Fenix_
Prispevkov: 212
Pridružen: Če apr 21, 2005 10:05 am
Kraj: Obala
Ford 1.6 Ecoboost VPOKLIC
Napisal/-a Fenix_ Sr jan 24, 2018 11:11 am
Včeraj dobil po pošti obvestilo da so resne težave z vozilo in jih je treba čim prej odpravit.
Sicer avto dela normalno in do sedaj ni bilo nobenih težav
Malo sem brskal po internetu in našel kaj vse je treba zamenjat
Na servisu so mi mi povedal da bo trajao cirka 6ur, po moje bo tudi cel dan
REASON FOR THIS SAFETY RECALL
17S09 - 17S09 - 1.6L GTDI COOLING SYSTEM
In the affected vehicles, localized overheating of the engine cylinder head may cause the cylinder head to crack, causing a pressurized oil leak that may result in a fire in the engine compartment.
The following parts are installed/replaced during the recall:
New coolant reservoir.
New coolant reservoir cap.
New thermostat.
New coolant bypass valve.
New coolant standpipe with coolant level sensor.
New wiring harness between the coolant level sensor and the EPAS module.
Modification of the battery tray (needed for the new wiring harness).
New, modified coolant hoses (the new hoses have a completely different routing and design than the old ones).
Mounting hardware (Bolts, screws, clips, etc. ).
Reprogramming of the IPC (instrument cluster) with new software.
Reprogramming of the PCM with new software (any remap will be lost).
Filling and bleeding of the coolant system.
The full description of this recall (which is applicable on all Ford models with the 1.6 ECOboost) is 56 pages long
https://ford.oemdtc.com/2754/17s09-cool ... -2015-ford
http://www.fordownersclub.com/forums/to ... ng-system/
Re: Ford 1.6 Ecoboost VPOKLIC
Napisal/-a pskoda Sr jan 24, 2018 12:13 pm
Ford ga pa zadnje čase biksa, da glava boli
Fenix_
Prispevkov: 212
Kraj: Obala
Napisal/-a Fenix_ Sr jan 24, 2018 12:39 pm
Zgleda da Po napaki na RS-ju so šli preverit še druge motorje
in še dobro da so šli
Firediver
Prispevkov: 4556
Napisal/-a Firediver Sr jan 24, 2018 12:51 pm
Pozdravljam odločitev Forda, je vsaj pošten, da je konstrukcijska napaka in se je lotil vpoklica!
Lahko bi se naredili "francoza" in prevalili krivdo na lastnike vozil, da motorje mrzle tiščijo, ne znajo voziti itd. (že videno npr. pri Renaultu ko je podaljšal interval menjave olja na 30kkm in so turbine ribale).
TrijoAdijo
Prispevkov: 4168
Napisal/-a TrijoAdijo Sr jan 24, 2018 1:00 pm
pskoda je napisal/-a:Ford ga pa zadnje čase biksa, da glava boli
Te vsaj priznajo in zadeve rešujejo s vpoklicem....Če bi se to švabom zgodilo, bi blo vse tiho, lastniki pa bi rekl, da je to vse super in fajn :lol: :lol:
Po forumu brska: 0 registriranih uporabnikov in 91 gostov
