uniXer
Prispevkov: 4
Pridružen: To avg 14, 2007 5:57 am
Audi a6
Napisal/-a uniXer To avg 28, 2007 8:54 am
Hey,
Zanima me vse o tem avtu. Poraba, kvaliteta, izdelava, napake.... pač vse kar veste. Avto je audi a6 2.8 2800 ccm, 142 kW / 194 KM, letnik 1997 in sicer C5.
AudiFreak
Prispevkov: 1257
Kraj: Ried im Innkreis
Napisal/-a AudiFreak To avg 28, 2007 9:28 am
To je model 4B.
Napisal/-a adis To avg 28, 2007 12:54 pm
What's Bad
Tiptronic gearbox lever works wrong way round (forward for upshifts, backwards for downshifts). Three-Star NCAP crash test rating. Reports of heavy oil consumption of 2.4 litre V6. Franchised dealer servicing can be expensive. Average warranty repair costs in 2003 Warranty Direct Reliability index (index 101.16 v/s lowest 31.93). Link:- www.reliabilityindex.co.uk 1998-2000 diesels average for problems and faults but poor for breakdowns in 2003 Which survey.
What to Watch Out For
Audi dealer service history. Accident damage repaired with non-galvanised panels or with bad welds which can rust. Timing belt of 1.8 20v needs changing before 4 years or 60k miles (whichever comes first) and tensioner at the same time. Clear bulkhead ventilation plenum chamber drains regularly. If the drains get blocked with leaves water will have nowhere to go except into the car where it can cause electrical and electronic problems.
ADAC in Germany reported a lot of other problems with A6 generally, including fuel pump, fuel tank, air-mass meter, wheel bearings, front wishbones, air filter, instruments, heated door mirrors and timing belts.
Recalls
A6s built March '98 to August '98: Steering ball joints (track rod ends)could fail. March 2001: Worldwide recall of 560,000 1999 model year A4s, A6s, A8s and VW Passats to replace steering ball joints (track rod ends). Announced Auto Bild 11/3/2001. 1-8-2002: Brake pedal may have a casting fault. Needs to be replaced on 56 cars. 16-10-02: On cars with 3 spoke steering wheels airbags may not work. Airbag to be replaced, but affects only 79 of 4,400 cars. April 2004: Worldwide recall of 870,000 1996-1999 Passat, 1994-1999 A4, 1997-1999 A6 and 1994-1999 A8s for "free check for possible damage of the rubber bellows of the front axle. The problem could lead to premature wear and, in isolated cases, to the failure of the bearing arm."
tole je mal na kratko napisan COPY/PASTE
sicer kakšnih večjih napak ni zaslediti ker so 2.6 in 2.8 motorji eni najboljših pri audi-ju kar se tiče kvalitete oz. vzdržljivosti[/b]
uniXer
Prispevkov: 4
Napisal/-a uniXer To avg 28, 2007 1:02 pm
Kaj pa poraba ? Če ima mogoče kdo izkušnje z tem.
kolesar
Prispevkov: 2913
Kraj: štajerska
Napisal/-a kolesar To avg 28, 2007 1:23 pm
uniXer je napisal/-a:Kaj pa poraba ? Če ima mogoče kdo izkušnje z tem.
veliko preveč :)
http://www.poraba.com/usage_view.php?carid=2666
če pije 2.4 12l
Quiksilver
Prispevkov: 377
Napisal/-a Quiksilver To avg 28, 2007 1:30 pm
Evo mi mamo doma 2.8 quattro 2002 letnik. Pri porabi je pa tko, od 10 do 12. Ni neke velike razlike med šparanjem oz. tiščanjem. Drugače pa nobenih težav z njim. Zelo miren motor, v notranjosti ga sploh ne slišiš.
AM
Prispevkov: 748
Napisal/-a AM To avg 28, 2007 1:50 pm
Sem mal gledal na teh omenjenih straneh, pa se audi zelo slabo odnese kot zanesljiv avto.
Vem pa da sem še nekje drugje gledal kjer se je dobro odnesel. Čist odvisno kje gledaš te stvari.
paskvale
Prispevkov: 379
Kraj: Liberty City
Napisal/-a paskvale To avg 28, 2007 3:25 pm
Glede povprečne porabe, mislim, da niti ni toliko glede na motor in avto kot takšen.
