martello
Prispevkov: 284
Pridružen: To okt 02, 2007 12:23 pm
Re: Trošarina bencin vs dizel
Napisal/-a martello Pe jul 13, 2012 10:32 am
V tistem članku, ki si ga nalimal, piše tole:
Plastic is believed to constitute 90 per cent of all rubbish floating in the oceans. The UN Environment Programme estimated in 2006 that every square mile of ocean contains 46,000 pieces of floating plastic,
Dr Eriksen said the slowly rotating mass of rubbish-laden water poses a risk to human health, too. Hundreds of millions of tiny plastic pellets, or nurdles – the raw materials for the plastic industry – are lost or spilled every year, working their way into the sea. These pollutants act as chemical sponges attracting man-made chemicals such as hydrocarbons and the pesticide DDT. They then enter the food chain. "What goes into the ocean goes into these animals and onto your dinner plate. It's that simple," said Dr Eriksen.
Po mojem mnenju gre bolj za to, da plastika predstavlja nevarnost morskim organizmom. Z dvigom vode najbrž res nima nič, saj plava na vodi, pa še površina oceanov (in volumen) sta tako velika, da si je težko predstavljati, da bi imela ta relativno majhna količina (v primerjavi z maso svetovnega oceana) kakšen velik vpliv na dvig vode.
evolva
Prispevkov: 79
Pridružen: Sr jun 09, 2004 11:42 am
Kraj: Lesce
Napisal/-a evolva Pe jul 13, 2012 7:39 pm
Trošarina za dizel je manjša, ker EU podpira to, da se porabi manj uvoženega goriva in imamo s tem večji BDP. Danes sem po radiju poslušal, kako bomo sedaj privarčevali z novimi standardi izpusta (ciljajo na povprečje 99g/km) in novimi gumami, ki zmanjšujejo porabo...cca. 4000€, naj bi avto privarčeval v 13-tih letih življenske dobe. Upajmo, da nas to reši iz krize ;)
Rollin´ on chrome
Napisal/-a nebivedu Pe jul 13, 2012 7:52 pm
Seveda trošarnina na dizla je cenejša, ker drugače bi vlade imele kamionarje v parlamentu. To je podpora kamionarjem, da je dizel cenejši, pa tudi dejstvo, da tega noben politik ne upa spremeniti.
Če pogledaš na petrolovi strani vidiš, da je cena bencina brez davka in trošarnin nižja od plinskega olja D2 (dizla) in to od leta 1999 naprej (od takrat imajo zapise na strani), potem pa država nabije trošarnine in davek na bencin, da pride maloprodajna cena višja od dizla.
J.McLane
Prispevkov: 1295
Napisal/-a J.McLane Po jul 16, 2012 8:00 am
evolva je napisal/-a:Trošarina za dizel je manjša, ker EU podpira to, da se porabi manj uvoženega goriva in imamo s tem večji BDP.
Zakaj misliš, da se pokuri manj uvoženega goriva? A dizel ni pridelan iz surove nafte? EU ne podpira nižje trošarine na dizel, EU predpisuje najnižjo trošarino, ki je že nekje 0,359 €/l in je enaka tako za bencin in dizel. Še več EU je hotela ta minimum na dizel zvišati, na bencin pa pustiti, ampak mislim, da to ni šlo skozi. Za cenovna razmerja so krive posamezne države in nima veze z direktivami Evrope.
Pogonsko gorivo kot tako ni krivo za to, da je realnost taka, da ima dizelski motor večji izkoristek. In ko govorimo o izkoristku moraš dizlu odbiti 10% kolikor je približna razlika v kalorični vrednosti med dizlom in bencinom (v litrih). Če bi bil v Evropi bencin že ves čas cenejši od dizla (tako kot je tržna cena) bi mogoče razvoj poskrbel, da bi bencinski motor dosegal enake izkoristke kot danes sodobni dizelski motor.
Zanimivo bi bilo tudi dobiti podatek kakšno razmerje dizla in bencina pridelajo iz evropskih rafinerij. Saj mi nikakor ne gre skupaj to, da glede na podatke iz Wikipedije naj bi se iz surove nafte pridelalo kar 46% bencina, ostalo ni samo dizel ampak še LPG, kerozin, mazut, katran ... Torej res mi ni jasno kako lahko v Sloveniji porabimo 72% dizla in 28% bencina, pa dodaj zraven še kurilno olje.
