Re: Skrite funkcije avtomobilov
Napisal/-a adis To dec 14, 2010 11:33 am
MyWay! je napisal/-a:@~toMmy~: Tukaj imaš še nekaj funkcij pri Golfu 5:
http://www.stuartdalby.co.uk/vwgolfmk5/ ... ecrets.php
je kaj funkcij za passata?
MyWay!
Prispevkov: 687
Napisal/-a MyWay! To dec 14, 2010 11:47 am
Tole sem našel za Passat B6 (nekaj so znana dejstva, nekaj je skritih funkcij):
adjustable radio, speed sound
Blue, not green glass in all window
European Parking lights. turn on blinker with key off. lights the led's low enough to protect your car but not run down your battery
sliding sun visors, when turned to side extend to block sun
3 blink turn markers on mirrors, touch once, blinks 3 times
fold down hooks in trunk, holds groceries, briefcase
self-draining umbrella pocket.
doors relock if not opened shortly after hitting the unlock button on the fob (perhaps a 30 second
Cruise control can be adjusted in +/- 5MPH _OR_ +/- 1 MPH increments. +/- 5 is done by pushing cruise stick up/down (like a turn signal motion). Cruise speed is increased +1 MPH by pulling the cruise stick toward the driver, decreased -1 MPH by pressing the Set button at the end of the cruise stick.
You cannot put the wipers in the service position when the hood is not locked
two red spot lights next to the sunroof control which light the front console very elegantly.
exterior door handles covers which hide the key hole, you have to use the small key inside the key fob to open this little secret cover
Plastic clip on inside of driver's side windshield to hold your parking permit
multiple settings for opening the moon roof. Also, the moon shade is vented, so you can let fresh air in and not have the sun beat down on you if its directly overhead
Electro-mechanical power steering. Doesn't rob power from the engine and doesn't use power steering fluid
Telescoping steering column
master hidden key can be fully inserted into main key, so the chrome back is completly smooth
Pulling up and holding the driverside window button after getting out of the vehicle with the windows down will close all windows and sunroof. When you unlock the door, push down on the driver's side window and all of the windows will roll down
Put the passat in reverse and the fresh air intake valve closes and the air inside the car is recirculated. Prevents you from breathing your own exhaust
micron air filter to block pollen and dust. It also has a charcoal filter to stop odors from entering the car
When your windshield wipers are on, your brakes apply slightly "wiping" the discs ever few minutes. Keeping your brakes dry and muck free
while listening to a cd(with dyanaudio) you can hold down the next track or previous track button on the steering wheel and fast foward or reverse the on the track you are listening to
If you have your windshield wipers on low(not intermediate), and you come to a stop, it will automatically go to intermediate mode. Once you let go of the gas, it goes back to low wiper blade mode
hooks on the inside part of the B pillar are specifically for suit jacket, doesn't block the window for driver view as the jacket 'drapes' out of the way
fresh air intake has a lid that will come off to clean out debris
Automatic Hazzards upon sudden braking
The "ding" sound alerts the driver when the temp falls below 40F. Potential road freeze warning little snowflake symbol next to the temp LED
temp needle and the gas guage needle always land at zero together
seat heater
The gas cap has a peg on it that can be conveniently inserted into a hole at the top of the hinge of the fuel door to keep it out of the way while fueling
There are holders in the glovebox for a pen or pencil and a notepad. They are on the back wall of the glovebox
When the wipers go to the resting position, they will periodically move UP the windshield about a 1/2 inch, to make sure that you're resting the rubber of the blade on the alternate side - it lengthens the service life of the wiper blades
the handle to get to the spare can be hooked onto the rubber gasket surrounding the trunk, so you can use both hands to get the spare out of the trunk
the brake lights are usually the external red circles which also act like blinkers, but when the position lights are on, then it's the internal circle the one that act as brake lights
holding in the trip odometer button next to the wrench until the display changes. It then shows your speed digitally in km/hr while traveling
tire pressure sensor
Radio can be made to stay on for up to 1 hour without the key
Winter tire speed control warning – in MFD
Adjustable max speed warning – in MFD
sunroof/moonroof has pinch protection, and it's always on. HOWEVER, if you want to disable it, push the front of the dial UP after rotating it back to the 'home' position (or 6 o'clock), and you'll turn OFF the pinch protection
windows with pinch protection
When you spray washer on the windshield after the 5 or 6 wipes they do with the spray they wait about 2 seconds and do another wipe "tear wiping".
