mrtwelvetrees
Prispevkov: 3208
Novo motorno olje GF-6 za GDI motorje
Napisal/-a mrtwelvetrees To sep 24, 2019 6:57 pm
Kaj menite od tem, to tudi to olje za tce 1.2 motorje ?
Mislim da bo tole še drag špas, da bo cena kar lepa za to olje :huh:
Prihaja na police spomladi 2020.
GF-6 motor oils will facilitate greater fuel economy while improving wear and deposit control, compared to their GF-5 counterparts. These new motor oils will protect against timing chain wear and Low Speed Pre-Ignition (LSPI), a potentially catastrophic phenomena that occurs in GDI (gasoline direct injection) engines.
https://www.youtube.com/watch?v=8HmGv1fgvtM
void
Prispevkov: 1852
Re: Novo motorno olje GF-6 za GDI motorje
Napisal/-a void To sep 24, 2019 7:49 pm
Koliko jaz razumem je isto kot RN17 standard, oz. ELF RN-Tech Elite 5w-30, ki je namenjen novim DI bencinarjem. Na voljo že kako leto.
danci1973
Prispevkov: 1277
Napisal/-a danci1973 To sep 24, 2019 9:28 pm
ILSAC (International Lubricants Standardization and Approval Committee) GF-6 je specifikacija, ki bo stopila v uporabo 1.5.2020.
GF-6 je / bo v dveh variantah - GF-6A za motorna olja, ki bodo kompatibilna tudi s starejšimi motorji in bodo na voljo v 'običajnih' viskoznostih SAE 0W-20, SAE 5W-20, SAE 5W-30 and SAE 10W-30 ...
GF-6B pa bo samo v viskoznosti 0W-16 in namejeno samo modernim DI motorjem.
Na tržišču so že olja, ki izpolnjujejo zahteve GF-6A oz. GF-6B, le oznake še ne morejo (smejo) uporabljati.
Na primer:
https://www.pennzoil.com/en_us/education/what-you-need-to-know-about-ilsac-gf-6.html
The testing protocol for ILSAC GF-6 has been established and engine test set-ups are available, but the test limits are still being established. For this reason, no motor oils in the marketplace can claim to meet ILSAC GF-6 at this time.However, SOPUS Products has completed the relevant GF-6 testing protocols for the following Pennzoil Platinum products. Based on those results, we expect the following products will meet ILSAC GF-6A- and GF-6B test limits:
ILSAC GF-6A:
o Pennzoil Platinum Full-Synthetic Motor Oils – SAE 0W-20, SAE 5W-20, SAE 5W-30 and SAE 10W-30
o Pennzoil Platinum High Mileage Full Synthetic Motor Oils - SAE 0W-20, SAE 5W-20, SAE 5W-30 and SAE 10W-30
ILSAC GF-6B:
o Pennzoil Platinum Full Synthetic Motor Oil - SAE 0W-16
As soon as the test limits for the ILSAC GF-6A and 6B licenses are set, we will seek licensing approval for these products and expect to claim ILSAC GF-6 for them on the first-use date.
PogachnyK
Prispevkov: 741
Pridružen: Sr maj 27, 2009 6:39 am
Napisal/-a PogachnyK To sep 24, 2019 9:36 pm
In to olje bom vliv v traktor, pa mi bo namesto 2l/h , popil 0.5l/h?
Kakšna bedarija...
void
Prispevkov: 1852
Napisal/-a void To sep 24, 2019 9:48 pm
0w-16 :shock: ha? kaj? Pa to je bolj tekoče od vode...
Sploh se nism poglobu niti posvetu.
Napisal/-a pskoda Sr sep 25, 2019 6:30 am
Ta olja oz to olje 0w16 je dobro samo če gledamo na okolje za motor je strup. Tudi 0w20, 0w30, 5w20 oz 5w30 ni bog ve kaj.
Da greš na raceland z oljem 0w16 bo motor sigurno v parih krogih ripnu
Zodd
Prispevkov: 461
Pridružen: To okt 17, 2006 9:38 pm
Mazda2
Prispevkov: 755
Pridružen: To sep 02, 2014 5:11 pm
Napisal/-a Mazda2 Če okt 31, 2019 9:11 am
Če kdo gleda na YT kanal Piotr Tester so včasih zelo čudni rezultati. Zakaj se potem z nekaterimi olji ...W30 kovinska palčka manj obrabi kot pri ...W40? Govorim za olja, ki jih pred tem ogreje in tudi za ista olja, le drugačne viskoznosti, 5W40 proti 5W30, npr. Fuchs.
sašo5
Prispevkov: 5085
Kraj: Brežice
Napisal/-a sašo5 Če okt 31, 2019 2:54 pm
GDI je imel Mitsubisi že l.99 v Carismi, pa se je uporabljalo olje 5-40......krepaval je pa sistem predvsem zaradi bencina (občutno preveč žvepla za tisti čas) zato še danes direktni vbrizg zahteva 98/100 vendar proizvajalci marketinško zapišejo najmanj 95
Je pa Ford že en čas na olju 0-20.