URL: http://www.spritmonitor.de/de/uebersich ... year_s=200
8)
uniXer
Prispevkov: 4
Napisal/-a uniXer To avg 28, 2007 6:43 pm
Hvala za vse informacije. Med letnikom ne morem izbirat ker bo tak letnik prodal sorodnik okoli februara (naj bi) in ker ga poznam se mi zdi da je dober nakup. Res pa je da so veliki stroški registracijo,cestnini itd....
black
Prispevkov: 1595
Napisal/-a black Če jul 23, 2009 6:35 pm
Da ne odpiram nove teme bom kar v tej 2 leti stari vprašal...
Kako se obnese 1.8 20V motor? Pokvarljivost,prožnost...?
Ta motor naj bi bil v zapakiran v A6 kateri je dokaj težak avto...
tnx
mihaing
Prispevkov: 2875
Kraj: Slovenc
Napisal/-a mihaing Če jul 23, 2009 6:43 pm
black je napisal/-a:Da ne odpiram nove teme bom kar v tej 2 leti stari vprašal...
tnx
A niso taki motor imele škode octavie?
tads
Prispevkov: 266
Pridružen: To maj 13, 2008 3:12 pm
Kraj: Šoštanj
Napisal/-a tads Če jul 23, 2009 6:46 pm
tnx
misliš 1.8T ?
ker mislim da A6 ta prejšnji model ni mel 1.8, imel je 1.8T
zlarre_
Prispevkov: 422
Pridružen: Po mar 16, 2009 10:54 pm
Napisal/-a zlarre_ Če jul 23, 2009 7:12 pm
tads je napisal/-a:
tnx
misliš 1.8T ?
Imajo 1.8 125km. ;)
http://www.avto.net/_EUROTAX/select_car.asp
sašo5
Prispevkov: 5085
Kraj: Brežice
Napisal/-a sašo5 Če jul 23, 2009 7:16 pm
1.8 20v brez turbine se najde v modelu 4B ...........vendar "globoko" odsvetujem, ne samo, da ne da nič od sebe, povrhu še poraba ne pade pod 10 niti pod razno.....osebno bi si v tej šestici omislil 2.8 (brez Q) pa naj rabi kolk rabi, sedaj so tako poceni, da resnično ni pomembno to o porabi....
P.S dizli pa tako; pod 250.000 bo utopija ga najdit....
mihaing
Prispevkov: 2875
Kraj: Slovenc
Napisal/-a mihaing Če jul 23, 2009 7:22 pm
sašo5
Prispevkov: 5085
Kraj: Brežice
Napisal/-a sašo5 Če jul 23, 2009 7:25 pm
mihaing je napisal/-a:najdejo se tudi v teh modelih
http://suchen.mobile.de/fahrzeuge/showD ... geNumber=4
no, saj sem napisal, da se najde tudi v modelih 4B..
P.S a tega z linka je cena 10jurjov :?: :roll: .....ja, kaj češ, A U D I pač :P
black
Prispevkov: 1595
Napisal/-a black Če jul 23, 2009 8:00 pm
Navaden 1.8 mislim ja, ne T.
Tega sem slučajno gledal v sredo.Avto je dobesedno nov!Ne najdeš napake...Edino vozil ga nisem :?
http://www.avto.net/_AVTO/ad.asp?ID=2994824&show=1
sašo5
Prispevkov: 5085
Kraj: Brežice
Napisal/-a sašo5 Če jul 23, 2009 8:54 pm
black je napisal/-a:Navaden 1.8 mislim ja, ne T.
kaj za en "k....." ima na zračnem filtru "prpopano" :?: (tud mašina bi se morala svetit, če že bluzijo o ohranjenosti...) ...aha; pa če bi veliki servis na pooblaščencu delal, bi bila na vezni steni kovinska nalepka in notri "vgraviran" datum in km. menjave....osebno, ga ne bi vzel, tud te oz-jke so mi mal mim.....če bi si ga pa ogledal v živo, oz. se zapeljal, bi pa verjamem našel še marsikaj...
...če te glih "srbi" nakup, reci da mu daš 5500 in basta(prodal, ga bo pa itak težko, kot pravim, najbolj mim motor, kar jih je lahko)
black
Prispevkov: 1595
Napisal/-a black Če jul 23, 2009 8:57 pm
Pomoje je na filtru balast za xsenon prpopan...
Sej glih mašina me najbl mori...Nebi šel rad na švohnejšo kot jo imam zdaj 145KM...
sašo5
Prispevkov: 5085
Kraj: Brežice
Napisal/-a sašo5 Če jul 23, 2009 9:01 pm
black je napisal/-a:Pomoje je na filtru balast za xsenon prpopan...
http://www.avto.net/_AVTO/ad.asp?ID=2504083&show=1
tega si oglej...
