šmeks je napisal/-a:upam ce upas stavt za 200.000sit da nebo nc narobe.
a boš potem tistih 200k porabil za drug motor oz. za popravilo![]()
1.8T je napisal/-a:Voith je napisal/-a:1.8t js sm tanku skos TXT not, pa k sm dau qmi zravn je bla obcutna razlika, tko da dej probi pol pa komentiri.
Indeed, TXTMineralno olje nizje kvalitete, glih toliko hydrocracked, da lahko zadostijo nekim osnovnim standardom.
/jan
TXT Softec
A synthetic engine oil that is suitable for use in almost all modern, high performance gasoline and diesel engines.
Key Benefits
Castrol TXT Softec provides excellent wear protection under all driving conditions and delivers good cold starting and oil pressure build up. TXT Softec uses fully synthetic base fluids and an advanced formulation to provide the following benefits:
Maximum wear protection and deposit control assured
Reduced friction allows easier cold starting and faster oil pressure build-up
Engine deposits are kept to the minimum possible to preserve engine life reduce ownership costs
Maximum possible drain interval intervals for standard applications
Voith je napisal/-a:em txt je drgac full sintetika.
ker ole pa ti tankas? :>
Voith je napisal/-a:od kot teb te podatki? pa kako da ne tankas ester ce je najbol stabiln?
Po forumu brska: Google [Bot] in 56 gostov