Mazda2
Prispevkov: 755
Napisal/-a Mazda2 Če okt 31, 2019 3:24 pm
Ja a ta 0W-20 je kar za vse klimatske pogoje predpisan?
Zodd
Prispevkov: 461
Napisal/-a Zodd Ne nov 17, 2019 5:24 pm
Mazda2 je napisal/-a:Ja a ta 0W-20 je kar za vse klimatske pogoje predpisan?
za primer civic v ameriških navodilih imajo samo 0w-20 po specifikaciji API SN, medtem ko za evropo in mislim da tudi afriko piše
se notri daje ORIGINALNO olje honda 0w-20, če pa ta ni na voljo gre notri 0w-30 ali 5w-30, mora pa biti ACEA A3 ali A5...
meni so pri prvi menjavi olja 7700km notri dali SHELL helix ultra 0w-20 ACEA A1, in sem na drugo menjavo dostavil svoje olje ki je A3
Castrol edge titanium 0w-30... niso komplicirali ko sem razložil da me moti pri 0w-20 da je A1 medtem ko honda zahteva a3 ali a5....
kot dobro gesto sem rekel tudi da lahko olje naročijo sami, da ne bo kdo slabe volje zaradi marže... meni je samo pomembno da je notri olje kot ga
zahteva proizvajalec, glede na to da je avto 1.5l turbo in direct injection in ima samo 3.7l olja notri sem prepričan da je olje precej obremenjeno in ga menjam 2x letno na cca 7-8k....
Napisal/-a abbe Po nov 18, 2019 1:30 pm
sašo5 je napisal/-a:GDI je imel Mitsubisi že l.99 v Carismi, pa se je uporabljalo olje 5-40......krepaval je pa sistem predvsem zaradi bencina (občutno preveč žvepla za tisti čas) zato še danes direktni vbrizg zahteva 98/100 vendar proizvajalci marketinško zapišejo najmanj 95
ford je na olju 5w20.
ne pa 0w20
nejc1
Prispevkov: 1965
Napisal/-a nejc1 Po nov 18, 2019 3:57 pm
1.5 ecoblue imajo 0w-20...
J.McLane
Prispevkov: 1295
Napisal/-a J.McLane Po nov 18, 2019 4:09 pm
Toyota je že 10 let na 0W-20, samo na servisih so do nekje 5 let nazaj vlivali 5W-30. Nizka viskoznost je tu samo in zgolj zaradi porabe goriva, no jaz sem kupoval poceni Total 0W-20, pa je bilo do 190k km vse OK, med menjavami ni popil nič olja.
Sem pa opazil, da je nova Corolla že na 0W-16 olju, ampak verjetno bodo na servisih še nekaj časa vlivali notri 0W-20.
Prius (prodan): Slika
Prius (2018):Slika
Hilux (prodan): Slika
Subaru XV Bi-Fuel: Slika
Mazda2
Prispevkov: 755
Napisal/-a Mazda2 Po nov 18, 2019 11:28 pm
Za moj avto so priporočene naslednje viskoznosti: 5W-20, 5W-30, 10W-40. ACEA A3/A5, API pa minimalno SL. Na servisu so nekaj časa vlivali 5W-40 A3, sam sem presedlal na 5W-30 A5, 5W-20 nebi dajal. Kar se porabe goriva tiče s tem oljem je verjetno tako majhna razlika, da je jaz ne zaznam, tudi pogoji vožnje niso nikoli enaki. Morda bi to opazil po AC relacijah, da bi cel tank pokuril na AC. Tako, da bi bilo morda bolje, če bi uporabljal 5W-40 ali 10W-40. Se pa po drugi strani sprašujem, če ni opazno zmanjšana poraba goriva s 5W-30 A5, ali ni potem morda z 5W-40 A3 zaščita motorja tudi zanemarljivo boljša?
J.McLane
Prispevkov: 1295
Napisal/-a J.McLane To nov 19, 2019 9:51 am
Razlika v porabi med 5W-30 in 0W-20 je tako majhna da jo je v praksi nemogoče izmeriti, ker bo vsaka meritev imela večjo napako kot pa je razliak v olju. Mobil1 obljublja od 0,5% do 2% razlike v porabi, verjetno je razlika večja v hladnem vremenu, ampak v hladnem vremenu s hladnimi zagoni je to še toliko težje izmeriti.
Prius (2018):Slika
mrtwelvetrees
Prispevkov: 3208
Napisal/-a mrtwelvetrees So apr 25, 2020 7:30 pm
Je že kdo probal to "novo" olje ?
Po forumu brska: 0 registriranih uporabnikov in 104 gostov