Cupholder in rear armrest will not extend if the armrest is not fully down
cruise control, a LED speedometer pops up on the screen and shows the numeric value. when the cruise control is active, the set speed is indicated by a LARGE display, but when you tap the brake to disengage, the set speed drops to a smaller font display
Tiptronic transmission, you can drive in auto or manual
If you have the hazards on you can still use the turn signals
If you do not have your seatbelt on the auto Hold will not come on
There is a light in the LOCK buttons on the doors that lights when the doors are locked and goes off when the doors are unlocked
red LED flashes when car is locked via the remote on both front doors
Doors automatically lock when car reaches 5 MPH
If your driving on a road with a crown in the middle, the car will self align so that you won’t have to steer against the crown
On the base 6 cd stereo, hold the Scan button for customization options
The side-view mirrors fold – manually
four wheel ABS works with the ESP on
when Auto Hold is engaged and you put the car into park the E-Brake engages automatically.
If you start your B6 and your passenger sits down in the front seat. The "Passenger Airbag Off" sign starts flashing wildly before going off
you can use the Tiptronic function to select 2nd gear for starting out in slippery conditions in the highway you can stay on tiptronic 6th gear, it wont downshift it will stay in 6th gear until you really press the accelarator till it "clicks"
the intermittent wipers not only have various predetermined time intervals but they are also speed sensistive and the intervals reduce as the car gains speed!!!!
If your key ever becomes stuck in the ignition, put the gear lever selector in, click the gear lever button three times and pull the key out
After running the A/C for a bit I hit the air recirculator button so that the A/C doesn't have to work so hard and so that the air is cooler. When I just go into the store or something and come right back out, the air recirculation is still selected on. However, when I let the car sit for a while and then go to drive it, the recirculation is off.
On the steering wheel and you are in the audio mode if you hold the up/down arrow you change to preset stations but you hold it in just a tad longer, you'll get an annoying 'ding' but you'll go up or down 1 channel
A/C ports in the consoles
Reflectors inside the trunk on both sides
Height of the front arm rest is adjustable to fit your angle
if you have the autohold on and open the the door, the car outs itself in park.
~toMmy~
Prispevkov: 5806
Kraj: Vinica
Napisal/-a ~toMmy~ To dec 14, 2010 12:07 pm
papi-chulo je napisal/-a:
~toMmy~ je napisal/-a:-ob vžiganju dizla v hladnih dneh je dobro imeti izklopljeno tipko ECON(vklopljeno "klimo"), saj se v tem primeru vklopi dodatni električni 1000W grelec za zrak.
To velja za vse Diesle, da če je vklopljena Klima začne prej pihat toplo ?
Ne bom trdil, imajo pa pomoje vsi novejši dodatni grelec, ne vem pa kako se pri ostalih vklopi(če ga je sploh treba posebej). Je pa res, da še vedno precej časa porabi za ogrevanje.
Hvala, ampak sem že vse preštudiral, tudi VAG-COM imam in jih je še kar nekaj dodatnih za vklopit/nastavit! :D Če kdo potrebuje kaj pomoči ali nasvetov na tem področju, naj me kar kontaktira na PM, med tednom sem v LJ.
@adis:
Te ki ti jih je MyWay! prilepil imam tudi sam v "arhivu", se pa ponavadi najde še precej nasvetov in Do It Yourself-ov (DIY). Recimo za montažo lučk v prostoru za noge ipd.
Preko kabla nekaj bolj uporabnih funkcij pri teh novih računalnikih(Golf V ipd.):
-preverit se da prevožene kilometre, ki jih računalnik preračunava neodvisno od števca(če niso tudi ti prirejeni)
-zamenjaš lahko jezik
-tudi na navadnem stikalu se da vklopit Comming Home(pustiš luči vklopljene, ugasneš in zakleneš avto, luči pa svetijo še 20-30s) in Leaving Home(luči se vklopijo ob odklepu avta)
-vklopiš/izklopiš lahko "selektivno" odklepanje-ob prvem pritisku na ključ se odprejo samo voznikova vrata
-zmanjšat se da delovanje EGR ventila
-izklopit opozorilo za pas
MBtouran
Prispevkov: 1010
Napisal/-a MBtouran To dec 14, 2010 4:08 pm
Courage™ je napisal/-a:
MBtouran je napisal/-a:-pri opel insigniji obstaja način da se avto preklopi v modus "transport" ka romogoča da se akumolator prazni veliko počasneje če avto dolgo stoji
povej več...
To funkcijo ti morejo odkleniti na servisu, nato držiš 20 sekund ključ v določeni poziciji in je to to.