Da je v Evropi lahko tako razmerje porabe je možno samo:
- rafinerije lahko razmerje med dizlom in bencinom delno prilagajajo, ampak kakšna je cena za to prilagajanje vejo samo tam. Mogoče imamo zato v Evropi "lažji" višje oktanski bencin in težji nizko oktanski bencin pristane v dizlu.
- mogoče pa Evropa dizel kupuje od Američanov, ker ga oni ne porabijo vsega, ker tam porabijo več bencina.
- mogoče pa evropske rafinerije prodajajo odvečen bencin v Ameriko
vsi zgornji scenariji pa pomenijo samo eno - dražja tržna cena (v Evropi) tako dizla kot bencina.
J.McLane
Prispevkov: 1295
Napisal/-a J.McLane Po jul 16, 2012 8:48 am
Pa sem izbrskal izvrsten dokument, ki opisuje razmerje pridelave med dizlom in bencinom (23. in 24. stran):
http://www.best-europe.org/upload/BEST_documents/info_documents/Best%20reports%20etc/D3.15_The%20BEST%20experiences%20with%20low%20blends%20in%20diesel%20and%20petrol%20fuels.pdf
The yield of petrol and diesel from oil refineries has an approximate constant ratio. For every litre of
diesel fuel oil that the refinery process produces, they get more than two litres of petrol,
With a reduced consumption of petrol and with a greater demand for diesel, the European refineries
produce against an unbalanced market. 2004 Europe had a net surplus petrol production of about 33
million tonnes. The shortage of diesel was more than 19 million tonnes, Table 6. The main volumes of the
surplus petrol Europe export to US and wherefrom Europe import the most diesel oil.
Torej vse moje ugotovitve držijo, leta 2004 je Evropa izvozila v 33 milijonov ton bencina v Ameriko in uvozila 19 milijonov ton dizla iz Amerike (danes verjamem da je situacija še slabša). Če pride do problemov pri distribuciji surove nafte bo dizelskega goriva zmanjkalo prej kot bencina (se je že zgodilo enkrat v Srbiji). To razmerje in mahinacije z uvozom in izvozom dizla in bencina nam DRAŽI VSA POGONSKA GORIVA V EVROPI.
Evropa nebi smela dopustiti državam da s trošarinami umetno cenijo dizelsko gorivo, ker trg dolgoročno tega ne bo prenesel.
martello
Prispevkov: 284
Napisal/-a martello Po jul 16, 2012 8:53 am
J.McLane je napisal/-a: Evropa nebi smela dopustiti državam da s trošarinami umetno cenijo dizelsko gorivo, ker trg dolgoročno tega ne bo prenesel.
Kje je torej problem: v predragem bencinu ali prepoceni dizlu?
J.McLane
Prispevkov: 1295
Napisal/-a J.McLane Po jul 16, 2012 9:43 am
martello je napisal/-a:Kje je torej problem: v predragem bencinu ali prepoceni dizlu?
Problem je v cenovnem razmerju, briga me (no v bistvu ne) koliko trošarin obesijo gor, samo da so enake in se s tem ohrani cenovno razmerje kot ga diktira trg.
BBoss
Prispevkov: 1933
Napisal/-a BBoss Ne jul 22, 2012 10:12 pm
Jebemtiš - še na globalno segrevanje se ne moreš več zanest - konec julija pa me že ta drug dan zebe. :roll:
domen_
Prispevkov: 714
Kraj: Varšavski lok
Napisal/-a domen_ Ne jul 22, 2012 10:18 pm
Ob večtedenskem vročinskem valu junija pa nisi nič rekel.
Cinične izjave sicer nimajo veze z resničnostjo, v argumentirani debati je to odvečna folklora.
BBoss
Prispevkov: 1933
Napisal/-a BBoss Ne jul 22, 2012 11:54 pm
domen_ je napisal/-a:Ob večtedenskem vročinskem valu junija pa nisi nič rekel.
