Gel Cell Batteries must be recharged correctly or the battery will suffer premature failure. The battery charger being used to recharge the battery(s) must be designed or adjustable for Gel Cell Batteries. If you are using an alternator to recharge a true Gel Cell a special regulator must be installed.
danci1973 je napisal/-a:http://www.batterystuff.com/kb/articles/battery-articles/gel-vs-agm.htmlGel Cell Batteries must be recharged correctly or the battery will suffer premature failure. The battery charger being used to recharge the battery(s) must be designed or adjustable for Gel Cell Batteries. If you are using an alternator to recharge a true Gel Cell a special regulator must be installed.
pskoda je napisal/-a:Da še dodam original akumulator Varta AGM (stop/star funkcijo) 68Ah za WV grupo je 250 eur. Zdaj pa računajte koliko bencina ali dizla moraš privarčevat, da prideš na cca 80eur, ki stane obični akumulator
Tinerine je napisal/-a:Pozdravljeni,
da ne odpiram nove teme...imam renault megana letnik 2010, 62000km. Pri zagonu avta se mi prižge ABS lučka in avto malo težje vžge vendar ne vedno. Ali je to akumulator ali kaj drugega?
