... pa še dva vitla zraven in greš pozim na mont everestSkull23 je napisal/-a:Kupte quattrota pa dejte mir
Energetik81 je napisal/-a:Praktično največji vpliv na trakcijo po snegu ima razporeditev mase spredaj/zadaj. Torej čim več mase na pogonskih kolesih. Sama celotna masa avta niti ni tako pomembna. Sploh pa nimajo kaj dosti veze kakšna prestavna prestavna razmerja (razen pri res hudih klancih, ko postanejo obrati že v 1. prestavi prenizki).
Seveda poleg dobrih zimskih gum.
ejsim je napisal/-a:Torej, da bi bil dober v snegu in super na AC in skozi ovinke, težko. Razen 4x4
Electronic Differential Lock
On the road with different surfaces on each side, for example dry tarmac on one side and ice or snow on the other, you will appreciate the EDL differential lock. This system works together with ABS sensors.
Electronic control unit continually receives data from ABS wheel speed sensors on the driven wheels. If ECU detects that one wheel is slipping, it applies the brake pressure to match its speed to the second, non-slipping wheel. This also directs the torque to the wheel with better traction, which is able to transfer more power.
The EDL advantages are most obvious during acceleration or driving up the hill with low traction under one of the driven wheels.
Our new XDS technology lets you grip the road when cornering fast. It improves responses to ensure an even safer drive.
XDS is an advanced electronic differential lock, linked to a sophisticated Electronic Stabilisation Programme (ESP) system. We designed it to maximise road holding and improve responses, especially when cornering.
How does it work?
In moments of fast cornering XDS gives out exactly the right amount of power, providing pressure on the inside wheel to prevent wheel spinning. The result is better traction and a reduction of any tendency to under steer.
You'll experience a more agile, precise and calm driving performance with better traction out of bends. In other words, you can enjoy sporty driving in your Volkswagen, knowing you have a reassuringly higher level of safety.
stench je napisal/-a:Moja izkušnja je taka da sem se nekak lažje po snegu vozu s Cliotom kot pa s Xantio. Nevem zakaj, verjetno je pa tudi k temu veliko pripomoglo da sem bil na cliota bolj navajen. Samo tudi drugač je bila situacija ista če sem vozu druge avte, ki niso bili moji in nisem bil na njih navajen, sem vedno lepše vozil lažji avto.
Po forumu brska: clio05 in 84 gostov