Sam res - vročina poleti, to je pa ja neki nezaslišanega in groznega. To je tako nenavadno kot sneg pozimi.
domen_
Prispevkov: 714
Kraj: Varšavski lok
Napisal/-a domen_ Po jul 23, 2012 10:24 am
BBoss je napisal/-a:
Tisto ni bila le navadna poletna vročina, ampak precej dolg in močan vročinski val (pravzaprav sta bila dva, z vmesno nekajdnevno ohladitvijo na 30°C). Temperature so se gibale okrog 35°C ali celo več, toplotna obremenitev je bila res velika. Tudi ponoči se ni spustilo pod 20°C. Že zdaj je jasno, da bo letošnje poletje med najbolj toplimi v zadnjih nekaj desetletjih.
To je precej bolj nenavadno kot pa kakšen dan ali dva dežja poleti, ki pride prav vsako leto.
maniaxxx
Prispevkov: 7338
Napisal/-a maniaxxx Po jul 23, 2012 4:02 pm
Zadnje čase res vročina pritiska ja....globalno zagrevanje my ass :roll:
domen_
Prispevkov: 714
Kraj: Varšavski lok
Napisal/-a domen_ Po jul 23, 2012 8:19 pm
Neverjetno kako kratek spomin imajo nekateri.
maniaxxx
Prispevkov: 7338
Napisal/-a maniaxxx Po jul 23, 2012 8:22 pm
domen_ je napisal/-a:Neverjetno kako kratek spomin imajo nekateri.
Prej je bilo res vroče, pa ni bilo prvič, pa najbrž tud ne zadnjič...
peroRS
Prispevkov: 5601
Napisal/-a peroRS Po jul 23, 2012 9:17 pm
waw, 2 tedna je trajala vročina z vesoljskimi 35 stopinjami. Šokantno, res! :roll:
Če povzamem vreme za celo leto:
od septembra do maja je zima (tudi če ni snega, pač nizke temperature), vmes je 2 tedna vročine (kjer termometer prileze do "neverjetnih" 35 stopinj), potem se ohladi na 10 stopinj in je dež 2 meseca (kao še poletje), pol pa spet september in zima.
Neko hudo globalno segrevanje je to ni kaj. :lol: :huh:
domen_
Prispevkov: 714
Kraj: Varšavski lok
Napisal/-a domen_ Po jul 23, 2012 9:31 pm
8 različnih krajev po Sloveniji, čisto v vsakem je letošnja temperatura višja od povprečja 1961-1990.
http://www.arso.gov.si/vreme/agrometeor ... ualno.html
Lahko se je delati norca, si zatiskati oči in imeti cinične pripombe vsepovsod. Ampak podatkov to ne spremeni, dejstva pač so kakršna so.
Napisal/-a nebivedu Po jul 23, 2012 11:11 pm
Domen, razloži malo te grafe. Jaz v njih vidim, da je še vedno vse v mejah normale v sedmih mestih (zadnji graf), v murski soboti pa celo pod povprečjem.
Drugače pa se ni nič spremenilo. Ljubljana zadnjih 100 let - temperature po mesecih (minimum, maximum in povprečje). Maximum v ljubljani je bil septembra 1974, ko je bilo 38 stopinj.
Lahko pa izpise še za druge mesece naredim(tiste ob strani - ampak temperature se vidijo že iz grafa.
domen_
Prispevkov: 714
Kraj: Varšavski lok
Napisal/-a domen_ Po jul 23, 2012 11:59 pm
nebivedu je napisal/-a:Domen, razloži malo te grafe. Jaz v njih vidim, da je še vedno vse v mejah normale v sedmih mestih (zadnji graf), v murski soboti pa celo pod povprečjem.
Prvi graf prikazuje odstopanje temperature tekočega leta od let 1961-1990. Povprečje med 1961-1990 je nastavljeno na 0, kar je nad 0 (odklon je pozitiven) je bilo letos topleje kot pa 1961-1990, kaj pa je pod 0 pa je bilo hladneje (odklon je negativen). Tista roza črta je letošnje povprečno odstopanje od povprečne temperature med 1961-1990.
Vidno je, da je bila velika večina letošnjega leta toplejša od povprečja 2012 (odklon je bil večinoma nad 0).
Drugi graf so padavine, to nas pri temperaturi ne zanima.