Sportivo
Prispevkov: 1762
Kraj: Cerkno
Napisal/-a Sportivo To dec 14, 2010 4:59 pm
Obstaja kakšna funkcija da se na Ibizi 6L ugasnejo dnevne luči?
~toMmy~
Prispevkov: 5806
Kraj: Vinica
Napisal/-a ~toMmy~ To dec 14, 2010 5:33 pm
Sportivo je napisal/-a:Obstaja kakšna funkcija da se na Ibizi 6L ugasnejo dnevne luči?
Pomoje ne, na enem forumu piše to:
Daytime Running Lights (DRL) are hard wired on the VW Polo (9N), Seat Ibiza (6L) and Skoda Fabia (6Y). Diagnostics won't help you here.
Se pravi, da so vezane direktno in računalnik nima vpliva (če je ta trditev resnična).
ghandaed
Prispevkov: 765
Napisal/-a ghandaed To dec 14, 2010 5:47 pm
Pozna kdo kako cako za Peugeot 307 po 2005 letu?
Mtg83
Prispevkov: 41
Pridružen: Ne sep 20, 2009 2:46 pm
Napisal/-a Mtg83 Sr dec 15, 2010 5:05 pm
Kaj pa mercedes c 2001-2005 Ali Twingo 1995-2000
Audi A4 1.8T 150KM
Lisjak83
Prispevkov: 34
Pridružen: Sr sep 01, 2010 9:20 am
Napisal/-a Lisjak83 Sr dec 15, 2010 5:40 pm
Ford Mondeo 2005 letnik??? oops
need 4 speed
Prispevkov: 403
Pridružen: Ne sep 06, 2009 9:17 am
Napisal/-a need 4 speed Sr dec 15, 2010 5:51 pm
Renault Megane 2:če maš odprte šajbe in ob zaklepu 2x pritisneš na tipko se vse šajbe zaprejo. Pa še ena:če prve pol minute po zagonu pritisneš tipko za reset pot. računalnika ti na displayu pokaže nivo olja.
peroRS
Prispevkov: 5601
Napisal/-a peroRS Če dec 16, 2010 1:27 pm
1) Ena zanimiva funkcija na Škodi Superb II (pa verjetno še katerem avtomobilu):
če ima senzor za dež, pustiš odprte šipe in začne padat dež, jih avtomatsko zapre
2) Na veliko VAG avtomobilov:
Z daljincem (ključem) lahko odpreš/zapreš vse 4 šipe, če nekaj sekund držih gumb za odklep/zaklep
Podobno je, če ključ vstaviš v ključavnico in ga držiš v poziciji odklep/zaklep
3) kot so nekateri že omenili...pri Škodi Octavii II/Yeti/Superb (za Fabio nisem prepričan), lahko postaviš brisalce v servisni položaj, če ob ugasnjenem avtu ročko za brisalce pritisneš navzdol (kot da hočeš da samo enkrat obriše). To lahko storiš samo, dokler po ugasitvi motorja ne odpreš vrat.
4) Pri Škodah (verjetno je podobno tudi drugje pri VAG): če nekaj sekund tiščiš gumb za reset dnevnih kilometrov (pri nekaterih gumb za nastavitev ure) resetiraš servisni interval (pokaže se servisni ključek, ura in črtice _ _ _)
5) Launch control pri DSG menjalniku (zopet ne pri vseh modelih):
http://www.youtube.com/watch?v=8Qh4soNDyUg
http://www.youtube.com/watch?v=UXZAZ5t6DtU
Jaz sem to probal na Superbu DSG, pa nima LC. Ne dvigne obratov, ampak hoče takoj speljat. Kaj pa vem. :?
To so samo nekatere (niso vse "skrite", v navodilih jih je opisano kar nekaj).
V Climatronicih jih je ogromno, pa veliko se jih da vklopiti tudi s testerjem, v najnovejših avtomobilih v potovalnem računalniku.
Napisal/-a IcEm4n Če dec 16, 2010 4:06 pm
Pri zadnji generaciji Corse:
* 3x prtisneš tipko reset, nato pa jo v četrte držiš cca. 10-15 sekund (se sliši pisk) in prideš v skriti meni, v njem pa digitalni števec obratov in hitrosti, temp. motorja, stanje akumulatorja, verzija software-a, kdaj je bil avto izdelan, koliko km in dni je preteklo od servisa (oz. resetiranja števca) in še nekaj drugih stvari
* daš ključ v ključavnico, k sebi stisneš obe obvolanski ročici, držiš nekje 10 sekund (dokler se ne sliši pisk) in imaš na voljo mislim da 6 funkcij (samodejno zaklepanje, ko avto preseže hitrost 12km/h, aktivacija zadnjega brisalca pri vzratni vožnji, vklop luči preko daljinca, glasnost smernikov, ...). Se pa nastavitve shranijo na ključ. Več o tem imate napisano tudi v navodilih.
