plastic dipstick of 1.6 HDI engine can break and drop into sump requiring removal of sump to retrieve it.
307: je od letnika 2001 ( podatkov za letnik 2006 še ni, a lahko tale spodnji post vzameš kot preventivo pri ogledu avta)
What's Bad
Mini MPV attributes do not extend to a flat floor with no centre console as in earlier versions of the Honda Civic. Doesn't shift the goalposts set by the Ford Focus. Clap hands wipers leave unwiped section next to screen pillars. Footwell designed for left hand drive.
Shocking 4th from Bottom of 100 models for reliability in Auto Express 2002 survey. Petrol models average for breakdowns and faults but poor for problems; diesels average for breakdowns bur poor for problems and faults in 2003 Which survey. 3rd from bottom out of 137 models in 2003 Top Gear survey. 307 3rd bottom model in 2004 JD Power Customer Satisfaction Survey. Clutch failures increasingly common. Came 20th = from bottom in 2005 JD Power/What Car Survey of 23,000 cars reg Sep 2002 to Aug 2003 with satisfaction score of 75.4%.
Problems include total power failures, total (Multiplex) electrical failures, trip computer failures, service indicator failures, poor starting, brake pedals falling off, steering column stalk malfunctions, splits in seat covers, rattles, screen leaks, cracked screens, complaints of poor ride quality even on 1.6 and 1.4HDI versions.
ECU problem with HDIs causes flat spots and hesitation. A permanent cure seems to be slow in coming through.
One Backroomer's list of problems:- "electronic service indicator counting down very very quickly, carpet coming adfift of the trim, exterior door rubbing strips coming adrift of the door, a breakdown whilst driving, steering lock/ignition key recall problem, glovebox release mechanism broken, horn intermittently not working, paint chipping on bonnet despite mainly slow speed driving, hatchback would not close until shut several times, rear seat velour stitching not finished, remote central locking intermittently not working, electronic oil level indicator reading empty despite being virtually full, etc."
sicer je tole v ang. jeziku upam da boš razumel, ker prevod v slo.jezik bi trajal kar dolgo, priporočam pa ogled strani iz kjer je bilo tole COPY/PASTE: http://www.honestjohn.co.uk/index.php?u ... /index.htm
bass
Prispevkov: 3140
Napisal/-a bass Sr avg 08, 2007 8:36 pm
http://www.youtube.com/watch?v=jom0NJNwpWA
Zadnjih 30sec je najboljših. ;)
Media3
Prispevkov: 537
Napisal/-a Media3 Sr avg 08, 2007 10:46 pm
Adis.
Tole je pa jeba :shock: .
Upam, da so pri prenovi popravili stvari.
Media3
Prispevkov: 537
Napisal/-a Media3 Sr avg 08, 2007 10:50 pm
bass je napisal/-a:http://www.youtube.com/watch?v=jom0NJNwpWA
Oz. zadja sekunda. :D
Ja 207 je čisto nov, resno upam da so pri 307 stvari popravili.
Napisal/-a adis Sr avg 08, 2007 10:50 pm
Media3 je napisal/-a:Adis.
tole je samo na splošno napisano za težave ki so se znale oz. so se dogajale, to še ne pomeni da je ta avto ki bi ga ti kupil imel take težave oz. bi jih imel...vse je na koncu odvisno tudi od tega na kakšen avto naletiš oz. v vsaki masovni seriji/proizvodnji so slabi in dobri modeli....ker je zravn garancija potem ti ni kej skrbet
Media3
Prispevkov: 537
Napisal/-a Media3 Sr avg 08, 2007 10:54 pm
adis je napisal/-a:
To ja, sam usen te mal zaskrbi. KO tole prebereš. Je pa tudi splošno znano, da je imel 307 na začetku ogromno težav.
SAVINJCAN
Prispevkov: 3780
Napisal/-a SAVINJCAN Sr avg 08, 2007 10:55 pm
207, sam ne kakega 1.4 16v, ko nikamor ne gre. ga vozim skoraj vsak dan.
Napisal/-a adis Sr avg 08, 2007 10:58 pm
SAVINJCAN je napisal/-a:207, sam ne kakega 1.4 16v, ko nikamor ne gre. ga vozim skoraj vsak dan.
Media3 je napisal/-a:Motor bi bil 1.6 hdi (90 oz 110 km).
a ti sploh prebereš temo od začetka savinjcan? al samo rukneš post pa je sam da je ena cifra več....?
da @media3 na začetku, ampak upajmo da so težav odpravljene
Zadnjič spremenil adis, dne Sr avg 08, 2007 10:59 pm, skupaj popravljeno 1 krat.
Media3
Prispevkov: 537
Napisal/-a Media3 Sr avg 08, 2007 10:59 pm
V upoštev pride samo 1.6 hdi. (90 oz 110km)
SAVINJCAN
Prispevkov: 3780
Napisal/-a SAVINJCAN Sr avg 08, 2007 11:02 pm
adis je napisal/-a:
a si ti mojo šef? pa kaj te briga kaj jaz pišem, za sebe se brigi
bass
Prispevkov: 3140
Napisal/-a bass Sr avg 08, 2007 11:56 pm
:lol: revček
Media3
Prispevkov: 537
Napisal/-a Media3 Če avg 09, 2007 9:44 pm
A kdo vozi 1.6 hdi ?
Media3
Prispevkov: 537
Napisal/-a Media3 Pe avg 10, 2007 7:17 pm
KARL ABARTH
Prispevkov: 680
Re: Peugeot 307 vs 207
Napisal/-a KARL ABARTH So avg 11, 2007 12:41 pm
Media3 je napisal/-a:Živjo!
-večji
-bolj moški avto :D
-cena
Za 207
-povsem nov model
V primeru, da gre za enaka agregata izberem 207. Najraje z 1,6 - 80 kW agregatom.