Tretji graf pa primerja letošnje temperature (rdeča črta) s povprečnimi med 1961-1990 (črna črta). Zgornja in spodnja modra domnevam da so izbrane maksimalne in minimalne dnevne temperature v letih 1961-1990. No iz tega grafa se sicer ne vidi najlepše (vsaj ne tako kot na prvem), ampak če pazljivo primerjaš letošnje s povprečnimi med 1961-1990 (torej rdečo in črno) se da brez večjih težav razbrati, da je bila letošnja temperatura večino časa višja kot pa je bilo povprečje med 1961-1990.
Je pa lepo vidno tudi to, da je bil februar letos zelo hladen, saj povsod izstopa od povprečja s precej nizkimi temperaturami.
nebivedu je napisal/-a:Drugače pa se ni nič spremenilo. Ljubljana zadnjih 100 let - temperature po mesecih (minimum, maximum in povprečje). Maximum v ljubljani je bil septembra 1974, ko je bilo 38 stopinj.
Kakšna fronta res lahko prinese tudi nov vremenski rekord, na ARSO je objavljen nek dokument, kjer opisujejo veliko takšnih vremenskih rekordov. Npr. najvišja temperatura v Sloveniji (odkar se meri) je bila v Črnomlju 5.7. leta 1950, temperatura je bila kar 40.6°C. Najnižja na Babnem Polju in sicer -34.5°C in to kar večkrat ista vrednost: 15. 2. 1956, 16. 2. 1956 in 13. 1. 1968.
No saj je veliko tega.
Ne vem kje si dobil te podatke za Ljubljano, lahko napišeš od kje ta graf? Sicer pa bi na istem grafu potrebovali še letošnje podatke, zato da se vidi primerjava.
J.McLane
Prispevkov: 1295
Napisal/-a J.McLane To jul 24, 2012 12:00 pm
Odziv pristojnega organa na predlog o izenačitvi trošarin:
http://predlagam.vladi.si/webroot/idea/view/3207
Dejansko je problem cela Evropska unija, posamezna država (sploh majhna) težko odstopa od svojih sosed, zato imamo neke vmesne cene med Italijo, Avstrijo, Madžarsko, Hrvaško, kar je logično.
Na ravni Evrope je pa bil predlog, da bi vse države trošarinsko politiko vezale na energijsko vrednost (s tem to pomeni direktno CO2 če kdo želi tako razumeti) in takoj so se pojavili članki tipa EU Plans to Increase Diesel Tax in zadeva posledično ni šla skozi. V tem članku so nekateri komentarji vrlih politikov:
“In the middle of an economic crisis, families are feeling the pinch,” she said. “Does the EU really want to tax its citizens further just for driving their kids to school or for turning on the heating?”
Ker bi bogi dizel podražili za 10% nebi mogli več straši vozit otrok v šolo, kaj pa tisti reveži, ki danes otroke vozijo z mini/starimi bencinskimi avti, ki imajo v bistvu isto porabo kot veliki dizelski enoprostorci? Kar se pa ogrevanja tiče biomasa bo zmeraj ostala neobdavčena, gre se samo za fosilna goriva
“However, while we will follow this approach it must not lead to an increase of price for diesel. Diesel cars are less polluting and are important for reducing CO2 from our transport system,” the Austrian MEP said.
Ta pa ne razume razlike o učinkovitosti motorja in obdavčitvi energenta, bo že trg poskrbel za to, da bodo dizli z nižjo porabo še zmeraj boljša izbira, po drugi strani je pa pri bencinskem motorju še veliko rezerve za izkoristke (Hibridi, enostavni prijemi kot Mazda Skyactive) in ko bo ekvivalentni bencinar v okviru 10% porabe dizla lahko govorimo o enakem izkoristku.
se dobi tudi kakšen pameten komentar:
"The Commission’s proposal does not seek to penalise diesel, but to tax fuels in a neutral way. All fuels would compete on the basis of their merits instead of tax advantages,"
cruiser1
Prispevkov: 2683
Napisal/-a cruiser1 To jul 24, 2012 12:27 pm
Debili! Kar se tega tiče je EU prav trapasta!
Po forumu brska: 0 registriranih uporabnikov in 52 gostov