* če imaš avtomatsko klimo (velja tudi za druge modele), držiš tipko SETTINGS in po cca. 10 sekundah (po pisku) se spet najde skriti meni (na osrednjem displayu).
* za reset intervala za servis (InSP) držiš tipko za reset kilometrine in daš kontakt in čakaš, da se na displayu (med števcema) pokaže - - -
* sovoznikov airbag deaktiviraš, ko daš kontakt (ko je avto prižgan, ga ni možno izključit) in držiš tipko za izklop airbaga. Za ponovno aktiviranje je isti postopek.
To mi je zaenkrat padlo na pamet. ;)
lojtra86
Prispevkov: 14
Pridružen: Če jan 14, 2010 10:42 pm
Napisal/-a lojtra86 Pe dec 17, 2010 1:14 pm
Ker vidim, da vsi nekaj o tem veste, bi pa še jaz prosil za citroena c2 hdi (ne vem če to igra vlogo) kje se da priti do skritih funkcij. Najbolj me zanima, če je mogoče, da se vidi temperatura motorja.
Hvala in lep mrzel pozdrav.
tdk
Prispevkov: 381
Pridružen: Sr feb 26, 2003 6:03 pm
Napisal/-a tdk Pe dec 17, 2010 1:49 pm
morda kakšen info o laguni III,2007?
lp tdk
_HellMan_
Prispevkov: 182
Pridružen: So avg 12, 2006 12:53 pm
Napisal/-a _HellMan_ Pe dec 17, 2010 2:09 pm
Kaj pa za Toyota Yaris? Modelno leto 2004
Hvala!
L.P Lenart
Bolj Star Bolj Nor!!!
mrtwelvetrees
Prispevkov: 3208
Napisal/-a mrtwelvetrees Pe dec 17, 2010 6:30 pm
za Scenica 2009/10 ?
- vem da se šipe same zaprejo če 2x klikneš na zaklepanje
ne vem kako ti prikaze na displayu nivo olja (ob zagonu) ~ sem probal vse mozne kombinacije...
Napisal/-a pskoda So dec 18, 2010 9:48 pm
IcEm4n je napisal/-a:Pri zadnji generaciji Corse:
1 - moraš nabrš imet mali dislpej na sredini armature, da to dela
2 - dela
3 - dela
4 - ne dela, sem šel probat
5 - sovoznikov airbag lahko izklopim ali vklopim kadar hočem (tudi med vožnjo)
Napisal/-a lisko So dec 18, 2010 10:49 pm
Jeep Cherokee:
Daš kontak za sekundo in vzameš.....ponoviš 4x in četrtič pustiš kontakt prižgan. Utripat začne CHEK ENGINE lučka. Utripa v intervalih. Recimo za kodo 55 vžge in ugasne 5x...sledi malo premora in spet utripne 5x. enako za druge kode. Iz tega potem razbereš kodo (npr 17, blinkne 1x sledi premor in nato 7x). Na netu najdeš seznam kaj ktera koda pomeni in tako ugotoviš napako, ki ti jo javi. Jaz imam spisek kr sprintan v avtu :D
Napisal/-a IcEm4n So dec 18, 2010 11:42 pm
pskoda je napisal/-a:1 - moraš nabrš imet mali dislpej na sredini armature, da to dela
2 - dela
3 - dela
1 - deluje VSEM (ročna (mali display) ali avtomatska klima (večji sredinski display)) - preizkušeno!
4 - mogl bi delat (do zdaj sem vedno sam tako resetiral). Probi še pedal bremze stisnt.
5 - za tole nisem bil čist prepričan - sem se že nekaj časa nazaj s tem igral, pa mi ga je uspel deaktivirat samo pri kontaktu (lahko, da sem pri prižganem avtu prehitr spustu tipko) - bom še enkrat probal.
Napisal/-a pskoda Ne dec 19, 2010 12:47 am
2 - dela
3 - dela
1 - ni isto kot da držiš tipko setinks dokler ne slišiš pisk nato se z tipko BC premikaš po skritem meniju
4 - bom probal še z bremzo
Po forumu brska: 0 registriranih uporabnikov in 81 gostov
