francko
Prispevkov: 287
Pridružen: Pe apr 08, 2016 7:53 pm
Webasto
Napisal/-a francko Ne feb 28, 2021 11:57 am
Zdravo
V avtu imam webasto grelec.
Zanima me če je treba to kaj servisirati?
Hvala
AssKicker
Prispevkov: 642
Re: Webasto
Napisal/-a AssKicker Ne feb 28, 2021 12:41 pm
Poleti ga na vsake toliko zalaufaš, da slučajn kej ne "zariba", drugače naj bi bil pa brez vzdrževanja...
francko
Prispevkov: 287
Re: Webasto
Napisal/-a francko Ne feb 28, 2021 5:24 pm
Hvala
golfabimu
Prispevkov: 289
Pridružen: Če apr 10, 2014 9:01 pm
Re: Webasto
Napisal/-a golfabimu Po mar 01, 2021 10:53 pm
Maintenance :
It is recommended that you have the vehicle maintained and checked at regular intervals by
an authorised Webasto dealer.
All repair or maintenance work must always be carried out by your authorised Webasto deal-
er. The dealer can also help with the specification of the required maintenance.
Warning
A great deal of repair and maintenance work performed on the heater requires spe-
cialised knowledge and special tools. Incorrect settings and maintenance can lead to
damage to the heater or accidents resulting in serious damage.
• For optimum performance, your authorised Webasto dealer should check and perform the
necessary maintenance work on the heating system at least every 2 years regardless of use.
• The heater must be switched off prior to cleaning.
• The heater may NOT be cleaned with high-pressure cleaning systems or compressed air.
Tkole pravi proizvajalec, kako je pa v praksi pa ne vem ( nimam izkušenj).
Lp,
Firediver
Prispevkov: 4558
Re: Webasto
Napisal/-a Firediver To mar 02, 2021 12:51 am
To so pa tako splošna navodila, da bi lahko veljala tudi za karkoli drugega na avtu. Pa nič o tem, kaj se pregleda/zamenja pri servisu.
golfabimu
Prispevkov: 289
Re: Webasto
Napisal/-a golfabimu To mar 02, 2021 5:40 pm
Ja vem. Pa vendarle je avtor teme vprašal ali je potrebno vzdrževanje (na kar je dobil dva odgovora DA oz. je priporočeno in NE) ni spraševal kaj je potrebno menjati/pregledati... pa niti ne poznam Webasto sistemov toliko, da bi lahko dal kakšen nasvet.
Lp,
Po forumu brska: madpanter in 11 gostov
