booxy
Prispevkov: 12
Pridružen: Po okt 09, 2006 8:46 pm
renault espace 1.9 dci
Napisal/-a booxy Ne avg 03, 2008 1:43 pm
kupujem renault espace 1.9 dci letnik 2005 -2006 na kaj pazit ???
Re: renault espace 1.9 dci
Napisal/-a adis Ne avg 03, 2008 1:56 pm
booxy je napisal/-a:na kaj pazit ???
What to Watch Out For
Have been problems with electric parking brake and clutch system on 4 cylinder diesels.
On 1.9 and 2.2 DCIs EGR valve should open to allow carbon dioxide, which acts as a cooling gas) into the combustion chambers when the engine is under load (>30% boost). This allows the combustion chamber temperature to drop and thus the temperature of the exhaust gases. If it sticks in the closed position the exhaust gas temperature will rise causing a) the turbo bearings to fail and b) engine oil into the induction system. This will cause the engine to go on running until it has consumed all its oil and then it will go bang.
Problems with EGR valves in Renault dCi engines are often the cause of rough running when the valve is stuck in the open position as well. In several cases turbos have blown but the EGR valve has not been replaced. Inevitably the new turbo unit will not last long.
Auto transmission problems also common. Often because ATF cooler is situated in the radiator and if it fractures engine coolant gets into the transmission.
Helpful hint: To change the digital display from mph to kmh and back again do the following (from Dutch handbook): Have the Renault card ready in your left hand but don’t insert it yet. Press and hold the computer function button on the end of the wiper stalk. Insert the card and start the engine. The speedo will flash for about 3 seconds. When it stops flashing, release the computer button and the speedo and the cruise control will switch to Km, though all other functions remain in miles. Simply repeat to change back to miles.
Recalls
18-7-2003: 359 Espaces recalled because electronic parking brake may not be fully effective. Parking brake computer software to be reprogrammed. July 2006 TSB or recall because clutch master cylinders of manuals may not return to position after having been depressed.
robertos_664
Prispevkov: 1244
Napisal/-a robertos_664 Ne avg 03, 2008 3:02 pm
pri teh letnikih ni nekih problemov glih.
Po forumu brska: 0 registriranih uporabnikov in 66 gostov
